Apple TV owners' thread. FAQ in first post - Page 798 - AVS Forum | Home Theater Discussions And Reviews
 28703Likes
post #23911 of 24946 Old 07-30-2019, 03:02 PM
lujan's Avatar
Quoted: 4516 Post(s)
Liked: 2576
Originally Posted by Pip View Post
Thank you so much. Enhanced mode? Where is that setting. I can't find it in the Denon and a search for "enhanced" in the user manual turns up nothing but "enhanced' WEP security and "enhanced" localization with Atmos.
Al my cables test fine and are premium certified hi speed with the hologram tags.
I've been dealing with this all day. If it's really this "enhanced" setting, I've got your bar tab if you ever visit.
Piip
Here
galonzo, musicman0725 and Musician like this.
lujan
541 Ultra HD
727 HD
4 SD
lujan is offline
post #23912 of 24946 Old 07-30-2019, 03:03 PM
Otto Pylot's Avatar
Quoted: 3397 Post(s)
Liked: 2444
Originally Posted by musicman0725 View Post
Do you have Video/4K Signal Format set to Enhanced mode on the Denon?
The difference between connecting the ATV 4K to the TV directly and receiver pass-through is typically you must turn an enhanced HDMI setting on for the receiver. Make sure device to receiver and receiver to TV are both using cables that can handle the bandwidth (18Gbps). HDMI premium certified cables are tested to handle the bandwidth at the length of the cable which I would recommend purchasing if you still have issues after verifying you enabled Enhanced mode on the receiver.
Enhanced Mode? Doesn't sound very intuitive if that solves his problem. On the Yamaha receiver it's just Direct (no video conversion) which just sends whatever the native signal is to the tv if the tv can handle it.
I never trust an atom, they make up everything.
Otto Pylot is offline
post #23913 of 24946 Old 07-30-2019, 03:13 PM
claw's Avatar
Quoted: 2305 Post(s)
Liked: 2141
Standard supports up to 10GHz signal input. Enhanced up to 18GHz. It needs to be set to enhanced for each HDMI input that will receive 4K60 4:2:0 10 bit or 4K60 4:2:2 12-bit input from a player.
galonzo likes this.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #23914 of 24946 Old 07-30-2019, 03:16 PM
Pip
Pip's Avatar
Quoted: 312 Post(s)
Liked: 143
Originally Posted by lujan View Post
Here
That's a Denon 4300 manual? What page? I did a word search on the pdf, and looked at the top of every page in the settings chapter. I can't find this in my manual.
Closest thing I can find is this.
Thank you,
Pip
Name:	Screenshot 2019-07-30 at 6.14.55 PM.png
Pip is offline
post #23915 of 24946 Old 07-30-2019, 03:18 PM
claw's Avatar
Liked: 2141
Thank you,
Pip
I think Denon added the 4K Standard/Enhanced setting starting with the 4400 model. My 4200 does not have the setting but my 6400 does.
galonzo and musicman0725 like this.
CJ
claw is offline
post #23916 of 24946 Old 07-30-2019, 03:21 PM
Pip
Pip's Avatar
Quoted: 312 Post(s)
Liked: 143
Does that mean the 4300 won't pass full HDR? Why has it always passed it to the JVC without issue?
Pip
Pip is offline
post #23917 of 24946 Old 07-30-2019, 03:23 PM
claw's Avatar
Liked: 2141
Pip
It will pass 4K60 10-bit. It just doesn't have a setting to allow/disallow it.
Did you see my post in another thread? Try setting your TCL to PC mode in order to accept 4:4:4.
CJ
claw is offline
post #23918 of 24946 Old 07-30-2019, 03:46 PM
lujan's Avatar
Liked: 2576
Thank you,
Pip
It on the 4400 manual on page 200.
lujan
541 Ultra HD
727 HD
4 SD
lujan is offline
post #23919 of 24946 Old 07-30-2019, 03:47 PM
Pip
Pip's Avatar
Quoted: 312 Post(s)
Liked: 143
Thanks. As claw noted, this setting isn't available on the 4300.
Pip
Pip is offline
post #23920 of 24946 Old 07-30-2019, 03:56 PM
Pip
Pip's Avatar
Quoted: 312 Post(s)
Liked: 143
Thanks claw. I didn't catch that.
Should this make a difference? I've already forced the TCL HDMI setting to 2.0. Also remember that direct from the devices (bypassing the Denon) the TCL displays everything perfectly at any and all output settings - both the ATV and 820 - even when set at 4:4:4 - never a problem.
The TCL in computer mode looses some picture settings so I'd rather avoid that.
