Apple TV owners' thread. - Page 487 - AVS Forum | Home Theater Discussions And Reviews
 27831Likes
post #14581 of 23755 Old 04-20-2018, 03:42 PM
thatJohann's Avatar
Quoted: 278 Post(s)
Liked: 62
Originally Posted by NashGuy View Post
Thanks. I think the video embedded in the earlier post here does a pretty good job of letting me know what I'm giving up in terms of tone mapping in native DV vs. artificially converted HDR10. Granted, the reviewer in that video is using a 2017 LG B7 OLED and I have a 2016 LG B6 OLED, but close enough.
I think my game plan, for now anyway, will be to leave the ATV4K set to 4K 60 HDR10, with Dynamic Range Match turned on and Frame Rate Match turned off. I'm very pleased with how the ATV4K displays motion/judder at 60Hz across a range of content I've looked at. And while I was getting a weird flickering effect in near-blacks before with upscaled 4K at 24 Hz, I've yet to see that on my TV if I keep the ATV4K output at 60Hz. So that's another bonus. And the ATV4K does a better job of 4K upscaling than my TV or Yamaha receiver.
I've verified that the main apps I use -- Netflix, Hulu, Showtime, HBO, Channels, PBS -- all work with Dynamic Range Match so that everything switches to SDR for native SDR content (which is most or all of those apps' content).
When I watch the occasional DV movie in iTunes, I'll turn on Frame Rate Match, allowing the ATV4K to pass a 4K DV 24Hz signal to the TV. Otherwise, I'll keep Frame Rate Match turned off. Maybe a third of Netflix's 4K content is in DV. I'll probably just let the ATV4K convert that to HDR10 at 60Hz (i.e. Frame Rate Match off). From what I've seen so far in bits of Mindhunter and Lost in Space, it looked fine.
Are you saying that turning off frame rate match improves the picture quality? I would assume that 24Hz content played at 60Hz would have stutter? Why not leave frame rate match on?
thatJohann is offline
post #14582 of 23755 Old 04-20-2018, 04:14 PM
cydeweyz's Avatar
Quoted: 421 Post(s)
Liked: 403
Depends on the capability of your TV-
https://www.rtings.com/tv/tests/motion/24p
galonzo likes this.
cydeweyz is online now
post #14583 of 23755 Old 04-20-2018, 04:16 PM
andygiddings's Avatar
Quoted: 118 Post(s)
Liked: 79
Originally Posted by R8ders2K View Post
True, but I don't understand why I can't watch 4K on my 5K iMac...
The whole video chain need to be HDMI 2.0a and HDCP 2.2 compliant to display 4k HDR streams which I suspect the Mac 5k display lacks
galonzo likes this.
Room 1 system: Paradigm Reference Active 7.2 system, Anthem AVM50, Oppo BDP-103. Pioneer Elite 610HD. Room 2: Samsung 65HU8550 with SEK3500, Paradigm Monitor 5.1 system, Denon AVR-X2400H, Oppo BDP-203, Nvidia Shield, Apple TV 4k
andygiddings is offline
post #14584 of 23755 Old 04-20-2018, 04:17 PM
cydeweyz's Avatar
Quoted: 421 Post(s)
Liked: 403
*Copyright Protection *
galonzo likes this.
post #14585 of 23755 Old 04-20-2018, 04:27 PM
Quoted: 1589 Post(s)
Liked: 891
Originally Posted by leonmckee View Post
This has happened to me! The latest example I had was the Expendables 1 which was an XML redeem for SD. I was getting SD with Dolby Vision. Crazy, but true! This is also an example of the only time I've seen iTunes making an upgrade available in the iTunes store. I was able to buy the 4K/DV version of the title and now my SD version is gone. The upgrade option pulldown menu was where the "Download" button is normally just below the "Play" button.
EDIT: I've also seen SD with Dolby Vision with rentals, but that's another story.
Leon McKee
RE your SD DV rental, which movie was it and did you select SD by mistake when ordering?
Mike
Sony XBR-65X930E | ATV4K-64GB & 32GB 5th Gen | Nvidia Shield TV Pro 2017 | Logitech Harmony Elite
m_snow is offline
post #14586 of 23755 Old 04-20-2018, 04:27 PM
thatJohann's Avatar
Quoted: 278 Post(s)
Liked: 62
Hmm I have the LG OLED B7A and it says I can do stutter free on every use case. I’ll have to check it out.
What’s driving me crazy is that when I enable match for frame rate and range, whenever I leave a video that’s playing like Netflix for example, the screen goes dark for like 4 seconds (I guess to match back the 60Hz of the Apple TV 4K). If I turn off matching, it goes back instantly without that 4 second blackout.
Is this normal? I’m using belkin 2.1 HDMI from Apple store
post #14587 of 23755 Old 04-20-2018, 05:40 PM
leonmckee's Avatar
Quoted: 487 Post(s)
Liked: 555
The only iTunes rentals I ever do are the $.99 ones that are 4K. The last one I tested was BayWatch and I even posted pics. SD with DV. I've not tested a rental since. The funny thing is that SD with DV actually looks pretty good!
