NVIDIA Shield (Android TV set-top box) - Page 374 - AVS Forum | Home Theater Discussions And Reviews
 3290Likes
post #11191 of 11298 Old 08-12-2019, 10:57 AM
UHD Addict
aaronwt's Avatar
Quoted: 9106 Post(s)
Liked: 5850
Originally Posted by imureh View Post
Yeah the file has atmos for sure. I had to change my audio setting even on my Oppo to bitstream to get it play the atmos signal otherwise it would go to DTS HD 7.1
How is it going to DTS-HD unless there is a DTS-HD track with it? Otherwise it should be playing Dolby True HD.
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #11192 of 11298 Old 08-12-2019, 11:03 AM
groove93's Avatar
Quoted: 965 Post(s)
Liked: 548
On some occasions, the Oppo 203 will not change the audio format, therefore you have to manually adjust the audio setting, or restart the player. A minor inconvenience.
Sony XBR55X900E
Marantz SR7010/Marantz MM7025
Oppo UDP-203 - Nvidia Shield
XBox One X
Klipsch RP-260f - RP-440C - RP140sa- RP-160m - RB10 - Sony SA-WM500
groove93 is offline
post #11193 of 11298 Old 08-12-2019, 11:36 AM
I released Refresh rate tool to google play, it allows automatic refresh rate switching and more.
Search for 'refresh rate' or 'mobi.bytearray.refreshrate' at google play
aaronwt, vapore0n, JGrana and 3 others like this.
TaMaX is offline
post #11194 of 11298 Old 08-12-2019, 12:05 PM
UHD Addict
aaronwt's Avatar
Liked: 5850
Thanks. I just had it downloaded to both of my Shields. I'll need to try it out when I get home tonight.
aaronwt is offline
post #11195 of 11298 Old 08-12-2019, 12:29 PM
lujan's Avatar
Quoted: 4462 Post(s)
Liked: 2510
So how does it work? Do you use the app before watching any content on Shield?
lujan
526 Ultra HD
729 HD
4 SD
lujan is offline
post #11196 of 11298 Old 08-12-2019, 12:47 PM
It depends what you want do, you can set startup display mode for each app. Or you can enable automatic display mode matching. Or you can enable displaying toast message witch detected video fps and set display mode manually by osd menu.
Best is read manual at nvidia forums first (link in app description at google play)
aaronwt, lujan and dfkimbro like this.
TaMaX is offline
post #11197 of 11298 Old 08-12-2019, 05:09 PM
UHD Addict
aaronwt's Avatar
Liked: 5850
I just tried it but is there any way to have an option less than five seconds? Like one or two seconds for it to change? From a normal device with framerate switching it switches in one or two seconds on my displays. But at five seconds a title starts playing then stops a few seconds later and goes to a black screen and then switches the framerate. If it happened within a second or two that would make it act more like other devices with framerate switching.
aaronwt is offline
post #11198 of 11298 Old 08-12-2019, 08:42 PM
dfkimbro's Avatar
Quoted: 193 Post(s)
Liked: 122
Welcome to the AVS forum, Mateusz!
ddigler likes this.
Well, Duncan, he's just this guy, you know?
dfkimbro is offline
post #11199 of 11298 Old 08-12-2019, 08:51 PM
dfkimbro's Avatar
Quoted: 193 Post(s)
Liked: 122
Mateusz (the developer) said that 5 seconds is the minimum over on the Nvidia forums. https://www.nvidia.com/en-us/geforce...l-google-play/
He said “It can be developed but minimal delay must be ~5 because system is reporting fps after first 120 frames from video start.“
I’m assuming that’s with 23.976 fps as the lowest video frame rate, it can take up to 5 seconds (or slightly more) to get to 120 frames and get an accurate, reliable result.
It’s almost impossible to use the Nvidia forums since the recent “refresh” and there’s no way to “number” or directly link to a post, otherwise I’d link to it. I think it was 3 days ago and is near the end of the thread.
Edit...I think I found how to copy a direct link to a post at Nvidias forums. https://www.nvidia.com/en-us/geforce...-play/2238130/
aaronwt likes this.
dfkimbro is offline
post #11200 of 11298 Old 08-13-2019, 06:39 AM
Also i can add to above information that in theory i CAN change mode without delay but it will be limited to full (rounded) fps values (24,25,30).
That is technical limitation, there is no exact data at video start. So i can add 'no delay' option but then you will get 23,97fps -> 24Hz, 29,97 -> 60Hz.
And one more thing, this app is 'hack', i connected multiple strange techniques to force this box to autorefresh rate, for some TVs or soundsystems this app will just not work. ¯\_(ツ)_/¯
aaronwt, ddigler and vn800art like this.
