Apple TV owners' thread. - Page 775 - AVS Forum | Home Theater Discussions And Reviews
 27804Likes
post #23221 of 23716 Old 06-18-2019, 01:21 PM
shoman94's Avatar
Quoted: 5048 Post(s)
Liked: 3574
Originally Posted by bodosom View Post
It sounds like you're thinking how it might work or how you'd hope it would work rather that actually doing it. None of what is mentioned above has anything to do with how it currently works.
You go to the calibration page and select wireless audio sync. A pop-up appears on your iOS device and you tap through three screens with your mobile device close to your TV*. Tones are generated via HDMI. There is no video and it doesn't use the camera in the mobile device.
I imagine it might send audio via HDMI to your speakers and perhaps the same audio via BT to the mobile device and compare the two audio inputs. Or not. Since there's no video being captured and you don't get to select any test specific audio attributes I don't see the point (yet). However this is a beta feature with all that implies.
*This bit makes it sound like this is for TV speakers. Not AVRs/soundbars.
Originally Posted by rsonnens View Post
How do you know apples calibration test won’t vary audio AND video signals when testing? The issue of delay is not limited to just the audio format as TVs vary depending upon both frame rate, hdr, and TV specific features. I know of no AVR that can handle all this. This solution is the best because the hdmi lip sync protocol seems to be implemented poorly across systems.
This is an inspired solution to a bad problem if implemented well.
I don't know that's why I'm asking. I'm not part of that beta. It sounds like a manual test and if it is then it sounds limiting. It's similar to the Shield TV manual adjuster with the bouncing ball but utilizing the phone as a mic adjusting it for you. There is just so many variables with different frame rates and audio formats that I don't think one adjustment fixes the HDMI lip sync.
Sent from my LG-H932 using Tapatalk
Sony LCD Master Series Calibration Thread
My P75-C1 Calibration Settings (5.0.14.1).
Sony XBR-75Z9F, Vizio P75-C1, Pioneer Kuro 5020, Pioneer VSX-1131, XBox One(X), Wii, NVIDIA SHIELD.v1, FireTV 4K-HDR, HDHR Connects, QNAP 431+
shoman94 is offline
post #23222 of 23716 Old 06-18-2019, 02:13 PM
Quoted: 68 Post(s)
just a question for maybe someone who knows i have a sony oled and everytime i turn frame rate matching on the background in near black scenes seems to flicker in i turn frame rate matching off it seems to stop just weird is there a reason i cant leave it on
Heavymetalhead55 is offline
post #23223 of 23716 Old 06-18-2019, 02:17 PM
rsonnens's Avatar
Quoted: 602 Post(s)
Liked: 452
Yes that is correct. Sad if it is only a solution for say airplay speakers.
rsonnens is offline
post #23224 of 23716 Old 06-18-2019, 03:21 PM - Thread Starter
bodosom's Avatar
Quoted: 1876 Post(s)
Liked: 1418
Two links have already been posted here about this new beta feature. You can start by reading that content. I'm sure there will be more (endless) discussion about the wonder or pointlessness of this capability -- as it's currently understood.
rsonnens likes this.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X3500/LG C8
bodosom is online now
post #23225 of 23716 Old 06-18-2019, 03:22 PM
pappaduke's Avatar
Quoted: 344 Post(s)
Liked: 356
Matrix Trilogy
Matrix Reloaded and Resolution will not load to play on my ATV 4K. The first Matrix does play. After spending some time on the phone with Apple and adding the suggested Belkin hi-speed cable, I was told some customers are having issues with the DV Atmos version of the last two Matrix movies. Just thought I’d mention it in case someone else is having the same issue.
Apple did refund my money for the trilogy. I like the ease and price of purchasing movies to stream, but there’s something to be said about having a shiny spinning disc......
ppasteur, galonzo and mik2h like this.
Man cave-Marantz 8012, Oppo 203, 4K ATV, Sony XBR-75X940E, Bluesound Vault 2, Harmony One, 2 Paradigm Monitor 9's, CC-390, 2ADP 390's/190's, 2 PDR 100's,
4 SVS Prime elevations. B&W P5. Living room- Yamaha 2010, Bluesound Node 2, Paradigm SE-1's, Zone 2-Paradigm-Stylus 370-SM
Bedroom- Samsung UN60ES7100F, Oppo 103D, Pulse Mini, JBL Bar Studio, ATV3 and Harmony 650
pappaduke is offline
post #23226 of 23716 Old 06-18-2019, 03:43 PM
shoman94's Avatar
Liked: 3574
I already read them..... Thanks though. I was hoping for users that are in the beta would comment if it works well.
shoman94 is offline
post #23227 of 23716 Old 06-18-2019, 04:16 PM
blenky's Avatar
Quoted: 924 Post(s)
Liked: 837
Originally Posted by Buddylee123 View Post
Looks like IOS 13 will include a feature to help sync audio on Apple TV’s, pretty cool
https://9to5mac.com/2019/06/18/ios-1...nc-issues/amp/
As the ATV 4K is the only Apple device I own it would have been nice if there was a way to manually adjust the audio sync.
ppasteur likes this.
