NVIDIA Shield (Android TV set-top box) - Page 284 - AVS Forum | Home Theater Discussions And Reviews
 4455Likes
post #8491 of 13817 Old 11-21-2018, 07:36 AM
atc98092's Avatar
Quoted: 1578 Post(s)
Liked: 787
Originally Posted by JRock3x8 View Post
How did you get kodi 18 on to your shield?
Just download it from Kodi.tv, copy to a thumb drive, then install it from the thumb drive. There's one or two security settings that have to be changed to allow installing apps locally, rather than from the Play Store. And you have to have an app that allows browsing the thumb drive. I think the one I have is called ES File Explorer.
Dan
Samsung JU7100 and NU7100 4K TVs, Yamaha RX-V583, Nvidia Shield (2017 & 2019), a number of Roku players and TVs, Windows 10 media server with Serviio and Plex. Other players and TVs as well.
atc98092 is offline
post #8492 of 13817 Old 11-21-2018, 09:06 AM
Charles R's Avatar
Liked: 883
Another way... If you have remote storage you can install/update it from there.
| 125" Projection | 5.2.4 Audio | Shield TV | CoreELEC/ODROID-C2 Kodi Media Client | Ubuntu/ODROID-XU4 NAS/Server | 65" OLED TV | TiVo | Shield TV | Fire TV 4K |
| Water cooled Threadripper & Radeon VII, NVMe PC - 43" 4K IPS Panel |
Charles R is offline
post #8493 of 13817 Old 11-21-2018, 12:20 PM
JGrana's Avatar
Quoted: 231 Post(s)
Liked: 143
16GB Shield on sale at Ebay - $119 and free shipping
Best Buy via Ebay with coupon code PICKFAST
aaronwt likes this.
JGrana is offline
post #8494 of 13817 Old 11-22-2018, 07:43 AM
JRock3x8's Avatar
Quoted: 1902 Post(s)
Liked: 633
vertical shift is now missing from the latest android build of kodi.
this is getting super irritating.
JRock3x8 is offline
post #8495 of 13817 Old 11-22-2018, 12:33 PM
bryansj's Avatar
Quoted: 1760 Post(s)
Liked: 795
I just signed up for Kodi beta access and my Kodi 17 from the play store got a version 18 pushed through as an update.
bryansj is offline
post #8496 of 13817 Old 11-22-2018, 06:46 PM
JRock3x8's Avatar
Liked: 633
Ok I found a way around this
Set zoom to 1.35 and use video calibration to bring the bottom of the screen up by 240 (no idea what that number means)
Or stretch Instead of zoom if it was encoded without the black bars.
No idea what I am doing to video quality with all this manipulation.
JRock3x8 is offline
post #8497 of 13817 Old 11-23-2018, 03:33 AM
coxy2416's Avatar
Quoted: 772 Post(s)
Liked: 456
Are there any big changes? I currently use Kodi 17 with no issues so I can't see wanting to upgrade unless there are some benefits?
coxy2416 is offline
post #8498 of 13817 Old 11-23-2018, 12:08 PM
Charles R's Avatar
Liked: 883
Yeah I was signed up as such on one of my previous Shields. Not sure I went through a major release though... does it keep 17 and 18 installed or does it nix 17?
post #8499 of 13817 Old 11-23-2018, 12:35 PM
seiji's Avatar
Quoted: 81 Post(s)
I can't seem to stream dolby atmos on Amazon Prime video or Vudu anybody having that problem?
seiji is offline
post #8500 of 13817 Old 11-23-2018, 01:01 PM
groove93's Avatar
Quoted: 1232 Post(s)
Liked: 725
Both apps steaming Atmos on my end.
Sony XBR55X900E
Marantz SR7010/Marantz MM7025
Oppo UDP-203 - Nvidia Shield
XBox One X
Klipsch RP-260f - RP-440C - RP140sa- RP-160m - RB10 - Sony SA-WM500
groove93 is offline
post #8501 of 13817 Old 11-23-2018, 01:29 PM
mjwagner's Avatar
Quoted: 1177 Post(s)
Liked: 1069
No problem getting ATMOS on both here...
Mark
mjwagner is offline
post #8502 of 13817 Old 11-23-2018, 07:11 PM
taz291819's Avatar
Quoted: 445 Post(s)
Liked: 333
I never signed up for beta access, but received the Kodi 18 update a couple of weeks ago as well.
Vizio P65-C1 (2016)
Onkyo Tx-NR656 (5.1.2 setup)
JBL Studio S-Center, JBL Studio S26ii (FL/FR), JBL N24 (LS/RS), JBL N24 (Overhead Atmos), JBL Studio SUB250
Nvidia Shield TV 2019 Pro / Fire Stick 4K
taz291819 is offline
post #8503 of 13817 Old 11-25-2018, 05:42 AM
coxy2416's Avatar
Quoted: 772 Post(s)
Liked: 456
Are there any major updates or advantages to using 18 vs 17?
coxy2416 is offline
post #8504 of 13817 Old 11-25-2018, 07:50 AM
beerhunt's Avatar
Quoted: 96 Post(s)
Liked: 49
Isn't kodi a native app (preinstalled) for the 2017 Shield TV? I couldn't find it in settings>device>apps/system apps
beerhunt is offline
post #8505 of 13817 Old 11-25-2018, 07:51 AM
atc98092's Avatar
Liked: 787
I'm sure there's quite a bit, but the one thing I've noticed compared to 17 is that it will play one movie after another without action. With 17, it always returned to the movie list when one finished. TV episodes would play continuous if I remember correctly, but movies didn't.
