NVIDIA Shield (Android TV set-top box) - Page 148 - AVS Forum | Home Theater Discussions And Reviews
 3035Likes
post #4411 of 10583 Old 11-10-2017, 05:44 AM
eday_2010's Avatar
Quoted: 24 Post(s)
Originally Posted by 65Goat View Post
PLEX isn't bad, but I wasn't crazy about the UI or the fact that it doesn't support all of the audio codecs (ATMOS, DTS-X). I've also tried playing around with the Shield and using SPMC as the movie streamer (from my server) - while it supported the audio codecs I wasn't real happy with the video aspects. For now I've fallen back to streaming via JRiver and am having trouble telling the difference between playback via JRiver and a shiny disc.
I'll give Plex a try. Kodi never seems to keep some of the settings I tell it to. For instance, I want the Videos menu item to point to the folder where I have various random videos, and display it in Files view. But do you think Kodi does this after the first time I go in it? Of course not.
So I will try Plex, and if I like it, then I will look into a Shield TV of a NUC. I will miss the nice UI of the Aeon Nox skin for kodi, but kodi has been very frustrating since I have started using it.
eday_2010 is offline
post #4412 of 10583 Old 11-10-2017, 08:04 AM
dabl's Avatar
Quoted: 59 Post(s)
Re: falling back to streaming via JRiver is this using Shield? With JRemote or Gizmo?
dabl is offline
post #4413 of 10583 Old 11-10-2017, 08:11 AM
dabl's Avatar
Quoted: 59 Post(s)
Shield colorspace 1080p / 4K auto resolution switching Issues
How are people here dealing with the Shield colorspace 1080p / 4K auto resolution switching Issues?
https://github.com/koying/SPMC/issues/1060
https://forums.geforce.com/default/t...uelguzmannv/3/
dabl is offline
post #4414 of 10583 Old 11-10-2017, 08:40 AM
cmdrdredd's Avatar
Quoted: 4216 Post(s)
Liked: 4510
I don’t. I set the shield for 4k 10bit and leave it alone. Everything looks fine. Plex or Kodi on the shield looks the same or better than the disc for my mkv files.
TKNice and beerhunt like this.
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #4415 of 10583 Old 11-10-2017, 09:02 AM
dabl's Avatar
Quoted: 59 Post(s)
The problem is, as I understand it, though it may look fine to you, upon closer inspection you'll discover the colors will not be correct for both 1080p and 2160p content without manually changing Shield settings.
mtthwgrms likes this.
dabl is offline
post #4416 of 10583 Old 11-10-2017, 09:14 AM
bryansj's Avatar
Quoted: 1753 Post(s)
Liked: 789
My family prefers the ease of use and variety of applications on the Shield over looking closely at and doing A/B comparisons to other less user friendly devices.
Plus if there is something lacking (Netflix DV) then I'll simply use my TV's built-in app (LG OLED).
mborland, groove93 and beerhunt like this.
bryansj is offline
post #4417 of 10583 Old 11-10-2017, 09:47 AM
dabl's Avatar
Quoted: 59 Post(s)
Ok.
Presumably there are some people here for whom having the correct colors on the Shield for both 1080p and 2160p content is important though?
dabl is offline
post #4418 of 10583 Old 11-10-2017, 09:49 AM
bryansj's Avatar
Liked: 789
Ok.
Just a couple people from the HTPC forum that bring it up every single time the Shield is mentioned outside of its dedicated thread.
bryansj is offline
post #4419 of 10583 Old 11-10-2017, 09:53 AM
groove93's Avatar
Quoted: 947 Post(s)
Liked: 533
Ok.
How important is subjective. Red is red and blue is blue. That said, although I researched and discovered some limitations, and improved the overall picture quality, for the average user, Pixel-Peeping is not that important.
Considering the lack of disgust regarding the Apple TV 4k's inability to Pass through HD Audio, and the fact that the Shield Can, amongst other things, this 2 and a half year old device, coupled with the amount of updates that have been implemented, is top-notch to many end-users here, short-comings and all.
Sent from my Pixel 2 using Tapatalk
cmdrdredd and beerhunt like this.
Sony XBR55X900E
Marantz SR7010/Marantz MM7025
Oppo UDP-203 - Nvidia Shield
XBox One X
Klipsch RP-260f - RP-440C - RP140sa- RP-160m - RB10 - Sony SA-WM500
groove93 is online now
post #4420 of 10583 Old 11-10-2017, 09:54 AM
mtthwgrms's Avatar
Quoted: 26 Post(s)
The Rec2020 is so muted on our Vizio that I've set Shield for Rec709 only, not watching any 4K material outside of discs so it was an easy decision.
mtthwgrms is offline
post #4421 of 10583 Old 11-10-2017, 10:07 AM
dabl's Avatar
Quoted: 59 Post(s)
Originally Posted by groove93 View Post
Red is red and blue is blue....
