Apple TV owners' thread. FAQ in first post - Page 791 - AVS Forum | Home Theater Discussions And Reviews
 29108Likes
post #23701 of 25544 Old 07-15-2019, 10:07 AM - Thread Starter
bodosom's Avatar
Quoted: 2088 Post(s)
Liked: 1628
Originally Posted by rsonnens View Post
If the only app with this problem then it is an Amazon app thing.
There's nothing like approaching a problem logically.
rsonnens likes this.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X3500/LG C8
bodosom is online now
post #23702 of 25544 Old 07-16-2019, 05:51 AM
galonzo's Avatar
Quoted: 1374 Post(s)
Liked: 1782
Originally Posted by box4m View Post
Hey guys,
So i just bought a sony oled + appletv4k and trying to figure out stuff to get the best picture, to my liking.
The problem i have is, when i have "match dynamic range" enabled, and watch a HDR10 movie - HDR kicks in, but to me it looks kinda washed out.
When i force Dolby Vision, and have "match dynamic range" off, it looks more correct to me - deeper blacks and better contrast. Im no picture tech pro but ive read quite abit and this seems weird to me, that DV looks better even though the movie isnt made for DV, what counts is ofcourse what i think but i wonder if im correct in thinking so, cause it seems weird to me.
The TV can handle both HDR10 and DV.
What is your initial thoughts on this?
Cheers
With that TV, the correct settings (4K/SDR with match enabled) should be hands down better than any other combination of ATV settings for HDR/DV content; I suspect you may need to tweak some picture controls for that HDMI input on your TV, so you may want to check the thread for your display.
Main: UN78HU9000/SEK-3500 | X4200W (Klipsch/HSU 5.1.2) | UDP-203 (fw 65-0131) | TiVo Bolt | Roku P+
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | AppleTV4K | TiVo Mini
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Scarface and other UHD Digital codes (and some HD codes)
galonzo is online now
post #23703 of 25544 Old 07-16-2019, 05:56 AM
box4m's Avatar
Quoted: 84 Post(s)
Liked: 30
You are correct, the difference was a very impactful setting now its all good, embarrasing
galonzo likes this.
Sony KD-77AG9 / AppleTV4k
box4m is offline
post #23704 of 25544 Old 07-16-2019, 09:23 AM
cbsdallas's Avatar
Quoted: 21 Post(s)
Liked: 32
I have an apple TV 4k and a 4k projector capable of HDR 10. I notice that sometimes when using netflix or prime that even though it doesn't say 4k or HDR when I play it my projector is stating 4k and premium HDR content is being displayed. This does not happen with Apple Itunes content as it displays what they say it is. Star Wars the last Jedi on Netflix showed to be playing in 4k HDR but was not advertised as such on Netflix. Has anyone else noticed this disconnect?
cbsdallas is offline
post #23705 of 25544 Old 07-16-2019, 11:31 AM
Brian Hampton's Avatar
Quoted: 1503 Post(s)
Liked: 918
Any signal would be unconverted to 4K on a 4K display so that sorts out half of your question. ... I think ... I'm still a little confused by your phrasing.
Brian Hampton is offline
post #23706 of 25544 Old 07-16-2019, 01:20 PM
cbsdallas's Avatar
Quoted: 21 Post(s)
Liked: 32
sorry for the confusion. My projector has a selection to see what signal it is receiving which would show the 4k signal and HDR or a 1080p signal regular. According to the Netflix site it showed just an HD signal but on the projector it showed it was receiving the 4k HDR signal maybe the Apple TV is up-converting the signal as it decodes the Netflix data? could be some setting combination in my Apple TV except it does not up-convert other signals or other sources.
post #23707 of 25544 Old 07-16-2019, 04:44 PM
freshmanjs's Avatar
Quoted: 195 Post(s)
Liked: 93
AppleTV does not change resolutions based on source. If you have it set to 4k, it outputs everything in 4k.
As for HDR, do you have match dynamic range setting on or off?
galonzo likes this.
freshmanjs is offline
post #23708 of 25544 Old 07-16-2019, 04:46 PM
galonzo's Avatar
Liked: 1782
@cbsdallas , if you're getting 4K/HDR with Star Wars from Netflix on the ATV, this means you have your Video output setting in the ATV incorrectly set to 4K/HDR; you'll want to change it to 4K/SDR with match dynamic range enabled (which will give you HDR when appropriate, I would also enable match for framereate). Native resolution is not supported by the ATV4k.
post #23709 of 25544 Old 07-16-2019, 07:52 PM
Quoted: 83 Post(s)
Liked: 37
What’s the most channels of audio the ATV4k will send out with an atmos system? I have a 5.1.2, but will be upgrading to a 7.2.4 within the next 6 months. The atv will handle that fine, correct? Does it go beyond that? 9.2.6 or something like that.. what’s the limit?
