NVIDIA Shield (Android TV set-top box) - Page 306 - AVS Forum | Home Theater Discussions And Reviews
 4060Likes
post #9151 of 13044 Old 12-31-2018, 03:18 PM
Gary J's Avatar
Quoted: 774 Post(s)
Liked: 362
Yes 1st page and did search on Atmos which found nothing. Did see some stuff about results equipment dependent though.
Gary J is online now
post #9152 of 13044 Old 01-01-2019, 05:41 PM
eday_2010's Avatar
Quoted: 24 Post(s)
Has anyone gotten the Harmony Touch remote and the Hub to work properly with the Shield TV? Specifically with Kodi running on the Shield. I have a Flirc, but I would like to not have to use it to keep the two USB ports on the back free. Whenever I follow various setup instructions on how to do it, the Harmony app tells me I have to pair the remote to the Hub. After I do that, when I try to use the remote, it tells me the same thing.
I used the kodi Flirc profile and plugged it into the Shield. The remote now works, but a lot of the buttons that used to work in kodi on my Raspberry Pi no longer function. The most important ones are pause and stop. None of the "VCR" controls work, and this is what has been giving me issues over the last couple of days. I want the remote to work properly in Kodi as well as other areas of the Shield.
Previously I have tried the steps detailed here (https://forums.geforce.com/default/t...16183/#5316183) and also tried this (https://forums.geforce.com/default/t...01763/#5201763) and I could not get the remote to work at all. Every time I touched the remote it told me I had to pair it to the hub.
So if anyone got it working, I would love to know how.
eday_2010 is offline
post #9153 of 13044 Old 01-01-2019, 08:37 PM
mjwagner's Avatar
Quoted: 976 Post(s)
Liked: 809
Isn’t the Harmony Touch an old IR only, non hub based Harmony remote? Not sure I understand your reference to a “Hub” in tne context of a Harmony Touch.
Mark
mjwagner is online now
post #9154 of 13044 Old 01-01-2019, 08:59 PM
eday_2010's Avatar
Quoted: 24 Post(s)
It is, but I have the Harmony Hub as well, which has WiFi and Bluetooth capabilities. Even their newest remote uses the Hub for Bluetooth as far as I know.
post #9155 of 13044 Old 01-02-2019, 05:23 AM
mjwagner's Avatar
Quoted: 976 Post(s)
Liked: 809
AFAIK the Touch has no way to connect to the Hub so you can control things with IR with the Touch but the Touch can't pair with the Hub. Hub based Harmony remotes communicate to the Hub using RF. The Hub is the thing that then actually pairs with devices and uses Bluetooth to control those devices. The Touch, again AFAIK since I never owned one, doesn't do RF so has no way to pair with and communicate to a Hub.
Mark
post #9156 of 13044 Old 01-02-2019, 05:37 AM
Quoted: 230 Post(s)
Liked: 108
incorrect, you can pair the touch with the hub. Instructions on the harmony website. Then he can control the shield via Bluetooth..
ipca204 is online now
post #9157 of 13044 Old 01-02-2019, 05:38 AM
Gary J's Avatar
Quoted: 774 Post(s)
Liked: 362
Does the Touch even have bluetooth?
post #9158 of 13044 Old 01-02-2019, 06:03 AM
Quoted: 230 Post(s)
Liked: 108
no harmony REMOTE has Bluetooth, but the hub does..
post #9159 of 13044 Old 01-02-2019, 06:05 AM
Gary J's Avatar
Quoted: 774 Post(s)
Liked: 362
Ok so how do they pair if both don't have bluetooth? Bluetooth pairs with, wait for it... Bluetooth.
post #9160 of 13044 Old 01-02-2019, 06:17 AM
Quoted: 230 Post(s)
Liked: 108
because the harmony remote does not pair to the hub with Bluetooth, but once you connect the touch to the hub using, wait for it,..... RF, the hub communicates to the shield via bluetooth... Once again, easy to follow instructions found on the harmony website..
blakemcginnis likes this.
post #9161 of 13044 Old 01-02-2019, 06:29 AM
Gary J's Avatar
Quoted: 774 Post(s)
Liked: 362
Let's see them.
post #9162 of 13044 Old 01-02-2019, 06:37 AM
mjwagner's Avatar
Quoted: 976 Post(s)
Liked: 809
Thanks. Didn't know that. As I mentioned, I never owned a Touch.
