Apple TV owners' thread. FAQ in first post - Page 426 - AVS Forum | Home Theater Discussions And Reviews
 29132Likes
post #12751 of 25612 Old 02-27-2018, 04:50 AM
Quoted: 62 Post(s)
Anyone experience ATK 4k remote lag?
I'm experiencing some random lag when using the touchpad, sometimes so bad I'm forced to reboot the unit. I have mine mounted behind the TV, and I'm wondering if I have a faulty touchpad (I've tried cleaning) or if the mounting location is having an affect.
Also, my TV goes into a normal screen saver from the main ATV Home page....however, I've noticed that sometimes during the fly-over screensavers, sometimes the TV will randomly switch on to the Netflix home page when the remote is set aside on a table. Could there be a link to the above issue? Anyone experience this?
CLE_802 is offline
post #12752 of 25612 Old 02-27-2018, 05:58 AM - Thread Starter
bodosom's Avatar
Quoted: 2098 Post(s)
Liked: 1634
Originally Posted by Keenan View Post
I realize that, but I still think it's a bit ironic that the files ChicagoChris wants to access are being serviced by the same cloud provider.
"such as S3 and Google" S3 is Amazon. The point was that the photos might be at Google or Amazon or even Apple.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X3500/LG C8
bodosom is offline
post #12753 of 25612 Old 02-27-2018, 08:00 AM
mwiebelhaus's Avatar
I have looked everywhere in the settings. How do you access quickstart to turn it on or off?
mwiebelhaus is online now
post #12754 of 25612 Old 02-27-2018, 08:14 AM
jong1's Avatar
Quoted: 527 Post(s)
Liked: 522
It's under "Apps / iTunes Films and TV programmes"
brotony likes this.
LG OLED65E6V, Yamaha RX-A3060 AVR, Oppo UDP-203 UHD Blu-ray player, Apple TV 4K, Sky Q 2TB, Chromecast Ultra
Home-built Ivy Bridge i5-3570K HTPC, 8GB RAM and Nvidia GTX1050 GPU with Plex and Jriver Media Centre,
Ruipro 15M Fiber HDMI cable, B&W FPM speakers, Logitech Harmony Ultimate intelligent remote.
jong1 is online now
post #12755 of 25612 Old 02-27-2018, 08:25 AM
reim0039's Avatar
MX-450 Issue
I have a URC MX-450 remote and having issues with the pre-loaded code sets working with the Apple TV 4K. Basically none of the code sets allow the Pause/Play button to work on my URC remote. Any thoughts? I also posted to the MX-450 thread. New to the forums so please redirect me if I'm in the wrong spot.
reim0039 is offline
post #12756 of 25612 Old 02-27-2018, 08:31 AM - Thread Starter
bodosom's Avatar
Liked: 1634
Please review the first post in this thread.
bodosom is offline
post #12757 of 25612 Old 02-27-2018, 08:54 AM
brotony's Avatar
Quoted: 432 Post(s)
Liked: 354
I've noticed the Netflix app will change screensaver behavior. Pause on a show and screensaver may be dismissed when Netflix reverts your view from show to info view with option to start from beginning or resume. It may happen again progressively with more steps but again when Netflix thinks you're not active. I've even seen promos run when screensaver gets dismissed. The screensaver may go active again but Netflix tends to want to do their own thing; more so than the other apps I use. Its annoying; I'd prefer screensaver to dismiss only on my input, not Netflix's bidding.
I don't see remote lag unless it's what I describe below.
About your remote lag, is it disconnecting? A pop-up may appear showing the remote is connecting when you use it; remote input may be ignored until connected again. I use a third party Logitech remote so I see this reconnecting remote pop-up often. In 11.3 beta, seems the remote reconnects quicker than 11.2.5 did; maybe this is improving?
Did you check your remote charge capacity? Maybe it needs recharging?
Location just might be a factor but I wouldn't think so; you could try removing the ATV from the mount temporarily to see how it behaves. I'd think hiding it behind the TV is doable but maybe your location isn't ideal; I guess it's possible you've located it too close to a component in TV that's interfering?