EyeWasAbducted is offline
post #23710 of 25544 Old 07-16-2019, 09:01 PM
mutelight's Avatar
Quoted: 2240 Post(s)
Liked: 2528
Someone correct me if I am wrong but the Apple TV 4K supports 7.1 since launch and that acts as the base layer and Dolby MAT 2.0 should easily scale to 4 height channels as it is all object based.
galonzo and EyeWasAbducted like this.
mutelight is offline
post #23711 of 25544 Old 07-17-2019, 04:48 AM
Ezra's Avatar
Quoted: 60 Post(s)
Liked: 47
My projector supports HDR in 4K/24 only. If I set my ATV to 4K/SDR with matching and dynamic on will I ever get anything in HDR? What would be the implications of setting it to 4K/SDR?
Ezra is offline
post #23712 of 25544 Old 07-17-2019, 04:53 AM
freshmanjs's Avatar
Quoted: 195 Post(s)
Liked: 93
Why would you not get HDR? If you set it that way and the source is 4k HDR 24Hz, then it will output at 4k HDR (because of dynamic range matching) and 24Hz (because of frame rate matching).
galonzo likes this.
post #23713 of 25544 Old 07-17-2019, 05:00 AM
Ezra's Avatar
Quoted: 60 Post(s)
Liked: 47
I'm not saying I wouldn't, I am asking to get an understanding of how it works.
Is there much 4K/24 content from the apps?
Ezra is offline
post #23714 of 25544 Old 07-17-2019, 05:14 AM
freshmanjs's Avatar
Quoted: 195 Post(s)
Liked: 93
Most 4k HDR video content is 24Hz...there is very little (but some) video content in HDR in 50 or 60Hz. Games are a different story -- 60Hz HDR is the norm.
galonzo and Musician like this.
post #23715 of 25544 Old 07-17-2019, 07:20 AM
cbsdallas's Avatar
Quoted: 21 Post(s)
Liked: 32
Thanks for the info. I saw last night that it was set to 4k HDR so I set it to 4k SDR and then the apple tv asked to move it back to HDR. I will try and set it to SDR tonight and see if I can exit and leave it set at SDR and dynamic range and framerate set to match.
Someone needs to write a book on how to set up all of this 4k HDR stuff or teach a class at a community college...intro to 4K.
Laserfan, galonzo and ballyerhead like this.
post #23716 of 25544 Old 07-17-2019, 08:25 AM
Quoted: 1712 Post(s)
Liked: 1008
If you check out the very first post in this thread you’ll see it’s all there. Well worth the long read IMHO.
gomo657, Ph8te, blenky and 2 others like this.
Mike
Sony XBR-65X930E | ATV4K-64GB & 32GB 5th Gen | Nvidia Shield TV Pro 2017 | Logitech Harmony Elite
m_snow is online now
post #23717 of 25544 Old 07-19-2019, 09:28 AM
cbsdallas's Avatar
Quoted: 21 Post(s)
Liked: 32
Ok finally got all the settings right and the picture looks great on both HDR 4k and SDR 4k sources. I realized that it wasset to 4k HDR 60hx so reset to 4k SDR 60hz. Noticed that the chroma had somehow defaulted to 4.4.4 and switched to 4.2.0. All working great switches to HDR when triggered and the non HDR 4k still looks great. No more sparkles on CBS all access as well (probably related to it being set on 4.4.4.)
Thanks for all the suggestions and help.
galonzo likes this.
post #23718 of 25544 Old 07-19-2019, 10:01 AM - Thread Starter
bodosom's Avatar
Liked: 1628
... Noticed that the chroma had somehow defaulted to 4.4.4 and switched to 4.2.0. ... No more sparkles on CBS all access as well (probably related to it being set on 4.4.4.)
That's not how chroma sub-sampling control works on the ATV4K. Please review the first post in this thread.
post #23719 of 25544 Old 07-19-2019, 10:11 AM
mutelight's Avatar
Liked: 2528
Having the video set to 4:4:4 with SDR content was putting too much strain on the HDMI cable that can't reliable carry the higher bandwidth signal, causing the sparkling artifacts.
4:2:0 is a fine setting though since all video content is in that format.
galonzo likes this.
post #23720 of 25544 Old 07-19-2019, 11:33 AM
Quoted: 406 Post(s)
Liked: 201
SDR Content in ATV is always outputted in 4:4:4. 4:2:0 is only for UI.
LG OLED 55 B7v | LG SK10Y Soundbar | Samsung 55KS8000 | LG Plasma 50PZ550 | i1D3 OEM | Calman Enthusiast
MrRobotoPlus is online now
post #23721 of 25544 Old 07-19-2019, 11:38 AM
terminaldawn's Avatar
Quoted: 211 Post(s)
Liked: 56
Question
TLDR: How can I get Apple TV to auto swap between Dolby 5.1 and Atmos On Automatically or get my AVR to upmix Multichannel PCM content to Dolby Atmos all the time similar to my Shield TV?
Just bought a Apple TV 4K mainly for the Dolby Vision and Atmos capability for Netflix and other apps. I also own a Shield TV which is an amazing streamer but notably lacks Dolby vision (all apps) and Dolby Atmos (for some apps). Hence the purchase of the Apple TV.