In that case, once you successfully pair the Touch with the Hub you then have another step which is to pair the Hub with the Shield via Bluetooth. It should show up on the Shield as a Bluetooth device called "Harmony Keyboard"....at least my Elites do.
Mark
post #9163 of 13044 Old 01-02-2019, 06:39 AM
Quoted: 230 Post(s)
Liked: 108
Let's see them.
seriously? Would it perhaps be easier for you if i just came over to your house and programmed it for you? smh...
post #9164 of 13044 Old 01-02-2019, 06:40 AM
Quoted: 230 Post(s)
Liked: 108
winner winner , chicken dinner!
post #9165 of 13044 Old 01-02-2019, 06:41 AM
mjwagner's Avatar
Quoted: 976 Post(s)
Liked: 809
The Harmony handhelds pair with their respective Hub using RF not Bluetooth. They communicate to the Hub with RF. The Hub pairs with the devices via Bluetooth and sends the commands to the devices via Bluetooth. The way it works for devices that are controlled via Bluetooth is the Harmony handheld sends the commands to the Hub via RF and the Hub then sends those commands to the device via Bluetooth.
Mark
post #9166 of 13044 Old 01-02-2019, 06:43 AM
Gary J's Avatar
Quoted: 774 Post(s)
Liked: 362
ok will look myself
HARMONY EXPERIENCE WITH NVIDIA SHIELD TV
The Harmony Team has confirmed:
It's compatible with Harmony IR based remotes*
* Newer 2017 models of SHIELD TV do not work with IR based remotes.
case closed
post #9167 of 13044 Old 01-02-2019, 06:54 AM
mjwagner's Avatar
Quoted: 976 Post(s)
Liked: 809
ok will look myself
case closed
If he is able to connect his Harmony Touch to a Harmony Hub and then pair the Hub with the Shield then it will use Bluetooth to control the Shield. What that note on the Harmony website is talking about is that you can't use a IR only remote, like the 650 as an example, to control the 2017 Shields because they don't have a built in IR receiver. That said, you can even get around that using an add-on IR receiver like a Flirc plugged into one of the USB ports on the Shield.
psuKinger and beerhunt like this.
Mark
post #9168 of 13044 Old 01-02-2019, 06:57 AM
Quoted: 230 Post(s)
Liked: 108
ok will look myself
case closed
LOL, I'm beginning to think "AVS special member" means something else...
eday_2010, ignore all post by Gary J and you will be fine. You can absolutely do what you want to do once you pair your touch to your hub, and then your Shield to the hub. Instructions on the harmony website, or p me in a few days when i get home from vacation and I will help you out..
blakemcginnis and beerhunt like this.
post #9169 of 13044 Old 01-02-2019, 07:03 AM
eday_2010's Avatar
Quoted: 24 Post(s)
ok will look myself
case closed
Which is why you need the Hub since it can pair to the Shield via Bluetooth. If you have the 2015 Shield of the Shield Pro, then you don't need the Hub since they have IR receivers. Seriously
The problem is that after going through the two sets of instructions to add my devices to be able to use the remote properly with the Shield and within Kodi, The Shield will not find the Hub when I go to pair them with Bluetooth.
When I was able to manage pairing the Hub and the Shield via Bluetooth (case closed), anytime I tried to use the remote the screen would tell me I need to use the phone app to pair the remote to the Hub, no matter how many times I actually did it. Following the instructions on the Harmony website gets it to work, but the controls in Kodi are crippled and limited to what can be done on the Shield. So play, pause, stop, etc do not work.
For now I am using the Flirc with a config that someone posted on Reddit that almost works the way I want it to. I tried creating my own by first going through the Shield profile and then moving to the Kodi profile, but when I wanted to map the Play button, it told me it already existed, which is odd.
post #9170 of 13044 Old 01-02-2019, 07:09 AM
Gary J's Avatar
Quoted: 774 Post(s)
Liked: 362
"The Bad Much more expensive than the superior Harmony 650; poorly placed "transport" buttons; lacks dedicated forward and reverse skip keys; limited customization options for the touch screen; nonremovable battery; no RF compatibility."