Leon McKee
galonzo, m_snow and markmanner like this.
LR: XBR-65X930E | ATV4K-64GB 5th Gen | UBP-X700 | URC MX-890 | SoundTouch 300 | Luminoodle Bias Lighting
MBR: KDL-65W850A | ATV4K-64GB 5th Gen | URC MX-890 | Luminoodle Bias Lighting
4K HDR/DV Chains: ATV4K/UBP-X700>3ft Monoprice Certified Premium Cables>65X930E
Computing, Truck & Communication Devices: Proud Apple Customer Since 1979
leonmckee is offline
post #14588 of 23755 Old 04-20-2018, 06:27 PM
ScottieBoysName's Avatar
Quoted: 1123 Post(s)
Liked: 305
So, I just ended up with a few Apple TV 4K's in our house, and we're primarily watching Youtube TV.
I have some old Panasonic Plasma 1080P displays, (P65VT50's).
Anything need to do or change or tinker with?
ScottieBoysName is offline
post #14589 of 23755 Old 04-20-2018, 07:34 PM
Quoted: 222 Post(s)
Liked: 202
https://youtu.be/TkHCFhsk4vg
It's normal.
galonzo and leojj25 like this.
Equipment: Epson 9300W projector, Panasonic UB-424, AppleTV4K, Procella Audio Speakers...
Uppsalaing is offline
post #14590 of 23755 Old 04-21-2018, 04:31 AM
tulsabrown's Avatar
Quoted: 77 Post(s)
Liked: 52
Originally Posted by Uppsalaing View Post
It's normal.
Thanks guys, check that one off my list...
galonzo likes this.
tulsabrown is offline
post #14591 of 23755 Old 04-21-2018, 05:44 AM
frankhj's Avatar
Quoted: 70 Post(s)
Liked: 71
I set my ATV to 24Hz with match on so that I very seldom get that screen blanking. Most of what I watch on the ATV is 24Hz.
galonzo likes this.
frankhj is online now
post #14592 of 23755 Old 04-21-2018, 06:22 AM
thatJohann's Avatar
Quoted: 278 Post(s)
Liked: 62
But then the UI is so choppy and sluggish, no?
post #14593 of 23755 Old 04-21-2018, 06:43 AM
leojj25's Avatar
Quoted: 332 Post(s)
Liked: 202
I would rather take the screen blanking for a few seconds and be able to enjoy what I am watching at the fullest than the opposite etc. I have my settings at 4K 60hz match frame and range on. Everything looks great.
Goalline, DaveC56 and jeep05 like this.
Vizio P65-E1 // Sony XBR49X900E
Sony Ht-ST5000 // RCA RTS7015B
Chromcast Ultra // Apple TV 4K
PS4 PRO
leojj25 is offline
post #14594 of 23755 Old 04-21-2018, 07:34 AM
frankhj's Avatar
Quoted: 70 Post(s)
Liked: 71
I've heard this sluggish complaint of the UI before, but I do not have a sluggish UI with 4K SDR, 24Hz, match range & frame rate. I just tried out the 60Hz setting again to confirm and I see no difference. Maybe it has something to do with TVs or receivers? I have an LG-C6 and Yamaha RX-V681 receiver.
galonzo likes this.
post #14595 of 23755 Old 04-21-2018, 07:40 AM
archer75's Avatar
Quoted: 697 Post(s)
Liked: 341
My ui is sluggish at 24hz. Same on my shield. I leave it at 60hz and just let it match.
I have an lg b6. I also have denon and yamaha receivers and tested on a vizio tv. Results are the same across the board.
Streaming Devices: Nvidia Shield, 2x Roku 3's, 1st/2nd gen chromecast, ATV4k, Apple TV 4, xbox 360/one
Displays: Vizio M602i-B3, LG OLED65B6, panasonic ax100u on a 145" S-I-L-V-E-R painted screen, 40" Samsung
Receivers: Denon X3300, Yamaha RX-V663. Bluray/UHD player: Oppo UDP-203
archer75 is offline
post #14596 of 23755 Old 04-21-2018, 08:09 AM
nathan_h's Avatar
Quoted: 2724 Post(s)
Liked: 1956
Nope. Full auto will work fine for you.
nathan_h is offline
post #14597 of 23755 Old 04-21-2018, 08:25 AM
Liked: 305
Great!
Gonna grab a 4K TV here soon. What then?
Sent from my iPhone using Tapatalk Pro
post #14598 of 23755 Old 04-21-2018, 08:52 AM
thatJohann's Avatar
Quoted: 278 Post(s)
Liked: 62
That’s weird. I don’t have a receiver. I plug in the Apple TV 4K directly to my LG B7A. And it’s super sluggish and choppy if I set the UI to 24Hz. Maybe it has to do with the Real Cinema setting? I have it set to ON
post #14599 of 23755 Old 04-21-2018, 09:21 AM
frankhj's Avatar
Quoted: 70 Post(s)
Liked: 71
I have Real Cinema On, TruMotion Off. Weird, am I the only one that doesn't have a sluggish UI @24Hz?
galonzo likes this.
post #14600 of 23755 Old 04-21-2018, 09:47 AM
Quoted: 1802 Post(s)
Liked: 1117
No, I have no problems with the UI being sluggish. I have a 4K Sony projector and it requires setting output to 24p for all HDR content. So I have Match frame rate and match dynamic range both set to on. I have my default output as 4K HDR 24p.
