Apple TV owners' thread. FAQ in first post - Page 484 - AVS Forum | Home Theater Discussions And Reviews
 29159Likes
post #14491 of 25652 Old 04-16-2018, 04:47 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6055
Just checked mine, I have been out of pocket. Lost in Space fired up, but then two different Punishers crashed. It is funny, the DV logo is popping up on the error screen LOL. Nothing more hi-tech than a error screen in DV.
galonzo, Maverickster2 and ROMIL like this.
XBR65A9G / XBR65A8F / 55R615
DP-UB420 / ATV4K (3) / PS Vue
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #14492 of 25652 Old 04-16-2018, 05:00 PM - Thread Starter
bodosom's Avatar
Quoted: 2102 Post(s)
Liked: 1637
My ATVKs talk to Netflix via IPv6, my working LG app and CCU use IPv4. I suppose I should check that too.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X3500/LG C8
bodosom is offline
post #14493 of 25652 Old 04-16-2018, 05:08 PM
Waboman's Avatar
Quoted: 7115 Post(s)
Liked: 16089
I've yet to experience this anomaly. What programs is it happening most often on?
Waboman is offline
post #14494 of 25652 Old 04-16-2018, 05:11 PM
ROMIL's Avatar
Quoted: 512 Post(s)
Liked: 238
With your ATV 4K settings set to 4K SDR and match frame rate and range turned on, it should happen if you try to watch a DV show on Netflix, such as Altered Carbon.
ROMIL is offline
post #14495 of 25652 Old 04-16-2018, 05:22 PM
Quoted: 380 Post(s)
Liked: 652
Here's hoping it gets resolved soon.
It really looks like the problem is with the new ATV Netflix app. No problems in Netflix DV on my Sony TV. Netflix runs fine on my Shield (but of course, no DV there). I don't see how it can be a network/ISP issue.
You have to be out of your mind to try to call tech support to report this issue. You'll spend 20 minutes going through their scripted trouble shooting which of course will do no good. Tried to find an email address for Netflix but couldn't.
I refuse to set my default ATV output to HDR. I find HDR for a non HDR sourced source is hideous.
Assuming the ATV Netflix app is buggy, this will take a very long time for Netflix to acknowledge the problem, find it, fix it, test it (certainly as well as they tested the current app) and then submit it to Apple.
Sony XBR-65Z9D
Oppo UDP-203 4K BD Player
Panasonic DMP-UB900 4K BD Player
Denon AVR-X6400H
Larry Little is offline
post #14496 of 25652 Old 04-16-2018, 05:39 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6055
Yup.
post #14497 of 25652 Old 04-16-2018, 05:40 PM
bguzman's Avatar
Quoted: 145 Post(s)
Liked: 865
Sup Wabs,
I haven’t seen this phenomenon either. I have the 4KSDR with match frame/range settings as well. Must have checked Altered Carbon a dozen times last night. I guess us Vinkings fans can win one once in a while.
galonzo likes this.
HT TCL 55P605, Mitsubishi HC6500, Pioneer UDP LX500, Panasonic LX1000, Firestick 4K, ATV4K, Onkyo TX-NR787, DefTech, Klipsch, Martin Logan, SVS @ 5.2.4 Atmos
Stereo Sansui SR-4050, Dual 1219, Pioneer UDP LX500, Emotiva PT-100, Be One Audio MA100, Polk Monitor 10, SVS SB1000
bguzman is offline
post #14498 of 25652 Old 04-16-2018, 05:50 PM
met_fan's Avatar
Quoted: 120 Post(s)
Liked: 72
Just experienced this with Altered Carbon...switched to the Netflix app on my C7. It’s always something...
met_fan is offline
post #14499 of 25652 Old 04-16-2018, 05:52 PM - Thread Starter
bodosom's Avatar
Liked: 1637
You can leave Match on. Ah, you probably meant non-Match apps. Nevermind.
bodosom is offline
post #14500 of 25652 Old 04-16-2018, 05:56 PM
HD-Master's Avatar
Quoted: 498 Post(s)
Liked: 535
Mine works perfectly after changing the DNS on my router and blocking Google DNS.
