NVIDIA Shield (Android TV set-top box) - Page 323 - AVS Forum | Home Theater Discussions And Reviews
 3298Likes
post #9661 of 11360 Old 02-14-2019, 06:54 AM
UHD Addict
aaronwt's Avatar
Quoted: 9133 Post(s)
Liked: 5858
Originally Posted by snorbaard View Post
Hi everyone, finally a media box that can do everything I needed: auto frame-rate switching, HDR, Dolby Atmos passthrough...
Well, not everything, I have found an unbelievable scenario.
Playing back a 4k 10-Bit HDR 23.976 fps video file @ 23.98 Hz shows noticeable colourbanding.
I tested in these apps: VLC, Plex and Kodi. Whenever the Shield TV outputs a signal at 23.98 Hz the video plays back in 8-bit. This signal info is confirmed on my projector (Optoma UHD50).
The strangest thing is that my projector engages HDR mode and the colours look correct, its just the colour gradations are really noticeable. This is odd because I thought HDR is always 10-bit.
When I set my Shield TV to [email protected] Hz HDMI mode (recommended) then the same video file plays back correctly in 10-bit HDR, and all colour gradations are practically indistinguishable. This is absolutely driving me nuts, because I can't stand the judder in this mode, and would like to play 24p files without judder.
Has anyone run into this issue? Is there a solution for this? Any suggestions?
What color space is being sent? Are you sure it's actually 8 bit.? Some devices erroroneously show 8bit when being sent 422 at 12 bit. But at a certain framerate it's impossible to get it at 8 bit because it is not part of the HDMI spec to send it at 8bit. Only at 12 bit. And many devices erroneously report 8 bit or no bitdepth at all.
Sent from my Nexus 7(16GB) using Tapatalk
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #9662 of 11360 Old 02-14-2019, 07:44 AM
Quoted: 85 Post(s)
Liked: 29
Originally Posted by Ken.F View Post
I've never been able to get passthrough to work with the speaker configuration set to anything other than 2.0 regardless of how many speakers I actually have.
Same here, anything else than 2.0 will mess up passthrough.
And remember, DON'T activate "sync to display".
Nordvarg is offline
post #9663 of 11360 Old 02-14-2019, 08:22 AM
thehun's Avatar
Quoted: 1127 Post(s)
Liked: 1136
Like I said in few pages back if the line "pass through" says "Android audio" you won't get pass through, because the player doesn't bypass the Android stack so not only will decode the signal but also truncate and sample everything at 16/48. Pay for MrMc and forget your problems. I did.
De sagittis Hungarorum libera nos, Domine!
Attention, don't read my posts if you're a snowflake or easily offended.
The Hun
thehun is offline
post #9664 of 11360 Old 02-14-2019, 11:16 AM
Liked: 0
It's sent in BT.2020 and I'm convinced it is in this colour space because the colours look correct and HDR is engaged on my projector. The signal info on my projector shows the signal is 8bit depth at 4:2:2 and in this scenario I notice colour banding. My Denon receiver (X1400H) has enhanced 4K mode enabled, and also shows the signal is BT.2020 YCbCr 4K HDR 24Hz, however it seemingly doesn't recognise the bit depth.
My test file is a 4K bluray remux, 23.976 fps, YUV, 420, 10-bit depth.
Do you think this can be attributed to the fact that, under HDMI settings my Nvidia Shield TV only have the following three modes under BT.2020 10-bit? They are:
3840x2160 60 Hz YUV 420 10-bit Rec. 2020
3840x2160 59.940 Hz YUV 420 10-bit Rec. 2020
3840x2160 50 Hz YUV 420 10-bit Rec. 2020
There is no mode for 10-bit Rec. 2020 at 3840x2160 23.98 Hz! This seems absurd. I also tried MrMC and no matter what I do, at 23.98 Hz I cannot get a 10-bit HDR signal to my projector.
The only logical conclusion that I can make is that the Nvidia Shield TV does not support 10-bit HDR at 23.98 Hz.
snorbaard is offline
post #9665 of 11360 Old 02-14-2019, 11:34 AM
UHD Addict
aaronwt's Avatar
Liked: 5858
10bit at 24hz is only supported with the RGB or 444 colorspace. Only what is supported in the HDMi spec can be used. (10 bit at 60hz is supported with the 420 colorspace)
And 422 is only supported at 12 bit in the HDMI spec. Whether at 24P or 60P. But many devices erroneously report 8 bit or no bit depth at all.
UHD 101: DEMYSTIFYING 4K, UHD BLU RAY, WIDE COLOR GAMUT, HDR, 4:4:4, 18GBPS AND THE REST!