Sent from my PH-1 using Tapatalk
brotony is offline
post #12758 of 25612 Old 02-27-2018, 08:54 AM
post #12759 of 25612 Old 02-27-2018, 09:06 AM
Quoted: 89 Post(s)
Liked: 8
I experience the lag as well. Sometimes I will get no response as I try to move around through the different apps and then it will all of a sudden catch up and start flying around. Ugh. It can be incredibly frustrating. I also do get the periodic disconnected/connected pop-up as well. My ATV4K is sitting by itself under the TV and has no obstructions so I don't know what could be causing interference.
Dan
Sony 65A1E - Apple TV 4K - Sony STR-ZA2100ES
dannyk100 is offline
post #12760 of 25612 Old 02-27-2018, 09:20 AM
psuKinger's Avatar
Quoted: 1594 Post(s)
Liked: 664
Anybody on here take advantage of the DirectTV Now deal (ATV4k + 3 months)? Any "catches" that I'm not seeing/understanding?
I don't really *need* either DirectTV Now or AppleTV. But I'd been toying with the idea of "trying" both, independently, just to "see what else was out there", and this seems like a great opportunity to do both at a great price... as long as their isn't a catch that I'm just not seeing...
Living Room: Sony x940E; Denon x4400h; Ascend Sierra RAAL Tower L/R's and 2EX center, Ascend HTM-200SE Rears, Rythmik F25 sub. NVidia Shield, ATV4k, OPPO UDP-203, CCA.
Basement: Samsung PN58B650 LN-T4065F (x2); Onkyo TX-NR809; Polk Monitor 70 Series II L/R's, SVS PB-1000 sub. NVidia Shield (x2), Windows Desktop, CCA.
psuKinger is offline
post #12761 of 25612 Old 02-27-2018, 09:24 AM - Thread Starter
bodosom's Avatar
Liked: 1634
Originally Posted by psuKinger View Post
Any "catches"
Apparently not. Search the thread for catch to see the previous discussion.
bodosom is offline
post #12762 of 25612 Old 02-27-2018, 09:28 AM - Thread Starter
bodosom's Avatar
Liked: 1634
Please note that as of 25-May-2017 the ATV1 (1st gen or 1,1) [will no longer be able to use the iTunes store].
bodosom is offline
post #12763 of 25612 Old 02-27-2018, 09:31 AM
Quoted: 971 Post(s)
Liked: 670
My Shield and ATV4K has intermittent remote lag, the Shiled is worse. None of my Rokus ever had lag.
LG 65C7P (Also XBR65X900E and XBR55X900E)
Denon x7200WA
Oppo BD-203
Klipsch RP-280F / RC-62ii / RP-140SA / RS-35 / RS-25
Dual PSA V1800s
kluken is offline
post #12764 of 25612 Old 02-27-2018, 09:33 AM
lujan's Avatar
Quoted: 4604 Post(s)
Liked: 2675
No catch, I cancelled as soon as I got my Apple TV 4k. There is no 4k content on DirecTV Now and there is no skipping commercials so I would never use it.
psuKinger likes this.
lujan
561 Ultra HD
721 HD
4 SD
lujan is online now
post #12765 of 25612 Old 02-27-2018, 09:34 AM
Keenan's Avatar
Quoted: 3946 Post(s)
Liked: 3652
No catch, you pay upfront for three months of the DirecTV Now service and get a "free" ATV4K. No taxes, at least in California, just a $7 service charge. It's a great way to get a 32GB ATV4K for a ridiculously low price. I got mine when it was a 4-month deal and have never even used the DirecTV service, I did the deal for the device.
Keenan is online now
post #12766 of 25612 Old 02-27-2018, 09:45 AM
Quoted: 1724 Post(s)
Liked: 1016
I jumped into it too and am very happy. The DTVN is outstanding quality with the only drawback being no DVR service but there are to things to mitigate that. One is your Directv Now account gives you access to the standalone apps like NBC, Bravo, ABC, etc. which do have full seasons of VOD. The second being that there is a DTVN "beta" program you can sign up for if you wish that includes DVR. One thing I love about it so far is that a lot of programming is 1080p both in the native app and many of the standalone apps. Most of the other services are 740p. The streaming device itself if pretty nice too...fast and reliable.
