Apple TV owners' thread. FAQ in first post - Page 253 - AVS Forum | Home Theater Discussions And Reviews
 29172Likes
post #7561 of 25666 Old 11-01-2017, 12:02 PM
mutelight's Avatar
Quoted: 2245 Post(s)
Liked: 2534
Originally Posted by bodosom View Post
In a follow-up @nathan_h notes the minute where the meta-data comparison is found.
kbmb linked me the video. I must have missed it. Sad news that it is doing it on the fly.
It does look like they do a decent job though, just wish they used a HDR10 core to close the gap since there are differences.
nathan_h and galonzo like this.
mutelight is online now
post #7562 of 25666 Old 11-01-2017, 12:03 PM
CCsoftball7's Avatar
Quoted: 1695 Post(s)
Liked: 1287
Originally Posted by lujan View Post
It's true, the Vizio "P" series will show the actual resolution coming from the apps such as Netflix. If it is an HD only show, the display "Info" button will show 1080p and not 2160p. Other devices such as the Shield, Apple TV 4k, Chromecast Ultra will all report 2160p regardless of the actual resolution. The Vizio may up-convert everything but it still shows us what the actual resolution that it's receiving.
The same would hold true of the other devices you mentioned (except CCU, no way to change the resolution) if the device sent the default resolution to your TV. The TV just reports what is being sent from the device.
Sony XBR75X940C & XBR65A1E Samsung UBD K8500
My Recommended Daytime Settings Apps(Video), My Recommended Daytime Settings Apps, My non-HDR and HDR Settings, Setting HDMI to show no overscan
Sony XBR75X940C, Samsung UBD K8500, Roku Ultra, DirecTV RVU and C61K, Chromecast Ultra
CCsoftball7 is offline
post #7563 of 25666 Old 11-01-2017, 12:04 PM
gomo657's Avatar
Quoted: 814 Post(s)
Liked: 801
The new update works like a charm to all of those on the fence hdr is hdr, sdr is sdr,24p,50 and 60p!
"well you know what doctor I'm going to go home take two aspirins and call you a b****"
gomo657 is online now
post #7564 of 25666 Old 11-01-2017, 12:05 PM
Liked: 1287
I'll update once I get home tonight. MUCH better experience IMHO.
post #7565 of 25666 Old 11-01-2017, 12:06 PM
thomasfxlt's Avatar
Quoted: 3328 Post(s)
Liked: 6178
An observation for everyone from my experience with 11.2 beta. The volume levels have improved for titles playing out of iTunes. Not sure what’s changed but I’m running 10dB lower than previous and getter better center channel separation for dialogue.
jeep05, aggrobot, Sujay and 2 others like this.
SONY Z9F LCD Master Series Owners Thread
Vizio 2016 P series FAQ, general info and Help
Sony Z9F 75, Vizio P75C1 UHD/HDR/DV, Pioneer Elite SC-95, Samsung UHD Bluray K8500, AppleTV 4K, CC Ultra
thomasfxlt is offline
post #7566 of 25666 Old 11-01-2017, 12:06 PM
bucknuts07's Avatar
Quoted: 177 Post(s)
Liked: 84
I'm thinking of picking up my first apple tv tonight. How do I download the public beta ? Also, I have a Yamaha receiver, so I guess I have to settle for hdr, until my receiver can pass Dolby Vison.
Xbox Live- bucknuts07
PSN-bucknuts07
bucknuts07 is offline
post #7567 of 25666 Old 11-01-2017, 12:08 PM
kbmb's Avatar
Quoted: 984 Post(s)
Liked: 778
Sign up here: https://beta.apple.com/sp/betaprogram/
Use the same Apple ID you use on the ATV. You'll get a new option under Updates to enroll in Beta. Turn this on and you'll start getting beta updates.
kbmb is offline
post #7568 of 25666 Old 11-01-2017, 12:14 PM - Thread Starter
bodosom's Avatar
Quoted: 2103 Post(s)
Liked: 1637
Originally Posted by rdh86 View Post
Appreciate the input. So they added in auto framerate and auto hdr/sdr switching but not resolution?
