Apple TV owners' thread. - Page 604 - AVS Forum | Home Theater Discussions And Reviews
 27804Likes
post #18091 of 23716 Old 09-18-2018, 06:29 AM
markmanner's Avatar
Quoted: 345 Post(s)
Liked: 294
Originally Posted by markus767 View Post
The cable test seems to be no longer available. The option disappeared for me in one of the last betas.
On mine (running the GM tvOS 12/final 12 release), it has a "Check HDMI Connection" tab under the audio/video tab, and that does a cable test. Is that not showing on yours?
Mark
System
Spoiler!
markmanner is offline
post #18092 of 23716 Old 09-18-2018, 06:36 AM
ROMIL's Avatar
Quoted: 512 Post(s)
Liked: 238
Shows up for me in the Video and Audio menu on the new software.
ROMIL is offline
post #18093 of 23716 Old 09-18-2018, 06:51 AM
markus767's Avatar
Quoted: 5645 Post(s)
Liked: 2667
Originally Posted by bodosom View Post
See [this post and this post]. I'll admit I haven't checked since the last update but I would shocked if Apple removed it.
Mark
Sorry to disappoint but it's gone on my ATV4K – see screenshot.
Name:	Screen Shot 2018-09-18 at 15.50.59.png
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #18094 of 23716 Old 09-18-2018, 07:01 AM
Quoted: 1584 Post(s)
Liked: 890
You have a problem. Try pulling the plug and check again. “Check HDMI Connection” should be right under “Match Content” and above “Reset Video Settings”.
Mike
Sony XBR-65X930E | ATV4K-64GB & 32GB 5th Gen | Nvidia Shield TV Pro 2017 | Logitech Harmony Elite
m_snow is online now
post #18095 of 23716 Old 09-18-2018, 07:02 AM
markus767's Avatar
Liked: 2667
No, don't have any problems. Atmos works
Markus
post #18096 of 23716 Old 09-18-2018, 07:06 AM
Liked: 890
So you don’t realize your missing at least one menu item?
Musician likes this.
Mike
post #18097 of 23716 Old 09-18-2018, 07:14 AM - Thread Starter
bodosom's Avatar
Quoted: 1876 Post(s)
Liked: 1419
Perhaps it depends on your supported bandwidth.
Brian Hampton likes this.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X3500/LG C8
bodosom is offline
post #18098 of 23716 Old 09-18-2018, 07:17 AM
Liked: 890
Hi, I wasn't criticising, just trying to help.
Yeah same here.
Mike
post #18099 of 23716 Old 09-18-2018, 07:18 AM
markus767's Avatar
Liked: 2667
Yes I do. But I really don't care at this point. There's other bugs I'd like Apple to take care of...
Markus
post #18100 of 23716 Old 09-18-2018, 07:54 AM
nrs111's Avatar
Quoted: 40 Post(s)
Guess I have to choose between DV or dolby Atmos. Have a TV that plays DV but doesn't pass atmos via ARC and a receiver that supports atmos but doesn't pass DV. Is there a work around out there for this setup?
nrs111 is offline
post #18101 of 23716 Old 09-18-2018, 08:00 AM
nathan_h's Avatar
Quoted: 2724 Post(s)
Liked: 1956
I believe this device does what you want. Maybe an owner can chime in (or check out the thread for it here on AVS).
https://www.hdfury.com/product/avr-key/
galonzo and nrs111 like this.
nathan_h is offline
post #18102 of 23716 Old 09-18-2018, 08:04 AM - Thread Starter
bodosom's Avatar
Liked: 1419
There are various options that will split the output into video/audio. A few have been mentioned previously in this thread but it's a common and generic issue.
bodosom is offline
post #18103 of 23716 Old 09-18-2018, 08:07 AM - Thread Starter
bodosom's Avatar
Liked: 1419
HDFury makes various products that split HDMI. Some folks don't like the performance/capabilities of the less expensive models. I have direct experience with the Vertex which can be fiddly.