LG OLED65C7P - Professionally Calibrated l Apple TV 4K l Microsoft Xbox One S l Sony STR-ZA1100ES l Polk Audio CS2 Series II Center Channel l Polk Audio Monitor 60 Series II Floorstanding L/R l Polk Audio Monitor 45B Rear Surround l Dual BIC V1220 Subwoofers
HD-Master is offline
post #14501 of 25652 Old 04-16-2018, 06:52 PM - Thread Starter
bodosom's Avatar
Liked: 1637
That didn't help. I'm still talking to the same NYC nodes using IPv6 or IPv4.
bodosom is offline
post #14502 of 25652 Old 04-16-2018, 07:26 PM
helvetica bold's Avatar
Quoted: 1737 Post(s)
Liked: 1098
Wait what happened overnight with Apple TV 4K and Dolby Vision. It was working perfectly on my TCL P 605 but when I tried to play Lost in Space its like a purple negative image? My internal Roku app has no issues with DV playback.
UPDATE: Switched from 4K SDR to Dolby Vision then back to 4K SDR and its working fine now.
helvetica bold is offline
post #14503 of 25652 Old 04-17-2018, 12:40 AM
wxman's Avatar
Quoted: 5405 Post(s)
Liked: 3827
My ATV is set to 4K SDR with match frame and range both on, and all my DV titles in Netflix work just fine, including altered carbon. Hard wired to my router and using OpenDNS.
LG 65E6P OLED - LG 65EF9500 OLED - OPPO 203 - OPPO 103D
wxman is offline
post #14504 of 25652 Old 04-17-2018, 12:59 AM
brotony's Avatar
Quoted: 433 Post(s)
Liked: 356
I didn't change my DNS and yet Netflix HDR now works with SDR 4K and match settings enabled.
Still think there's something off with this Netflix app update because I had to go back into video settings, enable HDR and reselect SDR 4K to get HDR with matching to work; was only showing 4K ultra HD with no HDR or DV logo in pulldown. So, initially, Altered Carbon launched in SDR 4K with those settings; enabling HDR and toggling back to 4K SDR got match dynamic range working again. This wasn't a problem for a long time; I'd get dynamic range matching with the SDR 4K and match enabled without having to turn on HDR so frequently. Just did this yesterday while giving up on dynamic range match working on this app.
Sent from my PH-1 using Tapatalk
galonzo likes this.
brotony is offline
post #14505 of 25652 Old 04-17-2018, 04:20 AM
jong1's Avatar
Quoted: 527 Post(s)
Liked: 522
Altered Carbon and The Defenders working here now in 4K SDR with match ON.
I switched back to SDR from HDR. Because of what others have posted I tried several episodes. I then went out of Netflix and back in. Then I force closed Netflix and restarted it. Still shows that didn't work yesterday work now.
No guarantee it will stay that way and all very odd!
galonzo likes this.
LG OLED65E6V, Yamaha RX-A3060 AVR, Oppo UDP-203 UHD Blu-ray player, Apple TV 4K, Sky Q 2TB, Chromecast Ultra
Home-built Ivy Bridge i5-3570K HTPC, 8GB RAM and Nvidia GTX1050 GPU with Plex and Jriver Media Centre,
Ruipro 15M Fiber HDMI cable, B&W FPM speakers, Logitech Harmony Ultimate intelligent remote.
jong1 is offline
post #14506 of 25652 Old 04-17-2018, 05:13 AM
rocky1's Avatar
Quoted: 454 Post(s)
Liked: 125
Tried and working now here aswell.Tried AC .Hope it stays working..
Sony XBR65A1E,(Pioneer 500m relocated), AppleTv 4K,Marantz sr7012, System Audio Loudspeakers( sa1750 mains), ML Grotto.
Eastern Electric Minimax cd, Oppo UDP-203, Toshiba HD, Pro Ject 1expression Carbon TT.
rocky1 is offline
post #14507 of 25652 Old 04-17-2018, 08:25 AM
leonmckee's Avatar
Quoted: 505 Post(s)
Liked: 582
Netflix appears to be working on my end with 4K SDR/YCbCr/4:2:0 and Match Content ON/ON.
That's was no fun!
Leon McKee
galonzo likes this.
LR: XBR-65X930E | ATV4K-64GB 5th Gen | UBP-X700 | URC MX-890 | SoundTouch 300 | Luminoodle Bias Lighting
MBR: KDL-65W850A | ATV4K-64GB 5th Gen | URC MX-890 | Luminoodle Bias Lighting
4K HDR/DV Chains: ATV4K/UBP-X700>3ft Monoprice Certified Premium Cables>65X930E
Computing, Truck & Communication Devices: Proud Apple Customer Since 1979
leonmckee is offline
post #14508 of 25652 Old 04-17-2018, 09:31 AM
Waboman's Avatar
Liked: 16089
Originally Posted by bguzman View Post
Sup Wabs,
We'll take whatever win we can get. No matter how small.
galonzo likes this.
