*OFFICIAL*POPCORN HOUR VTEN:The World First 4K Ultra HD network media player - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 168Likes
post #421 of 1018 Old 11-01-2015, 08:07 AM
UHD Addict
aaronwt's Avatar
Quoted: 9731 Post(s)
Liked: 6417
Originally Posted by neodante View Post
Sorry for the double post...
Any guide for how enclosure a hard drive and connect to vten ?
??? Just connect an external drive to the USB or eSata port. Although I have never tried my eSata connection. But I have at least half a dozen enclosures I could try it out. But I prefer to use network storage with my VTEN. Although I do have a 32GB SD card installed for local storage of some small test files.
neodante likes this.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #422 of 1018 Old 11-01-2015, 02:52 PM
leiff's Avatar
Quoted: 150 Post(s)
Liked: 26
Only one week after beta1 released beta ver2 is now out:
http://www.networkedmediatank.com/sh....php?tid=72879
leiff is offline
post #423 of 1018 Old 11-02-2015, 08:24 AM
Dhalmo's Avatar
Quoted: 218 Post(s)
Liked: 130
I don't know if everyone saw, but Cloud Media just released their dual-boot 4K Popcorn Hour A-500 Pro. The specs are shaping it up to be a beast for both audio and videophiles. Just started a new thread on it if anyone is interested in continuing the discussion.
aaronwt likes this.
Dhalmo is offline
post #424 of 1018 Old 11-03-2015, 08:15 AM
ivorygate's Avatar
Quoted: 25 Post(s)
One thing I don't like about players that don't allow for an internal drive is that external drives usually have those stupid blinking LEDs with I/O activity. However, I can't justify spending that much for the A-500 Pro to replace my ancient, but still working A-110. I'm also still confused about the whole VTEN-U deal, which doesn't appear to get all of the firmware updates that the non -U model gets? I'm also curious if anyone can distill down to why exactly the VTEN would be a better choice than the Roku 4 in terms of the ability to playback video (h.264/h.265) files with DTS audio (not stream from Netflix and the like which I have a smart TV to do that)... or is the Roku 4 a better choice at this point?
ivorygate is offline
post #425 of 1018 Old 11-03-2015, 08:22 AM
Ph8te's Avatar
Quoted: 6765 Post(s)
Liked: 6637
Well 1 the VTEN supports a more robust listing of files than the R4. The VTEN also supports lossless audio (TrueHD, DTSMAHD, Atmos, etc). The R4 does NOT support [email protected] either.
The only difference that I know of between the VTENU and the VTEN is that the NA market version will not downmix DD and the U/EU version will.
Sent from nowhere
Ph8te is offline
post #426 of 1018 Old 11-03-2015, 08:49 AM
SMHarman's Avatar
Quoted: 419 Post(s)
Liked: 140
Roku has a very specific set of codecs. Roku4 with not play h.264 UHD. It only goes to 1080. After that you need h.265.
Additionally there a're bandwidth constraints.
Popcorn has a far wider set of codec.
Oh and black sharpie or duct tape that HDD light.
SMHarman is offline
post #427 of 1018 Old 11-03-2015, 08:54 AM
UHD Addict
aaronwt's Avatar
Liked: 6417
Or get some LightDims.
http://www.lightdims.com/
I use them on dozens of LEDs to either reduce the light output or eliminate it. You can get the LightDims to block 100% of the light or block 50% to 80% of the light.
robnix, christoofar and neodante like this.
aaronwt is offline
post #428 of 1018 Old 11-03-2015, 09:26 AM
ivorygate's Avatar
Quoted: 25 Post(s)
Huh, what will they think of next. Thanks!
post #429 of 1018 Old 11-03-2015, 09:39 AM
ivorygate's Avatar
Quoted: 25 Post(s)
Thanks. I always assume the PH units with the Sigma chips are overall more capable, but then I have friends who have always gone with the WD Live or Roku 3 and they never seem to complain about not being able to play anything.
post #430 of 1018 Old 11-03-2015, 10:24 AM
captainbrent's Avatar
Quoted: 440 Post(s)
Liked: 507
Interesting!
