Bluesound Audio Streamer - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 101Likes
post #451 of 459 Old 02-13-2020, 08:01 AM
EmilG's Avatar
FWIW,
I have a Denon X4500H and Node2i.
They're connected all three ways, analog and both digital.
Honestly I can't tell the difference.
I use the analog to take advantage of the Node2i DAC and don't worry if I'm missing something.
Panasonic VT30
Denon x4500H
Bluesound Node2i
Klipsch 7.2.2
EmilG is offline
post #452 of 459 Old 02-13-2020, 12:59 PM
pacman9270's Avatar
Quoted: 109 Post(s)
Liked: 72
I did the same as EmilG. I performed a side-by-side comparison and there wasn't a significant difference, if any between going digital or analog from my Node 2i.
Theater Setup: 5.2.5 (10.1 Auro3D) / ~3100 cu.ft. / Vaulted Ceiling
Projector:JVC DLA-X570R Screen:SI Performance Series 16:9 100" Source Player:Oppo BDP-103D/UDP-203 Pre/Pro:Marantz AV8802A Amps:Emotiva XPA-5(Fronts/Surrounds) and BasX A500(Heights) Fronts/Surrounds:Sonus Faber Venere 2.0 Center:Sonus Faber Venere Center Front/Rear Heights:Definitive Technology PM1000 / ProCenter1000(VOG) Subwoofer:Dual SVS SB-2000 Speaker Wire:Monoprice CL2 12-AWG w/Bananas ICs:BlueJeanCables/Mediabridge
pacman9270 is offline
post #453 of 459 Old 02-13-2020, 02:03 PM
laserjock II's Avatar
Quoted: 1348 Post(s)
Liked: 761
Originally Posted by EmilG View Post
FWIW,
If you’re not using Pure Direct then you’re using a dual conversion ADC-> DAC ?
laserjock II is offline
post #454 of 459 Old 02-13-2020, 04:53 PM
EmilG's Avatar
Ya know, that's a very good point!
I'm not going direct so there is some digital processing going on in the front end which requires an Analog to Digital conversion, then a conversion back for the amplifier stage.
Going from the Node2i to the receiver digitally eliminates the Dac -> Adc -> Dac conversion! Great catch!
Now it will be Digital all the way to the Dac before the amplifier stage preserving the integrity of the signal digitally.
I'll be using the digital coax connection.
Thanks again!
Panasonic VT30
Denon x4500H
Bluesound Node2i
Klipsch 7.2.2
EmilG is offline
post #455 of 459 Old 02-14-2020, 12:47 AM
pappaduke's Avatar
Quoted: 477 Post(s)
Liked: 466
The analog connection will give you full MQA if one is interested in Tidal.
Man cave-Marantz 8012, Oppo 203, 4K ATV, Sony XBR-75X940E, Bluesound Vault 2, Harmony One, 2 Paradigm Monitor 9's, CC-390, 2ADP 390's/190's, 2 PDR 100's,
4 SVS Prime elevations. B&W P5. Living room- Yamaha 2010, Bluesound Node 2, Paradigm SE-1's, Zone 2-Paradigm-Stylus 370-SM. B&W PX for travel
Bedroom- Samsung UN60ES7100F, Oppo 103D, Pulse Mini, JBL Bar Studio, ATV3 and Harmony 650
pappaduke is offline
post #456 of 459 Old 02-14-2020, 03:56 AM
KenM10759's Avatar
Quoted: 3571 Post(s)
Liked: 2019
Yup, and if then pushed through a Denon or Marantz in their "Pure Direct" modes there's no further A-D conversion, only the analog amplification.
This is how one can test the same title in MQA and non-MQA most directly.
pappaduke likes this.
KEF R500, R200C, R100, R50, SVS SB2000 sub, NAD T758v3 AVR, LG UP875 4K BlueRay, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer. Office: NAD M10, KEF LS50, KEF Kube 10b, Pro-Ject RPM1 TT w/ Ortofon 2M Red.
KenM10759 is offline
post #457 of 459 Old 02-17-2020, 04:57 AM
Liked: 0
Originally Posted by Gus141 View Post
Anyone know if you can force a refresh in the iOS Bluesound app for things like the contents of a playlist?
I’m matching some playlists between TIDAL and Qobuz (don’t want to use Soundiiz) and when I add songs to a playlists in a service’s app but then want to play it through the Bluesound Node 2i, the BluOS app doesn’t show the newly added songs for a while. I have to navigate around the app for a while then come back to that playlist and *maybe* it’s updated. Force-quiting the app and then relaunching it doesn’t always speed things up either. Is there some CMD+R refresh equivalent?
Cheers
Gus
Why don't you want to use Soundiiz? Are you looking for an alternate. You may use MusConv Tool
Ethan Marcos is offline
post #458 of 459 Old 02-17-2020, 08:01 PM
Liked: 761
Good if you want a two channel experience and have full range speakers.
The Revels really sing.
post #459 of 459 Old 02-22-2020, 12:51 PM
Steelman99's Avatar
Quoted: 257 Post(s)
Liked: 90
So i noticed this new remote available for the Bluesound...https://www.bluesound.com/products/rc1-remote-control/
Is there a Harmony update for it?
Samsung QN55Q8FN / Pioneer Elite SC-81 AV Receiver/ ELAC Uni-Fi B5 Book Shelves/ SVS PB-1000 Subwoofer/ Nvidea Shield Pro / iFi SPDIF iPurifier/ MiniDSP 2x4 HD
Steelman99 is offline