Waboman is offline
post #14509 of 25652 Old 04-17-2018, 01:21 PM
NashGuy's Avatar
Quoted: 990 Post(s)
Liked: 624
Can anyone with a DV-compatible TV (preferably an LG OLED) comment on any differences they see between a 4K DV signal (from Netflix or iTunes) from their ATV4K vs. an HDR10 version of that same title if they force the ATV4K to convert DV into HDR10?
The reason I ask is because my LG B6 cannot accept DV at 60Hz; DV stuff must be at 30Hz or less. In the past, I have kept Match Frame Rate turned on, which would cause most DV content to transmit at its native 24Hz rate, so my TV's 30Hz limit on DV hasn't been a problem. But the ATV4K does such a great job processing motion with 3:2 pulldown (i.e. internally converting 24Hz content into a 60Hz signal), that I am considering just leaving the ATV4K at 60Hz with Match Frame Rate turned off.
My when B6 gets a 24Hz/24fps signal (i.e. virtually all movies and scripted TV series), the judder looks pretty harsh to me unless I apply a bit of artificial smoothing with LG's TruMotion feature. But, so far, if I let the ATV4K convert the 24fps content into 60Hz, motion looks great to me with the TV's TruMotion processing turned completely off. I'm going to keep trying this for awhile on various content. But part of me kinda hates to forego watching stuff in DV if the highlights and shadow detail aren't as good when DV content is converted to HDR10.
NashGuy is offline
post #14510 of 25652 Old 04-17-2018, 01:59 PM
galonzo's Avatar
Quoted: 1389 Post(s)
Liked: 1797
Been away from this thread for a while, does what was found in the HDTVTest YT vid still apply here?
NashGuy and relaxnl like this.
Main: UN78HU9000/SEK-3500 | X4500H (Klipsch/HSU 5.1.4) | UDP-203 (fw 65-0131) | TiVo Bolt | Roku P+
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | AppleTV4K | TiVo Mini
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Scarface and other UHD Digital codes (and some HD codes)
galonzo is offline
post #14511 of 25652 Old 04-17-2018, 03:26 PM
NashGuy's Avatar
Quoted: 990 Post(s)
Liked: 624
Yes, thanks, that gets exactly to the question I was posing. I wonder if Apple has made any changes in the tvOS software since that video was made which improves the DV to HDR10 conversion process? Sounds like Apple isn't doing a very good job of the conversion given that they're arbitrarily assigning min and max CLL values of 400 and 1000 to all the artificial HDR10 profiles they create.
So, as I figured, leaving the output frame rate at a fixed 60Hz will be a trade-off for me between (possibly) overall better motion vs. sub-optimal HDR (mainly in the form of blown-out highlights).
galonzo likes this.
NashGuy is offline
post #14512 of 25652 Old 04-17-2018, 04:31 PM - Thread Starter
bodosom's Avatar
Liked: 1637
All good here too with no change in tvOS or the Netflix app. I imagine Netflix would prefer not to have back-end glitches like this so it would be nice if there was a channel to communicate these problems back to them.
jong1 likes this.
bodosom is offline
post #14513 of 25652 Old 04-17-2018, 05:23 PM
galonzo's Avatar
Liked: 1797
Exactly what I was wondering, and this is why I have been avoiding using the ATV4K for my streaming HDR content viewing (which is most HDR content on Netflix; my display doesn't support DV, only HDR-10).
galonzo is offline
post #14514 of 25652 Old 04-17-2018, 05:37 PM - Thread Starter
bodosom's Avatar
Liked: 1637
Maybe. While the DV to HDR10 conversion now produces different, per scene, meta-data you would still have to plug a current tone mapped image into Vincent's test and see how things look.
Maybe. Rumor has it that HDR10 is subject to display whims while DV is more likely to be "consistent". So the rendered HDR10 image may be largely independent of Apple or anyone's process.
This is actually fairly complicated and there are no simple answers. Your best bet is to attempt to assess some tone mapping in both cases while ignoring motion issues and see what you think you're giving up.
bodosom is offline
post #14515 of 25652 Old 04-17-2018, 06:27 PM
sddawson's Avatar
Quoted: 285 Post(s)
Liked: 49
1) Sure.
2) I don't believe there's a way to know this for sure across all apps. In all the examples I've looked at forcing SDR results in a 2K stream (or less as seen in the above 720p Netflix example) but apps can source what they want. I normally only check iTunes and Netflix since I no longer care what Amazon and Vudu are not doing.
[edit] the 720p may be because the stream didn't have time to get to 1080p.