Samsung UE55KS8000 | Pioneer SC-LX701 | Dune HD Pro 4K | Zidoo Z9S | Apple TV 4K | Samsung UBD-K8500 UHD Player
blenky is offline
post #23228 of 23716 Old 06-18-2019, 06:11 PM - Thread Starter
bodosom's Avatar
Liked: 1418
As far as I can tell I don't have the ability to adjust a/v sync in my sources (except the OPPO). I can fix constant offsets with my AVR but source offsets can vary.
post #23229 of 23716 Old 06-19-2019, 10:26 AM
blenky's Avatar
Quoted: 924 Post(s)
Liked: 837
TBH the function to adjust audio sync on the fly is on boxes such as a Zidoo or Dune where you are playing your own media and not streaming apps. My point was that this is typical of Apple offering a solution that exists entirely within their walled garden!
blenky is offline
post #23230 of 23716 Old 06-19-2019, 10:49 AM - Thread Starter
bodosom's Avatar
Liked: 1418
Anti-Apple tropes are typically information-free but this observation seems particularly confusing. In any case all systems have design constraints.
Fortunately no one is forcing you to buy Apple products.
post #23231 of 23716 Old 06-19-2019, 12:16 PM
blenky's Avatar
Quoted: 924 Post(s)
Liked: 837
I simply meant that if you own an Apple TV - which I do and love BTW - but don't own a iPhone or iPad you can't take advantage of this new feature.
blenky is offline
post #23232 of 23716 Old 06-19-2019, 12:27 PM
leonmckee's Avatar
Quoted: 487 Post(s)
Liked: 553
Apple has been a closed eco-system since the 70's and look where it's got them Just saying!
Leon McKee
LR: XBR-65X930E | ATV4K-64GB 5th Gen | UBP-X700 | URC MX-890 | SoundTouch 300 | Luminoodle Bias Lighting
MBR: KDL-65W850A | ATV4K-64GB 5th Gen | URC MX-890 | Luminoodle Bias Lighting
4K HDR/DV Chains: ATV4K/UBP-X700>3ft Monoprice Certified Premium Cables>65X930E
Computing, Truck & Communication Devices: Proud Apple Customer Since 1979
leonmckee is online now
post #23233 of 23716 Old 06-19-2019, 12:32 PM
leonmckee's Avatar
Quoted: 487 Post(s)
Liked: 553
I vividly remember sitting in a coffee shop, circa 1991, with my first new Apple laptop (used for business). No internet back then, but what freedom! I can't even begin to count the number of comments I've received about Apple's faults in coffee shops. Just thinking out loud
Leon McKee
post #23234 of 23716 Old 06-19-2019, 01:47 PM
blenky's Avatar
Quoted: 924 Post(s)
Liked: 837
Leon McKee
I'm not having a pop at Apple - I fully understand how they work and their success. I was just making the observation
blenky is offline
post #23235 of 23716 Old 06-19-2019, 01:53 PM - Thread Starter
bodosom's Avatar
Liked: 1418
Yes, there are a number of ATV "features" which require an extra Apple device. As far as I know none of them prevent you from using an ATV to watch video or listen to audio.
By the way, given the current behavior it looks like Apple is trying to correct for distance from display/speakers to seating position (~3ms/m). I'm not aware that people consider this to be a problem unless you're in a very large room.
post #23236 of 23716 Old 06-19-2019, 03:10 PM
rsonnens's Avatar
Quoted: 602 Post(s)
Liked: 452
My guess is that then they really are just solving for WiFi / Bluetooth speaker lag. It is a problem but not the general lip sync issue that they could have tackled.
Edited: unless they synch to a video image it really is unclear it this solves anything other than knowing the absolute audio lag. But without knowing the video lag it cannot solve people’s problems, even with wireless speakers.
Craig Mecak and shoman94 like this.
rsonnens is offline
post #23237 of 23716 Old 06-19-2019, 04:01 PM
leonmckee's Avatar
Quoted: 487 Post(s)
Liked: 553
Just giving you a hard time as we say here in the USA. I lived on the Burtonwood Army Depot in Warrington as a kid. After attending English schools, as a Yank, and having to defend myself each and every single day I sometimes poke. So, just kidding with you!
Leon McKee
post #23238 of 23716 Old 06-19-2019, 04:16 PM
blenky's Avatar
Quoted: 924 Post(s)
Liked: 837
Leon McKee
blenky is offline
post #23239 of 23716 Old 06-19-2019, 04:26 PM
Quoted: 63 Post(s)
Liked: 64
Hi folks.
Does anyone here use multiple Apple TV 4K in your house?
I just ordered a second Apple TV 4K to use in our bedroom and wondering what would be the best way in terms of Apple ID?