TaMaX is offline
post #11201 of 11298 Old 08-13-2019, 12:11 PM
ddigler's Avatar
Quoted: 1020 Post(s)
Liked: 466
@TaMaX - can you explain to me what your refresh app does for Shield TV? I was reading from the Nvidia forums a post of 'best practices' someone had linked earlier. In that post, it recommends using your refresh app. I never used it because I'm not sure what I'm missing I guess haha
Is there a link were I can do some reading and try to understand what it does? My UHD BD rips seem to play very well on my Shield but occasionally have a 'stutter' in the video. Is this what you are fixing with your app?
ddigler is offline
post #11202 of 11298 Old 08-13-2019, 01:45 PM
JRock3x8's Avatar
Quoted: 1797 Post(s)
Liked: 558
I also have a very occasional frame drop. Shrug.
ddigler likes this.
JRock3x8 is online now
post #11203 of 11298 Old 08-13-2019, 05:46 PM
UHD Addict
aaronwt's Avatar
Liked: 5850
Is that from the Refresh Rate app? Because I am seeing something like that too.
aaronwt is offline
post #11204 of 11298 Old 08-13-2019, 05:55 PM
DaveFi's Avatar
Quoted: 753 Post(s)
Liked: 241
I've been posting about it here for a while. Since Nvidia's userforum is pretty much unusable now you can post here more often.
I installed 3.0 and a few things of note:
Automatic refresh rate switching doesn't work with HBO GO, it will error out. You have to change manually. Same sort-of goes for the new Hulu app, it will switch refresh rates, but it will pause playback every time it happens (which can get pretty annoying especially if you're running the ad-supported version).
Any chance of adding automatic resolution switching (to native refresh rate of source)? I assume that sort of information isn't included in the video so it's not possible?
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #11205 of 11298 Old 08-13-2019, 06:09 PM
whiteboy714's Avatar
Quoted: 975 Post(s)
Liked: 289
Any word on an update after the recent one that caused some issues?
ddigler and m_snow like this.
Samsung 55MU6290 -- Denon X1400h -- Klipsch RP600m -- RP450C -- Micca M-6S 6.5 -- Dual Klipsch RW-10
whiteboy714 is offline
post #11206 of 11298 Old 08-13-2019, 07:19 PM
Quoted: 1627 Post(s)
Liked: 913
A second hotfix is due out tomorrow. No word on when the next production update will be out.
ddigler and dfkimbro like this.
Mike
Sony XBR-65X930E | ATV4K-64GB & 32GB 5th Gen | Nvidia Shield TV Pro 2017 | Logitech Harmony Elite
m_snow is offline
post #11207 of 11298 Old 08-13-2019, 07:23 PM
dfkimbro's Avatar
Quoted: 193 Post(s)
Liked: 122
For HBO GO (or HBO Now) you should be able to just set it to 23.976 and be done with it.
dfkimbro is offline
post #11208 of 11298 Old 08-13-2019, 07:28 PM
dfkimbro's Avatar
Quoted: 193 Post(s)
Liked: 122
Beat me to it
dfkimbro is offline
post #11209 of 11298 Old 08-13-2019, 07:55 PM
HD-Master's Avatar
Quoted: 450 Post(s)
Liked: 488
More info...
Quick update. Hoping to share the second HotFIx image tomorrow with these issues addressed:
- Multiple Streaming apps failing to play for small number of users, netflix errors 116/115.
- The match content color space displaying incorrect format.
- Can't set the default launcher.
- VC1 playback not working.
- Volume UI with android P too bright, takes too long to disappear.
- Some controllers joysticks snap back to the center at the end of joystick travel. (Was in First HotFIx image)
- IR volume control not working when anything is turned on in accessibility
- When using Adoped storage, sdcard/InternalStorage not accessible.
- SHIELD Remote App connection issues & d-pad not working
- SHIELD Controller 2017 fails OTA with "accessory disconnected" error.
Sent from my iPad using Tapatalk Pro
ddigler likes this.
LG OLED65C7P - Professionally Calibrated l Apple TV 4K l Microsoft Xbox One S l Sony STR-ZA1100ES l Polk Audio CS2 Series II Center Channel l Polk Audio Monitor 60 Series II Floorstanding L/R l Polk Audio Monitor 45B Rear Surround l Dual BIC V1220 Subwoofers
HD-Master is offline
post #11210 of 11298 Old 08-13-2019, 07:58 PM
Quoted: 975 Post(s)
Liked: 289
Originally Posted by HD-Master View Post
More info...