That's not quite how it works. If you ask the ATV to send 1080 to what appears to be a 1080 sink but the display is actually 4K the display will convert it to 4K (because no one wants to see a quarter size image in the middle of the screen) while if you ask the ATV 4K to send a 1080 source to a 4K sink the ATV 4K will convert it 4K.
Like sending PCM instead of a bitstream this may not matter unless there's some display specific processing that you like (e.g. auto HDR) that's only triggered by 1080. Other than that it's simple 2x scaling which that should be hard to get wrong.
nathan_h and Brandon B like this.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X3500/LG C8
bodosom is online now
post #7569 of 25666 Old 11-01-2017, 12:17 PM
aggrobot's Avatar
Quoted: 24 Post(s)
This is seriously great news!!!!! I've been missing my 3rd gen ATV for this one single thing. Thank you for sharing.
aggrobot is offline
post #7570 of 25666 Old 11-01-2017, 12:20 PM
kwindrem's Avatar
Quoted: 46 Post(s)
Liked: 42
Appreciate the input. So they added in auto framerate and auto hdr/sdr switching but not resolution? Seems like an odd omission and reason enough to stick with my built in apps for now.
I noticed that also but you can get it to output HD instead of 4K at the expense of the menus and screen saver not being 4K.
If you set the main rate to 1080 SDR 60 Hz ATV will not upscale 1080 content. In this mode when you play 4K content ATV WILL switch to 4k output.
ATV WILL upscale SD to 1080 then the TV rescales that to 4K. This technically violates the "never scale twice" rule but in this case a 2:1 rescale would be hard to mess up or even notice unless you are very close to the TV.
galonzo likes this.
Kevin Windrem
kwindrem is offline
post #7571 of 25666 Old 11-01-2017, 12:20 PM
JMGNYC's Avatar
Quoted: 160 Post(s)
Liked: 126
Tried the public beta. I'm very impressed. At least on my setup with a Denon AVR and LG B6P the transitions changing refresh rate and dynamic range are short and smooth.
Here's what I've found so far from my Home Screen in SDR/60:
Netflix: Everything seems to be switching perfectly.
Tested
SDR/24
SDR/50
DV/24
iTunes: This is working fine too
Tested
SDR/24
HDR/24
DV/24
Hulu, Showtime, and Starz all switch nicely to SDR/24
HBO seems stuck at SDR/60
Plex: Sort of works
Direct Play from m4v works fine
Direct Stream from mkv does not change refresh rate
Infuse isn't ready yet, they'll need a release as they use their own player.
timeisapear and aggrobot like this.
JMGNYC is offline
post #7572 of 25666 Old 11-01-2017, 12:22 PM - Thread Starter
bodosom's Avatar
Liked: 1637
I'm just assuming my $2500 display will do a better job than the $250 ATV.
You shouldn't. It's simple scaling that's probably done by a video processor SOC. It could even be the "same" one Apple uses since they keep that a secret.
The cost of your display is dominated by the panel.
post #7573 of 25666 Old 11-01-2017, 12:22 PM
lujan's Avatar
Quoted: 4648 Post(s)
Liked: 2707
My Shield will show 2160p for everything even if it's SD content. The Apple TV 4k will send everything as 2160p but will correctly show HD when using the "swipe down" or "arrow down".
