*Official* WD TV Live Streaming Media Player Thread - Page 210 - AVS Forum | Home Theater Discussions And Reviews
 102Likes
post #6271 of 6285 Old 09-25-2018, 04:43 PM
Briguy65's Avatar
Quoted: 106 Post(s)
Liked: 67
Originally Posted by Otter0911 View Post
Windows 10 disable SMB 1 File Sharing which the WDs use...
How to re-enable the SMBv1 protocol on Windows 10
  • Open Control Panel.
  • Click on Programs.
  • Click on Turn Windows features on or off link.
  • Expand the SMB 1.0/CIFS File Sharing Support option.
  • Check the SMB 1.0/CIFS Client option.
  • Click the OK button.
  • Click the Restart now button.
That may help with my annoying network at work where I have computers with windows XP, windows 7 and windows 10. It's annoying but ironically the windows XP computer seems to be able to find the windows 10 computer, which is what I want. Whereas trying to find computers with windows 7 is a pain in the butt, and the head, LOL. Massive headache that day.
Otter0911 likes this.
Briguy65 is offline
post #6272 of 6285 Old 09-29-2018, 07:42 AM
de8212's Avatar
Quoted: 328 Post(s)
Liked: 24
thanks. Didn't help with either of my WD's.
de8212 is offline
post #6273 of 6285 Old 01-05-2019, 08:18 PM
guiri's Avatar
Quoted: 33 Post(s)
Guys, lately, I've had a few movies that DO have subtitles but I can't get them to work with my WD TV Live.
They play fine in VLC on my computer but not on the WD TV.
Any suggestions?
I can check the exact model if it makes a difference but this is what I think I have.
WDBAAP0000NBK
George
guiri is offline
post #6274 of 6285 Old 01-06-2019, 04:33 AM
spyrakos81's Avatar
Liked: 0
Any suggestions?
WDBAAP0000NBK
George
Hello my friend. Are you accessing your files locally or through network? If you are watching the movies from a networked source, you should create samba shares and don't use the media server option. I hope this helps.
Sent from my ONEPLUS A5010 using Tapatalk
spyrakos81 is offline
post #6275 of 6285 Old 01-06-2019, 12:22 PM
guiri's Avatar
Quoted: 33 Post(s)
It's hooked up to my router and so is the computer the movies are on so yes. I don't use the media server option when viewing things.
Just the network, find the movie and then play.
The thing is, this is normally not an issue. If VLC can see it, WD TV usually can too.
George
guiri is offline
post #6276 of 6285 Old 01-06-2019, 01:34 PM
cc_in_oh's Avatar
Quoted: 1098 Post(s)
Liked: 675
George
How was the movie file created? Do other movie files created the same way still work?
CC
Who knew "flammable" and "inflammable" mean the same thing???
cc_in_oh is online now
post #6277 of 6285 Old 01-06-2019, 04:49 PM
guiri's Avatar
Quoted: 33 Post(s)
Sorry, I really don't know as I downloaded it. I guess I could get some software to extract that info but I was really hoping for some
simple reply (although not holding my breath
I think more than anything, I was trying to understand why vlc would see the subs but not wd.
They are not in a separate file by the way although occasionally, I've had issues with separate files too.
guiri is offline
post #6278 of 6285 Old 07-05-2019, 06:18 AM
cc_in_oh's Avatar
Liked: 675
My SMP seems to be starting to fail, often requiring a replug to get it to boot. Are any of the $50-ish no-name android 9 boxes suitable replacements for playing local mkv & mp4 content?
Thanks...
CC
post #6279 of 6285 Old 07-05-2019, 09:35 AM
nirvana_av's Avatar
Last year I built a player using the Odroid C2 platform. I'm running the LibreELEC KODI software on it. It will play 1080p MKVs perfectly. Supposedly, this platform can also play 4K content, but I don't have a 4K setup to verify this. One odd thing is that it there's a slight stutter when playing 480p content. There are widespread complaints about this, but no fix has been made.
EDIT: Oh, one more thing, it passes Dolby TrueHD and DTS-MA.
nirvana_av is online now
post #6280 of 6285 Old 07-05-2019, 09:59 PM
Kelson's Avatar
Quoted: 2286 Post(s)
Liked: 1417
Before you toss the Live SMP, replace the power wart. I'm still using both my SMP's and they are running perfectly -- I haven't found anything better for playing BD & DVD rips. Whenever one of my SMP's started to act up and glitch, I replaced the power supply and once again all was well. You can get one on Amazon pretty cheaply. Make sure it has decent amperage in addition to the proper voltage. No harm in getting a higher amperage than the wart you are replacing. Apparently the chinese power warts only last a couple of years.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #6281 of 6285 Old 07-06-2019, 05:11 AM
cc_in_oh's Avatar
Liked: 675
Thanks - I'll try that. It goes through the first stage with the moon, then blanks out as usual but the second screen without the moon doesn't start. Happens maybe one out of 10 boots. Sometimes a 2nd try with the power button gets it going, sometimes it takes a replug. Never any problems once it's up.
If I keep it I'll be needing a new remote too - the OK button is pretty well shot after 10 years of everyday use...
CC
post #6282 of 6285 Old 07-06-2019, 01:40 PM
Kelson's Avatar
Liked: 1417
I use a Harmony with mine. The Live SMP is in their data base. Otherwise get a learning remote and teach it the SMP codes before the old remote completely craps out.
- kelson h
Kelson is offline
post #6283 of 6285 Old 07-11-2019, 09:24 AM
jdougmc's Avatar
Well it's not $50-ish, but I've switched to the Nvidia Shield. Does pretty much everything the WD Live can do, plus plays 4K content.
J Doug
jdougmc is offline
post #6284 of 6285 Old 07-11-2019, 10:04 AM
Johnny14o's Avatar
Quoted: 119 Post(s)
Liked: 29
I'm with you on this one. I also have the nVidia Shield TV (3 of them) as we as a couple of the $50 MiBox. The Shield is the way to go. The MiBox is too sluggish moving between applications, accessing media, etc..
FYI I went from the WD boxes to the Shield... ALL my frustrations went away.
Sent from my SM-G965U using Tapatalk
Johnny14o is offline
post #6285 of 6285 Old 11-28-2019, 07:25 PM
zaphod7501's Avatar
Quoted: 106 Post(s)
Liked: 87
Thanks...
It's not $50 but current sale price is pretty good and the Fire TV Cube with VLC installed will play from network shares on a connected PC. I can't comment on the other Fire TV devices.
Sturgeon's Law: "Nothing is always absolutely so."
Sturgeons Revelation: "Ninety percent of everything is crud."
My Thoughts: "A reasoned argument must share some basic common points."
zaphod7501 is offline
Western Digital Wd Tv Live Streaming Media Player Wifi , Western Digital Wd Tv Live Streaming Media Player
