NVIDIA Shield (Android TV set-top box) - Page 346 - AVS Forum | Home Theater Discussions And Reviews
 3043Likes
post #10351 of 10592 Old 05-17-2019, 09:02 AM
JRock3x8's Avatar
Quoted: 1691 Post(s)
Liked: 503
Yes gigabit network.
Yes usb3.
Thank you.
JRock3x8 is online now
post #10352 of 10592 Old 05-17-2019, 05:24 PM
mr b's Avatar
Quoted: 181 Post(s)
Liked: 83
Originally Posted by sjm817 View Post
What are you trying to do? Just add some storage for movies, music etc? Yes external storage and share it. See below
https://support-shield.nvidia.com/sh...m&rhsearch=smb
Is this still via SMBv1 only? Or is it possible to use SMBv3 to transfer files to/from a PC now?
My Gear:
Spoiler!
mr b is online now
post #10353 of 10592 Old 05-17-2019, 05:29 PM
atc98092's Avatar
Quoted: 1298 Post(s)
Liked: 519
Originally Posted by DaveFi View Post
Is there a way to turn off ARC on the Shield? Between the Shield and my XBR900 it is causing problems. When I use my avrkey to split the signal to my headphones my TV puts a "this audio format is unsupported" on the screen.
ARC is a function between a TV set and the audio device (AVR or soundbar). There's no ARC in the Shield. What is does have is audio out via HDMI. I have no idea how your avrkey functions, but if it takes the HDMI and removes the audio, your TV shouldn't be getting any audio. It sounds like your avrkey is outputting some sort of audio that the TV doesn't recognize.
Dan
Samsung JU7100 4K TV, Yamaha RX-V583, Nvidia Shield, a number of Roku players and TVs, Windows 10 media server with Serviio and Plex. Other players and TVs as well.
atc98092 is offline
post #10354 of 10592 Old 05-17-2019, 06:03 PM
rjih's Avatar
Quoted: 72 Post(s)
Liked: 57
SMBv3 was implemented with update 7.2.
Enhancements/bug fixes included with Nov 20, 2018 SHIELD Experience release (30.6.129.29)
Enhancements
General
[US Only] Adds Amazon Music. Open your apps drawer to access or add to your favorites
Adds option to automatically download and update SHIELD software (Settings > About > System upgrade > Auto upgrade)
Adds customizable Quick Settings (Settings > System > Customize Quick Settings)
Adds network link speed when connected via ethernet (Settings > Network > Connected) System
Adds option to disable Comfort Noise (Settings > Display & Sound > Advanced Settings)
Adds IR power control for sound bars
USB debug access no longer required to enable network debugging.
Upgraded to Android Kernel 4.9 from 3.1
Adds ability to control TV volume over HDMI-CEC from Alexa
Adds option to disconnect paired Bluetooth audio devices
Storage
Adds SMBv3 support when mounting networked storage (NAS or PC) to SHIELD. (Accessing SHIELD folders on PC over supports SMBv1)
Adds option to sleep USB connected drives when idle (Settings > Storage & reset > Sleep drives when idle)
[SHIELD 2015 and Pro] Adds notification to migrate app data from SD Card to internal storage
rjih is online now
post #10355 of 10592 Old 05-17-2019, 08:32 PM
DaveFi's Avatar
Quoted: 727 Post(s)
Liked: 233
It doesn't remove it, it just sends a second audio signal as HDMI 1.4 while passing through the original. The problem is when I play lossless audio to my headphone receiver it the TV sees the HDMI 2.0 signal and keeps putting up the "the format isn't supported" message. Unfortunately there is no way to disable this message on the TV, no matter what I do.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is online now
post #10356 of 10592 Old 05-18-2019, 01:29 PM
talon95's Avatar
Quoted: 332 Post(s)
Liked: 184
Anyone else having trouble with the Netflix app? It crashes every time I start playing anything now. I haven't tried it yet, but I read over on the Nvidia forums that reverting to 2.0 sound fixes it. Not in any hurry to test this as I'll just use my Roku before doing that.
talon95 is offline
post #10357 of 10592 Old 05-18-2019, 03:02 PM
UHD Addict
aaronwt's Avatar
Quoted: 8909 Post(s)
Liked: 5694
It's been working fine here today. I've been watching the second season of The Rain from Netflix on the Shield TV. I'm stil, receiving 5.1 DD+.
Sent from my Tab S 10.5
mjwagner likes this.
