NVIDIA Shield (Android TV set-top box) - Page 313 - AVS Forum | Home Theater Discussions And Reviews
 4388Likes
post #9361 of 13637 Old 01-13-2019, 07:36 AM
lockdown571's Avatar
Quoted: 483 Post(s)
Liked: 365
Originally Posted by jbarteli View Post
Wow just got the Shield, what a nice surprise coming from a Dune pro 4k.....no banding anymore on my 5040ub!
Everything is working great except auto resolution switching. I'm using KODI, can anybody help? Thanx!
Resolution switching seems to work better for me on MrMC. I would give that a shot if you're having trouble with Kodi. You may need to enable 'expert' settings to adjust it.
lockdown571 is offline
post #9362 of 13637 Old 01-13-2019, 07:39 AM
jbarteli's Avatar
Quoted: 328 Post(s)
Liked: 119
In kodi the only option I see is 4k, 1080p and 720p with expert settings on.
jbarteli is online now
post #9363 of 13637 Old 01-13-2019, 07:40 AM
Quoted: 483 Post(s)
Liked: 365
If you set Kodi to 1080p and try playing a 4K video, does it switch?
post #9364 of 13637 Old 01-13-2019, 07:43 AM
jbarteli's Avatar
Quoted: 328 Post(s)
Liked: 119
I get 4k but also with a 1080p source .... do I need to change something in the shield video settings?
post #9365 of 13637 Old 01-13-2019, 07:53 AM
groove93's Avatar
Quoted: 1214 Post(s)
Liked: 706
In Kodi, within the Settings, go to "System, then Display, and choose 1920x1080p
.For the Whitelist you may need to add various resolutions and refresh rates such as [email protected], [email protected], etc.
Hopefully, when you get things set up properly, your display should switch to 1920x1080p (you can also adjust the refresh rate as well).
Then your content should play at the proper resolution.
Sony XBR55X900E
Marantz SR7010/Marantz MM7025
Oppo UDP-203 - Nvidia Shield
XBox One X
Klipsch RP-260f - RP-440C - RP140sa- RP-160m - RB10 - Sony SA-WM500
groove93 is offline
post #9366 of 13637 Old 01-13-2019, 07:58 AM
JRock3x8's Avatar
Quoted: 1899 Post(s)
Liked: 633
If I have a folder full of demo clips, what is the best app to play them all sequentially?
My wd tv used to do this quite well.
JRock3x8 is offline
post #9367 of 13637 Old 01-13-2019, 08:01 AM
jbarteli's Avatar
Quoted: 328 Post(s)
Liked: 119
Wil try that, thanx
post #9368 of 13637 Old 01-13-2019, 08:19 AM
Stevetd's Avatar
Quoted: 341 Post(s)
Liked: 118
Does anyone have a link to latest DirecTV Now build? I’ve changed PCs and cannot find where I got the last one. Thanks!
Stevetd is offline
post #9369 of 13637 Old 01-13-2019, 09:23 AM
jbarteli's Avatar
Quoted: 328 Post(s)
Liked: 119
Ok where do I do that thing at the Whitelist?
Anyway to get bd menu's working?
post #9370 of 13637 Old 01-13-2019, 09:36 AM
Killroy's Avatar
Quoted: 666 Post(s)
Liked: 561
BD menu has not and probably will never work in Kodi.
Killroy is online now
post #9371 of 13637 Old 01-13-2019, 10:07 AM
jbarteli's Avatar
Quoted: 328 Post(s)
Liked: 119
And outsight Kodi and within the shield other possibilities?
post #9372 of 13637 Old 01-13-2019, 10:29 AM
Killroy's Avatar
Quoted: 666 Post(s)
Liked: 561
Within the Shield, no. Other players can do it only because they have workarounds that are not endorsed by the BD group. BD menus officially required a license.
post #9373 of 13637 Old 01-13-2019, 12:26 PM
jbarteli's Avatar
Quoted: 328 Post(s)
Liked: 119
I did this, but everything stays 1080p when kodi is set to 1080p.
And when I set kodi to 4k everything is 4k....what am I missing?
post #9374 of 13637 Old 01-13-2019, 12:55 PM
groove93's Avatar
Liked: 706
There are only two areas where I made adjustments in Kodi.
Within the System Settings, look at the first image to see if anything is differed from yours.
Within the Player settings look at the second image to see if anything is different from yours.
Sent from my Pixel 2 using Tapatalk
Sony XBR55X900E
XBox One X
groove93 is offline
post #9375 of 13637 Old 01-13-2019, 01:17 PM
talbain's Avatar
Quoted: 69 Post(s)
Liked: 33
Originally Posted by talbain View Post
with the new update my shield remote has suddenly lost the ability to control the volume on my denon receiver.
i would just like to reply to my own (unanswered) post to report that the latest 7.2.2 update fixed the issue. remote can now control the receiver volume again as if nothing ever happened
---talbain---
talbain is offline
post #9376 of 13637 Old 01-13-2019, 01:27 PM
Stevetd's Avatar
Quoted: 341 Post(s)
Liked: 118
Groove, If I’m not mistaken the white list is in Kodi 18 only.
Stevetd is offline
post #9377 of 13637 Old 01-13-2019, 01:28 PM
jbarteli's Avatar
Quoted: 328 Post(s)
Liked: 119
Installed the latest beta and now it works. Thanx
groove93 likes this.
post #9378 of 13637 Old 01-13-2019, 01:39 PM
groove93's Avatar
Liked: 706
Good Obvservation, I forgot this feature was not available in earlier versions.