This has pretty far-reaching implications if it applies to most movies. If you force SDR by setting the ATV default to, say, 4k SDR and turning off range matching, you will only ever get an HD stream. This might surprise a lot of people who have a 4k display that isn't HDR capable (admittedly, maybe mostly projector owners). They may think they're getting a 4k stream because the ATV is upscaling, but they're not. Have a got this right?
On the face of it, there may be some sense in this. Pretty much all 4k content on the streaming services seems to be HDR or DV. Apple would have to implement their own tone mapping to turn these streams into SDR, and maybe they just didn't want to do that, so they use the HD SDR stream instead. I'm guessing there aren't separate 4k SDR streams they could use. Do you think that's the case?
But is there any native non-HDR 4k content on the services? If so, would the HD stream be used for those too?
Interesting subject...
sddawson is offline
post #14516 of 25652 Old 04-17-2018, 07:55 PM - Thread Starter
bodosom's Avatar
Liked: 1637
Originally Posted by sddawson View Post
1) They may think they're getting a 4k stream because the ATV is upscaling, but they're not. Have a got this right?
2) I'm guessing there aren't separate 4k SDR streams they could use. Do you think that's the case?
3) But is there any native non-HDR 4k content on the services? If so, would the HD stream be used for those too?
1) Yes.
2) Not for Apple.
3) I'm sure Netflix has 4K/SDR streams for devices, like the 4K TiVo, that don't do HDR. At least the Netflix badging changes in response to device/display changes. YouTube has 4K/SDR streams. Amazon may.
Netflix is a special case. They've said their master 4K assets are DV but they generate an endless selection of video formats. It wouldn't surprise me if they do full-on post chain management and have static assets in various formats and do real-time scaling of those assets for bandwidth limits. It also wouldn't surprise if they have assets for every common circumstance. Netflix on the ATV4K probably does DV to HDR10 in the ATV because it's easy. They are reasonably open about this so it's probably all written down somewhere.
galonzo and Uppsalaing like this.
bodosom is offline
post #14517 of 25652 Old 04-18-2018, 02:00 AM
sddawson's Avatar
Quoted: 285 Post(s)
Liked: 49
1) Yes.
2) Not for Apple.
OK, thanks for all that. I think I've got all I need to make some informed decisions now!
galonzo likes this.
sddawson is offline
post #14518 of 25652 Old 04-18-2018, 05:45 AM
jong1's Avatar
Quoted: 527 Post(s)
Liked: 522
I wouldn't call this a rumour. DV, by design, attempts to give "the studio" control of how the image is presented (within the capabilities of the display). There is Dolby supplied software (and sometimes hardware) running on the display, which has been configured with an understanding of that display and attempts to recreate "the vision" with limited user modification (often there are options for a "bright mode" and a "dark mode" for example). Dolby have to make certain assumptions about how the display performs, based on averages, so a calibrator with precise information can tweak the image to get even closer to that vision, but the TV manufacturer is otherwise out of the loop.
HDR10 (including HDR10+) is philosophically the opposite. The source device provides metadata on either the entire movie or the scene (with HDR10+) and it is left to the TV manufacturer (and to a somewhat greater extent the user) to decide how to interpret this and bring out the best in their device.
Which approach people prefer is up to them. We haven't had a chance to see how HDR10+ works in practice on a wide variety of content yet, but mostly people seem to prefer DV over HDR10. How much of that is down to it's "dynamic" nature, which HDR10+ will "fix" and how much due to the end-to-end control, I guess we will find out in time.
K-Wood, galonzo, naustin and 1 others like this.
jong1 is offline
post #14519 of 25652 Old 04-18-2018, 08:40 AM - Thread Starter
bodosom's Avatar
Liked: 1637
I phrased it that way because Dolby* has explicitly said they give companies latitude in configuration. Dolby "suggests" they don't use that latitude but, according to Dolby, it's there. This belief is regularly used to explain why DV discs lock many of the OPPO image controls when it's more likely prohibited by authoring. BDA is to blame not Dolby.
*Interview with some Dolby VP. I don't have a link handy,
bodosom is offline
post #14520 of 25652 Old 04-18-2018, 08:47 AM - Thread Starter
bodosom's Avatar
Liked: 1637
In the case of my C7 I can change two lightness controls in DV mode. One is purported to break tone mapping and the other is purported to have a completely unexpected effect on DV. Presumably these are reasons why Dolby would prefer you not have these controls. By the way the currently unreleased in the US (i.e. beta) firmware for my display appears to minimize these controls, at least with some content from my ATV.
bodosom is offline
apple 4k tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , Samsung
