Apple TV owners' thread. - Page 658 - AVS Forum | Home Theater Discussions And Reviews
 27846Likes
post #19711 of 23810 Old 11-30-2018, 01:05 PM
Quoted: 92 Post(s)
Originally Posted by sonoftumble View Post
O.K. You are crazy! lol
Haha, I figured someone would follow up with that.
Projector: VPLHW40ES + DIY 125" Screen AVR: CX-A5100 + B&K REF 200.7
Speakers: DEFINITIVE TECHNOLOGY BP2000(FL/FR), CLR2000 (C), DEFINITIVE TECHNOLOGY BP10 (RL/RR),
MONITOR AUDIO CT265FX (Ceiling ATMOS/DTS), (4) MONITOR AUDIO CT265FX (Ceiling R/L REAR SURR)
Tweeter2002 is offline
post #19712 of 23810 Old 11-30-2018, 02:14 PM
Quoted: 92 Post(s)
Originally Posted by bodosom View Post
The comments were regarding E-AC-3 vs. AC-3. Not AC-3 vs LPCM (I assume you mean AC-3 not E-AC-3 (DD+) since the ATV doesn't bitstream E-AC-3).
Note that if you force the output to AC-3 on E-AC-3 content you're:
  • Minimizing/Removing/Down-mixing two of the seven channels (converting 7.1 to 5.1).
  • Cutting the effective bandwidth roughly in half -- assuming the presumption of the post you responded to is correct (E-AC-3 is twice as efficient as AC-3).
Correct, my mistake. I prefer selecting Dolby Digital (AC-3) over Dolby Atmos / Best audio unless Dolby Atmos is offered. I haven't rented or purchased any movies with Dolby Digital 7.1, and since I leave my pre/pro up mix everything to 11.1 I feel I am not losing quality. I do realize that selecting best audio is a better choice - on paper, but so was dts surround and it didn't sound superior.
post #19713 of 23810 Old 11-30-2018, 03:49 PM
freshmanjs's Avatar
Quoted: 161 Post(s)
Liked: 85
When I play 4k HDR content from iTunes with match frame rate on and match dynamic range on, I am only getting 8 bit color according to my AVR's info screen. I get 10 bit color on the main menus if I have the default set to HDR, but do not get 10 bit when I play iTunes movies. Any idea why that would be?
Other devices have no trouble sending 10 or 12 bit color.
freshmanjs is online now
post #19714 of 23810 Old 11-30-2018, 04:09 PM
cydeweyz's Avatar
Quoted: 423 Post(s)
Liked: 404
I’ll beat Bodosom and say “Read the 1st page of this thread” for your answer
Brian Hampton and galonzo like this.
cydeweyz is online now
post #19715 of 23810 Old 11-30-2018, 04:10 PM
freshmanjs's Avatar
Quoted: 161 Post(s)
Liked: 85
I read it. According to that, i should NOT be getting only 8 bit for my HDR content at 24Hz. So, that's why I'm asking.
post #19716 of 23810 Old 11-30-2018, 04:26 PM
PJO1966's Avatar
Quoted: 267 Post(s)
Liked: 79
I know the obvious solution for this problem is to turn off HDMI-CEC, but...
I have two devices hooked into my sound bar, the ATV 4K and a new OTA TiVo Bolt. The TiVo recently got HDMI-CEC functionality. The problem I'm having is that even with the TiVo in Standby, it keeps switching the sound bar to its input. I have to switch to the ATV 4K several times before it sticks. From what I've heard with others, the ATV is the only device that allows the input to be pulled. Is there any setting anyone can think of that would prevent this from happening?
PJO1966 is online now
post #19717 of 23810 Old 11-30-2018, 06:54 PM - Thread Starter
bodosom's Avatar
Quoted: 1890 Post(s)
Liked: 1430
You'll have to be more specific and use an expected trouble-shooting process.
Note that the first post in this thread says Assume the ATV is working correctly. So if you're not seeing what you expect make sure everything is set-up correctly including using appropriate content.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X3500/LG C8
bodosom is offline
post #19718 of 23810 Old 11-30-2018, 07:02 PM - Thread Starter
bodosom's Avatar
Liked: 1430
... From what I've heard with others, the ATV is the only device that allows the input to be pulled.