However I was able to get Kodi to perform properly in earlier versions as well. Making the adjustment to the display resolution and, then in the Video/Playback section, adding a slight delay in the refresh rate change so my system would not hang up.
MrMC works without the need of a whitelist. It will also adjust resolution and refresh rate. The adjustments are in the same areas as Kodi.
Sony XBR55X900E
XBox One X
groove93 is offline
post #9379 of 13637 Old 01-13-2019, 04:41 PM
JRock3x8's Avatar
Liked: 633
PSSST! Hi guys!
JRock3x8 is offline
post #9380 of 13637 Old 01-13-2019, 04:44 PM
atc98092's Avatar
Quoted: 1543 Post(s)
Liked: 749
Make sure you haven't enabled "Sync playback to display", as that overrides some settings and disables audio bitrate passthrough as well.
Dan
Samsung JU7100 and NU7100 4K TVs, Yamaha RX-V583, Nvidia Shield, a number of Roku players and TVs, Windows 10 media server with Serviio and Plex. Other players and TVs as well.
atc98092 is offline
post #9381 of 13637 Old 01-13-2019, 05:05 PM
psuKinger's Avatar
Quoted: 1648 Post(s)
Liked: 727
PSSST! Hi guys!
I'm not sure I know of any app that allows you to "queue" up multiple local files in a row (except maybe Plex? I think that's a feature maybe? But I don't use it so I'm not sure...).
For manual playback I'd think anything like Kodi, MX Player, ES File Browser, etc, would work just fine...
psuKinger is online now
post #9382 of 13637 Old 01-13-2019, 05:25 PM
atc98092's Avatar
Liked: 749
In the Kodi 18 beta, there is a setting that will allow playback of one video after another. Previous versions would only continue playback for TV episodes. It works fine with my DLNA server, either using a playlist or just from the Titles selection. The one issue I have with Kodi (and it applies to MrMC, VLC and every other DLNA player I've tried) is that it ignores the file sort of my playlists, and changes the sort to the default Kodi sort, usually by Title name. Using a Roku or Blu Ray player, they stay in the order in the playlist. Haven't found any setting that disables the sort and just displays them as presented by the DLNA server.
Dan
atc98092 is offline
post #9383 of 13637 Old 01-13-2019, 05:26 PM
Ken.F's Avatar
Quoted: 2326 Post(s)
Liked: 2642
Kodi does playlists.
https://kodi.wiki/view/Basic_playlists
Ken.F is offline
post #9384 of 13637 Old 01-13-2019, 06:18 PM
cburbs's Avatar
Quoted: 154 Post(s)
Liked: 39
Need some help here. I wanted to do some more general pic calibration and downloaded the files from the avshd 709 thread but I can't get it to play on my plex/shield setup. It plays fine from my plex web and on my Roku from plex. Can anyone else download the files and test a file.
I get - An error occurred while attempting to play this video. Please try restarting both the Plex Media Server and this app.
Restarting all devices did not help.
I am back looking at this again - Can anyone test the same thing and see if they have the same issue?
http://w6rz.net/
I have the MP4 version. I used the self extracting link. I moved the folders to my server under a folder where all the other files work but for some reason these files won't play back.
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is offline
post #9385 of 13637 Old 01-13-2019, 06:40 PM
Quoted: 20 Post(s)
Liked: 8
Add the folder as a media source in Kodi, just like for a movie folder, but select "none" for "this directory contains..." Then, for "play next video automatically" in the player settings, make sure "uncategorized" is selected. All you media sources should be visible in the video widgets.
JRock3x8 likes this.
harvos is offline
post #9386 of 13637 Old 01-13-2019, 06:43 PM
malmstump's Avatar
Quoted: 176 Post(s)
Liked: 369
hi guys , just got and setup a shield today .using my surround sound receiver and sound is really quiet on streaming apps ..yes i turned vol all the way up on remote and played with settings ...just finding it very very low , any help ?
klipsch klf-30 s Vizio p65
klipsch klf c-7 x 2
klipsch klf-20 s
onkyo tx Nr-818 soon denonx4500
3 crown xls 2502 1 xls 1502, HSU vtf-15 Mk 2
malmstump is offline
post #9387 of 13637 Old 01-13-2019, 06:48 PM
Quoted: 20 Post(s)
Liked: 8
The switch happens automatically only if both the resolution and refresh rate of the source video are a match in the whitelist. So, since the Shield doesn't support resolutions lower than 720p, SD videos will be displayed at [email protected] or 4K, depending on your output settings. What you can do is to manually change from the OSD controls, after playback has started, to any combo from your whitelist . I have to do that all the time when I play lower resolution videos because I don't like to play at 23.97 refresh rate and all the videos are at 23.97.
harvos is offline
post #9388 of 13637 Old 01-13-2019, 07:14 PM
Quoted: 20 Post(s)
Liked: 8
http://w6rz.net/
Is your plex server on the Shield? I've seen some people on the nvidia forums having issues with it after the last update.
harvos is offline
post #9389 of 13637 Old 01-13-2019, 07:18 PM
Quoted: 20 Post(s)
Liked: 8
How is your Shield connected to the avr? Which apps? Have you compared them with the same apps on other devices?
harvos is offline
post #9390 of 13637 Old 01-13-2019, 07:26 PM
psuKinger's Avatar
Liked: 727
http://w6rz.net/
Have you tried just playing the files directly using something like ES File Browser and the built-in video player?
nvidia shield remotes , onkyo ht s7800 , samsung ks8000
