Apple TV owners' thread. FAQ in first post - Page 792 - AVS Forum | Home Theater Discussions And Reviews
 28219Likes
post #23731 of 24409 Old 07-19-2019, 04:36 PM
Musician's Avatar
Quoted: 2644 Post(s)
Liked: 5253
Originally Posted by claw View Post
For 4K24, 4:2:0 is not a valid output format for HDMI 2.0. The ATV must output either 4:4:4 or 4:2:2. It cannot output 4:2:0 even though that is how the content was encoded.
For 4K60, 4:2:0 is a valid output format.
I was just about to post a chart I prepared along the same lines (see thumbnail 1).
Going through the SDR settings, only when choosing 4K SDR @ 60Hz does my TV allow me the choice between 4:2:0 or 4:4:4 (see thumbnail 2) otherwise 24Hz and 30Hz only provides the option of 4:4:4 so what @bodosom said about his chroma changing from 4:2:0 to 4:4:4 when the frame rate changes from 60 to 24 in SDR mode makes perfect sense (assuming match frame rate is on).
Cheers! 🍹
ID:	2592638   Click image for larger version
galonzo and musicman0725 like this.
Samsung UN78HU9000 & SEK-3500U/ZA - Firmware 1540.3
Samsung UN40HU7000 & SEK-3500U/ZA - Firmware 1540.3
Samsung UBD-K8500 UHD Blu-ray Player; Apple TV 4K
Arris VIP5662W UHD Whole Home DVR; Chromecast Ultra
Marantz SR7005 Receiver; Magnepan Speakers; Martin Logan Subwoofer
Musician is online now
post #23732 of 24409 Old 07-19-2019, 04:51 PM - Thread Starter
bodosom's Avatar
Quoted: 1936 Post(s)
Liked: 1493
There's one in the first post of this thread. Unfortunately the company that produced it is no more so they won't do another version for HDMI 2.1.
Musician likes this.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X3500/LG C8
bodosom is online now
post #23733 of 24409 Old 07-19-2019, 05:14 PM - Thread Starter
bodosom's Avatar
Liked: 1493
Originally Posted by mutelight View Post
I'm not sure what you're proving here as you are showing 4:4:4, which I assume is during media playback but your ATV UI should have the same.
What I said was that the home screen and overall UI should always have a 4:4:4 signal. (which it will unless something else is at play)
I'm not sure what you're proving. The OP specifically said switching to 4:2:0 fixed the CBS All Access video issue. In a typical 4K configuration setting the UI to 4:2:0 doesn't change SD output to 4:2:0.
post #23734 of 24409 Old 07-19-2019, 05:22 PM
mutelight's Avatar
Quoted: 2214 Post(s)
Liked: 2501
I'm not sure how you aren't following. Some apps force 4:4:4 which strains an incapable HDMI cable more than when an app outputs 4:2:0 because it requires more bandwidth of the cable. Some apps respect the system level setting, some do not.
mutelight is online now
post #23735 of 24409 Old 07-19-2019, 06:02 PM
terminaldawn's Avatar
Quoted: 211 Post(s)
Liked: 55
Originally Posted by bosom View Post
You didn't read the first post carefully enough. Notably there is no pass-through AC-3/E-AC-3, it's decoded to PCM in the ATV4K. Depending on your AVR you will see variations on MPCM as the input and possibly Atmos (ATMOS).
@bosom;- I read it very carefully . I am aware that Apple TV does send PCM, the point you may have missed from my message... it also can re-encode to DD+. This is the option I was using to force my AVR to upmix to Atmos and the only way i knew how to upmix to atmos. Hence my question.... I dont want to switch settings. I want it all to just work... @galonzo ;answered my question though.
Originally Posted by galonzo View Post
@terminaldawn , you simply cycle the "movie" button on your AVR remote until you have "MultiIN + Dolby Surround", which is the non-Atmos up-mixer (this setting will stick for this input), then you'll get Atmos when appropriate and Multi-channel PCM will be up-mixed
@galonzo - Awesome, this is what I was looking for, EXACTLY. ONE MILLION THANKS!!!! As a side note this setting sticks, so I can be super lazy and not worry about having to switch it around.
I just really wonder why apple and other devices go through all the trouble of not doing pass-through? I could care less about their device sounds.... Its a pet peeve of mine.. just give me the choice for my AVR to do everything... sigh ...