Also there's a side benefit for you and me. You can sideload the Shield version from apkmirror. The version you need for the Shield is DIRECTV NOW 1.0.22.4821.
Mike
Sony XBR-65X930E | ATV4K-64GB & 32GB 5th Gen | Nvidia Shield TV Pro 2017 | Logitech Harmony Elite
m_snow is online now
post #12767 of 25612 Old 02-27-2018, 09:48 AM
Daryl L's Avatar
Quoted: 654 Post(s)
Liked: 450
I looked and could not discover any catch so I jumped on the deal just over a week ago. As soon as it arrives I will cancel my subscription. I have the Direct Now app on my Roku but I'm not going to use it. I only used the offer to get the Apple TV.
Sony XBR-55A9F OLED
Samsung SMT-H3272 HDC DVR Cable Box / Panasonic DP-UB820 4K BD Player
Roku Premium+ 4k / AppleTV 4K 4th Gen
Denon AVR-X4500H AV Receiver / Klipsch 5.1.2 Speakers
Daryl L is offline
post #12768 of 25612 Old 02-27-2018, 10:04 AM
leonmckee's Avatar
Quoted: 505 Post(s)
Liked: 582
I've had 2 to 3 units of every single ATV ever produced in my household. The only time I've ever had ongoing remote issues are with beta's of the tvOS. What version of the tvOS are you running?
Edit: I'm referring to IR remote control. Please clarify if you're referring to IR or Bluetooth control.
Leon McKee
LR: XBR-65X930E | ATV4K-64GB 5th Gen | UBP-X700 | URC MX-890 | SoundTouch 300 | Luminoodle Bias Lighting
MBR: KDL-65W850A | ATV4K-64GB 5th Gen | URC MX-890 | Luminoodle Bias Lighting
4K HDR/DV Chains: ATV4K/UBP-X700>3ft Monoprice Certified Premium Cables>65X930E
Computing, Truck & Communication Devices: Proud Apple Customer Since 1979
leonmckee is offline
post #12769 of 25612 Old 02-27-2018, 10:11 AM
leonmckee's Avatar
Quoted: 505 Post(s)
Liked: 582
Touchpad on your ATV4K remote or when using the app?
Bluetooth and not IR or wi-fi?
What version of tvOS are you running?
Leon McKee
Tesla1856 likes this.
post #12770 of 25612 Old 02-27-2018, 10:22 AM
psuKinger's Avatar
Liked: 664
Awesome, thanks for the input guys.
I need to confirm for myself RTings claim that my TV (Sony 940E) can pass Dolby Digital 5.1 and DTS 5.1 over Optical (I won't bore you guys with the SHINFO why), but assuming it can, one or two more questions:
1) Does setup require an iOS device? My iOS devices are pretty old/outdated at this point. If I can't do it with my Win10 Laptop or Android Phone/Tablet, I'm concerned my iPad (probably 6-7 years old at this point) my not be up to the task...
2) anyone on here controlling their ATV 4K with a Logitech Harmony, 650 or other?
I'll search back through the thread and see what others are saying about the Logitech, but if anyone can weigh in specifically on the setup/config without a current iOS device, that'd be really helpful.
post #12771 of 25612 Old 02-27-2018, 10:57 AM
Ph8te's Avatar
Quoted: 6526 Post(s)
Liked: 6240
1) just use the included remote
2) yes, many
Ph8te is offline
post #12772 of 25612 Old 02-27-2018, 11:13 AM
bucknuts07's Avatar
Quoted: 177 Post(s)
Liked: 84
Sure wish apple would get in gear, and roll out support for Atmos. Hard to believe that were coming up on March, and still stuck with pcm, and 5.1 surround. I would have little need for the physical disc, if movies were putting out their correct sound track. Anyone know when this is coming ?
Xbox Live- bucknuts07
PSN-bucknuts07
bucknuts07 is offline
post #12773 of 25612 Old 02-27-2018, 11:19 AM - Thread Starter
bodosom's Avatar
Liked: 1634
You should assume it's not coming. If it happens to be made available on this (6,2) hardware then you'll be pleasantly surprised.
nathan_h and dwaleke like this.
bodosom is offline
post #12774 of 25612 Old 02-27-2018, 11:20 AM
chunon's Avatar
Quoted: 3837 Post(s)
Liked: 3775
It’s only a rumor as far as I know , no official comment from Apple on a timeline , in other words don’t hold your breath .