The first point is correct (or you could switch to HDMI "2.1", CEC is purported to be properly defined in that version of the spec).
The second point is incorrect.
The third point should be discussed in the thread for your soundbar since that's the device that's changing.
Another option would be to block the TiVo since that's the offending component.
bodosom is offline
post #19719 of 23810 Old 11-30-2018, 07:46 PM
freshmanjs's Avatar
Quoted: 161 Post(s)
Liked: 85
Issue is Apple TV outputs 24Hz HDR content at 4:2:2 12 bit. Some receivers (including mine) downconvert that to 8 bit. So, I have to choose between 60Hz for 24Hz content and whatever stutter that introduces or I can live with 8 bit color and the proper frame rate. Or, I can just use SDR.
Some quick googling reveals that a lot of folks have same issue. It used to be a problem with Panasonic blu ray players, but they added an option to force 10 bit output. It would be nice if Apple did the same.
post #19720 of 23810 Old 12-01-2018, 09:25 AM - Thread Starter
bodosom's Avatar
Liked: 1430
That violates the current spec so there's no reason to expect Apple to make that change assuming the HDMI transceiver even supports it.
bodosom is offline
post #19721 of 23810 Old 12-01-2018, 10:35 AM
Quoted: 92 Post(s)
Originally Posted by m_snow View Post
I would expect more iTunes deals around Christmas yes. Get your Gift Cards ready!
You might want to check your wish list, and also check out the "UNDER $8 DEALS" in the iTunes menu. Definitely some keepers there. I picked up 2012 for $5 last night.
m_snow likes this.
post #19722 of 23810 Old 12-01-2018, 11:50 AM
claw's Avatar
Quoted: 2221 Post(s)
Liked: 2074
Typically what happens with players that allow you to choose 10-bit instead of 12-bit is that the player will switch to 4K24 4:4:4 10-bit output instead of 4:2:2 12-bit. That doesn't violate anything.
galonzo and smhealey like this.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #19723 of 23810 Old 12-01-2018, 12:29 PM
freshmanjs's Avatar
Quoted: 161 Post(s)
Liked: 85
That’s not true. 4:4:4 10 bit is in spec.
galonzo likes this.
post #19724 of 23810 Old 12-01-2018, 01:54 PM - Thread Starter
bodosom's Avatar
Liked: 1430
Sure.
Yes it is. So is 4:2:2 12b. I think your issue is with the AVR vendor.
bodosom is offline
post #19725 of 23810 Old 12-01-2018, 01:57 PM
freshmanjs's Avatar
Quoted: 161 Post(s)
Liked: 85
Sure.
I know you see yourself as Apple’s defender, but I didn’t say anything about what companies I have or don’t have an issue with. I just said my system isn’t working correctly and asked for help. You didn’t give help, only snark. Not surprising given your other posts here.
post #19726 of 23810 Old 12-01-2018, 03:31 PM - Thread Starter
bodosom's Avatar
Liked: 1430
I did offer help. I suggested you approach the company that sold you a broken AVR. I didn't mean issue in the sense you mean but I can see the ambiguity. I should have said: "The issue you see is because your AVR is out of spec".
On other occasions people have suggested I defend Apple, so I expected that response, but of course I don't. I defend being sensible. People have trouble with that when it's their ox being gored. E.g. I was opposed to OPPO spending engineering resources to provide DV P5 for Sony. Some people thought that ignoring Sony's self-made problem was not appropriate for a company that was in the business of selling things and to ignore Sony would be to their detriment. OPPO closed anyway and features they were admired for that were in development suffered and will likely never be completed. But they let you toggle between 12, 10 and 8 bit output.
Apple is a different case. The struggle with simplicity. They apparently don't want a device as tunable as a 203. So in the case of HDMI given multiple output formats they pick one. It's always been that way. Usually the one that results less bandwidth. E.g. in your case given three output choices they pick the one that needs 9G rather than 18G. So back to your broken AVR -- I suspect it's unlikely Apple will add complexity to produce a work-around for out of spec devices. I certainly hope not because they have multiple, real problems to fix.
m_snow likes this.
bodosom is offline
post #19727 of 23810 Old 12-01-2018, 07:13 PM
bearcatscott's Avatar
Quoted: 16 Post(s)
Originally Posted by bearcatscott View Post
Thanks, JWORT! I will have my mom buy something and see what happens.
