NVIDIA Shield (Android TV set-top box) - Page 375 - AVS Forum | Home Theater Discussions And Reviews
 4165Likes
post #11221 of 13154 Old 08-14-2019, 03:50 PM
cnelson87's Avatar
Quoted: 53 Post(s)
Originally Posted by aaronwt View Post
I've been doing that since I got my Shields last Spring. I can play my 1:1 UHD MKV rips with Atmos audio from Plex and Kodi etc.. And then I can play my 1:1 UHD BD ISOs with Kodi and probably MrMC.
The Shield has no problem playing Back the UHD BD rips in UHD/HDR10 with bitstreamed lossless Atmos/DTS:X audio.
The Oppo is the only option if you want DV and lossless audio. And it has to be in the folder format for that. There is a way to get DV with MKV but you will lose the lossless audio, plus you have to spend more time creating it. So I don't mess with that since I want the Lossless audio. So if I want the DV from my UHD BD, I will play the actual disc. If I want HDR10 from my UHD BDs, then I will either play the MKV I created using Plex or Kodi. Or I will play the UHD BD ISO I created with Kodi. (I create a UHD BD ISO and a UHD MKV from every UHD BD title I rip.) And MrMC should still work. But I haven't used it in awhile. Lately I've stuck with the native Plex app, Plex in the Kodi app, or just the Kodi app.
Thank you aaronwt, your posts are always helpful. I forgot to mention previously but lossless audio is a must. Also, I don't have an OPPO, I only mentioned it because I had read it's the only option for DV.
I'm fine with no DV as long as I can still get HDR10 as I'm not sure if my eyes will really be able to discern much difference (I'm not positive but I think most UHDs that have DV also have HDR10). Do you know if there's a way to choose HDR10 over DV when either ripping the disc or when playing back via Kodi? Or to convert DV to HDR10? I mentioned that I would prefer main-movie-only folder structure, but if that isn't an option due to remux issues then I would prefer to go with mkv.
In Kodi, is there an advantage of any format over another (ISO, folder structure, or mkv)?
cnelson87 is offline
post #11222 of 13154 Old 08-14-2019, 04:27 PM
atc98092's Avatar
Quoted: 1443 Post(s)
Liked: 655
I can also confirm that MrMC will play my UHD/HDR rips (all in MKV), and TrueHD/Atmos and DTS:X both come through as an untouched bitstream. I use Serviio as a DLNA server, but the profile used does zero transcoding. I can watch the network card in my PC and see bitrates exceeding 120 Mbps, so I'm sure I'm getting the untouched video bitstream as well.
Dan
Samsung JU7100 and NU7100 4K TVs, Yamaha RX-V583, Nvidia Shield, a number of Roku players and TVs, Windows 10 media server with Serviio and Plex. Other players and TVs as well.
atc98092 is online now
post #11223 of 13154 Old 08-14-2019, 04:33 PM
K_Thompson's Avatar
Quoted: 161 Post(s)
Liked: 59
Since we're discussing playing UHD rips on the Shield, what optical drive is currently considered the best for ripping UHD 4K discs using MakeMKV? I'm probably going to replace my aging 1080p plasma soon and want to have content ready to go for when I do.
K_Thompson is offline
post #11224 of 13154 Old 08-14-2019, 04:41 PM
atc98092's Avatar
Liked: 655
Originally Posted by K_Thompson View Post
Since we're discussing playing UHD rips on the Shield, what optical drive is currently considered the best for ripping discs using MakeMKV? I'm probably going to replace my aging 1080p plasma soon and want to have content ready to go for when I do.
I use the LG WH14NS40, which isn't even on the list of drives that work, but it does. I believe firmware is important as well, and if I remember correctly, on the LG drives the firmware has to be 1.02 or below. On the MakeMKV forum, they discuss drives that work: https://www.makemkv.com/forum/viewto...p?f=16&t=16832
home_theatre_man and TheMach like this.
