Popcorn hour c200 or a210? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 56 Old 12-14-2010, 10:45 AM
NewPannyGuy's Avatar
Originally Posted by talman View Post
Agreed. A modified A200 will play back full menus without fail. The one thing that will not work is an internal drive--thereby loosing NMT apps etc. And I believe you can restore to a A200 firmware.
I've been looking for a PCH C200 like player with full BD playback support but smaller (without the internal BD drive). If the A210 can be flashed with the C200 fw, it might just fit the bill. However, what is this issue about it not supporting internal hard drive? Doesn't C200 support it? Will be doing a little more research about this fw swap.
NewPannyGuy is offline
post #32 of 56 Old 12-14-2010, 01:55 PM
pmcd's Avatar
Quoted: 13 Post(s)
What is wrong with the C200? Neither unit is really portable. Flashing the A210 just to imitate a C200 seems risky and a pain.
Philip
pmcd is offline
post #33 of 56 Old 12-14-2010, 02:39 PM
Philip
The only problem is that I've run out of space in my cabinet and that's why I wanted something smaller which would fit. Plus I don't really need the internal bluray drive (if an external usb one works that would be great).
Btw, does anyone know if the C200 (or the A210) support a source direct option to avoid any kind of upscaling/deinterlacing (I'll be connecting it to an external video processor).
post #34 of 56 Old 12-14-2010, 04:02 PM
UHD Addict
aaronwt's Avatar
Quoted: 8984 Post(s)
Liked: 5759
No it doesn't. but you can have it set to output 1080P24 when playing that content.
I have mine set for 1080P60 and then it switches to 1080P24 for 1080p24 Bd titles.
53TB unRAID1a--53TB unRAID2--73TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #35 of 56 Old 12-18-2010, 08:50 AM
CDLehner's Avatar
Quoted: 1049 Post(s)
Liked: 1942
So...I've only been casually following the A-210. Are they just pushing the release a week at a time?
CD
All The Music In The World > Auralic Aries Mini > Musical Fidelity M2si > Dynaudio EMIT M10s
CDLehner is offline
post #36 of 56 Old 12-18-2010, 06:49 PM
sugatam's Avatar
Does the C200 support bluray forced subs now? The firmware I'm on now (May) doesn't, and I can't upgrade because they broke DD5.1 core extraction from TrueHD tracks sometime back, and aren't fixing it.
sugatam is offline
post #37 of 56 Old 12-18-2010, 10:49 PM
pmcd's Avatar
Quoted: 13 Post(s)
CD
They had them at the place I normally buy media players. Sold out and the next arrival will be in 10 days. I guess they are dealing with selling of the A200, introducing the A210 and getting ready for whatever new chips will come out next year. The A210 is a very nice media player.
philip
pmcd is offline
post #38 of 56 Old 12-19-2010, 01:29 AM
oceanjumper's Avatar
@philip: I had this posted in another thread:
Originally Posted by oceanjumper View Post
Should be getting my A210 in the next week or so. Currently I am transferring my 1 TB movie collection to my new drobo fs (which, btw, is taking forever!!). In the meantime I am reading up on what jukebox to use and how to prepare for it. I learn that renaming the movie files in a certain format is the first thing to do (several renamer tools are available). However, where I get stuck in my understanding is how to use NMJ. I also hear Oversight is a nicer jukebox but it is unclear if Oversight *uses* NMJ -so i'll need both- or that it *replaces* NMJ... Any reco's?
Could you clarify?
oceanjumper is offline
post #39 of 56 Old 12-19-2010, 02:15 AM
pmcd's Avatar
Quoted: 13 Post(s)
Could you clarify?
NMJ is built in to the A210. You have a choice of using it or the list interface ( the old one). Oversight is an alternative interface that runs on the A210. You have to install it. It does not require NMJ. You can use either or both. The very nice thing about Oversight is it has great scraping capability, does not require a computer and is simple. I installed mine from a Mac because I have both on the same TV. I used NMT Community Software Installer to install it. This will also work from a PC. Once installed you can either connect to the A210 from a browser and set up Oversight there or do it from the A210 without the computer. You basically tell it where your files are and so on...
Hope that help,
philip
pmcd is offline
post #40 of 56 Old 12-19-2010, 02:17 AM
Very clear. Thanks!
post #41 of 56 Old 12-21-2010, 02:45 PM
I just added an internal hard (a Seagte Barracuda LP 2TB - straight out of the box) disk but the A-210 doesn't see it... The Installation guide mentions the "SATA/power cable" (step 8), but seriously, where the heck is that cable?? Doesn't the drive slide into the internal connectors?
Any ideas?
post #42 of 56 Old 12-21-2010, 03:00 PM
pmcd's Avatar
Quoted: 13 Post(s)
Any ideas?
Does the drive spin up? It should be the usual sata connectors. Usually two things- data connector and power cable. Try formatting the drive first if all else fails. On my c200 it just worked. There is the business that you used to need NMT apps, I think, installed in order to prepare the drive.
Philip
pmcd is offline
post #43 of 56 Old 12-21-2010, 06:32 PM
I'm reading up on networkedmediatanked .com where people keep mentioning a NMT Setup Wizard Menu. I only received my A-210 yesterday and immediately upgraded the firmware. However, I sure don't have this wizard. What gives?