case closed (again)
post #9171 of 13044 Old 01-02-2019, 07:10 AM
eday_2010's Avatar
Quoted: 24 Post(s)
I was able to get it working a few times over the last couple of days, but the controls in Kodi were always lackluster, which is where my issue lies. Other people have had success creating an activity for the Shield using both the Shield and Kodi as devices and configuring the buttons, but that hasn't worked for me (i.e. the endless "You have to pair this device" issue). If I haven't figured things out by the end of the week I'll message you.
post #9172 of 13044 Old 01-02-2019, 07:13 AM
Quoted: 230 Post(s)
Liked: 108
eday, if I were you, I would do a factory reset on both the touch and the hub, then pair the touch to the hub. Then priced proceed from there. Sounds like something is awry, and starting from scratch ( while a pita) usually takes care of anomalies like this...
post #9173 of 13044 Old 01-02-2019, 07:16 AM
Quoted: 230 Post(s)
Liked: 108
case closed (again)
Confirmed! "AVS Special Member" has a new meaning!
case closed...
post #9174 of 13044 Old 01-02-2019, 07:18 AM
UHD Addict
aaronwt's Avatar
Quoted: 9393 Post(s)
Liked: 6084
The solution seems to be to get a newer harmony remote. One the doesn't use IR but rf. My two Harmony remotes and two Harmony hubs, work great with my two shields. Plus i don't need line of sight to communicate with the hub.
Sent from my Nexus 7(16GB) using Tapatalk
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #9175 of 13044 Old 01-02-2019, 07:22 AM
Quoted: 230 Post(s)
Liked: 108
no, he can do what he wants with his existing equipment...I have the same setup on one of my systems at home...
post #9176 of 13044 Old 01-02-2019, 07:53 AM
IronMan77's Avatar
Quoted: 23 Post(s)
Liked: 0
I can cofirm that a Harmony Touch and a Harmony Hub is working perfectly with a 2017 Shield via Bluetooth.
See the Thread "Tips for setting up your Logitech Harmony for use with SHIELD Android TV" Post 379 as i am not allowed to post links here.
I have two Activites Shield & Kodi. Remapped some Buttons in the Kodi Activity like mentoined in the Post. You have to pair Two Harmony Keyboards with the Shield But in the end only one is Show but both Activites work flawless.
Tried Flirc with the Harmony Touch before but it was really laggy. With the Hub it's workin without any lags.
Gesendet von meinem Mi MIX 2 mit Tapatalk
IronMan77 is online now
post #9177 of 13044 Old 01-02-2019, 08:10 AM
shoeboo's Avatar
Quoted: 96 Post(s)
Liked: 92
case closed (again)
This is flat out wrong as has been posted several times. I am using a harmony touch paired with a harmony hub to control my shield 2017 via bluetooth from the hub. This setup works better for me as I can control my patio TV via IR directly from remote (which other harmony remotes that come with hub lack) while controlling all equipment inside via the hub directly.
JVC RS-440 | SI Slate 1.2 120" Zero Edge 16x9 screen | Fusion Lagoon Seating
Denon x4300H | Revel 5.1.4 F206/C205/W893/C763 | Dayton
Sealed 18-HO | Behringer EP4000
Tivo Bolt | Oppo 203 | Apple TV 4K | PS4 Pro | Nvidia Shield TV
shoeboo is online now
post #9178 of 13044 Old 01-02-2019, 08:14 AM
shoeboo's Avatar
Quoted: 96 Post(s)
Liked: 92
If you haven't yet, try holding the power button down on the remote to do a full reboot. Did you buy the hub on its own or do you have the smart control remote? If so, does that one work?
post #9179 of 13044 Old 01-02-2019, 08:20 AM
Killroy's Avatar
Quoted: 584 Post(s)
Liked: 468
ipca204 likes this.
Killroy is online now
post #9180 of 13044 Old 01-02-2019, 08:25 AM
eday_2010's Avatar
Quoted: 24 Post(s)
This is the one thing I didn't do yet. I deleted my remote from the MyHarmony program, removed all the devices and activities, but did not do a factory reset on the remote or the Hub.
I tried this and it did not work the way it was supposed to. When I did the test in Step 7, the remote constantly told me to pair it with the Hub.
I did a full reboot. I bought the Hub on it's own and added it to my profile; it's been working great for years. Perhaps a factory reset on everything is in order. I have everything written down (model numbers, HDMI ports, etc), so adding everything again shouldn't be too bad. My setup isn't complicated.
nvidia shield remotes , onkyo ht s7800 , samsung ks8000