@The Group ... Are these the "best" Video settings for my display [LG OLED65C7P]: ??
Enable Dolby Vision
4k SDR
YCbCr
4:4:4
Match Content Range and Frame Rate
Thanks again!!!
galonzo likes this.
terminaldawn is offline
post #23736 of 24409 Old 07-19-2019, 06:17 PM - Thread Starter
bodosom's Avatar
Liked: 1493
I don't know what constraints apply when you say respect. The idea that Format (or a particular video setting in general) overrides content constraints is confusing me.
In any case although I don't have CBS/AA I did check Vudu and AMC. Both switch to (force) 4:4:4 in my video chain.
post #23737 of 24409 Old 07-19-2019, 06:20 PM - Thread Starter
bodosom's Avatar
Liked: 1493
Originally Posted by terminaldawn View Post
bosom- I read it very carefully . I am aware that Apple TV does send PCM, the point you may have missed from my message... it also can re-encode to DD+.
Again I would suggest you read the first post in this thread more carefully. In any case I'm glad you have a solution that suits you.
post #23738 of 24409 Old 07-19-2019, 07:08 PM
mutelight's Avatar
Liked: 2501
Well, I know you're really particular as far as you quoting people and have a tendency to strip the context but what I mean is that not all apps will enforce a certain color space.
For example, I set the ATV at 4:2:0 and open DirecTV Now and it stays at that signal. I then set the Apple TV at 4:4:4 and open the app and it remains in that color space.
post #23739 of 24409 Old 07-19-2019, 08:31 PM - Thread Starter
bodosom's Avatar
Liked: 1493
Okay, assuming you mean "show a motion picture" when you say "open" then currently output chroma is unpredictable.
post #23740 of 24409 Old 07-19-2019, 11:15 PM
Quoted: 481 Post(s)
Liked: 430
If match framerate is off though, won’t the menu chroma setting be maintained? I thought it only switched when it was handshaking?
Sent from my iPad using Tapatalk Pro
Andrew Stirling is offline
post #23741 of 24409 Old 07-19-2019, 11:31 PM
usc1995's Avatar
Quoted: 386 Post(s)
Liked: 250
Ok I have a very strange issue that I haven’t seen reported with Netflix on the ATV4K. The show Dark is no longer in Atmos even though other titles are showing in Atmos. I took the pics attached tonight. The movie Point Blank is in Atmos on my ATV4k as per the pic attached. Dark is in Atmos on my Xbox One S as it should be. I have heard of Netflix not indicating or playing Atmos even when set and some members have struggled getting it to work but I have never heard of just individual titles not functioning correctly. Any ideas?Click image for larger version
ID:	2592696Click image for larger version
ID:	2592698Click image for larger version
usc1995 is online now
post #23742 of 24409 Old 07-20-2019, 01:42 AM
Quoted: 211 Post(s)
Liked: 55
bosom- I read it very carefully <img src="https://www.avsforum.com/forum/images/AVSForum/smilies/tango_face_wink.png" border="0" alt="" title="Wink" class="inlineimg" />. I am aware that Apple TV does send PCM, the point you may have missed from my message... it also can re-encode to DD+.
What do you think I missed in the first post exactly? Pretty sure I fully comprehend how the audio is processed on the Apple TV.
Display: LG OLED65C7P 65-Inch | AVR: Denon AVR-X3300W
Speakers Klipsch: Front: RP-260F Atmos: RP-140S, Center RP-450C, Rear: R-15M | SUB: Rythmik FV15HP (Currently Running 3.1.2)
Devices: Apple TV 4K | Nvidia SHIELD TV Gaming Edition | Xbox One X Scorpio Edition | PS4 PRO | Nintendo Switch | Custom Gaming PC
post #23743 of 24409 Old 07-20-2019, 09:12 AM
Quoted: 94 Post(s)
Liked: 44
Originally Posted by usc1995 View Post
Ok I have a very strange issue that I haven’t seen reported with Netflix on the ATV4K. The show Dark is no longer in Atmos even though other titles are showing in Atmos. I took the pics attached tonight. The movie Point Blank is in Atmos on my ATV4k as per the pic attached. Dark is in Atmos on my Xbox One S as it should be. I have heard of Netflix not indicating or playing Atmos even when set and some members have struggled getting it to work but I have never heard of just individual titles not functioning correctly. Any ideas?Attachment 2592696Attachment 2592698Attachment 2592700
AFAIK season 2 of Dark is not in Atmos, but season 1 is. Why, no one seems to know.
