Apple TV owners' thread. FAQ in first post - Page 577 - AVS Forum | Home Theater Discussions And Reviews
 29110Likes
post #17281 of 25550 Old 08-12-2018, 09:11 AM
Quoted: 1715 Post(s)
Liked: 1009
Originally Posted by captainbrent View Post
Well yes, that text is a copy and paste from the Infuse forum sticky about the purchase options...sorry I didn't put it in between quotation marks but I thought it was a bit obvious.
On topic or off topic, Infuse is discussed often here and the three of you, that I quoted, were discussing the purchase options so I thought that I would shed some light on the difference between the two options and how to get lifetime upgrades, including the major updates. So yes, it does mention how to get a lifetime purchase option...download the free Infuse 5 and make an in-app purchase of the Pro version and the subscription is now lifetime.
It’s discussed here often because it’s an awesome product!
I’m not sure they call the lifetime version Pro though, I think it’s labeled just Infuse because there’s no sub but I’ll check later.
Mike
Sony XBR-65X930E | ATV4K-64GB & 32GB 5th Gen | Nvidia Shield TV Pro 2017 | Logitech Harmony Elite
m_snow is online now
post #17282 of 25550 Old 08-12-2018, 09:20 AM
captainbrent's Avatar
Quoted: 437 Post(s)
Liked: 501
Hi m_snow,
It certainly is an awesome product for our ATV's and James provides awesome support!
I can confirm that the in-app purchase of the Pro version, will result in lifetime upgrades, including major versions, so essentially the same subscription that you have.
m_snow likes this.
Marantz AV8802A | Wyred 4 Sound (500W X 3, 250W X 2) | Marantz MM7025 (140W X 2) | Oppo UDP-203 | Roon ROCK Music Server | ATV4K | Vero 4K+ | LG OLED 65E6P | MiniDSP DDRC-88A | Oppo PM1's | APC H-15 power conditioners (x2) | GoldenEar Triton 1's (FL & FR) | SuperCenter XL (C) | Aon 2's (SL & SR) | SuperSat 3's (FHL & FHR) | SVS PB13-Ultra | Unraid NAS 40TB
captainbrent is offline
post #17283 of 25550 Old 08-12-2018, 09:52 AM
lockdown571's Avatar
Quoted: 425 Post(s)
Liked: 315
Originally Posted by sjchmura View Post
But plex does too right?
I believe it downgrades TrueHD to EAC3 (not sure about DTS-MA). See here: https://forums.plex.tv/t/how-to-appl...layback/226811
lockdown571 is offline
post #17284 of 25550 Old 08-12-2018, 09:56 AM
Mr.G's Avatar
Quoted: 1325 Post(s)
Liked: 1702
Originally Posted by Matt Pasquinelli View Post
I have a sony VPL-VW365 projector that is only capable of 8bit HDR. Apple tv will not recognize the HDR signal and there is no way i can see to get it playing hdr. Anyone have any advice?
The Sony VW365 is similar to the Epson 5040 and 4000 projectors, you can't get HDR at 60Hz, it has to be output at 24p.
Here is a mention in the Owner's thread starting here:
https://www.avsforum.com/forum/24-di...l#post51501825
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #17285 of 25550 Old 08-12-2018, 10:16 AM
claw's Avatar
Quoted: 2315 Post(s)
Liked: 2170
Originally Posted by sbquart View Post
I'm trying to run the Apple TV through my oppo 203 so I can use the 21:9 feature on my scope screen. If I have it setup for Atmos I get no sound to my preamp. Does anyone know how to get the audio to function properly?
The Oppo HDMI input does not support Dolby MAT which is how the ATV4K is encoding Atmos. You would need to disable Atmos in the ATV4K in order to get any audio from titles that have Atmos.
galonzo likes this.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is online now
post #17286 of 25550 Old 08-12-2018, 12:51 PM
Soundizer17's Avatar
Quoted: 735 Post(s)
Liked: 163
Should audio be set to Dolby 5.1 or Best Quality - if APTV4K is connected directly to TV and TV HDMI ARC to Receiver?
Soundizer17 is offline
post #17287 of 25550 Old 08-12-2018, 12:58 PM
lujan's Avatar
Quoted: 4589 Post(s)
Liked: 2664
I'm guessing in your case it doesn't matter unless your TV supports 7.1?
lujan
561 Ultra HD
721 HD
4 SD
lujan is offline
post #17288 of 25550 Old 08-12-2018, 01:01 PM
Quoted: 735 Post(s)
Liked: 163
No TV can send thru LPCM 5.1/7.1. This is why it is so confusing.
post #17289 of 25550 Old 08-12-2018, 02:13 PM
MacinMan's Avatar
Quoted: 1054 Post(s)
Liked: 267
That's why the way Apple did the audio settings for the Apple TV really irritates me and makes me mad at times.
The Roku, which is a much cheaper device, that I also own along with the 4k Apple TV has an auto setting for audio, and it's compatible with sending audio through a TV out optical, or ARC, and the lossey codecs are passed without issues. In my case, if the TV can process Dolby Plus internally, is also a benefit because it converts the D+ signal coming from the roku to standard DD, and i get standard DD 5.1 from Netflix, VUDU, etc.