65Goat likes this.
post #9666 of 11360 Old 02-14-2019, 11:44 AM
Liked: 0
Thanks for the info.
I am extremely disappointed. It seems there is no way to play these files correctly then.
post #9667 of 11360 Old 02-14-2019, 05:28 PM
K_Thompson's Avatar
Quoted: 154 Post(s)
Liked: 55
Not sure what it means, but on both my Shields there is a line right below "Allow passthrough" that is greyed out and says "Passthrough output device.......... Android, audiotrack". It remains greyed out whether "Allow passthrough" is selected or not. Also, only one of my Shields is connected to an AVR. The other is connected directly to the display. The AVR connected Shield bitstreams all the lossless and lossy codecs.
I checked out the lite version of MrMc just to see what all the fuss was about, but I didn't find it any better or worse than Kodi.
K_Thompson is offline
post #9668 of 11360 Old 02-14-2019, 06:27 PM
thehun's Avatar
Liked: 1136
I had the Kodi 17 play store version it never worked for bitstream, so I did lots of research regarding of it and the setting I was referring to was indeed grayed out,even though it was not supposed to according lots of tutorials I had found online, so I downloaded the SMPC, which was basically the same thing, yet it let me change that particular item so it was working fine, however it was buggy in other ways, and the developer abandoned it so I dumped both.
There is no fuss, only a product that actually works as advertised and being supported by the guy who started both Kodi and SMPC. YMMV.
The Hun
thehun is offline
post #9669 of 11360 Old 02-17-2019, 05:31 AM
JRock3x8's Avatar
Quoted: 1805 Post(s)
Liked: 569
Is there a way to stop shield and all apps from checking for updates?
MrMC updated this week and I was greeted with a completely blank screen upon start up this week.
Needless to say I was not thrilled.
This business of forcing consumers to update their devices (Apple is the worst at this) and then post update they don’t work as well as when you bought them simply has to stop.
JRock3x8 is offline
post #9670 of 11360 Old 02-17-2019, 05:45 AM
mjwagner's Avatar
Quoted: 858 Post(s)
Liked: 669
Yes. Click on the Google Play Store app, go into settings and turn off auto update. Of course that will only work for apps installed thru the Google Play Store, if you have side loaded apps then check the app itself. Depending on the app you may be able to turn auto update on/off.
Mark
mjwagner is online now
post #9671 of 11360 Old 02-17-2019, 06:13 AM
JRock3x8's Avatar
Liked: 569
Deleted
JRock3x8 is offline
post #9672 of 11360 Old 02-17-2019, 06:14 AM
JRock3x8's Avatar
Liked: 569
Thank you. What about shield itself? Shield experience?
JRock3x8 is offline
post #9673 of 11360 Old 02-17-2019, 06:24 AM
mjwagner's Avatar
Quoted: 858 Post(s)
Liked: 669
I am unaware of any setting but I have never received a Shield Experience update without being given the option to install or not. I have always seen a splash screen that indicates that an update is available and asking whether I want to install it.
Mark
post #9674 of 11360 Old 02-17-2019, 06:58 AM
Ken.F's Avatar
Quoted: 2242 Post(s)
Liked: 2463
Go to settings and under device click "About". Go in "System Upgrade" and turn off Auto-upgrade.
mjwagner likes this.
Ken.F is offline
post #9675 of 11360 Old 02-17-2019, 07:13 AM
JRock3x8's Avatar
Liked: 569
Not seeing that.
JRock3x8 is offline
post #9676 of 11360 Old 02-17-2019, 07:55 AM
Ken.F's Avatar
Liked: 2463
Not seeing that.
This is what I see in the System upgrade settings.
Name:	Shield Upgrade.jpg
Ken.F is offline
post #9677 of 11360 Old 02-17-2019, 08:01 AM
JRock3x8's Avatar
Liked: 569
What version are you on?
JRock3x8 is offline
post #9678 of 11360 Old 02-17-2019, 08:10 AM
Ken.F's Avatar
Liked: 2463
7.2.2 (30.7.130.7)
Maybe it looks different because I'm in developer mode? Your screenshot shows you have auto update turned off already so I guess it really doesn't matter what the settings screen looks like.
beerhunt likes this.