53TB unRAID2--45TB unRAID3--35TB unRAID1a
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #10358 of 10592 Old 05-18-2019, 03:21 PM
mr b's Avatar
Quoted: 181 Post(s)
Liked: 83
re: SMBv3 support
[QUOTE=rjih;58062956]SMBv3 was implemented with update 7.2......./QUOTE]
Thanks for that. I have yet figure out how to view my files on the shield via my PC so I may be missing something.
This line is a bit confusing though:
"Storage
[SHIELD 2015 and Pro] Adds notification to migrate app data from SD Card to internal storage"
My Gear:
Spoiler!
mr b is online now
post #10359 of 10592 Old 05-18-2019, 03:40 PM
chi_guy50's Avatar
Quoted: 2145 Post(s)
Liked: 2137
FWIW, it always works like a charm for me.
Living Room: Sony XBR-65Z9D; Oppo UDP-203; Nvidia Shield TV; Roku Ultra; Denon AVR-X8500H (9.1.4/13.1); Polk Audio RTiA7 (Fl/r), CSiA6 (C), RTiA5 (Sl/r & FW), OWM5 (SB), 80F/X-RT (FH, RH); SVS SB-2000 (SW)
Bedroom: Sony XBR-55HX929, DarbeeVision DVP 5000S, Amazon Fire TV 4K, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is online now
post #10360 of 10592 Old 05-18-2019, 05:18 PM
Cliff Olson's Avatar
Quoted: 57 Post(s)
Liked: 52
If it's not appropriate to post her, would someone be willing to PM me about adding Netflix to Kodi? I'm not looking for anything free or extra or anything. I sub to the 4k plan and I just want to see how ATMOS sounds through the Shield. I have a blank Kodi app because I've never really set it up before. Thank you.
Sent from my SM-G965U using Tapatalk
Cliff Olson is offline
post #10361 of 10592 Old 05-18-2019, 06:51 PM
mjwagner's Avatar
Quoted: 779 Post(s)
Liked: 593
I have seen no other reports of a problem so does not appear to be systemic.
Mark
mjwagner is offline
post #10362 of 10592 Old 05-18-2019, 07:37 PM
sjm817's Avatar
Quoted: 710 Post(s)
Liked: 280
https://forum.kodi.tv/showthread.php?tid=329767
sjm817 is online now
post #10363 of 10592 Old 05-19-2019, 12:14 AM
lujan's Avatar
Quoted: 4255 Post(s)
Liked: 2398
I had an issue a while back where I was only getting 2.0 on Netflix where nothing fixed it except a factory reset. Once I did the factory reset all was well again.
lujan
505 Ultra HD
720 HD
4 SD
lujan is online now
post #10364 of 10592 Old 05-19-2019, 04:19 AM
JRock3x8's Avatar
Liked: 503
And of course the same week I pull the trigger on buying a USB drive the my clouds go on sale.
Argh.
post #10365 of 10592 Old 05-19-2019, 07:00 AM
Quoted: 57 Post(s)
Liked: 52
Thanks. I tried everything. Step by step. But like all the other guides that skip the obvious portions (that aren't obvious to Kodi newbs), it fails. I cant connect to the Netflix repository to install it. I did figure out everything to that point. But maybe this 'Nightly' build is required and I have no clue what it is as it's not in the links instructions
post #10366 of 10592 Old 05-19-2019, 07:51 AM
Quoted: 57 Post(s)
Liked: 52
Got it. Thank you. I had to install from zip file and not from repository like the instructions said. Which I'm going to assume means that I'll need to update Netflix manually in the future.... So we get multi-PCM when using audio pass through? Or did I miss a setting? Thanks again for your help
post #10367 of 10592 Old 05-19-2019, 08:28 AM
sjm817's Avatar
Quoted: 710 Post(s)
Liked: 280
It should auo update. No its not Multi-PCM. It should be "Atmos"
post #10368 of 10592 Old 05-19-2019, 09:27 AM
Quoted: 57 Post(s)
Liked: 52
I forgot to restart the Shield and those audio options opened up. Thank you.
post #10369 of 10592 Old 05-19-2019, 09:45 AM
Quoted: 22 Post(s)
Liked: 7
Can I ask how you get the display to show source-shield, sound-dolby atmos and signal-dolby atmos/digital+? I'm guessing I'm missing something simple.
hpottr is offline
post #10370 of 10592 Old 05-19-2019, 09:50 AM
sjm817's Avatar
Quoted: 710 Post(s)
Liked: 280
Thats what the Denon AVR does when you hit the info button.