Apple TV on the other hand, can pass LPCM multi channel for supported connections which is great! However, for connections that can't you have to settle for everything being re-encoded as Dolby Digital 5.1, or settle for stereo. This is almost an insult from a company like Apple, which I've come to expect a lot more from, then they've delivered in the last few years. What bothers me more is a less expensive device can handle multiple types of setups a lot more reliably then the more expensive Apple product, which you would automatically expect to be better then the cheaper product. In some ways it is, in other's it's worse.
galonzo likes this.
MacinMan is offline
post #17290 of 25550 Old 08-12-2018, 05:18 PM
MacinMan's Avatar
Liked: 267
Does anyone here use Tubi for Apple TV? I have an issue with the app where, if I don't use it for a while, it asks me to login again. This doesn't seem to happen on the Apple TV 4, only the 4k. I removed the app, and reinstalled it fresh, and the issue still showed up (even with a clean install of the tubi app)
MacinMan is offline
post #17291 of 25550 Old 08-12-2018, 05:52 PM
barong's Avatar
Quoted: 83 Post(s)
Liked: 30
Just wondering if anyone else is having colour banding issues with 10bit content?
I've tried swapping out multiple HDMI cables (all capable of 18 - 21 Gpbs) and it still hasn't helped.
Small .mp4 test file here:
https://ufile.io/k6dnu
Using a Sony 930E and don't have this issue when using the built in video play or other external players.
barong is offline
post #17292 of 25550 Old 08-12-2018, 06:50 PM
sbquart's Avatar
Quoted: 170 Post(s)
Liked: 40
Well this is disappointing news. I'll have to return the Apple TV and continue with the Roku. Real bummer. Thanks for the answer.
galonzo likes this.
sbquart is offline
post #17293 of 25550 Old 08-12-2018, 07:24 PM
slimoli's Avatar
Quoted: 751 Post(s)
Liked: 332
It happens with other apps as well, STARZ,HBOGO,AMC and some others. Annoying, probably a bug.
I was so happy without HDR...
slimoli is offline
post #17294 of 25550 Old 08-12-2018, 07:49 PM
gomo657's Avatar
Quoted: 807 Post(s)
Liked: 784
I’ve had it happen on other devices as well, probably apps after non use for a period of time just asking to login again.
"well you know what doctor I'm going to go home take two aspirins and call you a b****"
gomo657 is online now
post #17295 of 25550 Old 08-13-2018, 02:24 AM
Quoted: 735 Post(s)
Liked: 163
What I don’t understand is why does it need to re-encode to Dolby 5.1 if the Audio is already in Dolby 5.1, such as a Netflix Movie? Confusing.
post #17296 of 25550 Old 08-13-2018, 02:52 AM
Craig Mecak's Avatar
Quoted: 330 Post(s)
Liked: 254
Two reasons:
1. Netflix is not Dolby Digital, it's Dolby Digital Plus.
2. It decodes then re-encodes so it can overlay Apple system sounds.
galonzo and Soundizer17 like this.
Yamaha RX-A3060 7.1.4 Receiver [+Sony Power Amp for Rear Height] / Sony KD-65Z9D / JVC HD1 DILA Projector / 90" screen / OPPO UDP-203 UHD blu-ray / Apple TV 4K
Ascension Summoner 3-way Front Speakers / Ascension 3-way Centre Speaker / Peachtree D5 Surrounds / Yamaha NS-555 3-Way Rear Speakers / ERA D4 x 4 Height Speakers / Rythmik Audio F15HP Sub
Craig Mecak is online now
post #17297 of 25550 Old 08-13-2018, 03:12 AM
Quoted: 735 Post(s)
Liked: 163
If i set Apple tv4k audio to [BEST QUALITY AVAILABLE] or [DOLBY 5.1], my TV shows Dolby Audio. Only if I set Apple tv4k audio to STEREO] will my TV show PCM. The above is whem Dolby Audio is playing such as Netflix Movies.
So why not just leave it on Best Quality Audio?
post #17298 of 25550 Old 08-13-2018, 07:59 AM
MacinMan's Avatar
Liked: 267
Hey guys, got a couple questions here:
1. Is there a way to tell when it's time to do a factory reset of the ATV vs just an app issue where deleting and reinstalling the app(s) will fix the issue?
2. The 4K Apple TV has the gigabit Ethernet port, and I also have a 2013 model Airport extreme with MIMO 80211ac, that has direct line of sight to the 4k TV. Currently I have the ATV4k hardwaired to a gigabit connection, but was wondering if changing to wireless would make any difference as in, would it matter which I use as both have a solid connection here ? My ATV 4, in the bedroom is connected by wireless, and doesn't seem to have any issues with local streaming, or internet streaming. The other thing is, does the ATV have any features that require wireless to be active vs Ethernet ? e.g. location services, or similar?
P.S. I wanted to add, that I have enabled developer mode on my Apple TVs so I have access to the HUD and other functions.