Ken.F is offline
post #9679 of 11360 Old 02-17-2019, 08:14 AM
JRock3x8's Avatar
Liked: 569
7.2.2 (30.7.130.7)
Ok I am on 7.1 - mine is the same as I picked it up from Best Buy - no settings changed other than audio pass through I think
JRock3x8 is offline
post #9680 of 11360 Old 02-17-2019, 06:25 PM
WynsWrld98's Avatar
Quoted: 561 Post(s)
Liked: 217
Shield/Kodi 18/Denon X6300H PCM only no bitstream
Shield, Kodi 18, Denon X6300H A/V receiver get PCM out of of Kodi no matter what I try. My latest settings match https://kodi.wiki/view/Audio_quickstart_guide except I played with channels as 7.1 and 2.0 (suggested by some to set it to 2.0 even if have 7.1) but all I get is PCM out of Kodi to my Denon A/V receiver, tried Direct on the Denon still get PCM.
For those who have bit stream working can you please compare your Shield/Kodi settings to mine? Thanks
ID:	2527248   Click image for larger version
ID:	2527250   Click image for larger version
Name:	Shield settings.jpg
ID:	2527252   Click image for larger version
Name:	Shield Sync Playback to Display OFF.jpg
WynsWrld98 is offline
post #9681 of 11360 Old 02-17-2019, 10:02 PM
DaveFi's Avatar
Quoted: 753 Post(s)
Liked: 241
Unfortunately Nvidia still hasn't been able to fix the black screen problem with my setup. Something that worked perfectly fine for me for years Nvidia broke with the 7.2 update.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #9682 of 11360 Old 02-18-2019, 03:38 AM
JRock3x8's Avatar
Liked: 569
And this is why I never ever want to update anything ever
JRock3x8 is offline
post #9683 of 11360 Old 02-18-2019, 10:31 AM
DaveFi's Avatar
Quoted: 753 Post(s)
Liked: 241
At this point I have little faith Nvidia will ever fix it. They've tried but I fear they will eventually give up. So the main reason why I purchased the Shield- Kodi, isnt really usuable for me because almost every time it changes refresh rate/resolution I get a black screen.
Often times I need to get up and physically unplug the power cord in order to get the picture back.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #9684 of 11360 Old 02-18-2019, 11:47 AM
Quoted: 561 Post(s)
Liked: 189
Under Shield advanced settings, I have "high quality Stereo" under USB audio mode and "Auto" under Surround Sound.
System sounds is OFF
In Kodi 18 Leia audio system settings I have
Audio output device = android, audiotrack but greyed out
Number of channels = 7.1 (I have that system)
Output configuration = Optimized
Under Audio Passthrough
Allow passthrough = ON
Passthrough output device = android, audiotrack greyed out
* receiver are ON
tinhvo is offline
post #9685 of 11360 Old 02-18-2019, 05:25 PM
lax01's Avatar
Quoted: 563 Post(s)
Liked: 360
* receiver are ON
Pretty sure Output Configuration should be set to Best Match...optimized means processing is happening and it will only output PCM:
Also ensure that all the appropriate formats are enabled...from DD to Dolby TrueHD to DTS
smhealey likes this.
Josh
lax01 is offline
post #9686 of 11360 Old 02-18-2019, 06:00 PM
K_Thompson's Avatar
Quoted: 154 Post(s)
Liked: 55
Mine is set to optimized as well and I definitely do not get PCM.
Gary J likes this.
post #9687 of 11360 Old 02-18-2019, 07:09 PM
lax01's Avatar
Quoted: 563 Post(s)
Liked: 360
https://kodi.wiki/view/Settings/Syst..._configuration
1.3 Output configuration
Settings level: Advanced
Description: Set the properties of the audio output. Available options are as follows:
Fixed - Output properties are set to the specified sampling rate & speaker configuration at all times.
Best Match - Output properties are set to always be as close a match to the source properties as possible.
Optimised - Output properties are set at the start of playback and will not change if the properties of the source change
If you want to always use SOURCE audio, you want Best Match, not Optimized
Josh
lax01 is offline
post #9688 of 11360 Old 02-18-2019, 07:36 PM
WynsWrld98's Avatar
Quoted: 561 Post(s)
Liked: 217
I have them turned on per the Wiki instructions but still PCM.
Gary J likes this.
post #9689 of 11360 Old 02-18-2019, 07:56 PM
lax01's Avatar
Quoted: 563 Post(s)
Liked: 360
What are the rest of your settings set at? Got anymore screenshots...
Josh
lax01 is offline
post #9690 of 11360 Old 02-18-2019, 08:12 PM
Quoted: 20 Post(s)
Liked: 7
Have you signed up for the test images? I think I've seen people on nvidia froums with similar problems. https://forums.geforce.com/default/t...test-images/1/
harvos is offline
onkyo ht s7800 , samsung ks8000
