Apple TV owners' thread. FAQ in first post - Page 992 - AVS Forum | Home Theater Discussions And Reviews
 33218Likes
post #29731 of 30451 Old 05-24-2020, 08:06 PM
solarrdadd's Avatar
Quoted: 477 Post(s)
Liked: 334
Originally Posted by PlanetAVS View Post
The ATV is capable of both Atmos and DV. What app are you using? The rest of your config looks compatible.
the app he is using doesn't support Atmos on any device.
eaayoung likes this.
TCL-65R615, 55P605 DV/HDR10 & 49S405 HDR10, Philips BDP7501, BPD7502 UHD Players
Oppo BDP-105D, 105, 93, Marantz AV7702MKII, NR1607. Xbox One S
Emotiva XSP-1, XPA5,UPA2, UPA200 & Mini X Amps, ATV4K 32gb
Speakers, Polk SDA-2, Monitor 10A & 5A, Axiom M80,
VP180, QS8, M2, QS4, ATMOS 7.1.4 & 5.1.2 NYGiants!
solarrdadd is online now
post #29732 of 30451 Old 05-24-2020, 08:37 PM
eaayoung's Avatar
Quoted: 361 Post(s)
Liked: 217
I only tried to get Atmos with ST Discovery and Picard via CBS All Access. It probably works for movies.
eaayoung is offline
post #29733 of 30451 Old 05-24-2020, 08:44 PM
PlanetAVS's Avatar
Quoted: 2487 Post(s)
Liked: 3731
As others mentioned, try a different app. Netflix/Vudu/Itunes
PlanetAVS is online now
post #29734 of 30451 Old 05-25-2020, 06:23 AM
nathan_h's Avatar
Quoted: 3053 Post(s)
Liked: 2132
Originally Posted by OldSenileGuy View Post
Can someone confirm for me that I've got my black levels set up correctly between my AppleTV 4K and my LG C8? I understand how a mismatch will result in the image being either lifted or crushed, but I also know that every manufacturer has a different name how they define full range vs limited range, and often times those names are counter-intuitive.
Anyway, I have my AppleTV set to RGB High and on my LG C8 the Black Level is set to Low. This seems correct to me, though when I was watching Star Wars last night it felt a bit crushed.
Fake EDIT: Unless I need to set the black level per-input for Dolby Vision and HDR?
Real EDIT: Ok so in Dolby Vision the Black Level on the TV is locked to Low. And in plain-HDR it can be changed, but I've left it set to Low. So that tells me the TV has to be set to Low. And if I change the Apple TV to RGB Low instead of high, everything gets crushed, so RGB High must be the correct AppleTV setting.
Did I work that out right?
RGB "high" on the ATV gives you the correct video levels. But using YUV is typically better than RGB unless you have a particular problem you are trying to solve.
KC-Technerd and galonzo like this.
My current setup.
Recommended podcasts: The Next Picture Show, the /filmcast, AV Rant.
nathan_h is offline
post #29735 of 30451 Old 05-25-2020, 11:16 AM
R8ders2K's Avatar
Quoted: 179 Post(s)
Liked: 164
Originally Posted by solarrdadd View Post
with Picard & Discovery via CBSAA (the standalone app) on ATV4K, you get 1080p DV/DD+ 5.1 only. I also have roku and it only gives 1080p/DD+ 5.1 at least that is my experience. that's been my experience.
I'll say one thing, the upscaling on my 940E really makes Picard's 1080p POP!
eaayoung and solarrdadd like this.
Sony XBR-75X940E
Onkyo TX-NR797
DIRECTV HS17 + C61K
Oppo UDP-203
TV 4K
R8ders2K is offline
post #29736 of 30451 Old 05-25-2020, 01:04 PM - Thread Starter
bodosom's Avatar
Quoted: 2511 Post(s)
Liked: 1985
Not quite. On the ATV RGB-235/CE/Video is called High. Unless you're using your display as a computer monitor it should be set to RGB-235/CE/Video which is often called RGB Low*. However nearly everyone should be using YCC (or Auto) to watch video content and however you set the default video format the ATV will send video using it's preferred format, which varies according to content range and resolution.