SETUP -> Maintenance -> NMT Setup Wizard menu
I found this link:
http://www.networkedmediatank.com/sh....php?tid=39738
What a PITA
post #44 of 56 Old 12-22-2010, 04:40 AM
For those reading this who had run into the same issue as I did, indeed, creating a partition table and formatting the new drive made it work. Once the the internal hard disk was recognized, also the NMT Setup Wizard showed up under 'Settings'>'Maintenance'
Here are very clear instructions on how to initialize (msdos partition) and format (I used ext3) a new 2 TB drive:
http://www.networkedmediatank.com/sh....php?tid=26629
post #45 of 56 Old 12-22-2010, 02:12 PM
pmcd's Avatar
Quoted: 13 Post(s)
Notice that you can install the NMT apps on a USB flash drive and then format your 2TB as ntfs for what it's worth. I don't know if you can have the NMT apps on an ntfs drive.
Have you used it yet?
Philip
pmcd is offline
post #46 of 56 Old 12-22-2010, 02:49 PM
Philip
Oh yes. It's been great. I can't decide if I will install a jukebox of some kind or just stick to the file structure. The jukebox that came with it only downloaded small pictures for album art. It looked like crap... I guess I can redo all the artwork myself but that seems quite a large job (finding files, naming them correctly etc etc). I was looking into Oversight, and it does look better, but I haven't gotten to installing it yet
post #47 of 56 Old 12-22-2010, 02:52 PM
Btw... has anyone tried installing the C200 firmware on the A-210? I saw a Youtube clip of someone who had it on the A-200. The full BD menu does look great to have...
post #48 of 56 Old 12-22-2010, 03:08 PM
pmcd's Avatar
Quoted: 13 Post(s)
I would be very careful with that. There is a warranty issue and also, you would want to make sure you could revert back. Whenever PCH releases firmware it is never simultaneous for both the C200 and the A210/200.
Of course since I have my c200 fixed at 720p I don't appreciate the appeal of those menus in full HD
Philip
pmcd is offline
post #49 of 56 Old 03-01-2011, 08:00 AM
Elderan's Avatar
So does the A210 have any advantage over the C200, besides it being smaller and not having a fan?
If you were going to pick one, A210 or C200 right now and money not being a factor which one would you choose?
Elderan is offline
post #50 of 56 Old 03-01-2011, 08:10 AM
Linda's Avatar
I chose the A-210, largely for two reasons. I didn't need Bluray menu support since I rip to mkv and I wanted IR support without having to get an extra IR dongle.
However, my A-210 order is now delayed until the 24th so I may have to rethink my choices...
Linda is offline
post #51 of 56 Old 03-02-2011, 11:24 AM
Nazo's Avatar
Does anyone know how much capacity is on the sata drive that Popcorn hour had on their site that you can add with the c200?
Nazo is offline
post #52 of 56 Old 09-15-2011, 01:30 PM
SoundForSound's Avatar
BTW - according to a few other recent posts, the PCH A-210 now supports Bluray .iso files with Menus just as the C200 did.
SoundForSound is offline
post #53 of 56 Old 09-27-2011, 12:44 PM
Don Landis's Avatar
Quoted: 1465 Post(s)
Liked: 429
New owner here with an A210 and 2TB internal drive. I wish someone would explain how they get those menus and extra features on the A210. All I get is the main movie.
My 3D and 360VR videos and more
Don Landis HT System: Projector Sony VPL VW665ES Players: Samsung UBD K8500 OPPO BD93 Sony BDP S6200 All Regions Player Denon AVR S940, 7.1 JBL Professional series and Klipsch PS3, XBOX360, Dish VIP722K; 3D Edit Suite:Adobe Premiere, Edius7.53, Vegas Pro v13, Power Director16, i9-7980XE/GTX1080Ti, LG 3D TV DM2752
Don Landis is offline
post #54 of 56 Old 09-27-2011, 01:42 PM
dbone1026's Avatar
Quoted: 407 Post(s)
Liked: 205
In the settings is there an option for BD playback that is set to BD Lite?
Cheers
dbone1026 is offline
post #55 of 56 Old 09-28-2011, 12:38 AM
Don Landis's Avatar
Liked: 429
I hadn't even looked in that settings selection. The actual selection was defaulted to " Simple File View" not "BD lite". but I got your clue and discovered there are several selections I should experiment with but selection of "full navigation" gave me full look and feel of playing a disk in a BD set player. This is what I wanted! Thank you very much!
post #56 of 56 Old 02-09-2014, 12:45 AM
johnno08's Avatar
good morning to all
I have just joined this site so far very impressed ...
I cannot find a section that related to my issue ......
I have a C-200 and have some mkv files in 3d   I noticed the other day  that I get a line down the right hand side of the screen  I say line it is part of the picture   that should be on the left hand side   hope that makes sense ....  if I play files through pc no problems    I think I have altered a setting somewhere  but for the life of me  don't know what...
can anyone help
 sorry if this is in the wrong  section but looked and cannot find a suitable section
thanks in advance
johnno
johnno08 is offline
Popcorn Hour C 200 Networked Media Tank Black