LG 77C8
LG 55B7A
DirectTV/ ATV4k/Panasonic UB820/Sony Z9F Soundbar
Calman Enthusiast, Lightspace, C6 HDR 2000 I1Pro2
chunon is online now
post #12775 of 25612 Old 02-27-2018, 11:24 AM
Charles R's Avatar
Liked: 820
If you are waiting for bitstreaming HD audio... I think you'll be waiting forever. I just don't see it happening based on their closed ecosystem and target market. They have virtually zero interest in serving local media. If they did it pretty well brands them as endorsing "illegal" activities, no? Why else would you need it... and it opens the door to being "branded" much like Kodi regardless of the actual facts. Now support for DD+ Atmos is another story...
125" Projection | 5.2.4 Audio | Shield TV | LibreELEC/ODROID-C2 Kodi Media Client | Ubuntu/ODROID-XU4 NAS/Server | 65" LG OLED TV | TiVo | Shield TV |
| Water cooled Threadripper & Radeon VII, NVMe PC - 43" 4K IPS Panel |
Charles R is offline
post #12776 of 25612 Old 02-27-2018, 01:20 PM
bucknuts07's Avatar
Quoted: 177 Post(s)
Liked: 84
Apple has given statements to tech sites that Atmos is coming. Just thought they couldn't get it out at launch , but would release after.
https://www.cultofmac.com/504227/app...g-apple-tv-4k/
https://www.theverge.com/circuitbrea...support-coming
PSN-bucknuts07
post #12777 of 25612 Old 02-27-2018, 01:21 PM
atbear's Avatar
Quoted: 286 Post(s)
Liked: 141
Quick question to better my understanding of all of the Match Dynamic Range discussions on the last few pages-
I understand what Match Dynamic Range does and how it's used. I also understand that each source of content / app must have the appropriate flag to allow the Match Dynamic Range feature to work (for example, if your default is 4K HDR and your source is SDR it'll revert to SDR). I've also read that the recommendation is to keep the default setting to 4K SDR with Match Dynamic Range on so that you'll be in the standard SDR for most content and then flip to HDR when the source calls for it.
My question is, if the source content / app does not have the appropriate flag to allow Match Dynamic Range to work, will you be stuck in SDR even for HDR content? I know that if you are in HDR mode with Match Dynamic Range on but the flag is missing that you'll stay in "fake" HDR mode even if the content is SDR. The reason I ask is that I'd rather err on the side of HDR than SDR if that flag is missing from a content source / app... not to mention I'd prefer my screensavers to be HDR.
Thanks for any clarification.
Sony XBR-65X930E | NVIDIA SHIELD TV | Apple TV 4K | Samsung BD-P1600
Yamaha TSR-7810 | Energy C-100 / Energy C-C100 / Energy S10.3 / Polk RC60i
Logitech Harmony 950 / Smart Control w/ Harmony Hub
atbear is offline
post #12778 of 25612 Old 02-27-2018, 01:28 PM
rsonnens's Avatar
Quoted: 679 Post(s)
Liked: 514
Just because it is “on the roadmap” does not mean that they will every ship it. No one should assume it is coming. Great if they do it but never buy on the hope it may happen.
Greg TB and Uppsalaing like this.
rsonnens is online now
post #12779 of 25612 Old 02-27-2018, 02:28 PM
met_fan's Avatar
Quoted: 120 Post(s)
Liked: 72
I see this on mine
met_fan is offline
post #12780 of 25612 Old 02-27-2018, 02:38 PM
Ph8te's Avatar
Liked: 6240
It would be the same as no flag with SDR when I’m 4K HDR mode. The problem is that if there is no flag for HDR content, then the app doesn’t support it, thus you’d be getting the same “fake” HDR setting as before. Thus far there are no apps that don’t flag for any HDR flavor, there are quite a few that don’t flag themselves as SDR however.
Ph8te is offline
apple 4k tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , Samsung
