Apple TV owners' thread. FAQ in first post - Page 295 - AVS Forum | Home Theater Discussions And Reviews
 29120Likes
post #8821 of 25584 Old 12-06-2017, 05:20 AM
steelman1991's Avatar
Quoted: 464 Post(s)
Liked: 230
Anybody having problems getting HDR? from the Amazon Prime app?
steelman1991 is offline
post #8822 of 25584 Old 12-06-2017, 05:23 AM
Goldenbear24's Avatar
Quoted: 22 Post(s)
Liked: 5
not getting Dolby Digital plus though! only stereo. Netflix works fine so it is the AP App
galonzo likes this.
Goldenbear24 is offline
post #8823 of 25584 Old 12-06-2017, 05:26 AM
kbmb's Avatar
Quoted: 984 Post(s)
Liked: 777
Yeah same here. PCM 2.0 only.
galonzo likes this.
kbmb is offline
post #8824 of 25584 Old 12-06-2017, 05:26 AM
Liked: 0
I just received my LG OLED C7 55". Total novice here. I also have bought an Apple TV 4K.
What are the best settings to use under "Video"?
Should I enable Dolby Vision? And under Match Content should both DR and FR be activated?
Dahousecat is offline
post #8825 of 25584 Old 12-06-2017, 05:28 AM
Quoted: 464 Post(s)
Liked: 230
Yip - same. You had a chance to see if HDR working
post #8826 of 25584 Old 12-06-2017, 05:29 AM
frankhj's Avatar
Quoted: 76 Post(s)
Liked: 84
Yup, same here. Tried several with 5.1 in description. All 2.1.
galonzo likes this.
frankhj is offline
post #8827 of 25584 Old 12-06-2017, 05:32 AM
Quoted: 22 Post(s)
Liked: 5
HDR works
galonzo likes this.
post #8828 of 25584 Old 12-06-2017, 05:32 AM
kbmb's Avatar
Quoted: 984 Post(s)
Liked: 777
Yes I checked Grand Tour and Sneaky Pete. Both activated HDR on my Sony. I do have 11.2 installed with Match Dynamic Range set to on.
galonzo likes this.
kbmb is offline
post #8829 of 25584 Old 12-06-2017, 05:34 AM
LDBetaGuy's Avatar
Quoted: 326 Post(s)
Liked: 199
HDR is working for me. HDR on Amazon, though, always makes the video look too dark, almost as if the contrast has been turned down just a little too much;black is crushed just a bit. I see this not only on the ATV 4K, but also on Roku. If I switch to 4K SDR, the black levels look normal. My TV is a Sony 65” X900e. Does anyone else see this or is it just me?
LDBetaGuy is offline
post #8830 of 25584 Old 12-06-2017, 05:34 AM
Quoted: 464 Post(s)
Liked: 230
Ah crap!!!!
Your settings match mine - need to troubleshoot some more
post #8831 of 25584 Old 12-06-2017, 05:36 AM
kbmb's Avatar
Quoted: 984 Post(s)
Liked: 777
Yeah I see similar with Amazon on my X930E. Look at something like Grand Tour, it is shot more in the daylight. Something like Sneaky Pete is really dark but I think it was partially shot that way.
kbmb is offline
post #8832 of 25584 Old 12-06-2017, 05:56 AM
PTV Programmer's Avatar
Quoted: 508 Post(s)
Liked: 144
Nope, working like a charm.
galonzo likes this.
PTV Programmer is offline
post #8833 of 25584 Old 12-06-2017, 06:33 AM
Quoted: 79 Post(s)
I had a 75" X900e briefly and noticed this too. I returned it for an LG OLED which looks punchy as hell. To get brighter colors on the Sony I had to turn on one of the Dynamic Color settings to high (forget what it was called). That made it much brighter and colors popped, but unfortunately, it made SDR content look like hell. If I remember correctly, the Sony locks the auto brightness to "on" in HDR mode. I think it is too aggressive with it's dimming. I hated that.
bigjeep127 is offline
post #8834 of 25584 Old 12-06-2017, 06:43 AM
umenon's Avatar
Quoted: 987 Post(s)
Liked: 351
HDR works
I played Z and it triggered HDR and then tried Bosch and got a “Cannot Play” error. Came back to Z and got the same error. Confused? Non-HDR contents seems to play fine though.
umenon is offline
post #8835 of 25584 Old 12-06-2017, 07:16 AM
Quoted: 32 Post(s)
Having problems with AV sync with the prime video app. Video trailing audio. No problems with other apps like Netflix.
utility73 is offline
post #8836 of 25584 Old 12-06-2017, 07:52 AM
Quoted: 65 Post(s)
Liked: 179
There is no one right answer to your questions. It really depends on whether you want the ATV to convert everything to the same format, or pass through each piece of content in its original format. I have a 65C7 and go with DV enabled, and both match settings set to On. Some on this forum don’t want to drive their sets in DV mode unless the original content is in DV, to avoid stressing their hardware. With an LG this shouldn’t be an issue, so you can just try it both ways and see what you like.