I was thinking the same thing!
captainbrent is offline
post #431 of 1018 Old 11-03-2015, 11:04 AM
halfelite's Avatar
Quoted: 650 Post(s)
Liked: 332
WD live was sigma based. Was usually a generation behind what the current offerings from DUNE or PH were. As for the ROKU 3 anyone running one for content that they have local usually run something like plex. They let plex transcode on the fly to a format that the roku can play. It works well enough for most people but then you miss out on things like TRUEHD/DTSHD and some of the higher bitrate content as you need a beefy computer to transcode a 1:1 bluray on the fly.
halfelite is offline
post #432 of 1018 Old 11-03-2015, 12:51 PM
neodante's Avatar
Quoted: 21 Post(s)
Liked: 4
How I can update the firmware beta version ? I downloaded the las beta version and put on usb flash drive on zip and unzip versions but don't know how update ?
neodante is offline
post #433 of 1018 Old 11-03-2015, 02:44 PM
halfelite's Avatar
Quoted: 650 Post(s)
Liked: 332
click into settings the maintenance and update firmware
post #434 of 1018 Old 11-03-2015, 05:05 PM
elove's Avatar
Quoted: 98 Post(s)
I tried to update firmware via USB. I unzipped the file and placed it on the usb; however, the file does not show up on the USB drive.
What am I doing wrong? Help!
Edit: Never mind i see halflites post above!
elove is offline
post #435 of 1018 Old 11-03-2015, 05:17 PM
elove's Avatar
Quoted: 98 Post(s)
I am having trouble opening some JPG files. Not sure why! Some open some don't!
The error message says "could not open"
Any ideas!
elove is offline
post #436 of 1018 Old 11-04-2015, 05:13 AM
neodante's Avatar
Quoted: 21 Post(s)
Liked: 4
I didn't to do also...the problem was that the usb flash drive must to be on fat32 class...when was on ntfs don't recognize the update file.
neodante is offline
post #437 of 1018 Old 11-10-2015, 01:06 PM
neodante's Avatar
Quoted: 21 Post(s)
Liked: 4
This works on vten ? :
neodante is offline
post #438 of 1018 Old 11-10-2015, 01:51 PM
halfelite's Avatar
Quoted: 650 Post(s)
Liked: 332
Yes a USB hub will work but I suggest getting a powered USB hub
post #439 of 1018 Old 11-10-2015, 03:08 PM
Quoted: 440 Post(s)
Liked: 507
What is the reason for choosing a powered hub over a non-powered one?
Cheers
post #440 of 1018 Old 11-10-2015, 03:09 PM
halfelite's Avatar
Quoted: 650 Post(s)
Liked: 332
All PCH models have always had weak powered USB ports. So if you are going to be hanging 3 drives off of it. I would go with a powered HUB to reduce problems.
post #441 of 1018 Old 11-10-2015, 03:30 PM
SMHarman's Avatar
Quoted: 419 Post(s)
Liked: 140
Cheers
Of course they have just look at the amps oitput rating on the wall wart.
SMHarman is offline
post #442 of 1018 Old 11-11-2015, 03:40 AM
neodante's Avatar
Quoted: 21 Post(s)
Liked: 4
There's any possibility of connect a external usb 2'5 hard drive to vten using esata cable ?
I wonder for a external hard drive without power plug.
neodante is offline
post #443 of 1018 Old 11-11-2015, 05:48 AM
Quoted: 440 Post(s)
Liked: 507
Ahh, I see, good to know!
Cheers
post #444 of 1018 Old 11-11-2015, 08:32 AM
UHD Addict
aaronwt's Avatar
Liked: 6417
I don't know about the eSata connection. But I've connected a bunch of 2.5" USB 3.0 powered hard drives to the VTEN without any issues.
aaronwt is offline
post #445 of 1018 Old 11-11-2015, 09:21 AM
dmoneyman2323's Avatar
Quoted: 32 Post(s)
Liked: 35
Does anyone know if NMJ supports local stores trailer files? I have a large collection of blu-rays and have people over regularly that watch movies. The only thing holding me back is whether NMJ will recongize trailer files stored in the movie folders.
dmoneyman2323 is offline
post #446 of 1018 Old 11-11-2015, 11:23 AM
halfelite's Avatar
Quoted: 650 Post(s)
Liked: 332
From memory NMJ does not support local trailer files but if you run yamj/eversion as the jukebox it does support trailers.
post #447 of 1018 Old 11-11-2015, 12:02 PM
neodante's Avatar
Quoted: 21 Post(s)
Liked: 4
Vten have any app for to see films trailers ? (Without count YouTube)
neodante is offline
post #448 of 1018 Old 11-13-2015, 11:07 AM
neodante's Avatar
Quoted: 21 Post(s)
Liked: 4
New firmware out today !
aaronwt likes this.
neodante is offline
post #449 of 1018 Old 11-16-2015, 12:09 PM
Liked: 0
Hi. Just got my vten, but having problems with audio. Works ok from network storage on audio tracks but no audio when watching video files. Picture is on.
Any help please.
Deanio is offline
post #450 of 1018 Old 11-16-2015, 02:01 PM
Liked: 0
Any help please.
Update: Works on movies but not on homemade videos
Deanio is offline