CCsoftball7 likes this.
lujan
562 Ultra HD
724 HD
4 SD
lujan is online now
post #7574 of 25666 Old 11-01-2017, 12:54 PM
Quoted: 21 Post(s)
Liked: 1
Apple is offering a high speed Belkin HDMI cabel with 48gbit/s. Other cables only offer 18gbit/s. is it important to use the 48gbit/s cable? In the Apple TV 4k settings it says that you need a high speed HDMI cable for chroma 4:2:2
this is the cable recommended by Apple for the ATV 4k: https://www.apple.com/shop/product/H...-hdmi-cable-2m
enigma2k is offline
post #7575 of 25666 Old 11-01-2017, 12:56 PM
mutelight's Avatar
Liked: 2534
Premium Certified 18Gbps cables are fine.
galonzo likes this.
post #7576 of 25666 Old 11-01-2017, 01:06 PM
sutton8's Avatar
Quoted: 361 Post(s)
Liked: 128
I’m also waiting for my Denon receiver to get the DV update. Meanwhile I’m connecting the ATV directly to the TV and getting DD back to my amp via optical. OK solution for now.
7.1 Yamaha RX-A3080, Monitor Audio (Apex & Silver), Seismic 110, XBOX, Cambridge Audio CXUHD, Dune HD Solo 4K, Roku SS+, Panasonic TX65GZ950B
5.1 Denon X7200WA, Focal Dome, LG OLED E7V
In both Setups Virgin Tivo V6, Zappiti 4K HDR, FireTV Stick 4K, Harmony Elite
sutton8 is offline
post #7577 of 25666 Old 11-01-2017, 01:34 PM
tylerk86's Avatar
Quoted: 257 Post(s)
Liked: 43
Alright. I came home and looked through a cardboard tube held up to the black bars at Brightness 50 for SDR, HDR and Dolby Vision purchased content from iTunes. Dolby Vision glows at Brightness 50. Neither HDR nor SDR glow at 50. The fact that HDR doesn’t have this issue leads me to believe it’s a flaw with the Apple TV’s DV implementation, but if no one else is seeing this then I’m stumped. ALSO, I’m not sure if would be a factor, but I’ve disabled ABL in the service menu.
LG OLED55C7P
Apple TV 4K
Nintendo Switch
tylerk86 is offline
post #7578 of 25666 Old 11-01-2017, 01:42 PM
dodo/lurker's Avatar
Quoted: 40 Post(s)
Liked: 66
Well, it's nice to see the source specific HDR and Dolby Vision pop ups on the tv now.
Next step: Dolby Atmos. Please?
janila likes this.
dodo/lurker is offline
post #7579 of 25666 Old 11-01-2017, 01:53 PM - Thread Starter
bodosom's Avatar
Liked: 1637
48Gbps is HDMI 2.1 speed. There are no retail HDMI 2.1 devices, including the ATV 4K so there's no assurance this cable will be "future-proof". If you can get one for the same price as the equivalent Premium Certified HDMI 2.0 cable then it might be worthwhile. Or not, it depends on non-technical issues.
brotony likes this.
post #7580 of 25666 Old 11-01-2017, 01:53 PM
cgpublic's Avatar
Quoted: 220 Post(s)
Liked: 178
Take Your Pick
Originally Posted by dodo/lurker View Post
Next step: Dolby Atmos.Please?
What's your Atmos set-up? Have you tried an up mix to Dolby Surround or DTS Neural:X? Regardless, I would have to imagine with HomePod on the horizon, an update will be in the near future.
Space | The Media Room: 590 CUFT [10.5 L x 7.5 W x 7.5 H] | View Distance: 6' | Audyssey MultEQ | FiOS Gigabit Ethernet
Sound | 5.1.2 Atmos: Denon AVR-S920W | Pioneer A. Jones SP-BS22-LR/SP-C22/SP-T22A-LR | Polk OWM3 | Emotiva BasX S8
Vision | 4K OLED: LG C8 | LG UBK90 | Sony UBP-X800 | Apple TV 4K | Microsoft XB1S | FiOS Moto
cgpublic is offline
post #7581 of 25666 Old 11-01-2017, 02:04 PM
cgpublic's Avatar
Quoted: 220 Post(s)
Liked: 178
Now & Later
This is the cable I'm using hand-in-hand with the Vizio-Supplied HDMI cable, and it works as advertised, 4K Dolby Vision @60hz with chroma as 4:2:2; chroma also at 4:4:4. It's $30, but many have had success with cheaper cables from Amazon and Monoprice. No word if the HDMI port in the ATV4K is upgradable, so just be prepared to upgrade in the near future for HDMI 2.1.