My mom bought a free National Geographic movie and all of the family members’ movies showed up on her ATV4. Thanks again for the tip!
Brian Hampton and cydeweyz like this.
BearcatScott
Equipment: Sony XBR-X940E | Denon X1400H | Apple TV 4k
bearcatscott is offline
post #19728 of 23810 Old 12-01-2018, 09:37 PM
cydeweyz's Avatar
Quoted: 423 Post(s)
Liked: 404
Where does this Sharing Library show up because I am testing now and can’t get it.
galonzo likes this.
post #19729 of 23810 Old 12-02-2018, 06:28 AM
freshmanjs's Avatar
Quoted: 161 Post(s)
Liked: 85
I'm hoping to reach a better understanding of the following:
- Is there any setting I can choose on AppleTV that will output 24Hz HDR at 10 bit color? I think the answer is no from what I've read
- Is the Apple TV outputting 24Hz HDR at 12 bit 4:2:2 and my Integra AVR is for some reason treating it as 8 bit (it shows 8 bit as input and output)? Or is the Apple TV for some reason outputting 8 bit for non-DV HDR display? How can I tell?
- Is it possible that the display is actually receiving 12 bit and the Integra is just reporting the information incorrectly? Is there a simple way to tell?
I'm less interested in trying to get either of the companies to change the products. Seems fruitless from my experience.
post #19730 of 23810 Old 12-02-2018, 08:18 AM - Thread Starter
bodosom's Avatar
Liked: 1430
1) Not that I'm aware of.
2) The output per Vertex on my LG is 4:2:2 12b.
3) My previous 4K AVR wouldn't display 10b (status) so if your display doesn't report bit-depth it could be hard to know with certainty. An HDMI sniffer like the Vertex will identify the signal. You might be able to determine visually using something like the Masciola UHD patterns disc with and without the AVR in the video chain.
I was thinking about this and if you bought an EDID manager (like the Vertex) you could remove 12b (or 4:2:2) from the relevant display capability block. That might force 4:4:4 for all bit depths (what the 203 does in Auto mode) -- but I haven't tried this. Note that if you set the UI to [email protected]/HDR you can't change the chroma from 4:2:2. This could mean that Apple might refuse to send 4K HDR to a sink that doesn't support 4:2:2.
Attached is some EDID data for my display.
Name:	Screen Shot 2018-12-02 at 10.12.38 .png
ID:	2490094   Click image for larger version
Name:	Screen Shot 2018-12-02 at 10.21.08 .png
bodosom is offline
post #19731 of 23810 Old 12-02-2018, 08:27 AM
freshmanjs's Avatar
Quoted: 161 Post(s)
Liked: 85
Interesting experiment I did this morning using the 10bit test pattern on netflix.
- ATV set to 4k HDR 60Hz with match content off. Since my projector is known to show 8 bit color in this mode, I expected to see banding in the 10-bit test. I did indeed see banding. So, as expected. Integra showed 10 bit in and out, but projector converted to 8 bit.
- ATV set to 4k HDR 60Hz with match frame rate on, match range off. Expect ATV to output 24Hz 4:2:2 12 bit. AVR reports 24Hz 4:2:2 8 bit in and out. However, I don't see any banding. 10 bit test looks smooth. This leads me to suspect that the 12 bit color is actually making it to the display and the AVR is simply reporting incorrectly.
If this is correct, it's good news.
nathan_h and galonzo like this.
post #19732 of 23810 Old 12-02-2018, 08:49 AM
bdmckinl's Avatar
Quoted: 72 Post(s)
Originally Posted by Tweeter2002 View Post
no, but thankfully the list returned. Not sure why it up and left, it as if apple didn't want me to take advantage of the weekend movie deals. Since I'm new to iTunes and Apple products, should I expect more deals as we get closer to Christmas?