Thanks so much as always
Pip
Pip is offline
post #23921 of 24946 Old 07-30-2019, 04:04 PM
healthnut's Avatar
Quoted: 959 Post(s)
Liked: 957
Am I to understand from recent posts that HDR is presently inoperative on the ATV?
healthnut is offline
post #23922 of 24946 Old 07-30-2019, 04:14 PM
thomasfxlt's Avatar
Quoted: 3321 Post(s)
Liked: 6161
It’s working in Movies and VUDU, but mixed luck in Netflix and Amazon Prime. I’ve got a few UHD/HDR10 movies in Prime that work but Jack Ryan, Hanna do not. Bosch worked though.
The things I tested that weren’t working on the ATV work in my native Sony display apps.
SONY Z9F LCD Master Series Owners Thread
Vizio 2016 P series FAQ, general info and Help
Sony Z9F 75, Vizio P75C1 UHD/HDR/DV, Pioneer Elite SC-95, Samsung UHD Bluray K8500, AppleTV 4K, CC Ultra
thomasfxlt is offline
post #23923 of 24946 Old 07-30-2019, 04:41 PM
musicman0725's Avatar
Quoted: 74 Post(s)
Liked: 110
Yup, my 2016 Sony AVR with 4K HDR pass-through and my new Denon both have “enhanced” format, so I knew to look for it when seeing the same thing the other week. Samsung has the HDMI UHD Color setting on their TVs which also impacts supported UHD bit depth and chroma. Different vendors have different names for it. On the Sony AVR it can be set per hdmi input. On the Denon it’s just on or off for all inputs.
galonzo and Musician like this.
Samsung UN55KS8000 | Denon AVR-X4500H | AppleTV 4K | DirecTV HR54 + 4K RVU | Samsung UBD-M8500
Samsung UN55HU8550 + SEK-4500/ZA | Samsung Soundbar HW-H550 | AppleTV 4K | DirecTV C41W | Samsung UBD-K8500
Samsung UN32EH4003 | AppleTV 4th Gen | DirecTV C41W
musicman0725 is offline
post #23924 of 24946 Old 07-30-2019, 04:41 PM
Pip
Pip's Avatar
Quoted: 312 Post(s)
Liked: 143
As of this afternoon my ATV was had no problem with HDR on Netflix or iTunes. Prime TV shows had HDR also. Couldn’t pay me to watch a movie on the Prime app. Can’t speak for any other source
Pip
musicman0725 likes this.
Pip is offline
post #23925 of 24946 Old 07-30-2019, 04:52 PM
Otto Pylot's Avatar
Liked: 2444
Cool. Hopefully it was as simple as enabling enhanced on the his Denon.
post #23926 of 24946 Old 07-30-2019, 05:01 PM
Quoted: 123 Post(s)
Liked: 50
hdr?
Just got home to test. The app says HDR but watching it the HDR badge does not show up on my TV. The picture looks really good though
Sent from my iPhone using Tapatalk Pro
lujan likes this.
My setup: Sony 65X900F w/ Sony UBP-X700, Tivo Bolt 4k, AppleTV 4k (64GB), Sony HT-Z9F soundbar w/ Sony SAZ9R rear wireless speakers. TCL 4K 43" S405 w/ Sony UBP-X800, Tivo Mini 4k and Sony HT-XT100 soundbar.
jtrippe is offline
post #23927 of 24946 Old 07-30-2019, 05:06 PM
Quoted: 74 Post(s)
Liked: 110
According to the article below the enhanced setting was added with the 2017 Denon AVRs for compatibility across all inputs. @Pip , try using a different input on the receiver:
https://denon-uk.custhelp.com/app/an...gh-not-working
In this article they say to only use HDMI 5, 6 or 7 (which is not necessary for my 2018 Denon since it has the Enhanced setting).
galonzo, beerhunt and RobKnapp like this.
post #23928 of 24946 Old 07-30-2019, 05:20 PM
rsonnens's Avatar
Quoted: 668 Post(s)
Liked: 505
Ok folks can we please move this to the Denon avr forum. He will get the best help there. (I have an ATV, Denon 4300 & LG and everything works fine.)
ynnek63 and iceman5664 like this.
rsonnens is offline
post #23929 of 24946 Old 07-30-2019, 05:21 PM
bobby94928's Avatar
Liked: 830
I see HDR using HDMI 1 to my Vizio P75-C1 on my X2300W which is older than his model.
Bobby
bobby94928 is offline
post #23930 of 24946 Old 07-30-2019, 05:49 PM
Quoted: 74 Post(s)
Liked: 110
Okay, your comment actually proves both the ATV and receiver should work with HDR. I would be happy to hear what the resolution is as many visit this thread and look for answers to similar problems with their equipment and ATV.
