HD Dune 3,0 Base and MKV not working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-22-2014, 07:48 PM - Thread Starter
sac130e's Avatar
Have my current collection as BD iso files, but converted some to mkv using makemkv.
The when tried to play thru the Dune, it just sits on a blank screen, says its playing but nothing.
I jumped to a chapter in the movie, and the picture, when it loads, is just still and hardly moves at all.
What is wrong with the situation. Have heard others not having any problems with mkv.
Is there a certain way to do this, or are there known issues with Dune and mkv format.
Thx
sac130e is offline
post #2 of 7 Old 11-23-2014, 07:08 PM
robnix's Avatar
Quoted: 1021 Post(s)
Liked: 767
Thx
I've ripped all my Blurays to MKV with MakeMKV. My Dune Base 3D plays them back just fine.
Looky here!
robnix is offline
post #3 of 7 Old 11-25-2014, 01:01 PM - Thread Starter
sac130e's Avatar
Tried ripping a few more to mkv, still not playing thru the Dune player (hardly moves at all), but plays fine on VLC or in Plex itself.
Just not wanting to convert all 400 movies to mkv - delete the iso - and never be able to play thru Dune again. can't save both since I will run out of server space quickly.
maybe a different firmware on the Dune would help, using the current beta version.
Thx
sac130e is offline
post #4 of 7 Old 11-26-2014, 07:57 AM
the_abbot's Avatar
Quoted: 233 Post(s)
Liked: 39
Thx
It's gotta have something to do with the way you're doing the rip. What bitrate are you using?
the_abbot is offline
post #5 of 7 Old 11-26-2014, 09:42 AM - Thread Starter
sac130e's Avatar
Using whatever MakeMKV gives me. Just looked at it again, and there are no setting to change or even see what the bitrate is with this free beta software. May have to look into the DVDFab version, since I have to pay for it, it should let me set a bitrate.
Scott
sac130e is offline
post #6 of 7 Old 11-26-2014, 10:46 AM
bluewhale1's Avatar
Quoted: 507 Post(s)
Liked: 230
Scott
Which movies have you tried(dvd /blu ray)? I haven't had any problems with mkvs and my Dune Base. If you are using Makemkv the bitrate should be whatever the movie is(should make a 1:1 copy just put in the mkv container). If you change the bitrate arent you then re-encoding and not make a 1:1 copy?
bluewhale1 is offline
post #7 of 7 Old 11-26-2014, 11:41 AM - Thread Starter
sac130e's Avatar
I originally used DVDFab to make 1:1 copies of all my BD (just the movie/HD audio/subs), and they all play fine on everything I have.
So whatever the bitrate was then, is same for MKV I guess. I will try some others and see if I can better results before moving to DVDFab ripper.
Scott
sac130e is offline
