Apple TV owners' thread. FAQ in first post - Page 225 - AVS Forum | Home Theater Discussions And Reviews
 31998Likes
post #6721 of 29062 Old 10-14-2017, 01:29 PM
ht guy's Avatar
Quoted: 258 Post(s)
Liked: 235
Originally Posted by akadennis View Post
Movies ported over from other retailers in HD are outputted through apple in HDR if available, however you do not get the full 4k resolution. At least that has been my experience.
Is this true, even when redeeming the "digital copy" code from a physical UHD?
ht guy is offline
post #6722 of 29062 Old 10-14-2017, 01:45 PM
Carter D's Avatar
Quoted: 403 Post(s)
Liked: 180
Originally Posted by thomasfxlt View Post
Let’s not confuse resolution and dynamic range. HD or 4k/UHD is resolution. HDR is High Dynamic Range at it’s not embedded in the resolution of a video file. It’s metadata and it can work with an HD file or UHD file. In the case of HDR10, we set the parameter manually on the ATV and the file displays inside that range and color space. In the case of DV, we set it manually as well, but the metadata varies dynamic range on a scene by scene basis inside the color space.
The HD files I’ve referenced are all recognized by iTunes as 4k files and no option for me to purchase or upgrade is available. I’ll observe on a case by case basis tonite precisely what’s happening with each.
Hi Thomas. When I select HDR in settings the picture is quite dark. Is there a work around for this or is just as it’s supposed to be.
Carter
LG 65 EF 9500,Yamaha 3050,Oppo 203
Directv C61 4K box, Apple TV, SONOS Connect
Triad Bronze Center, Triad Bronze LR-H Atmos, Elan inwall surrounds, Velodyne Subs,
Savant Remote, Harmony Ultimate Home remote
"It ain't 4K if it ain't shot in 4K"
Carter D is offline
post #6723 of 29062 Old 10-14-2017, 02:02 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 12108 Post(s)
Liked: 7213
Originally Posted by MarkMul1 View Post
Thanks !
I’ve figured out that if I tell it to go to sleep first and turn it back on from being off it comes back up fine. Must not like to try and re sync while still being on. I can’t tell if there is an actual sleep or power off command. I’m using my harmony remote and haven’t figured that out yet.
Since your using it with the E6 and are probably ahead of me, I just picked it up. Are you leaving it in DV all the time or switching back to SDR if your watching non true hdr content?
Thanks again.
You can initiate a “Sleep now” using the ATV remote by a long press on the TV button. I spent quite a bit of time trying to program this onto my Harmony but was unsuccessful. If anyone knows how to program the Sleep Now command on the Harmony, please let us know.
AustinJerry is online now
post #6724 of 29062 Old 10-14-2017, 02:06 PM
akadennis's Avatar
Quoted: 577 Post(s)
Liked: 232
I don't believe so. If your redeeming a Digital Copy from a physical UHD then you should get the full 4k HDR treatment if available.
ht guy and tylerk86 like this.
akadennis is offline
post #6725 of 29062 Old 10-14-2017, 02:21 PM - Thread Starter
bodosom's Avatar
Quoted: 2441 Post(s)
Liked: 1924
Originally Posted by Cheezmo View Post
Just a heads up for those playing with the developer HUD. I turned it on and later asked to see beta updates (I wanted 11.1b2 which fixes the UI brightness issue in HDR).
If you're running beta code you need to get the appropriate version of Xcode. That may require having a developer account.
Cheezmo likes this.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X3500H/LG C8
bodosom is offline
post #6726 of 29062 Old 10-14-2017, 02:26 PM - Thread Starter
bodosom's Avatar
Liked: 1924
You can bet the easy way to enable the HUD without an active developer account will soon go away. Apple doesn't want people peeking into the details like this.
I'll take that bet. Apple publishes an enormous amount of information for developers that's public, they're not particularly secretive about how things work when using public APIs -- they're just not obvious.
Sujay and tylerk86 like this.
bodosom is offline
post #6727 of 29062 Old 10-14-2017, 02:29 PM - Thread Starter
bodosom's Avatar
Liked: 1924
Movies Anywhere
When we were asked to move the MA discussion to an MA thread I was curious who might have complained given the low volume of traffic. I now see those complaints were prescient. More of the MA posts seem unrelated to the ATV and might be better posted elsewhere.
Just sayin'
ht guy, I WANT MORE and brotony like this.
bodosom is offline
post #6728 of 29062 Old 10-14-2017, 02:39 PM - Thread Starter
bodosom's Avatar
Liked: 1924
4K bandwidth shaping
So I've been adjusting my bandwidth. The bad news is yes Apple is now using various resolution steps in the face of network impairment for HD content and I've seen some instances of resolution changes even with no impairment although it's almost a flicker. In my limited testing it's much faster than I rember Netflix being but I haven't decided if I'm going to test the Netflix app.