To move the topic along, in response to @healthnut , I haven’t had any issues with HDR on the ATV (on tvOS 12.4). Netflix, iTunes Movies, and Vudu have all been working well, however I don’t use Amazon very often. They seem to have a lot of issues reading this forum. Vudu / MA is a great way to watch Disney content in 4K HDR on the ATV. I had an issue recently where Atmos stopped working on all apps. Restarted / pulled the plug on everything. The fix was actually to just turn off Atmos on the ATV and turn it back on. Of course I did the simplest thing last and haven’t had the issue since.
galonzo likes this.
post #23931 of 24946 Old 07-30-2019, 05:50 PM
grimley141's Avatar
Quoted: 12 Post(s)
Originally Posted by grimley141 View Post
This issue is strictly limited to HDR/DV iTunes content. It occurs continuously and most noticeably in the TV app after the 12.3 update. Match frame rate on or off has no effect on this particular bug, unfortunately.
With the latest update to tvOS 12.4 last week thus bug appears to have been resolved. Can anyone else confirm that this issue is no longer present on tvOS 12.4 public release?
grimley141 is offline
post #23932 of 24946 Old 07-30-2019, 05:52 PM
Pip
Pip's Avatar
Quoted: 312 Post(s)
Liked: 143
Thanks. I did try every HDMI input the Denon. Same results.
Pip
Pip is offline
post #23933 of 24946 Old 07-30-2019, 06:21 PM
Quoted: 74 Post(s)
Liked: 110
Pip
Another thing to try might be changing the TCL input setting from Auto to HDMI 2.0 (same as enhanced mode on the denon which apparently was added to later models).
https://support.tclusa.com/televisio...lay-in-4k-60hz
The denon article I previously posted mentioned disabling video conversion. Also worth a shot. Good luck!
galonzo likes this.
post #23934 of 24946 Old 07-30-2019, 06:54 PM
healthnut's Avatar
Quoted: 959 Post(s)
Liked: 957
Thanks for your input. I’m considering buying one of these, but want to make sure it’s going to work properly.
post #23935 of 24946 Old 07-30-2019, 07:41 PM
radamo's Avatar
Quoted: 251 Post(s)
Liked: 71
Looking for help to determine where my issue is. I have a new Yamaha 3080 receiver and an Apple TV 4k hooked up to an LG C9. My speaker config is 5.1.4 and I am really struggling getting Atmos from ATV with either the Amazon Prime or Netflix apps. Vudu seems to not have an issue. I did some searches and not sure I found anything worthwhile. Any suggestions?
LG OLED65C9, Yamaha RX-A3080, Paradigm Reference Studio 80 Mains, Atmos 5.1.4 config, Panasonic UB820, PS4 Pro, Apple TV 4K
radamo is offline
post #23936 of 24946 Old 07-30-2019, 07:50 PM
Quoted: 74 Post(s)
Liked: 110
No problem, the ATV is a great streaming device. Apple updates the firmware and adds new features periodically. There are many apps in the App Store and they are actively maintained by developers. If you get one be sure to switch the video settings to 4K SDR (4:4:4) and enable match range and frame rate.
post #23937 of 24946 Old 07-30-2019, 08:17 PM
Quoted: 1659 Post(s)
Liked: 947
Both of those apps are having issues right now. I’m confident Netflix correct it. Not so sure about Prime.
Mike
Sony XBR-65X930E | ATV4K-64GB & 32GB 5th Gen | Nvidia Shield TV Pro 2017 | Logitech Harmony Elite
m_snow is offline
post #23938 of 24946 Old 07-31-2019, 03:15 AM
radamo's Avatar
Quoted: 251 Post(s)
Liked: 71
Seems I didn't read that last page or two which pointed that out. Thanks for the follow up. I almost started ripping cables out. But I saw that Vudu was working so knew the connection was good. Guess I will just be "patient"... or my version of that.
m_snow likes this.
radamo is offline
post #23939 of 24946 Old 07-31-2019, 03:43 AM
healthnut's Avatar
Quoted: 959 Post(s)
Liked: 957
Thanks again. I recognize that all these streaming boxes have their issues, I’m hoping that Apple is the least problematical.
post #23940 of 24946 Old 07-31-2019, 05:45 AM
brooks5333's Avatar
I have had no problems since the update to tvOS 12.4. (I also upgraded the firmware on my Sony 75Z9D.)
brooks5333 is offline
apple 4k tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , Samsung