Dan
post #11225 of 13154 Old 08-14-2019, 04:43 PM
K_Thompson's Avatar
Quoted: 161 Post(s)
Liked: 59
Thanks for the info and the link!
post #11226 of 13154 Old 08-14-2019, 04:48 PM
groove93's Avatar
Quoted: 1148 Post(s)
Liked: 631
Yes, and whatever you do, DO NOT UPDATE THE FIRMWARE.
Sony XBR55X900E
Marantz SR7010/Marantz MM7025
Oppo UDP-203 - Nvidia Shield
XBox One X
Klipsch RP-260f - RP-440C - RP140sa- RP-160m - RB10 - Sony SA-WM500
groove93 is online now
post #11227 of 13154 Old 08-14-2019, 04:54 PM
cnelson87's Avatar
Quoted: 53 Post(s)
I have an ASUS BW-16D1HT and it works great! I also have an LG WH16NS40 which is supposed to work but I've only tried it on one disc so far and it didn't work, so who knows.
post #11228 of 13154 Old 08-14-2019, 04:57 PM
cnelson87's Avatar
Quoted: 53 Post(s)
What happens if mkv UHD rip has DV, does it downgrade to HDR10? Or are you able to choose HDR10 instead of DV?
post #11229 of 13154 Old 08-14-2019, 05:04 PM
atc98092's Avatar
Liked: 655
I only have a small number of UHD discs, and honestly don't know if they contain DV, as I don't have a DV display. But they all do trigger HDR mode in my Samsung JU7100. The titles I have are
Close Encounters of the Third Kind
Dracula (1992 with Gary Oldman)
The Fifth Element
Independence Day
Jurassic Park (and JP II and III)
Jurassic World
Solo - A Star Wars Story
If any of these have DV, then I would say that the HDR base layer must still be there.
Dan
post #11230 of 13154 Old 08-14-2019, 05:14 PM
cnelson87's Avatar
Quoted: 53 Post(s)
The Fifth Element
Independence Day
Jurassic World
Thank you. According to blu-ray.com, none of those are DV.
post #11231 of 13154 Old 08-14-2019, 06:18 PM
UHD Addict
aaronwt's Avatar
Quoted: 9447 Post(s)
Liked: 6133
All UHD Blu-ray Discs with DOlby Vision also have HDR10. You rip it like normal and the title will have HDR10. They look great being played back from the Shield.
cnelson87 likes this.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #11232 of 13154 Old 08-14-2019, 06:53 PM
cnelson87's Avatar
Quoted: 53 Post(s)
Fantastic. I'm good to go.
post #11233 of 13154 Old 08-14-2019, 08:03 PM
mutelight's Avatar
Quoted: 2279 Post(s)
Liked: 2584
Indeed, all 4K Blu-rays have the HDR10 base layer with a "1080p" DV metadata extension layer which is simply discarded while remuxing them to a MKV container.
mutelight is offline
post #11234 of 13154 Old 08-15-2019, 07:25 AM
mjwagner's Avatar
Quoted: 998 Post(s)
Liked: 830
Originally Posted by HD-Master View Post
More info...
Sent from my iPad using Tapatalk Pro
Based on some preliminary testing I did last night on my 2 Shields after installing the Hotfix - Color space switching looks to have been resolved and seems to be working exactly the way it should.
Mark
mjwagner is online now
post #11235 of 13154 Old 08-15-2019, 07:45 AM
whiteboy714's Avatar
Quoted: 1474 Post(s)
Liked: 614
Did you have to sign up for it or did it show up. I had put my name in a Google form and got a hot fix earlier but I think that one was just related to The controller.
Edit## I found it.
TCL 65R625 -- Denon X1400h -- Klipsch RP600m -- RP450C -- Micca M-6S 6.5 -- Dual Klipsch RW-10
whiteboy714 is online now
post #11236 of 13154 Old 08-15-2019, 08:01 AM
mjwagner's Avatar
Quoted: 998 Post(s)
Liked: 830
Edit## I found it.
If you entered your Shield serial number (don't ever recall one asking for your name) in the form and received the first hot fix you should be good to go.