2228x928 is what you get at 10Mbps (after a while). I assume that a download would resolve the HD issue.
nathan_h likes this.
bodosom is offline
post #6729 of 29062 Old 10-14-2017, 02:45 PM
thomasfxlt's Avatar
Quoted: 3331 Post(s)
Liked: 6192
I’ve seen this as well while monitoring the last 2 days. Input resolution steps up. I’m running a 62gbps cable connection but WiFi to the AppleTV and at a consistent 50gbps connection, full 4k streams at 30mps bitrates are no problem.
Sent from my iPad using Tapatalk Pro
SONY Z9F LCD Master Series Owners Thread
Vizio 2016 P series FAQ, general info and Help
Sony Z9F 75, Vizio P75C1 UHD/HDR/DV, Pioneer Elite SC-95, Samsung UHD Bluray K8500, AppleTV 4K, CC Ultra
thomasfxlt is offline
post #6730 of 29062 Old 10-14-2017, 02:56 PM - Thread Starter
bodosom's Avatar
Liked: 1924
Originally Posted by thebignewt View Post
Will the 4K Apple TV Netflix app be the same way
The Netflix app is sending 4K DV.
cgpublic likes this.
bodosom is offline
post #6731 of 29062 Old 10-14-2017, 03:00 PM
thebignewt's Avatar
Quoted: 340 Post(s)
Liked: 94
I just bought Goodfellas in 4k/HDR. It comes with a DL code from Ultraviolet. I'm assuming iTunes DL isn't an option. I have a VuDu account though. If I DL it to VuDu will I be able to access it via my 4K ATV (coming tomorrow) and watch it in 4k or DolbyVision using the VuDu app, or iTunes?
[/B] LG OLED65E6P TV, Yamaha RX-V383 AVR with Paradigm speakers, Cableone STB, Samsung UHD BD player, AppleTV 4K[/B]
thebignewt is offline
post #6732 of 29062 Old 10-14-2017, 03:01 PM
Ash Sharma's Avatar
Quoted: 1163 Post(s)
Liked: 841
Thanks !
Thanks again.
Leaving it on DV
MarkMul1 likes this.
Ash Sharma is online now
post #6733 of 29062 Old 10-14-2017, 03:15 PM
cydeweyz's Avatar
Quoted: 456 Post(s)
Liked: 441
The 4k redeem sheet says yes. Vudu for code. If it shows UHD in Vudu, iTunes should follow in 4k
cydeweyz is offline
post #6734 of 29062 Old 10-14-2017, 03:18 PM
thomasfxlt's Avatar
Liked: 6192
Mine came across to iTunes as HD from VUDU, likely because the 4k version on VUDU is a remaster and its only HD on iTunes (for now anyway).
post #6735 of 29062 Old 10-14-2017, 03:28 PM
cydeweyz's Avatar
Quoted: 456 Post(s)
Liked: 441
Yes but seeing as he bought the 4k disc, the included code should not redeem as a the remaster title, I hope. Just in case, this is the redeem link from the Google Sheet- https://my.vudu.com/redeem.html?pdefid=10:252
cydeweyz is offline
post #6736 of 29062 Old 10-14-2017, 03:33 PM
thebignewt's Avatar
Quoted: 340 Post(s)
Liked: 94
Yeah I tried going to wb.com/redeemdigital like the thing said, and got steered to the Ultraviolet site to put in the code, it says I'll get SD only if I do it.
post #6737 of 29062 Old 10-14-2017, 03:34 PM
roland6465's Avatar
Quoted: 446 Post(s)
Liked: 456
Count me in the camp of "ATV4K forcing HDR isn't a problem." I use the "Oledurt Bright Cinema HDR" settings on my Epson 6040 projector, and with HDR content, it looks to my eyes as good as a UHD disc. With 4K, non-HDR content, the settings push blue and green, so I change the color space to rec.709, and the picture is stellar. It took me about 3 episodes of Ozark to get it, but I'm more than satisfied.
galonzo and cgpublic like this.
roland6465 is offline
post #6738 of 29062 Old 10-14-2017, 03:36 PM
cydeweyz's Avatar
Quoted: 456 Post(s)
Liked: 441
This is the redeem sheet I’m talking about that’s shared throughout the forums-
https://docs.google.com/spreadsheets...htmlview#gid=0
cydeweyz is offline
post #6739 of 29062 Old 10-14-2017, 03:57 PM
cgpublic's Avatar
Quoted: 220 Post(s)
Liked: 178
Mindhunter
I watched the first two episodes directed by David Fincher, and the presentation in 4K DV was absolutely stellar, with a real Zodiac vibe. Nicely done all around.