My UI is as smooth as butter. Maybe it is an issue when connected to the LG B models.
galonzo likes this.
GregCh is offline
post #14601 of 23755 Old 04-21-2018, 10:53 AM
Quoted: 40 Post(s)
Liked: 4
I hope people don't mind my asking this without having read through all 400+ pages here first looking for the answer ...
Often, when I haven't used my ATV 4K for overnight or so, when I fire it up it does this thing where the screen goes dark, and then the home screen comes back, repeatedly at a rate of about once every couple of seconds. The only way I can get it to work is to unplug the power cord and plug it back in.
This is viewing on a Sony XBR 900E-series TV, which lord knows has its own flakiness issues. But given that cycling the power fixes the problem, I think it's probably the ATV's fault.
jge1 is offline
post #14602 of 23755 Old 04-21-2018, 11:06 AM
kbmb's Avatar
Quoted: 980 Post(s)
Liked: 765
Yes others have had similar issues, especially with Sony TVs. Doesn’t seem universal though as plenty of people with Sonys don’t have the issue. Definitely something between the ATV and the Sony.
galonzo likes this.
kbmb is offline
post #14603 of 23755 Old 04-21-2018, 11:44 AM
Quoted: 480 Post(s)
Liked: 430
Your UI will be updating at 24fps as opposed to 60fps if you used 60hz. It will be as sluggish as everybody else’s set at that setting. It must just be that you’re not sensitive to it.
Andrew Stirling is offline
post #14604 of 23755 Old 04-21-2018, 12:21 PM
Quoted: 333 Post(s)
Liked: 136
anyone know of any issues with Apple TV 4k ,wifi extremely slow ,this is number 2 and its the same issue ,I've tried my 3 gen one in the same spot and no issues if I check speeds 60/60 ,the 4k one is like 3/ 3. .it does not load or loads slow everything ,the movies ,title pictures on the various apps .nothing else is running slow , I've reset it ,updated to 11.4 ,nothing starting happening about a month ago .sometimes when I reboot it it fixes it for maybe 30 min ,then goes right back to slow . I've reset the router .I looked on line there r some people with the same problems ,I talked to apple ,of course they never heard of such issue. mind u this is the second one ,I've had it since sept ,but no issues until about a month ago.
greatone99
Dave Scurrah is offline
post #14605 of 23755 Old 04-21-2018, 02:31 PM
gomo657's Avatar
Quoted: 758 Post(s)
Liked: 742
No besides my iPhone the ATV is my fastest device 270 Mbps
galonzo likes this.
"well you know what doctor I'm going to go home take two aspirins and call you a b****"
gomo657 is offline
post #14606 of 23755 Old 04-21-2018, 04:31 PM
cydeweyz's Avatar
Quoted: 421 Post(s)
Liked: 403
Sounds like a router problem. What kind do you have?
galonzo likes this.
post #14607 of 23755 Old 04-21-2018, 04:50 PM
Quoted: 333 Post(s)
Liked: 136
Verizon /can it be the router ? all 3 computers ,2 iPhones ,another Apple TV ,playstation ,xbox ,2 tv all on wifi with no issues
greatone99
post #14608 of 23755 Old 04-21-2018, 05:04 PM
goldenegg's Avatar
Quoted: 51 Post(s)
I just picked up an Apple TV 4k today and can't get it to use Dolby Vision on my Sony 65x930e. I've read all over the place that Dolby Vision is supposed to work through the Apple TV on my set. Any ideas what might be going wrong? I have 11.3 installed and have tried both iTunes Movies and Netflix for Dolby Vision content.
EDIT:
Just figured it out. My receiver (Denon 4200) won't be getting Dolby Vision support until this summer. I'll need to connect the Apple TV directly to the Sony TV.
rlb and galonzo like this.
goldenegg is offline
post #14609 of 23755 Old 04-21-2018, 05:12 PM
archer75's Avatar
Quoted: 697 Post(s)
Liked: 341
EDIT:
I just searched for specs on the tv and it doesn't support Dolby vision. It's not mentioned in reviews or the marketing.
archer75 is offline
post #14610 of 23755 Old 04-21-2018, 05:29 PM
goldenegg's Avatar
Quoted: 51 Post(s)
Yes. It supports Dolby Vision.
I’m surprised you didn’t find references to it, as it was a big deal when support was made available through a software update.
EDIT:
So I got Dolby Vision working, but for some reason I'm only getting stereo audio over HDMI ARC. Any thoughts as to why?
EDIT 2:
Got the audio working. Had to set the Apple TV is output Dolby Digital 5.1, rather than LPCM.
galonzo likes this.
apple 4k tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , mgy52ll , mqd22ll , Samsung