Mark
post #11237 of 13154 Old 08-15-2019, 08:03 AM
Liked: 614
This was like a week or so ago with a previous hotfix. I guess I'll find out today if I need to do it again.
post #11238 of 13154 Old 08-15-2019, 10:49 AM
DaveFi's Avatar
Quoted: 847 Post(s)
Liked: 273
If I remember correctly, mine is set for 10bit 4:2:0 at 2160P60. Then in Plex, Kodi etc, when it switches to 2160P24, it switches to 12 bit 4:2:2.
Mine switches properly as well but my $30 S912 Coreelec (Kodi) box still has better PQ (it's pretty noticable), and it outputs all HDR material at 4:4:4. Odd that a $30 box can look better than a $150 one.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is online now
post #11239 of 13154 Old 08-15-2019, 11:09 AM
Liked: 614
Dave what would you say specially about the pq that is better. Have you set them up side by side? Or are you just saying between the two it's that obvious?
I always see people say this but have never seen any real data to back it up.
I switch between the Shield and an HTPC and I can't say I see a huge difference.
Dave can you link to that box? So many choices and I don't see anything in the $30 range. Those things can't do hdr can they?
post #11240 of 13154 Old 08-15-2019, 12:06 PM
DaveFi's Avatar
Quoted: 847 Post(s)
Liked: 273
The new version of the app will allow for automatic refresh rate switching with apps like HBO Now.
Unfortunately 3.1 doesn't work with either HBO Go or Showtime, HBO Go crashes back to the launch screen upon refresh switch and Sho goes back to the video title screen. Hulu still pauses every time there is a rate switch.
Whiteboy- I don't know how I can provide data on pq because it's totally subjective- I run both boxes on the same setup and I can only say to my eyes the S912 box looks better. I have a MeCool BB2, but there are so many of these S912 boxes I would just buy the cheapest I can find for CoreElec and hope for the best. Just make sure it has gigabit ether net.
Definitely don't spend much on one, especially if it doesn't do what you want. Yes, they all can do 4k HDR 4:4:4 with lossless audio (Atmos/DTS-X, etc). The UI on mine is kind of slow but I hear ymmv depending upon the model you get. If all you want is Kodi (I use a Harmony hub with it and map keyboard commands to the Remote) it works fine.
There are a lot of them on ebay and ali-express. I suggest looking at the Kodi and coreelec forums before you buy.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
post #11241 of 13154 Old 08-15-2019, 01:15 PM
Liked: 614
Cool man thanks for the feedback. I didn't know they could do HDR. I might grab one just to play with.
post #11242 of 13154 Old 08-15-2019, 01:42 PM
home_theatre_man's Avatar
Quoted: 79 Post(s)
Liked: 102
I did the same and concur with OP thus far.
One note I would add is that the conversion to 12 bit 4:2:2 suffers slightly compared to 10 bit 4:2:0. There is noticeable banding in 8 bit luma and chroma ramps with the Shield at 12 bit 4:2:2 compared to other devices such as the Oppo 203 and Fire TV Stick 4K. 10 bit 4:2:0 from Shield is much cleaner and comparable to the other devices running 12 bit 4:2:2. For this reason, I am leaving Shield at 10 bit 4:2:0 for the present time, which, unfortunately, precludes frame switching.
I don't typically do exhaustive comparisons of PQ between devices, especially if I don't see anything off the go on patterns that jumps out as being wrong. I did cycle a few 2K SDR clips from Alita: Battle Angel and Oblivion on the Shield, Oppo, and Fire TV and deemed the quality on all three to be adequate for my purposes, although there were differences. PLEX server, MKVs, PLEX and Kodi clients where available.
I didn't see anything on HDR patterns, but it was far from a thorough look.
Chase Walton
Technical Editor
PMI, Ltd. / MSR, Inc.