*There's a small bit of ambiguity here which is easily avoided by using the official names for quantization ranges.
galonzo likes this.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X4700H/LG C8
bodosom is online now
post #29737 of 30451 Old 05-25-2020, 11:06 PM
bmcleod's Avatar
Quoted: 302 Post(s)
Liked: 217
With a new tvOS and apparently a Netflix app update, I had hope the flying center channel might be fixed ... but no. 🙁 We’d heard good recommendations for “Extraction” and started it tonight, the center kept switching to my left surround, it bothered my wife so much she didn’t want to watch (the blood didn’t help). Hard to believe this is so hard to fix.
Spoiler!
bmcleod is offline
post #29738 of 30451 Old 05-26-2020, 04:05 AM
aka jfinnie
Quoted: 3361 Post(s)
Liked: 2609
Does it do it consistently in the same places in the movie?
galonzo likes this.
bobof is online now
post #29739 of 30451 Old 05-26-2020, 08:52 AM
bmcleod's Avatar
Quoted: 302 Post(s)
Liked: 217
To be honest I’ve heard about it so much since last summer that I figured I didn’t need to troubleshoot as it was widespread. I only started experiencing it in the last month when I upgraded my Netflix account to 4K and started getting 4K/Atmos mixes.
The conditions to produce are: Netflix, 4K/Atmos stream, Apple TV4K, my 7.2.2 system
The symptom is: Center channel info randomly jumps to the left surround speaker and back to center
I’ve heard with other systems that it jumps to different locations, like a height Speaker, there may be some height involved in mine, but I hear it from the left surround. I’ve also heard people say the ‘dialog’ jumps, which of course makes sense as center is mostly dialog, but I hear other center information (ambience, sound effects) jump as well. I’ve also heard speculation that certain configurations are more susceptible, or maybe that it doesn’t occur with some configurations. So maybe it happens with my 7.2.2 setup, but not with someone else’s 7.2.4 (I don’t remember the specific configs). I should also say I haven’t read about it as much lately, but it’s been reported here and elsewhere often, so some may be rolling their eyes.
I’ll just continue to report it to Netflix as that seems to be the source, but obviously the TV is involved (to be clear I don’t have this issue under any other condition). If I get a chance today I’ll watch the opening of Extraction and see if it always happens in the same place.
Edit: I know there are references to this issue earlier in this thread, but here are a couple external sources. The second link speculates that it happens when the bitrate drops too low. The main reason I held off getting Netflix 4K was the limited bandwidth of my ISP, but I’ve been using a hotspot to stream lately and getting over 25mbps which I hoped would be enough. If this turns out to be the cause, then I guess I’m wasting my money on NF4K.
https://www.avforums.com/threads/net...blems.2253575/
https://www.reddit.com/r/appletv/com...tflix_atv_app/
shoman94 and avtoronto like this.
Spoiler!
bmcleod is offline
post #29740 of 30451 Old 05-26-2020, 02:31 PM
blenky's Avatar
Quoted: 1038 Post(s)
Liked: 962
I've never noticed this. Are you able to give a couple of time codes so I can check? Cheers
Samsung UE55KS8000 | Pioneer SC-LX701 | Zidoo Z9S | Apple TV 4K | Nvidia Shield TV (2019) | Fire TV Stick 4K | Samsung UBD-K8500 UHD Player
blenky is offline
post #29741 of 30451 Old 05-26-2020, 04:30 PM
Dan Hitchman's Avatar
Quoted: 5048 Post(s)
Liked: 3057
This really seems to be a compatibility interaction with certain Dolby Atmos decoders and the Dolby MAT (PCM 2.0) repack the AppleTV performs on the Dolby Digital Plus stream from the streaming company's headend. If the audio stream's metadata is not translated correctly or has been corrupted then audio objects and channels will get thrown out of wack. This is especially fraught with the way Dolby Digital Plus lossy encoding is done to Dolby Atmos tracks, where the metadata is king. Dolby TrueHD lossless packed Atmos tracks on disc are encoded differently and are less "fragile."