That said, I installed 18 beta almost immediately after I bought my Shield, so didn't really use 17 much. I might have just overlooked a setting somewhere.
coxy2416 likes this.
Dan
atc98092 is offline
post #8506 of 13817 Old 11-25-2018, 01:08 PM
Quoted: 35 Post(s)
Liked: 7
Have Sony 900F and using Shield (Kodi-Netflix-Hulu) to stream mostly 1080p movies. Is it better to set Shield resolution to 1080 and let the TV perform upscaling?
killbill07 is offline
post #8507 of 13817 Old 11-25-2018, 01:14 PM
atc98092's Avatar
Liked: 787
That's what some say. And Kodi is capable of sending 4K native even when the Shield is set to 1080. Can't say if that can happen with Netflix or Hulu.
killbill07 likes this.
Dan
atc98092 is offline
post #8508 of 13817 Old 11-25-2018, 01:18 PM
beerhunt's Avatar
Quoted: 96 Post(s)
Liked: 49
@KillBill ....go into the settings > device > Display & sound, then it will reveal the recommend resolution
beerhunt is offline
post #8509 of 13817 Old 11-25-2018, 01:29 PM
Quoted: 35 Post(s)
Liked: 7
Recommended res is 4K 59.940 Hz by default. I was wondering if users here achieved better picture quality with setting it to 1080p 59.940 Hz and let tv do upscaling. I guess that depends on the app as well (Netflix vs Kodi)
post #8510 of 13817 Old 11-25-2018, 02:06 PM
beerhunt's Avatar
Quoted: 96 Post(s)
Liked: 49
@KillBill ....I am just a novice at this stuff, but from what I have read about the Shield TV's upscaling ( not so good) then let the TV do it!
beerhunt is offline
post #8511 of 13817 Old 11-25-2018, 05:03 PM
JRock3x8's Avatar
Liked: 633
Somewhat off topic but the shield home screen looks like ass in 4k
JRock3x8 is offline
post #8512 of 13817 Old 11-25-2018, 06:46 PM
sjm817's Avatar
Quoted: 881 Post(s)
Liked: 385
In your case, yes. Let the Sony do the upscaling.
sjm817 is offline
post #8513 of 13817 Old 11-26-2018, 06:00 AM
JRock3x8's Avatar
Liked: 633
FYI deals on the shield just keep getting hotter. Look at slickdeals.net for details.
aaronwt likes this.
JRock3x8 is offline
post #8514 of 13817 Old 11-26-2018, 08:31 AM
whiteboy714's Avatar
Quoted: 1660 Post(s)
Liked: 736
In what way? Color, resolution?
whiteboy714 is offline
post #8515 of 13817 Old 11-26-2018, 09:11 AM
zzoo's Avatar
Quoted: 49 Post(s)
If I want my TV handling the 4K upscaling, instead of Shield. Should I just set Shield resolution to 1080p or just set Kodi to output 1080p or both at the same time ?
zzoo is offline
post #8516 of 13817 Old 11-26-2018, 09:37 AM
groove93's Avatar
Liked: 725
I noticed you posted in the x900F forum. Since you have a Sony, I would just leave it alone. Keep the Shield at 3120x2160.
On the TV, set HDR to "Auto", Colorspace to "Auto" and RGB to "Limited".
Note that the Shield does not have the ability to switch Colorspace from rec 709 to bt2020, and vise/versa. The Sony is great at handling scaling and colorspace (at least in my experience).
If you use Kodi/SPMC/MrMC, set the resolution within the App to 1080p. This will allow for any 1080p content to display at this resolution. Any 4k Content viewed through one of these apps will leave the resolution at 3120x2160. Also enable Refresh Rate switching within the app as well. This will allow for 24p content to play at the correct refresh rate, and thus allow the TV to switch to "Cinema Home" or Cinema Pro".
Sony XBR55X900E
XBox One X
groove93 is offline
post #8517 of 13817 Old 11-26-2018, 09:59 AM
JRock3x8's Avatar
Liked: 633
Both. Looks really muddy
JRock3x8 is offline
post #8518 of 13817 Old 11-26-2018, 10:07 AM
sjm817's Avatar
Quoted: 881 Post(s)
Liked: 385
If Kodi is not the only app you use, set the Shield to 1080P. You want the Sony to upscale to 4K, not the Shield.
sjm817 is offline
post #8519 of 13817 Old 11-26-2018, 10:45 AM
Cliff Olson's Avatar
Quoted: 173 Post(s)
Liked: 123
Nothing on the Shield will touch the up-scaler in your TV (it would take a pretty crappy TV for any software on the Shield to do a better job). I leave it on 1080p/59.94Hz; 8-bit; 4:4:4 until I watch something in 4k/HDR. Then I just click the recommended resolution (4k/59.94Hz; 10-bit; 4:2:0). I filter the results in the advanced settings to include only 1080p, 4:4:4 and 8-bit to make it easy to change it back to 1080. Still a bit of a pain but it is what it is.
EDIT: I don't use Kodi and I know there are users whom are happy with the up-scaling that it provides. So ignore my advice if using Kodi. Or you can experiment and see what you prefer.
Cliff Olson is offline
post #8520 of 13817 Old 11-26-2018, 11:50 AM
sjm817's Avatar
Quoted: 881 Post(s)
Liked: 385
Kodi upscalers are nothing special. There was a special fork called SPMC that had advanced upscalers. Another fork, MrMC also has the advanced scalers. I dont use my Shield for anything 4K and just leave it set to 1080P and have the Sony do the upscale.
sjm817 is offline
nvidia shield remotes , onkyo ht s7800 , samsung ks8000