Download an app called ‘CheapCharts’ - it will show you all the daily deals in iTunes. If you don’t want to get inundated, you can even tailor it to just notify you about a certain type of media, and/or a specific wish-list you create.
cydeweyz, galonzo, Mr.G and 1 others like this.
4K/3D Projector: Sony VPL-VW295es | Screen: 120" 16x9 framed 'Screen Goo’ (Digital Grey) | 4K Player: Panasonic DP-UB820-K | Streaming: Apple TV 4K (64 GB) | Gaming: PS4 (500 GB), PS3 Slim (320 GB) | Receiver: Denon AVR-X6500H | Speakers (5.1.4): Axiom VP150 (centre), Axiom M60 x2 (towers), Axiom EP350 (LFE), Axiom QS8 quadpolar x2 (surrounds), Axiom M3 In-Ceiling x4 (atmos) | Remote: Harmony Elite
bdmckinl is offline
post #19733 of 23810 Old 12-02-2018, 12:24 PM - Thread Starter
bodosom's Avatar
Liked: 1430
Presumably if it looks smoother/different you're getting extra bits passed through the AVR. However although the pattern is labeled 10b it's 8b on the ATV (I haven't checked it on other platforms) so when you force HDR you are getting 4:2:2 12b but not from Netflix.
bodosom is offline
post #19734 of 23810 Old 12-02-2018, 12:31 PM
freshmanjs's Avatar
Quoted: 161 Post(s)
Liked: 85
Hmm -- do you know of a free 10 bit test pattern that can be displayed via ATV? thanks
post #19735 of 23810 Old 12-02-2018, 01:23 PM
Keenan's Avatar
Quoted: 3811 Post(s)
Liked: 3509
Here's one place you might look,
10 bit Gradient Test Patterns
Musician likes this.
Keenan is online now
post #19736 of 23810 Old 12-02-2018, 04:22 PM
Quoted: 16 Post(s)
Movies iTunes -> Purchased -> Family Sharing
When you move cursor on Family Sharing you should see icons for all family members on the right side of the screen
cydeweyz likes this.
BearcatScott
post #19737 of 23810 Old 12-02-2018, 05:47 PM - Thread Starter
bodosom's Avatar
Liked: 1430
I don't. None of the HDR10 demos I tried report HDR including the Masciola demo files from 2016 linked from his thread. I've "always" used current Masciola files which do work. The demos certainly suggest they should be HDR10 (10b, HEC) but they don't trigger HDR. I use Infuse and Computers apps. Perhaps I'm making an obvious error.
I do wish Masciola would release the Title file and a couple of ramps in mp4.
bodosom is offline
post #19738 of 23810 Old 12-02-2018, 06:37 PM
dturturro's Avatar
Quoted: 33 Post(s)
Originally Posted by ejewels View Post
I got a new ATV 4K today as a part of the direct tv deal. Set it up to my Sony 900F and works great so far.
I'm considering an upgrade to 4k this season and I'm focused on the Sony 900F. I have a few questions:
1. Has the performance held up after your initial thoughts?
2. How does the PQ hold up on non-4k content?
dturturro is online now
post #19739 of 23810 Old 12-02-2018, 06:41 PM
TheRatPatrol's Avatar
Quoted: 217 Post(s)
Liked: 185
How about some good news?
I just bought a second ATV4K for the bedroom TV. Using my iPhone it took less than 10 minutes to set up, plus it also programmed the ATV remote to control my TV volume without me having to do anything.
Pretty neat I think.
TheRatPatrol is online now
post #19740 of 23810 Old 12-02-2018, 07:05 PM
Quoted: 1595 Post(s)
Liked: 892
You should check at the link below for your 900F questions as this is the ATV4K thread but as an owner of the Sony 930E I can tell you these TV’s and the X1 Extreme processors are known for their high quality of upscaling HD content.
https://www.avsforum.com/forum/166-l...rice-talk.html
Mike
Sony XBR-65X930E | ATV4K-64GB & 32GB 5th Gen | Nvidia Shield TV Pro 2017 | Logitech Harmony Elite
m_snow is online now
apple 4k tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , mgy52ll , mqd22ll , Samsung