Sweet thank you. Looks good to me.
ddigler likes this.
post #11211 of 11298 Old 08-13-2019, 09:20 PM
confinoj's Avatar
Quoted: 1224 Post(s)
Liked: 1029
Ya the new forum interface over there is a complete disaster. It’s just about impossible to find anything. No idea how that made it to production.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | Tivo Roamio OTA | Nvidia Shield | ATV 4K | Oppo UDP-203 | Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is offline
post #11212 of 11298 Old 08-14-2019, 12:40 AM
JRock3x8's Avatar
Liked: 558
no mrmc
post #11213 of 11298 Old 08-14-2019, 01:34 AM
lujan's Avatar
Liked: 2510
After installing the Refresh Rate app, my Shield was having video issues where it would go on and off every few seconds. I ended up uninstalling it.
lujan
526 Ultra HD
729 HD
4 SD
lujan is offline
post #11214 of 11298 Old 08-14-2019, 03:18 AM
DaveFi's Avatar
Quoted: 753 Post(s)
Liked: 241
Unfortunately not. HBO is a mix between 29.97 (30fps? I haven't quite figured it out) and 23.97. Shows like Bill Maher and John Oliver are the former rather than the later.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #11215 of 11298 Old 08-14-2019, 04:39 AM
dfkimbro's Avatar
Quoted: 193 Post(s)
Liked: 122
I stand corrected. I wasn’t thinking about their news commentary shows.
dfkimbro is offline
post #11216 of 11298 Old 08-14-2019, 05:58 AM
HD-Master's Avatar
Quoted: 450 Post(s)
Liked: 488
The new version of the app will allow for automatic refresh rate switching with apps like HBO Now.
post #11217 of 11298 Old 08-14-2019, 10:04 AM
scubasteve2365's Avatar
Quoted: 296 Post(s)
Liked: 361
Those that are using the Shield for local UHD/HDR rips (assuming with Kodi) what display frequency and color/depth settings are you using?
I'm mostly new to HDR, and I thought 10-bit was the standard. I understand the latest update for the Shield broke the auto color space change. My understanding is that most UHD HDR content is 2020 anyway, so I have my shield set on there. However, the options do not show a 10-bit option. Only 8 bit and 12 bit. Am I missing something?
"The Scuba Tank" thread here
PSN/XBL/Steam : ScubaSteve2365 - PC = i7-8700k, RTX 2080Ti, DDR4-3200 Ram
My VR Podcast on Youtube - VR Roundtable - Pimax, Playstation VR, Rift-S, and Quest
Theater = Epson 5040UB, Denon x4400, Klipsh RF 7.2, 4-FiCar 18" IB, HTMarket Pembrokes, Aura BassShaker
scubasteve2365 is offline
post #11218 of 11298 Old 08-14-2019, 01:18 PM
UHD Addict
aaronwt's Avatar
Liked: 5850
If I remember correctly, mine is set for 10bit 4:2:0 at 2160P60. Then in Plex, Kodi etc, when it switches to 2160P24, it switches to 12 bit 4:2:2.
aaronwt is offline
post #11219 of 11298 Old 08-14-2019, 02:10 PM
cnelson87's Avatar
Quoted: 47 Post(s)
Some dumb questions that have probably been answered somewhere in the last 370+ pages...
Does the Shield + Kodi (or any other app) play full uncompressed 4K UHD rips, with HDR? Either as ISO, folder structure, or mkv? Or is the OPPO 203/205 the only option?
Regarding ISO or folder structure, it's my current understanding that the full rip can't be processed into a main-movie-only due to no software is able to remux the streams correctly. Is that true or is my info out of date? I would prefer a main-movie-only folder structure but I also don't really care and will be happy to go with whatever works.
Regarding mkv, I understand mkv doesn't support DV, correct? Is there a way to convert DV to regular HDR?
Edit: And just like that, two posts before mine is someone playing full UHD rips with Shield and Kodi. Nice.
cnelson87 is offline
post #11220 of 11298 Old 08-14-2019, 02:28 PM
UHD Addict
aaronwt's Avatar
Liked: 5850
I've been doing that since I got my Shields last Spring. I can play my 1:1 UHD MKV rips with Atmos audio from Plex and Kodi etc.. And then I can play my 1:1 UHD BD ISOs with Kodi and probably MrMC.
The Shield has no problem playing Back the UHD BD rips in UHD/HDR10 with bitstreamed lossless Atmos/DTS:X audio.
The Oppo is the only option if you want DV and lossless audio. And it has to be in the folder format for that. There is a way to get DV with MKV but you will lose the lossless audio, plus you have to spend more time creating it. So I don't mess with that since I want the Lossless audio. So if I want the DV from my UHD BD, I will play the actual disc. If I want HDR10 from my UHD BDs, then I will either play the MKV I created using Plex or Kodi. Or I will play the UHD BD ISO I created with Kodi. (I create a UHD BD ISO and a UHD MKV from every UHD BD title I rip.) And MrMC should still work. But I haven't used it in awhile. Lately I've stuck with the native Plex app, Plex in the Kodi app, or just the Kodi app.
aaronwt is offline
onkyo ht s7800 , samsung ks8000