LG OLED 65C7P <- Oppo UDP-203 -> Denon AVR-X4300H; Dish Hopper; Apple TV 4K; Paradigm speakers
GordonBlu is offline
post #8837 of 25584 Old 12-06-2017, 08:00 AM
guitarguy316's Avatar
Quoted: 2101 Post(s)
Liked: 791
I have a 4K version that I can get the Amazon app on the app store. Does anyone know if they are pushing this to Apple TV MD199LL/A (3rd generation) that don't have app stores?
guitarguy316 is offline
post #8838 of 25584 Old 12-06-2017, 08:12 AM
JMGNYC's Avatar
Quoted: 160 Post(s)
Liked: 126
Amazon seems to be working fine for me and it's nice to see the integration with the TV app. HDR is quite good and working.
However, even though Amazon is saying 5.1 on their display it is only giving stereo no matter the setting on ATV.
galonzo likes this.
JMGNYC is offline
post #8839 of 25584 Old 12-06-2017, 08:23 AM
Liked: 0
Why Apple TV 4K Amazon vs LG Amazon app?
A newbie here. Just wondering what advantage, if any, to using Apple TV 4k to view Amazon Prime movies vs using the app on LG's webOS?
Richinwalla is offline
post #8840 of 25584 Old 12-06-2017, 08:29 AM
ataneruo's Avatar
Quoted: 161 Post(s)
Liked: 159
To route through your AVR for your surround sound speaker system without using TV speakers or ARC, if that is your setup (like it is mine).
galonzo likes this.
ataneruo is offline
post #8841 of 25584 Old 12-06-2017, 08:30 AM
Quoted: 79 Post(s)
Mainly for the convenience of not switching inputs. The AppleTV now has pretty much all major apps except for Youtube TV. Also on the AppleTV it appears to integrate Amazon into the TV app which shows you the next show playing on the home screen (from any app that supports this).
It's also very possible that the video quality on the AppleTV is superior as the AppleTV wins in this category often. The Apple TV 4K also always wins in speed (my experience).
I have an LG B7 OLED and the built-in Amazon app looks and works better than on the new and old 4K Fire TV box. Tonight I will be able to see if it looks the same or better on the AppleTV.
The only thing AppleTV lags in now is audio format/quality as there is no Atmos and still some dynamic range issues, though it's not terrible by any means.
ataneruo likes this.
post #8842 of 25584 Old 12-06-2017, 08:31 AM
Quoted: 79 Post(s)
The folks that aren't getting surround sound out of the Amazon app... Are you using HDMI ARC or are you going straight to a receiver?
post #8843 of 25584 Old 12-06-2017, 08:32 AM
Liked: 0
I have my Apple TV connected to LG and the receiver connected to the LG via ARC HDMI.
post #8844 of 25584 Old 12-06-2017, 09:07 AM
JMGNYC's Avatar
Quoted: 160 Post(s)
Liked: 126
Straight to an AVR in my case.
galonzo likes this.
JMGNYC is offline
post #8845 of 25584 Old 12-06-2017, 09:15 AM
adam355's Avatar
Quoted: 202 Post(s)
Liked: 174
Its actually worse on the Apple TV since you cant make purchases, subscriptions, etc so content is more limited. You only get access to prime content with the Apple TV app.
They are probably better off using prime video with the WebOS , Shield TV or Roku depending on their needs.
galonzo likes this.
adam355 is offline
post #8846 of 25584 Old 12-06-2017, 09:25 AM
JMGNYC's Avatar
Quoted: 160 Post(s)
Liked: 126
This is a valid point. If you want/need to make purchases through your TV the ATV is not ideal. You need to purchase/rent on a PC or through a browser before it'll show up in the ATC app.
Personally, I don't really buy/rent through Amazon so my use case is Prime Video only.
galonzo and ataneruo like this.
JMGNYC is offline
post #8847 of 25584 Old 12-06-2017, 09:38 AM
ROMIL's Avatar
Quoted: 512 Post(s)
Liked: 238
How do we report the stereo-only audio issue with the Amazon app? To Amazon or Apple or both?
wasima likes this.
ROMIL is offline
post #8848 of 25584 Old 12-06-2017, 09:40 AM
roland6465's Avatar
Quoted: 416 Post(s)
Liked: 412
Nice to come over to see that we got AP before the end of the year. I'm about to download to my ATV4K. Sucks that 5.1 isn't enabled yet, but it would seem to be a pretty easy fix on Amazon's end.
roland6465 is offline
post #8849 of 25584 Old 12-06-2017, 10:06 AM
JMGNYC's Avatar
Quoted: 160 Post(s)
Liked: 126
I chatted with Amazon support and was told they are aware of the issue and are working on the fix. I don't think Apple has anything to do with this one so no use contacting them.
A.Bell, galonzo, Bullwyf and 3 others like this.
JMGNYC is offline
post #8850 of 25584 Old 12-06-2017, 10:25 AM
boltsfan21's Avatar
Quoted: 169 Post(s)
Liked: 131
Amazon. Apple didn't make the app.
boltsfan21 is offline
apple 4k tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , Samsung