Isn't that kind of dismissing concepts like HDR and Wide Color Gamut though?
dabl is offline
post #4422 of 10583 Old 11-10-2017, 10:09 AM
groove93's Avatar
Quoted: 947 Post(s)
Liked: 533
No, it simply states that many of us here are content with what we have and have other more important things to worry about than whether or not Smurfette is the right kind of blue.
Sony XBR55X900E
XBox One X
post #4423 of 10583 Old 11-10-2017, 10:10 AM
65Goat's Avatar
Quoted: 118 Post(s)
Liked: 72
Another program that you might want to give a try, if you are keeping the Shield, is SPMC (available on the Google Store). It supports the audio codecs - I, personally, found that the colors did not correct on my plasma TV but I didn't play with any of the video settings to try and adjust (just don't have the patience for that).
Processor: Marantz 8802a Amplifiers: ATI Signature AT6007, Emotiva XPA5 Floor Speakers: (3) Triad Inroom Gold Monitors and (4) Gold Minimonitors ATMOS Speakers: (4) Atlantic Technology IC-6 OBA BR Players: Oppo BDP-95, Panasonic DMP UB900 Streamers: Dune D1, Roku 4, nVidia Shield Screen: Panasonic Plasma TC-P65VT25 Subs: (2) Velodyne Optimums and (1) HSU ULS-15
65Goat is offline
post #4424 of 10583 Old 11-10-2017, 10:12 AM
65Goat's Avatar
Quoted: 118 Post(s)
Liked: 72
No - I should have been clearer on that - currently I use a JRiver client on a laptop connected to my pre/pro but have intentions of getting an Intel Nuc in the future (because of it's size).
65Goat is offline
post #4425 of 10583 Old 11-10-2017, 10:16 AM
dabl's Avatar
Quoted: 59 Post(s)
Just to be clear I'm not trying to pick a fight or stir up a hornets nest.
I'm honestly trying to understand how to best deal with what seems like a fundamental flaw at the moment. Obviously I hope it simply gets fixed.
If being someone from the HTPC forum makes me a discerning user than I guess I am one.
I've been reading shield threads for a long time and only just recently bought one. I had not heretofore heard of this colorspace problem and wondered if it was something I had just missed in the discussion.
I always assume a thread on avsforums contains experts who care about quality.
If most people here are truly just overlooking this issue that does help me calibrate my expectations.
beerhunt and mtthwgrms like this.
dabl is offline
post #4426 of 10583 Old 11-10-2017, 10:31 AM
eday_2010's Avatar
Quoted: 24 Post(s)
Once I truly get fed up of kodi on the Pi3, I will be looking at the Shield and the NUC. If it comes down to price, the I will probably go with the Shield. I will keep SPMC in mind. I might see if i can try it on the Samsung tablet that lives in our house somewhere.
post #4427 of 10583 Old 11-10-2017, 01:00 PM
cmdrdredd's Avatar
Liked: 4510
Here's the thing, I put in a disc and it looks one way. I play the mkv on my shield and I can't tell the difference. Colors aren't correct without a full on calibration anyway which I never did. I know what correct looks like as I work in the print industry but white point is much more important for video which has nothing to do with the shield output.
For the record I have zero desire to do back and forth pixel peeping to come on a forum and say "ah ha! The device is broken!" like so many others seem to enjoy doing. You could literally find a flaw with every single electronic device ever devised if you search for it. At some point you have to draw the line and decide what is good enough because perfection is impossible.
beerhunt likes this.
post #4428 of 10583 Old 11-10-2017, 01:02 PM
cmdrdredd's Avatar
Liked: 4510
That's Vizio's broken update not the Shield.
post #4429 of 10583 Old 11-10-2017, 01:15 PM
taz291819's Avatar
Quoted: 252 Post(s)
Liked: 148
The best way most people deal with it right now is to set it to 4k 10-bit Rec.709, since most stuff isn't HDR. When you are going to watch something in HDR, change it to 4k 10-bit Rec.2020. Only takes about 10 seconds to do.
I leave mine at 4k 10-bit Rec.2020 (or 12bit), and found only one or non-HDR films that are totally screwed up (30 Meters Down was one of them).