MacinMan is offline
post #17299 of 25550 Old 08-13-2018, 08:05 AM
markus767's Avatar
Quoted: 5650 Post(s)
Liked: 2694
You want to set your Apple TV to "Best Quality Available". See https://support.apple.com/en-us/HT204069
Dolby Digital (AC-3) and Dolby Digital Plus (E-AC-3) will be decoded and sent as uncompressed PCM over HDMI. This is a lossless process.
Dolby Digital Plus with Dolby Atmos will pass through (coming in tvOS 12).
If you select "Dolby Digital 5.1" or "Stereo" audio will be decoded, downmixed and re-encoded. This is a lossy process.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #17300 of 25550 Old 08-13-2018, 08:25 AM
Liked: 1009
When my troubleshooting is exhausted I do a “reset and update” with “one home screen” enabled so all my apps are reinstalled.
Ethernet is almost always better than WiFi. It’s a steadier and usually faster connection. The 1gig speed for your internal network is great especially if using apps like Infuse.
Mike
post #17301 of 25550 Old 08-13-2018, 09:14 AM
slimoli's Avatar
Quoted: 751 Post(s)
Liked: 332
I have the ATV linked to a Sony Z9D and the Sony via ARC to a Pioneer receiver. Setting the ATV to "best quality" will produce stereo sound only . Setting to DD will produce DD . Is that because the Sony can't handle the PCM input ?
slimoli is offline
post #17302 of 25550 Old 08-13-2018, 09:26 AM
galonzo's Avatar
Quoted: 1374 Post(s)
Liked: 1782
Correction: The ATV4K will support Atmos via Dolby MAT (currently does in beta), like the XBONE does.
Musician likes this.
Main: UN78HU9000/SEK-3500 | X4200W (Klipsch/HSU 5.1.2) | UDP-203 (fw 65-0131) | TiVo Bolt | Roku P+
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | AppleTV4K | TiVo Mini
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Scarface and other UHD Digital codes (and some HD codes)
galonzo is online now
post #17303 of 25550 Old 08-13-2018, 09:41 AM
Doug Schiller's Avatar
Quoted: 103 Post(s)
Liked: 60
I hope they don't follow Microsoft's approach and have Atmos turned on for everything.
I hate that on my Xbox.
janila, galonzo and MacinMan like this.
Doug Schiller is offline
post #17304 of 25550 Old 08-13-2018, 09:56 AM
Quoted: 27 Post(s)
Liked: 42
The ATV Remote has volume up/down buttons and there is a way to configure them.
default configuration is, as far as I can determine, using CEC in my setup to control volume via my AVR.
I can turn this off in ATV settings and volume up/down no longer works from the ATV Remote.
Here is something to test for anyone who is having “CEC” problems after attaching an ATV 4K to their systems. Turn off both “CEC” and Volume Control.
Bob Holmes
Curmudgeon
Der Alte is online now
post #17305 of 25550 Old 08-13-2018, 10:10 AM
mutelight's Avatar
Quoted: 2240 Post(s)
Liked: 2528
The Sony is handling the PCM input. What you are seeing is the bandwidth limitations of ARC which applies to every TV with ARC support. ARC only supports stereo PCM.
Unless they are going to change the current behavior last minute before the public release, they aren't. Atmos only engages when the source has Atmos metadata.
galonzo likes this.
mutelight is offline
post #17306 of 25550 Old 08-13-2018, 11:01 AM
MacinMan's Avatar
Liked: 267
It seems like to really get an accurate AV experience that works how it should is to buy devices from companies that specialize in theater components. It seems like people who don't specialize in AV stuff always break something, or do it wrong.
MacinMan is offline
post #17307 of 25550 Old 08-13-2018, 12:36 PM
Quoted: 735 Post(s)
Liked: 163
Should weset to Best Quality if the TV shows Dolby Audio when doing so?
post #17308 of 25550 Old 08-13-2018, 01:09 PM
rwinston's Avatar
Quoted: 71 Post(s)
I have an ATV4K hooked up to an LG B7 through a Denon S930H. I recently bought Crouching Tiger, Hidden Dragon from iTunes in 4K Dolby Vision. Is there a known issue with this transfer? It looks like crap with my setup. Extremely grainy, and faces look like there are worms crawling under the skin. Even the subtitles are not very sharp. I have no problems with other iTunes 4K DV movies. I watched Spider-Man: Homecoming and John Wick 2 this weekend with the same setup, and they looked fantastic. SM looked nearly as good as the UHD disc version. The HDX version of CTHD on the ATV Vudu app looked much better than the 4K DV iTunes version, as did the UHD non-HDR version on the LG’s Amazon app. So what’s up with this?
galonzo likes this.
rwinston is offline
post #17309 of 25550 Old 08-13-2018, 01:11 PM
markus767's Avatar
Liked: 2694
Probably. Any specific reason why you don't connect the ATV to the AVR?
Markus
post #17310 of 25550 Old 08-13-2018, 01:12 PM
markus767's Avatar
Liked: 2694
Not sure about that as this would mean TrueHD which you won't find in low bandwidth streamed content. Would be much easier for Apple to just pass through the Atmos encoded E-AC-3 stream. Have to dig deeper though.
galonzo likes this.
Markus
apple 4k tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , Samsung