bodosom is offline
post #18104 of 23716 Old 09-18-2018, 08:14 AM
nrs111's Avatar
Quoted: 40 Post(s)
Thanks. This sounds like it will work. Figured there were devices out there that accomplished this but couldn't find them.
nrs111 is offline
post #18105 of 23716 Old 09-18-2018, 08:15 AM
nrs111's Avatar
Quoted: 40 Post(s)
nrs111 is offline
post #18106 of 23716 Old 09-18-2018, 08:26 AM
nathan_h's Avatar
Liked: 1956
Personally, unless you have a special attachment to your AVR, I'd just sell it and upgrade. Might cost a little more than buying a splitter but will be far less fiddly imo.
umenon, Goalline, galonzo and 4 others like this.
nathan_h is offline
post #18107 of 23716 Old 09-18-2018, 09:04 AM
rolltide1017's Avatar
Quoted: 493 Post(s)
Liked: 491
I bet you don’t see it because you are set to 1080p SDR.
PSN ID: CrimsonNagus
XBL GT: Crimson Nagus
rolltide1017 is offline
post #18108 of 23716 Old 09-18-2018, 09:05 AM
Quoted: 480 Post(s)
Liked: 430
Please spend a bit of time hanging around the relevant forum on this website if you’re intending to purchase the avr key. It seems to have some limitations / performance issues with the Apple TV. Im loathe to share this information because I’m not 100% sure but I heard it didn’t support Apple TVs chosen method of sending atmos
Andrew Stirling is offline
post #18109 of 23716 Old 09-18-2018, 09:05 AM
markus767's Avatar
Liked: 2667
Switch yours to 1080p SDR and you'll know.
Markus
post #18110 of 23716 Old 09-18-2018, 09:20 AM
Quoted: 493 Post(s)
Liked: 491
I just might do that this evening after work.
post #18111 of 23716 Old 09-18-2018, 09:53 AM
Quoted: 493 Post(s)
Liked: 491
Originally Posted by mutelight View Post
DD+ which is internally decoded and passed to the AVR via PCM MAT 2.0.
Thanks. I learned something new today. I thought Atmos metadata could only be sent with DD+ or TrueHD, didn’t know it worked with PCM. So, it seems like Apple has little reason to add true bitstreaming now. I was hopping that Atmos was going to push them in that direction.
It’s cool, DD Atmos lights up on my Denon even though I do not have any Atmos speakers. I’m still stuck with an old fashion 5.1 setup. This might get me to look at adding height speakers or those Dolby Atmos speakers that go on top of your fronts.
galonzo likes this.
post #18112 of 23716 Old 09-18-2018, 10:08 AM
Musician's Avatar
Quoted: 2635 Post(s)
Liked: 5210
I can save you the trouble. That wasn’t it — see the first thumbnail below. I have also included an additional thumbnail depicting the typical settings that many of us use with the device set to 4K SDR.
I could be wrong @markus767 , but since you have your Format set to 1080p SDR I presume your display doesn’t support 4K so perhaps EDID is telling the ATV4K you have no need for a Check HDMI Connection option. Likewise the reason the Enable HDR option is missing in your screen shot.
Something else you might not have noticed in your settings is that when you have the ATV4K set to 1080p SDR the Chroma setting is missing (which appears to be normal based on my first screen shot below using that Format).
ID:	2456740   Click image for larger version
galonzo likes this.
Samsung UN78HU9000 & SEK-3500U/ZA - Firmware 1540.3
Samsung UN40HU7000 & SEK-3500U/ZA - Firmware 1540.3
Samsung UBD-K8500 UHD Blu-ray Player; Apple TV 4K
Arris VIP5662W UHD Whole Home DVR; Chromecast Ultra
Marantz SR7005 Receiver; Magnepan Speakers; Martin Logan Subwoofer
Musician is online now
post #18113 of 23716 Old 09-18-2018, 10:15 AM
markus767's Avatar
Liked: 2667
Originally Posted by Musician View Post
you have your Format set to 4K SDR
You mean 1080p SDR.