cgpublic is offline
post #7582 of 25666 Old 11-01-2017, 02:06 PM
aggrobot's Avatar
Quoted: 24 Post(s)
As mentioned, premium 18gbps cables should be fine. I have both the belkin cable you've linked, as well as some bluejeans HDMI premium cables, and with my vizio e65 e1 I still cant get 4:2:2 chroma for the apple tv regardless of which cable I'm using. 4:2:0 is I guess what I get.
galonzo likes this.
aggrobot is offline
post #7583 of 25666 Old 11-01-2017, 02:08 PM
Quoted: 40 Post(s)
Liked: 66
I have a Yamaha A760, using 5.1.2, which is still waiting for the DV update. I'm running the ATV straight to the TV for now (so I can at least experience DV), and optical out to the receiver from the tv. I do use Dolby Surround or Neural:X sometimes depending on the source. Just hoping that once the receiver gets the Dolby update, running everything through it will go smooth.
post #7584 of 25666 Old 11-01-2017, 02:11 PM
cgpublic's Avatar
Quoted: 220 Post(s)
Liked: 178
Good To Know
Originally Posted by nathan_h View Post
Vudu has had DV content for two years & things like the Chromecast work with just about any display.
Yes, I've had Vudu via Vizio with DV, but for some reason my Dad had issues with the CCU and Vudu app w/o DV about this time last year, something about a firmware update, and he couldn't update it, whatever, he returned it back then, made do with his TV apps and now has an ATV4K.
cgpublic is offline
post #7585 of 25666 Old 11-01-2017, 02:16 PM
JMGNYC's Avatar
Quoted: 160 Post(s)
Liked: 126
Does anyone know on an LG 2016 OLED how to display what refresh rate it is currently in and/or bit depth?
JMGNYC is offline
post #7586 of 25666 Old 11-01-2017, 02:18 PM
cgpublic's Avatar
Quoted: 220 Post(s)
Liked: 178
Smooth
The Denon in my sig was updated a few months ago and it's pretty smooth, no issues with DV, and now that the Vizio has been updated for HLG, good to go there as well via pass-thru. I switch between both depending on the title, and have to say, if you have an Atmos setup, it's not Atmos, but it's not too shabby.
cgpublic is offline
post #7587 of 25666 Old 11-01-2017, 02:20 PM
tylerk86's Avatar
Quoted: 257 Post(s)
Liked: 43
You have the option for 4K Dolby Vision 60Hz 4:4:4?
LG OLED55C7P
Apple TV 4K
Nintendo Switch
tylerk86 is offline
post #7588 of 25666 Old 11-01-2017, 02:22 PM
cgpublic's Avatar
Quoted: 220 Post(s)
Liked: 178
Via AVR
Not sure about LG, but your AVR should provide info re: HDMI signal info.
cgpublic is offline
post #7589 of 25666 Old 11-01-2017, 02:22 PM
tylerk86's Avatar
Quoted: 257 Post(s)
Liked: 43
Where have you found plain 4K SDR content in the Apple TV? I just set my baseline to 1080p, and realized I own no movies in 4K that aren’t HDR. So I checked Netflix, and when I have my ATV set to 1080p, all their content is labeled as HD only, including the HDR stuff.
LG OLED55C7P
Apple TV 4K
Nintendo Switch
tylerk86 is offline
post #7590 of 25666 Old 11-01-2017, 02:24 PM
Soundizer17's Avatar
Quoted: 747 Post(s)
Liked: 163
Perhaps this issue has been noted on this thread.
When Netflix Mindhunter end credits appear the screen goes dark grey and then black and so on.
Anyone seen this?
Soundizer17 is offline
apple 4k tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , Samsung