If a fix is not at hand, I would sadly suggest using a different streaming device for Netflix; one that sends raw and untouched audio bitstreams via HDMI.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is offline
post #29742 of 30451 Old 05-26-2020, 04:51 PM
jeep05's Avatar
Quoted: 264 Post(s)
Liked: 260
I really wish either CBS or Apple would fix the audio cut-out issue with the CBS app on my ATV4K. Audio cuts out every couple seconds for a couple seconds. This is the only app that the problem occurs on. I do have All Access.
jeep05 is online now
post #29743 of 30451 Old 05-26-2020, 05:23 PM
solarrdadd's Avatar
Quoted: 477 Post(s)
Liked: 334
Is this something that has just started happening? I have this on my ATV4K and I’ve never had that issue. I haven’t used the app in about a month or so which is why I asked if this is a new issue. Did the audio issue happen on particular shows? What show(s) were you watching?
I’ll check it out in the next couple of days when I turn my ATV4K on again and I’ll report back.
post #29744 of 30451 Old 05-26-2020, 06:41 PM
bmcleod's Avatar
Quoted: 302 Post(s)
Liked: 217
I don’t like the idea of another streaming device (but would certainly welcome a bitstream option), I’ll have to evaluate my need for Netflix or Netflix 4K too. I’m also interested in the speculation linked in my second post, that bandwidth/bitrate may play a role, it would be interesting if others who’ve experienced this problem also have limited bandwidth. I would love if my local Redbox rented UHD as those are still the king of the best picture and sound.
Spoiler!
bmcleod is offline
post #29745 of 30451 Old 05-26-2020, 06:46 PM
lujan's Avatar
Quoted: 5223 Post(s)
Liked: 3240
This started several months ago. I haven’t used the ATV4K device for Netflix in a long time, especially if the title has Atmos audio.
lujan
697 Ultra HD
742 HD
4 SD
lujan is online now
post #29746 of 30451 Old 05-26-2020, 08:08 PM
naustin's Avatar
Quoted: 2024 Post(s)
Liked: 1371
What do you currently use for Netflix Atmos programming. Would an nVidia Shield proved Netflix DV and Atmos?
naustin is offline
post #29747 of 30451 Old 05-26-2020, 10:00 PM
bmcleod's Avatar
Quoted: 302 Post(s)
Liked: 217
Except the original comment was about CBSAA, not Netflix.
Spoiler!
bmcleod is offline
post #29748 of 30451 Old 05-26-2020, 10:03 PM
bmcleod's Avatar
Quoted: 302 Post(s)
Liked: 217
So it sounds like you had the Netflix Atmos / TV4K moving center problem? What kind of bandwidth do you have?
Spoiler!
bmcleod is offline
post #29749 of 30451 Old 05-26-2020, 11:07 PM
Liked: 3057
If it was bandwidth related then all your apps would have a problem with Atmos content and quite possibly your video stream would drop to a lower resolution and/or pixelate or you might even end up with buffering. I just don't think that is the cause.
lujan and galonzo like this.
post #29750 of 30451 Old 05-27-2020, 02:15 AM
lujan's Avatar
Liked: 3240
I hear the 2019 Shield has DV and Atmos on Netflix but my two Shields are 2017 models. I use the internal Netflix app on my LG C9 for DV and Atmos.
naustin likes this.
lujan
697 Ultra HD
742 HD
4 SD
lujan is online now
post #29751 of 30451 Old 05-27-2020, 02:17 AM
lujan's Avatar
Liked: 3240
I didn't realize it was also happening with CBS AA as well as Netflix? I don't have CBS AA so I haven't experienced it there, only Netflix.
lujan
697 Ultra HD
742 HD
4 SD
lujan is online now
post #29752 of 30451 Old 05-27-2020, 02:22 AM
pappaduke's Avatar
Quoted: 509 Post(s)
Liked: 516
I purchased a FireCube just for Netflix Atmos. Didn't really want a second streamer, but the problem doesn't seem to be getting any attention. I put in a ticket a several months ago with Netflix (after a couple of calls) and haven't heard from them since. Never bothered to address with Apple.
AFAIK it does not happen to everyone.