Markus
post #18114 of 23716 Old 09-18-2018, 10:23 AM
Musician's Avatar
Liked: 5210
You mean 1080p SDR.
Oops, yes that is what I meant to say. Corrected above.
post #18115 of 23716 Old 09-18-2018, 10:39 AM
Brian Hampton's Avatar
Quoted: 1307 Post(s)
Liked: 761
I'm tempted to buy Oceans 8 again ... just to see if I can fix my problem that way.
Someone gave me an iTunes gift card and it's currently on sale.
The version I have was a Vudu UDH code that ported into iTunes with 4K. (THough JPFK is also problematic and I bought that in iTunes proper.)
In the meantime, what helps is I found some movies with HDR/4K that aren't affected and also the movies that are affected I can watch using the Vudu app on ATV4k.
(I tried disconnecting my VUDU from MA and reconnecting it .. that didn't help.)
Since I can watch other stuff without problem... I've just been doing that. I think maybe if I watch enough to over -rite any cache of the problematic movies then maybe they will load properly.
The good news for now is the whole system is still functional. I can watch 4K HRD iTunes movies (whew... I was concerned none of them would work)... just some movies that want to be problematic.
Brian Hampton is offline
post #18116 of 23716 Old 09-18-2018, 10:58 AM
Waboman's Avatar
Quoted: 6874 Post(s)
Liked: 15452
The problem is you're trying to watch Oceans 8. Your ATV is just trying to protect you from the mental anguish. If anything take that giftcard and reward that selfless ATV4K with a right proper movie.
Waboman is online now
post #18117 of 23716 Old 09-18-2018, 11:17 AM
claw's Avatar
Quoted: 2214 Post(s)
Liked: 2069
I believe that only the HDfury Vertex can pass Dolby MAT. Need to verify that.
Before you purchase anything, have you verified that your AVR can accept non-DV input with Atmos? Some older AVRs do not support Dolby MAT either.
galonzo likes this.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Vertex/Linker/Integral
claw is online now
post #18118 of 23716 Old 09-18-2018, 11:38 AM - Thread Starter
bodosom's Avatar
Liked: 1419
[I thought I check Vertex+MAT but now I don't think so.]
I believe @nathan_h has a Vertex so my response should be taken in that context . The Vertex can actually be extremely fiddly. I wouldn't suggest one except under special circumstances, e.g. you have multiple HDMI outputs and can dedicate one to the Vertex.
Early versions of the Vertex firmware wouldn't pass ATV (Profile 5) DV. Later versions wouldn't work when directly connected to the ATV4K. Recent versions won't pass video from my Sony 700 player. You really want a splitter that's built with commodity HDMI 2.1 transceivers rather than a device that can do many clever things but requires programming an FPGA every time an uncommon HDMI feature (DV, MAT) becomes popular.
bodosom is offline
post #18119 of 23716 Old 09-18-2018, 11:45 AM - Thread Starter
bodosom's Avatar
Liked: 1419
My point was supported bandwidth not the ATV output setting. @Musician 's response suggests the former. There's no reason to test the wrong thing. Perhaps we'll find out if the sink supports 4K.
bodosom is offline
post #18120 of 23716 Old 09-18-2018, 12:38 PM
Musician's Avatar
Liked: 5210
...There's no reason to test the wrong thing. Perhaps we'll find out if the sink supports 4K.
Agree.
I suspect his ATV4K might be hooked up to a projector that doesn’t support 4K since a recent post of his indicates he owns an LG PF1000U which supports a maximum of Full HD (1920 x 1080).
It is always helpful for folks to list the equipment they are using when posting about possible flaws such as missing options. 🕵️
jeep05 likes this.
apple 4k tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , mgy52ll , mqd22ll , Samsung