Also of note: I have a Denon avr x3300w with a 3.1.2 config.
I read through the first post and also read through this link and I want to make sure I am not missing anything.
https://developer.dolby.com/blog/dol...t-on-apple-tv/
When I play cbs all access (Star Trek discovery) and amazon prime content with my shield i get Dolby digital plus. All my speakers are active and my avr is correctly up mixing to 3.1.2. When I do the same thing on my Apple TV 4K I am getting multichannel PCM and my Dolby Atmos height speakers are not active and I am getting noticeably less impressive sound. My apple tv is set to Auto and Atmos On.
If I switch to force Dolby Digital 5.1 this resolves my above issue however this disables my ability to play native Atmos content.
How can I have my cake and eat it too here? I do not want to have to toggle the audio menu every-time i want to play Atmos content.... At that point i would just stick with my XBOX ONE X to play Dolby Vision / Atmos content and use my shield for everything else. Am i missing anything? If not I am really lacking understanding any hype at all over the AppleTV, why even bother with this over the ShieldTV?
Thanks in advance for anyone with ideas!!!!
terminaldawn is offline
post #23722 of 25544 Old 07-19-2019, 11:46 AM
mutelight's Avatar
Liked: 2528
That is incorrect. If the Apple TV is set to 4:4:4, for SDR content it will always output that signal format, then the opposite applies to when the Apple TV is set to 4:2:0.
If what you said was the case, the TV would blank whenever you start content as it renegotiates the video signal.
Also it wouldn't make much sense to run the UI (which could potentially benefit from 4:4:4) in 4:2:0 over video content which is all 4:2:0.
post #23723 of 25544 Old 07-19-2019, 11:47 AM
Quoted: 406 Post(s)
Liked: 201
My HDFury Integral 2 says what I said. If you have match frame rate off you force the frame rate that's why you don't see blank screen everytime.
post #23724 of 25544 Old 07-19-2019, 11:57 AM
galonzo's Avatar
Liked: 1782
@terminaldawn , you simply cycle the "movie" button on your AVR remote until you have "MultiIN + Dolby Surround", which is the non-Atmos up-mixer (this setting will stick for this input), then you'll get Atmos when appropriate and Multi-channel PCM will be up-mixed
post #23725 of 25544 Old 07-19-2019, 01:49 PM
mutelight's Avatar
Liked: 2528
My AVRs and Pre-pro say otherwise on my 3 different setups with 3 different ATV 4Ks.
I have dynamic range and frame rate matching enabled on all 3.
post #23726 of 25544 Old 07-19-2019, 03:04 PM - Thread Starter
bodosom's Avatar
Liked: 1628
And yet (at least at my house) that's exactly how it works. Both my Vertex and Denon agree that the (8b) signal changes from 4:2:0 to 4:4:4 (and the FR changes from 60 to 24). This has always been the case (at my house). I do know that display capability can effect output, my display does everything so the ATV4K switches when SDR content begins.
Whether or not the screen blanks for a handshake depends on the Match settings.
UI Settings:
4K SDR 60Hz
YCbCr
4:2:0
Chuck666 and MrRobotoPlus like this.
post #23727 of 25544 Old 07-19-2019, 03:12 PM - Thread Starter
bodosom's Avatar
Liked: 1628
You didn't read the first post carefully enough. Notably there is no pass-through AC-3/E-AC-3, it's decoded to PCM in the ATV4K. Depending on your AVR you will see variations on MPCM as the input and possibly Atmos (ATMOS).
Chuck666 likes this.
post #23728 of 25544 Old 07-19-2019, 03:25 PM
Quoted: 406 Post(s)
Liked: 201
I'm very confident about HDFury hardware.
ID:	2592620   Click image for larger version
post #23729 of 25544 Old 07-19-2019, 04:13 PM
claw's Avatar
Quoted: 2315 Post(s)
Liked: 2170
For 4K24, 4:2:0 is not a valid output format for HDMI 2.0. The ATV must output either 4:4:4 or 4:2:2. It cannot output 4:2:0 even though that is how the content was encoded.
For 4K60, 4:2:0 is a valid output format.
galonzo likes this.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #23730 of 25544 Old 07-19-2019, 04:36 PM
mutelight's Avatar
Liked: 2528
I'm not sure what you're proving here as you are showing 4:4:4, which I assume is during media playback but your ATV UI should have the same.
What I said was that the home screen and overall UI should always have a 4:4:4 signal. (which it will unless something else is at play)
UI Settings:
4K SDR 60Hz
YCbCr
4:2:0
No, any time the chroma changes, it will renegotiate with the display, unless you have a unicorn display.
With both match settings enables going through no intermediary device to capable displays, if I have it set to 4:4:4, with SDR content it stays there. If I force 4:2:0 on the ATV4K with native content, it stays there.
*EDIT* OK, let me correct myself, after further testing. Apple content wants to force 4:4:4 even in SDR even if you have the system set to 4:2:0 but some 3rd party apps adhere to the 4:2:0 chroma subsampling.
apple 4k tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , Samsung