Man cave-Marantz 8012, Oppo 203, 4K ATV, FireCube 2, Sony XBR-75X940E, Bluesound Vault 2, Harmony One, 2 Paradigm Monitor 9's, CC-390, 2ADP 390's/190's, 2 PDR 100's,
4 SVS Prime elevations. B&W P5. Living room- Yamaha 2010, Bluesound Node 2, Paradigm SE-1's, Zone 2-Paradigm-Stylus 370-SM. B&W PX for travel
Bedroom- Samsung UN60ES7100F, Oppo 103D, Pulse Mini, JBL Bar Studio, ATV3 and Harmony 650
pappaduke is online now
post #29753 of 30451 Old 05-27-2020, 02:44 AM
lujan's Avatar
Liked: 3240
No, if you call Netflix or Apple about it, they will just think there is something wrong with your system so I don't bother. I think it will eventually happen to everyone, they just haven't noticed it yet. You may also need to have a certain Atmos speaker setup for it to occur?
lujan
697 Ultra HD
742 HD
4 SD
lujan is online now
post #29754 of 30451 Old 05-27-2020, 03:05 AM
bmcleod's Avatar
Quoted: 302 Post(s)
Liked: 217
It sounds like a different problem, I’ve not experienced it, my CBS has been pretty good, especially lately.
Spoiler!
bmcleod is offline
post #29755 of 30451 Old 05-27-2020, 03:10 AM
bmcleod's Avatar
Quoted: 302 Post(s)
Liked: 217
I do get pixelation and buffering with Netflix, more so it seems than other platforms, but it’s not necessarily at the same time I have the center jump.
Spoiler!
bmcleod is offline
post #29756 of 30451 Old 05-27-2020, 05:54 AM
met_fan's Avatar
Quoted: 147 Post(s)
Liked: 83
No 4K or HDR yet for HBO Max, but at least it sounds like it's providing improved streaming quality compared to it's HBO Go and Now apps. Not sure how it compares with the Apple Channels version of HBO.
musicman0725 likes this.
met_fan is offline
post #29757 of 30451 Old 05-27-2020, 05:57 AM
dianebrat's Avatar
Quoted: 412 Post(s)
Liked: 424
I'm now in month 2 of my free CBSAA trial and have been heavily binging, starting with Picard and now on Discovery and I have never experienced the issue you're describing, so there's that data point.
ATV4K > Marantz SR7011> LG E6.
DougDingle and galonzo like this.
dianebrat is offline
post #29758 of 30451 Old 05-27-2020, 06:24 AM
ggrossen's Avatar
Quoted: 255 Post(s)
Liked: 185
I sometimes have the centre channel move to the left speaker when watching ATV+ Trying. Happens for a few seconds and then all ok. For me this seems to be once per episode. But that is it never noticed on Netflix. Only watching Trying as set in Camden Town where I used to live for a long time - george
galonzo likes this.
LG C9 | Lyngdorf MP50 (eARC)| NAD M25 | Nord One NC500DM MKII 3 Channel Monitor Audio | Platinum PL100 II | Monitor Audio Platinum PLC150 II | 6 Monitor Gold GXFX | JL Audio F212v2 | Virgin v6 | Pioneer LX 500 4k Blu-Ray | Apple TV 4k | Linn Sondek LP12
ggrossen is offline
post #29759 of 30451 Old 05-27-2020, 06:33 AM
gossamer88's Avatar
Quoted: 376 Post(s)
Liked: 282
Supposedley on the roamap...that could be next year for al we know!
LG OLED 65C7P • Apple TV 4K • Roku Ultra 2018 • Oppo BDP-103 Blu-ray • LG UP970 UHD BD
Denon X3400H AVR • Paradigm Cinema 110 CT Speaker System • SVS SB-1000
gossamer88 is offline
post #29760 of 30451 Old 05-27-2020, 06:35 AM
Quoted: 106 Post(s)
Liked: 93
So content that is already in HDR, such as Doom Patrol, you will have to pay for DC Universe to get it in HDR.
Frank Monroe is online now
apple 4k tv , apple tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , Samsung