Vizio P65-C1 (2016)
Onkyo Tx-NR656
JBL Studio Series (Front, Center, Right), JBL 250W Sub, Kenwood Rears, Onkyo Atmos Upfiring
LG UP970 UHD Player
Nvidia Shield TV
taz291819 is offline
post #4430 of 10583 Old 11-12-2017, 10:45 AM
K_Thompson's Avatar
Quoted: 150 Post(s)
Liked: 53
My TVs are 1080p only. Should I be using the Shield "recommended" color space settings (RGB 8-bit Rec. 709) or is there a better setting?
K_Thompson is offline
post #4431 of 10583 Old 11-12-2017, 10:55 AM
groove93's Avatar
Quoted: 947 Post(s)
Liked: 533
Because of your display, you won't have access to any 4k content, so 8bit- rec.709 is fine.
Sony XBR55X900E
XBox One X
post #4432 of 10583 Old 11-12-2017, 11:51 AM
K_Thompson's Avatar
Quoted: 150 Post(s)
Liked: 53
Yes, but should I be using RGB or YUV 444?
post #4433 of 10583 Old 11-12-2017, 07:13 PM
cmdrdredd's Avatar
Liked: 4510
RGB is mostly for gaming and YUV is for video content but either should look the same. The difference is that RGB requires a conversion from YUV before being sent to the display.
post #4434 of 10583 Old 11-13-2017, 07:03 AM
Quoted: 24 Post(s)
Liked: 5
Running it 4k 60p auto resolution off ;-)
I have received my Shield TV on Saturday and I'm totally happy with its performance as a media player. 1080p upscales just fine, 4k UHD HDR rips are running smooth, Atmos and DTS:X passthrough to receiver works fine, I'm using Kodi 17.5 and glad with it. For now - allmost no glitches for me except some Logitech Harmony Elite settings.
One question - in Linux \ Windows Kodi you can press "O" on keyboard and see current bitrate\codecs\etc info. is there a way to do the same on Shield?
PS4PRO, Nvidia Shield + Kodi
Anthem 720 (pre\pro only) + 5.1.4: Pass labs INT-30A -> Crites Cornscala; Emotiva A-700 -> Crites CS-1; Crites CSC-1; Onkyo Atmos on-walls, SVS SB-4000.
JVC 7500 + 110" screen
RAzZin is offline
post #4435 of 10583 Old 11-13-2017, 07:06 AM
Quoted: 127 Post(s)
Yep press X
enkrypt3d is offline
post #4436 of 10583 Old 11-13-2017, 02:18 PM
atbear's Avatar
Quoted: 286 Post(s)
Liked: 141
Anybody else having intermittent cut outs / sluggishness with the included Shield Remote (not the controller) on the 2017 Shield? Sometimes it works very responsive, and sometimes it's like it's not working at all for many seconds both on navigation and voice search. In comparison, my Harmony Smart Control remote that I have paired via Bluetooth seems to be very responsive at all times (except that it doesn't have voice capabilities). Just wanted to check to see if anybody else experienced this and if they had a workaround. Thanks!
sparky7 and reddice like this.
Sony XBR-65X930E | NVIDIA SHIELD TV | Apple TV 4K | Samsung BD-P1600
Yamaha TSR-7810 | Energy C-100 / Energy C-C100 / Energy S10.3 / Polk RC60i
Logitech Harmony 950 / Smart Control w/ Harmony Hub
atbear is offline
post #4437 of 10583 Old 11-13-2017, 03:12 PM
ROMIL's Avatar
Quoted: 512 Post(s)
Liked: 238
Yes. The Shield remote is the worst remote I've ever used and one of the primary reasons (other than lack of DV) that I plan to switch to the Apple TV 4K soon.
reddice likes this.
ROMIL is offline
post #4438 of 10583 Old 11-13-2017, 03:18 PM
lujan's Avatar
Quoted: 4226 Post(s)
Liked: 2389
I never have used the Shield remote (or controller) and it's still in the original box. I immediately programmed my Harmony Elite for the Shield when I got it.
lujan
505 Ultra HD
720 HD
4 SD
lujan is online now
post #4439 of 10583 Old 11-13-2017, 03:26 PM
ROMIL's Avatar
Quoted: 512 Post(s)
Liked: 238
I have a Harmony One that won't work with it. Even tried Flirc with no success.
ROMIL is offline
post #4440 of 10583 Old 11-13-2017, 03:36 PM
cmdrdredd's Avatar
Liked: 4510
My TV remote controls my shield via HDMI-CEC so I don't have to use the shield remote. Though I don't hate it if I had to use it.
onkyo ht s7800 , samsung ks8000