Home Theater Design and Calibration Insider
My comments are my own and do not necessarily reflect the opinion of PMI, Ltd. or MSR, Inc.
home_theatre_man is offline
post #11243 of 13154 Old 08-15-2019, 04:16 PM
Murilo's Avatar
Quoted: 274 Post(s)
Liked: 65
Interesting markswift2003 who is active on this forum had did an analysis of the shield framerate at 23.976 fps and test for banding and according to his chart the shield passed both at 4:2:2 12 bit 4k along with MaxFALL and MaxCLL which is pretty great to see on a streaming device.
Murilo is offline
post #11244 of 13154 Old 08-15-2019, 04:22 PM
Murilo's Avatar
Quoted: 274 Post(s)
Liked: 65
If using mrmc I would definitely let it output native resolution when possible so your tv is doing the scaling. I dont know what aspects of pq you are referring to or what content you are viewing. Shield is not great at scaling thats why resolution switching is important to me. Blu-rays look much better outputting to my tv at 1080p using MRMC on the shield compared to letting the device itself do the scaling.
Murilo is offline
post #11245 of 13154 Old 08-15-2019, 06:47 PM
DaveFi's Avatar
Quoted: 847 Post(s)
Liked: 273
I'm using Kodi and I do output everything at it's native resolution. I still think my Coreelec box looks better. Coreelec has some interesting Amlogic features like being able to disable the noise reduction and deinterlacing in hardware. I have the noise reduction disabled and it looks quite good. Of course there's no way for me to prove this, could be just my imagination.
That said, these Android boxes do a nice job just for Kodi considering the price. When the S922x boxes come down in price it will be a good value as well.
Still wouldn't give up my Shield tho, great for an all-around box. Love Gamestream (when it works). Unfortunately it crashes half the time. lol
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
post #11246 of 13154 Old 08-15-2019, 07:41 PM
Murilo's Avatar
Quoted: 274 Post(s)
Liked: 65
I see. I own a zappiti and apple tv 4k and htpc, the shield to me looks as good or better then the others in most cases such as 4k content (proper 24fps output, I have not seen banding, and of course maxfall and maxcll information). As long as I am not letting it do any scaling on lower quality content and letting my tv scale. That is the shields one weakness.
I dont think the shield has any post processing features that I know of such as noise reduction active. I know mrmc although I have not played around with it on the shield lets you disable deinterlacing I believe, but it should only be activated anyway if using interlaced content or not being able to match refresh rate to your display.
Murilo is offline
post #11247 of 13154 Old 08-18-2019, 08:55 PM
confinoj's Avatar
Quoted: 1281 Post(s)
Liked: 1115
Ever since the 8.0 upgrade (including the 2 hotfixes) I’m running into Plex on the Shield giving me the “your connection to the sever is not fast enough” error when playing my UHD rips. No issues with this before. I’m all wired to a windows 10 based server with near gigabit speeds and no issues in other Shield apps accessing the Plex server like mrmc or kodi. I decided to try a factory reset tonight but issued persisted. It’s variable how long it takes to happen but usually on the order of 5-20 min of watching. Anyone else run into this since the upgrade? I could post on the Nvidia forums but to be honest I can’t stand the new format over there.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | HDHomeRun Quatro | Nvidia Shield Pro 2019 | ATV 4K | Oppo UDP-203 | 40TB Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is online now
post #11248 of 13154 Old 08-19-2019, 04:15 AM
x-evil-x's Avatar
Quoted: 151 Post(s)
Liked: 31
Does hulu do 4k and 5.1 on the shield?
x-evil-x is offline
post #11249 of 13154 Old 08-19-2019, 07:07 AM
groove93's Avatar
Liked: 631
Not sure about 4K but it definitely now does 5.1.
Sony XBR55X900E
XBox One X
post #11250 of 13154 Old 08-19-2019, 11:58 AM
UHD Addict
aaronwt's Avatar
Liked: 6133
I've noticed just the opposite. Before the 8.0 upgrade I saw the “your connection to the sever is not fast enough” occasionally. But I would always back out of the message and it was fine. But since the upgrade to 8.0, I have not seen that message pop up. Although I don't think I have the Hot fixes. I know I never signed up for them.
nvidia shield remotes , onkyo ht s7800 , samsung ks8000