Do you guys prefer to use the same Apple ID across multiple ATV or different Apple IDs?
(All of our family members use iPhone and family sharing is enabled across our Apple IDs.)
ShePearl is offline
post #23240 of 23716 Old 06-19-2019, 04:55 PM
bobby94928's Avatar
Liked: 796
Originally Posted by ShePearl View Post
Hi folks.
I use the same Apple ID across all of my Apple devices: AppleTV, iPad, Mac, iPhone.....
ShePearl likes this.
Bobby
bobby94928 is offline
post #23241 of 23716 Old 06-19-2019, 05:14 PM - Thread Starter
bodosom's Avatar
Liked: 1418
Hi folks.
Currently the Computers app needs a consistent ID for Home Sharing and the ATV needs a consistent ID for iCloud features (e.g. Home Screen layout). Family Sharing is easier if you use the same ID but sharing is supported. I use the same IDs (Apple and iTunes) on all of mine. Apple really needs [to] fix iCloud sharing.
post #23242 of 23716 Old 06-19-2019, 05:49 PM - Thread Starter
bodosom's Avatar
Liked: 1418
Yes. That was my point earlier before I tried to imagine how the current process could be useful.
I posted the relevant images in the beta thread. The only thing missing is the wavefront animation. You can see a single frame of it in the third ATV image.
post #23243 of 23716 Old 06-19-2019, 06:02 PM
Mikenificent1's Avatar
Quoted: 161 Post(s)
Liked: 46
I searched this thread for “HomePod” to see if any one is using stereo HomePods as the output for their Apple TV. It doesn’t look like anyone here is. I read a while ago that if you set the HomePods as the out of the Apple TV that the change wouldn’t stay. Also that the left and right channels could could get out of sync.
I wanted to see if those issues have been fixed?
Mikenificent1 is offline
post #23244 of 23716 Old 06-19-2019, 06:45 PM
mutelight's Avatar
Quoted: 2173 Post(s)
Liked: 2460
Hi folks.
I have 3 in my home and the main account of all of them is the same Apple ID and it all syncs perfectly as far as the home screen layout and installed apps.
With tvOS 13, you can add additional accounts but I would recommend having the same base/primary account on all of them if you are going to "manage" them.
mutelight is offline
post #23245 of 23716 Old 06-20-2019, 05:54 AM
Soundizer17's Avatar
Quoted: 591 Post(s)
Liked: 138
Originally Posted by brotony View Post
Have you considered Bluetooth headphones? Those can vary in cost from cheap to expensive but for TV likely gets the job on the cheap. The Apple TV 4K will do Bluetooth audio too.
Your TVs may support Bluetooth as well. Private listening with Roku consumes a lot of battery.
Sent from my PH-1 using Tapatalk
Bluetooth from Apple TV4K is only SBC. I tested with my Sony WH1000XM3 Headphones which shows the bluetooth codec name in its Sony Headphone IOS APP. It shows SBC when connected to both my AppleTV4K devices and AAC when connected to my iPhone and iPad.
SBC Sounds awful. Very compressed. I complained to Apple about it. They replied that it does support AAC over Bluetooth.
Soundizer17 is online now
post #23246 of 23716 Old 06-20-2019, 05:59 AM
Quoted: 591 Post(s)
Liked: 138
I think there will be a hardware update to Apple TV4K this September to offer:
1. Better processing power for Gaming.
2. Possible update to support HDR 10+ and HDR HLG.
3. Faster frame rates at 120fps for certain games.
4. A H1 Chip for blue tooth which is on the Airpods 2 and Beats pro.
5. Support for Game Controllers - Xbox and Playstation
leonmckee likes this.
post #23247 of 23716 Old 06-20-2019, 06:53 AM
leonmckee's Avatar
Quoted: 487 Post(s)
Liked: 553
I've not heard any rumors, but your list seems plausible with my only major hmm being the HDR10+. We shall see
Leon McKee
Soundizer17 likes this.
post #23248 of 23716 Old 06-20-2019, 07:00 AM
Quoted: 591 Post(s)
Liked: 138
Leon McKee
A prediction based on a few things including the launch of gaming services Apple announced this year in a keynote speech.
And maybe it will stream 2020 Olympics in HDR HLG.
post #23249 of 23716 Old 06-20-2019, 08:16 AM - Thread Starter
bodosom's Avatar
Liked: 1418
I'll just note that the H1 part is used in headphones -- the ATV4K already supports BT 5.0 -- and Apple announced Xbox and Playstation controller support on the ATV4k as part of tvOS 13. I'm not saying that there won't be new hardware announced in the fall but it won't be for the above reasons.
post #23250 of 23716 Old 06-20-2019, 08:27 AM
Quoted: 591 Post(s)
Liked: 138
Yes aware that it is part of Headphone Bluetooth connectivity.
I forgot that the controllers compatibility were already announced - good call.
apple 4k tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , mgy52ll , mqd22ll , Samsung