Bill Wolfer is offline
post #23744 of 24409 Old 07-20-2019, 09:42 AM
Noel Hart's Avatar
Liked: 2
What is the current state of lip sync delay issues with the Apple TV 4k? I just installed mine and am getting 85-125 ms delay on Netflix. I haven't gone through and checked other apps yet. I can set the delay on my receiver, but am a bit annoyed that I haven't had this issue with my Amazon firetv or smart tv. Does anyone have any tips on how best to set the delay since i've read it likely will vary based on content, apps, and resolution?
Noel Hart is offline
post #23745 of 24409 Old 07-20-2019, 09:50 AM
rsonnens's Avatar
Quoted: 648 Post(s)
Liked: 475
The delay is usually elsewhere in your chain, AVR/tv, and not the ATV and can vary by video/audio type. Some exceptions usually are Amazon which is all over the place and is just often delivered out of sync.
That said I have a delay set in your range set on my AVR and generally things are then spot on. (I have a denon and lg tv.)
galonzo likes this.
rsonnens is online now
post #23746 of 24409 Old 07-20-2019, 10:31 AM
usc1995's Avatar
Quoted: 386 Post(s)
Liked: 250
Interesting as I had not heard that. Why does Dark on the Xbox show the Atmos tag (along with the Dolby Vision tag) whereas it only shows 5.1 on the ATV? Very strange. I will try to stream an episode from season one again and see if I get Atmos even though I am not getting it on season two. Unfortunately, I cannot verify if the Xbox is actually sending Atmos for season two as it stupidly wraps all audio in an Atmos container regardless if the source is Atmos or not. Maybe I will stick my ears up against my height speakers and see if I am getting anything when watching season two on the Xbox. It certainly seemed to sound a little better last night when I was comparing it to the ATV but it might be confirmation bias from seeing the Dolby Atmos logo light up on my AVR.
post #23747 of 24409 Old 07-20-2019, 10:47 AM
musicman0725's Avatar
Quoted: 70 Post(s)
Liked: 99
Thanks for posting this! Just got a Denon to replace my Sony AVR and saw this right before setting it up. Really appreciate it and thank you!
galonzo and Musician like this.
Samsung UN55KS8000 | Denon AVR-X4500H | AppleTV 4K | DirecTV HR54 + 4K RVU | Samsung UBD-M8500
Samsung UN55HU8550 + SEK-4500/ZA | Samsung Soundbar HW-H550 | AppleTV 4K | DirecTV C41W | Samsung UBD-K8500
Samsung UN32EH4003 | AppleTV 4th Gen | DirecTV C41W
musicman0725 is online now
post #23748 of 24409 Old 07-20-2019, 02:02 PM - Thread Starter
bodosom's Avatar
Liked: 1493
However I just checked:
  • ABC
  • AMC
  • CBS
  • Hulu
  • iTunes
  • Movies Anywhere
  • NBC
  • Netflix
  • Prime Video
  • Spectrum
They all behave the same way. The app interface maintains the UI default but 8b SDR content is sent as 4:4:4. I note this to clarify my questioning note about opening an app versus playing content in that app. And, of course, the first post says that the ATV4K disregards the UI default when sending 4K/8b/SDR if possible. Or something like that.
MrRobotoPlus likes this.
post #23749 of 24409 Old 07-20-2019, 05:07 PM
mutelight's Avatar
Liked: 2501
  • ABC
  • AMC
  • CBS
  • Hulu
  • iTunes
  • Movies Anywhere
  • NBC
  • Netflix
  • Prime Video
  • Spectrum
4:2:0
post #23750 of 24409 Old 07-20-2019, 05:55 PM
flyinion's Avatar
Quoted: 485 Post(s)
Liked: 332
Ok all this range and chroma talk has me wondering what I should be running. I'm still connected to a VT60 plasma hoping to go 4k early next year. I've been running 1080p SDR obviously but also have frame rate set to match. I assumed I should not match dynamic range since the TV can't do HDR. Also output is set to YCbCr but I wasn't sure what RGB high vs low would do? Just want to make sure I have the best config for my current TV.