post #10371 of 10592 Old 05-19-2019, 09:52 AM
lujan's Avatar
Liked: 2398
It's not the display giving this information but the Denon AVR. I know because I have a Denon AVR and I get this information by going into settings and then scrolling down to Video and then Information (page 251 of owners manual).
lujan
505 Ultra HD
720 HD
4 SD
lujan is online now
post #10372 of 10592 Old 05-19-2019, 11:18 AM
Quoted: 57 Post(s)
Liked: 52
I now remember why Kodi and I could never be friends. Trying to get rez switching to work is a futile task. Looks like the only way is to check the box that says 'Sync playback to display'. Problem with that is it breaks audio passthrough. So I get Multi PCM and no Atmos or even DD+ (I have a 2016 Samsung Ks8000). Ah well it still looks better out the TV's app anyway.
post #10373 of 10592 Old 05-20-2019, 04:52 AM
vapore0n's Avatar
Quoted: 20 Post(s)
Originally Posted by waitsone View Post
Quick question, I'm about to purchase a Shield, but I'm not a fan of the remote control. Does anyone known if allbor any Sony 4K TV remotes that will sync with the Shield and can control the functions?
They do, via CEC. Power, arrow keys, volume.
The issue is that remote functionality will be limited (not configurable). I did find using my Sony TV remote was fairly fast and responsive.
I now use a Harmony remote with hub and its the best thing. I do have it configured to use the Sony's Guide button. This will bring up the Live Channel's guide on the Shield. This is one button that is not available on the Shield, so I had to do it that way.
mjwagner and beerhunt like this.
Sony x900e, Sony STR-DN1080, Sony Core Series speakers (5.1.2), NVidia Shield TV, Synology 4 bay NAS (12TB total)
vapore0n is offline
post #10374 of 10592 Old 05-20-2019, 04:58 AM
vapore0n's Avatar
Quoted: 20 Post(s)
Did you white list enable all resolutions on the system settings in Kodi?
Can you try changing manually when content is played? Play something, click enter to show the OSD, go to settings and in video options select the video resolution. I'm guessing if you cant do this part then the list of resolutions is not enabled.
vapore0n is offline
post #10375 of 10592 Old 05-20-2019, 08:10 AM
Quoted: 57 Post(s)
Liked: 52
I thought I went over everything I could find on Kodi video settings but I dont recall seeing an actual list of supported resolutions. Just a global resolution for Kodi. I'll look into it tonight though. Thank you!
post #10376 of 10592 Old 05-20-2019, 12:43 PM
whiteboy714's Avatar
Quoted: 646 Post(s)
Liked: 183
Yeah I missed that part too and once I did all was well.
whiteboy714 is offline
post #10377 of 10592 Old 05-20-2019, 02:06 PM
Quoted: 169 Post(s)
Liked: 31
Originally Posted by dfkimbro View Post
Unless someone here has the specific make and model TV you’re considering, I would check if you can find a definitive answer on the Nvidia forums at https://forums.geforce.com/default/board/159/shield-tv. CEC is notoriously finicky any time you mix equipment manufacturers, not just Sony or the Shield, and is one of the more common issues on those forums.
I gave up on CEC years ago and went with a Harmony remote.
I love CEC and never found it to be finicky with a Sony 900E. My Sony TV remote is better than the Harmony hub/remote system I tried with the exception of no 'Home' button function. Unless you have to switch inputs on the TV and AVR for different viewing situations, I see little advantage of Harmony remotes (especially with the lack of an IR receiver on the Shield) over HDMI CEC.
sjm817 likes this.
Tfid is offline
post #10378 of 10592 Old 05-20-2019, 03:07 PM
JRock3x8's Avatar
Liked: 503
Uhm what do I do to transfer files from my pc?
This doesn’t work.
post #10379 of 10592 Old 05-20-2019, 03:31 PM
Radio81's Avatar
Quoted: 271 Post(s)
Liked: 100
This doesn’t work.
I’ve always used ES File Explorer for remotely accessing my PC from the shield. I think I had to sideload the apk, but it’s a been awhile since I’ve messed with it.
Oh, and rather than purchasing the cloud drives as you mentioned earlier, it may be a better option to buy a wireless router with USB support. Then you can connect your existing drive(s) and share them over your network.
Radio81 is offline
post #10380 of 10592 Old 05-20-2019, 03:39 PM
JRock3x8's Avatar
Liked: 503
I have two asus black diamonds but is that going to be fast enough for 4k?
onkyo ht s7800 , samsung ks8000