Space | The Media Room: 590 CUFT [10.5 L x 7.5 W x 7.5 H] | View Distance: 6' | Audyssey MultEQ | FiOS Gigabit Ethernet
Sound | 5.1.2 Atmos: Denon AVR-S920W | Pioneer A. Jones SP-BS22-LR/SP-C22/SP-T22A-LR | Polk OWM3 | Emotiva BasX S8
Vision | 4K OLED: LG C8 | LG UBK90 | Panasonic DP-UB820 | Apple TV 4K | Microsoft XB1S | FiOS Moto
cgpublic is offline
post #6740 of 29062 Old 10-14-2017, 05:15 PM
tmdorsey's Avatar
Quoted: 476 Post(s)
Liked: 455
Here’s my report:
Every title I mentioned in my post earlier is working as I described. Natural size is 4k resolution @ 3828 x XXXX. 4/k level bitrates anywhere from 16-40. HDR headers displaying and working as spec’d per title. All of those titles were procured w HD codes.
So if I’m understanding this right movies bought elsewhere in HD and linked to iTunes through MA will play in UHD provided they get the appropriate bandwidth for UHD playback and if not they down convert to 2K?
I need to know this as Amazon has a sale on the digital HD version of Wonder Woman, but if I can’t get that copy upgraded to UHD when in it comes over to iTunes, I’m not purchasing it.
tmdorsey is offline
post #6741 of 29062 Old 10-14-2017, 05:18 PM
thomasfxlt's Avatar
Liked: 6192
Don’t rely on me. My HD titles were purchased as iTunes compatible codes and specific ones have worked. I’ve not tried anything from Amazon.
post #6742 of 29062 Old 10-14-2017, 05:23 PM
cydeweyz's Avatar
Quoted: 456 Post(s)
Liked: 441
3rd Party HD will stay HD. Some may be viewed as HD with HDR. 3rd Party 4k (Vudu/GooglePlay)should transfer as 4k. iTunes HD, purchased or redeemed in iTunes, will upgrade to 4k.
nathan_h and ZephyrForza79 like this.
cydeweyz is offline
post #6743 of 29062 Old 10-14-2017, 05:27 PM
thomasfxlt's Avatar
Liked: 6192
I’ve demonstrated today that 3rd party HD codes are in fact upgrading to 4k and working correctly in many instances. If you read back a bit you’ll find my post. I’ve verified natural file resolution is streaming at 4k with the right HDR headers. Confirmed using HUD/Developer tool.
Both of these titles were iTunes compatible HD codes bought from 3rd parties. I’ve got at least 10 that are working correctly.
Deepwater Horizon
John Wick 2
nathan_h, meles and chunon like this.
post #6744 of 29062 Old 10-14-2017, 05:42 PM
zAndy12's Avatar
Quoted: 344 Post(s)
Liked: 252
Deepwater Horizon
John Wick 2
As far as I know if they were itunes hd codes then they would play in 4k (if available) regardless of where you bought the code. It's when you buy a hd uv code i.e non itunes code that gets propagated through to itunes via MA that it won't play in 4k
Sent from my SM-G935F using Tapatalk
zAndy12 is offline
post #6745 of 29062 Old 10-14-2017, 05:51 PM
william06's Avatar
Quoted: 922 Post(s)
Liked: 511
Quick question. On atv apps so far is vudu and netflix just 2 channel audio but itunes 5.1 and 7.1. Thanks in advance.
william06 is offline
post #6746 of 29062 Old 10-14-2017, 05:59 PM
Quoted: 34 Post(s)
Not sure about Vudu but Netflix is 5.1 at a minimum.
Nordic4tKnight is offline
post #6747 of 29062 Old 10-14-2017, 06:57 PM
william06's Avatar
Quoted: 922 Post(s)
Liked: 511
post #6748 of 29062 Old 10-14-2017, 07:00 PM
Quoted: 387 Post(s)
Liked: 186
Vudu has tons of movies in 5.1 including Atmos
LG OLED 55C6P | LG OLED 65B7A | Denon AVR-X8500H | Denon AVR X4300H | Parasound 2125, Monolith X7 and ATI 1506 Amps | Definitive Technology Speakers /w Earthquake SuperNova MKV-12 with 9.1.4 Atmos | LG UP970 and Oppo 203 UHD Players | Nvidia Shield | ATV4K | Roku Ultra | Amazon FireTV
TohaLA is offline
post #6749 of 29062 Old 10-14-2017, 07:05 PM
william06's Avatar
Quoted: 922 Post(s)
Liked: 511
Im talking about the apple tv 4k specifically. Vudu app and netflix app the apple tv4k I don’t think is atmos enabled yet. I know the roku advanced models do though but no Dolby Vision.
post #6750 of 29062 Old 10-14-2017, 08:32 PM
nathan_h's Avatar
Quoted: 2844 Post(s)
Liked: 2033
Won’t work.
Should work but no one has posted screen shots showing it yet.
Here’s my report:
Yep if you actually own an HD copy in iTunes you are golden. But if you own an HD copy elsewhere ported over, not so much.
nathan_h is offline
apple 4k tv , apple tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , Samsung