Pansonic TC-P60VT60 | Denon AVR-X4500H | Sony UBP-X800 | Chane A2.4 L/C/R | Chane A1.4 SR | SVS Elevation Atmos/height | SVS PB-2000 | Logitech Harmony 950 | Arris MX011ANM (Xfinity X1) | Apple TV 4K
flyinion is offline
post #23751 of 24409 Old 07-20-2019, 07:13 PM - Thread Starter
bodosom's Avatar
Liked: 1493
4:2:0
Is this DirecTV Now or another app?
post #23752 of 24409 Old 07-20-2019, 07:19 PM - Thread Starter
bodosom's Avatar
Liked: 1493
You use a chroma upsampling error (CUE) test to compare YCC to RGB high (for "motion pictures"). If you can tell the difference use the better setting. There are some other checks and in-depth discussion via Spears & Munsil.
post #23753 of 24409 Old 07-21-2019, 03:56 AM
lujan's Avatar
Quoted: 4462 Post(s)
Liked: 2512
Enable Dolby Vision
4k SDR
YCbCr
4:4:4
Thanks again!!!
I was wondering about the ATV4K settings as well because on some SDR 4k content (such as the Bond movies) I'm seeing video in white or very light areas as snowy areas where it looks like a bunch of small pixels. I don't notice this when watching HDR-10 or Dolby Vision, only with SDR. Could changing from 4:4:4 to 4:4:2 help? I also have an LG OLED TV.
lujan
526 Ultra HD
729 HD
4 SD
lujan is offline
post #23754 of 24409 Old 07-21-2019, 04:17 PM
GPowers's Avatar
Quoted: 87 Post(s)
Liked: 114
Originally Posted by Soccerdude View Post
I have three 4kATV boxes only 1 of them somehow allows me to do Dolby Atmos tho they all are the same .Can't figure it out.
Did you ever get an answer?
I can not get my Apple TV 4K to send Atmos to my Marantz AV7702. The option doesn't even show up on the Apple TV (yes all software is current). The Oppo UHD player works great and I get Atmos. BUT not from the Apple TV and Apple streamed moves that support Atmos?
GPowers is offline
post #23755 of 24409 Old 07-21-2019, 06:13 PM - Thread Starter
bodosom's Avatar
Liked: 1493
Please review the first post in this thread.
post #23756 of 24409 Old 07-21-2019, 08:30 PM
Dave3000's Avatar
Quoted: 79 Post(s)
4:2:0
Isn't an average of 5.33 mbps low for a 4k video even if it's a cartoon even by iTunes standards?
Dave3000 is online now
post #23757 of 24409 Old 07-21-2019, 08:48 PM
Quoted: 24 Post(s)
Liked: 0
Hi guys, I'm new to movies streaming. Subscribed to Netflix and streaming through my Sony x700 bluray player. So far so good as it has 4k, but no atmos support. And Netflix audio is not impressive.
Can I know if anyone has compare android box with apple TV 4k?
Apple 4k tv has atmos playback for Netflix.
How is the audio and picture quality when compared to android box for Netflix streaming?
deadrick is offline
post #23758 of 24409 Old 07-21-2019, 08:51 PM - Thread Starter
bodosom's Avatar
Liked: 1493
It might be but this isn't a 4K source. It's 720p from the provider. Who knows what the original resolution might be.
post #23759 of 24409 Old 07-21-2019, 09:02 PM
cydeweyz's Avatar
Quoted: 431 Post(s)
Liked: 410
Old animation and from Disney. Sounds about right. Show us what Spider-Man into the Spiderverse reports back.
cydeweyz is online now
post #23760 of 24409 Old 07-22-2019, 05:45 AM
PlasmaHiDef's Avatar
Quoted: 337 Post(s)
Liked: 117
An external streaming device is the way to go. Can't comment on the android part. TV apps and bluray player apps are not as good. From my experience, the internal apps are not updated as often as the ATV is. Netflix audio and pq are great via ATV 4K.
bobby94928 likes this.
LG OLED55B8PUA
LG OLED65C7P
LG UBK90
ATV 4K
Samsung HW-N950
PlasmaHiDef is offline
apple 4k tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , mgy52ll , mqd22ll , Samsung
