NVIDIA Shield (Android TV set-top box) - Page 444 - AVS Forum | Home Theater Discussions And Reviews
 4341Likes
post #13291 of 13557 Old 12-12-2019, 03:57 PM
Kubrickain's Avatar
Quoted: 61 Post(s)
Originally Posted by aelara View Post
Hi there. Bought a Shield Pro tv and connected it to my DENON AVR-X4300H which projects to a BENQ1000. Having issues finding Shield when i turn the DENON on and switch the source to find Shield which is connected to the Media player Hdmi port.
Another issue is what ever player I've tried i cannot pass through the surround sound, but it only plays from my two front channels. Denon identifies the source, DD, DD+etc, but audio comes out only from the two front speakers.
Please help.
Thanks a lot
Theo
Have you tried a different HDMI cable?
The advance sound settings should be set to Surround Sound > available formats > auto
Kubrickain is offline
post #13292 of 13557 Old 12-12-2019, 10:16 PM
aelara's Avatar
Three different. Maybe there is something else i have to change to Denon.? If i play a blu ray from my Panasonic player everything plays fine from all speakers. Which player is the best for playing mkv stored in an external drive connected to the shield?
aelara is offline
post #13293 of 13557 Old 12-13-2019, 06:11 AM
Quoted: 45 Post(s)
Although I don't have your AVR (mine is a Onkyo RZ840), I've successfully use Plex to play mkv file (my blu-ray rips) with ATMOS audio. Plex is configured (server side on my Win10 HTPC), with the web client having both direct play and direct stream checked. See: Settings->Web Client->Debug->(Direct Play / Direct Stream). I have a Shield 2019 tube. I'm also not sure if those Web Client settings effect the Shield's Plex app but I've also not had the problem you've described.
3DSammy is offline
post #13294 of 13557 Old 12-13-2019, 06:39 AM
groove93's Avatar
Quoted: 1206 Post(s)
Liked: 696
Performed yet another system reset of my Shield last night. I was having some "frame drop" issues with just about any video content played on the Shield. This started after the update from last week. It got really annoying after a couple of days and I thought it may have something to do with the refresh rate settings of the Shield. Going back and forth between 60 and 59.xxx did not fix the issue. Adjusting the refresh rate within Kodi and Plex did not fix the issue as well. When I noticed Youtube videos and OTA Channels were affected as well, then I knew something else was going on. So I decided to perform a system restore.
I got to hear the pretty music this time around when i was setting it up. Just your typical set up of peripherals and apps. Not only did this eliminate the frame dropping issue, but the installation of the Netflix Add-On for Kodi was much faster this time around. All of the plug-ins required for the Add-On installed properly, plus that long ESN was already configured. Just a few adjustments for 4K and HDR content, and I had this Add-On working within 5 minutes.
Now the only real challenge was the process of restoring content information for my Plex Media Server. I was notified that the external storage would not be erased, but when the Shield was finished with its Restore process, the SD card was not recognized by the system, so I just formatted. Not a big deal as it didn't take long to restore my content Metadata for Plex, but I will need to read more tutorials to overcome this.
Sony XBR55X900E
Marantz SR7010/Marantz MM7025
Oppo UDP-203 - Nvidia Shield
XBox One X
Klipsch RP-260f - RP-440C - RP140sa- RP-160m - RB10 - Sony SA-WM500
groove93 is offline
post #13295 of 13557 Old 12-13-2019, 07:09 AM
Quoted: 2055 Post(s)
Liked: 1316
I take it you hadn’t backed up your PMS database. Lesson learned. Just curious how your SD card was formatted.
Mike
Sony XBR-65X930E | ATV4K-64GB & 2-32GB 5th Gens | Nvidia Shield TV Pro 2017 | Nvidia Shield TV Pro 2019 | Logitech Harmony Elite
m_snow is online now
post #13296 of 13557 Old 12-13-2019, 07:24 AM
groove93's Avatar
Liked: 696
The PMS data was backed up on the drive from the last conversation we had. I was able to see the contents you pointed out where the information would be stored. But after the Shield finished its restore process last night, the SD card could not be recognized.
After the "sluggishness" issues I had a few weeks ago, I restored my PMS data from my SD card back to the internal storage, then per your assistance, I moved the data back to the SD card and it worked much better.
One thing I did notice was there were two areas regarding the SD Card and how it should be used. The Shield's methods of using External Storage, and the PMS method of storing data. The Shield's process would require formatting the drive. The PMS method just needed to know how the external storage would be used. I did not format the drive the first time around, I just moved the data over to it. I also left the drive in the Shield considering the information on this card would not be wiped out.
Sony XBR55X900E
XBox One X
groove93 is offline
post #13297 of 13557 Old 12-13-2019, 07:33 AM
Liked: 1316
Did you put the SD in your computer to see if all the data was still there? How was it formatted, ExFAT, FAT32, etc? I always zip and copy the com.plexapp.mediaserver.smb folder to another spot for backup.
Mike
post #13298 of 13557 Old 12-13-2019, 07:35 AM
vapore0n's Avatar
Quoted: 45 Post(s)
Liked: 26
Originally Posted by vapore0n View Post
I found this article today:
https://piunikaweb.com/2019/12/09/ne...rience-v8-0-1/
I had the same problem with Netflix. Wont work due to error 2.10.0. I am still on the older 7.x build due to it just working.
NVidia apparently decided that 8.0.1+ was required for streaming, and thus I may now be forced to update to a possibly broken build (due to all the complains and listed limitations).
I might wait till next year for this update. I used my TVs Netflix app for finishing up on a series, and plan on doing Disney+ next year anyway.
Updated to the latest version, 8.0.1 release. So far no issues whatsoever. Netflix works again too. I was worried about the Kodi issues listed, like no passthrough, hdmi out of sync, etc.
Im glad I waited though.
Sony x900e, Sony STR-DN1080, Sony Core Series speakers (5.1.2), NVidia Shield TV, Synology 4 bay NAS (12TB total)
vapore0n is offline
post #13299 of 13557 Old 12-13-2019, 07:36 AM
btran33's Avatar
Quoted: 246 Post(s)
Liked: 55
Hi:
I hope someone here can help me with a quick question. I have the old 2017 Nividia shield TV and for some reason, which I think only after the 8.01 update, the Shield TV won't change the system resolution. Here is my set up:
Nvidia Shield (2017) to Marantz AV7022MkII preamp (passthrough) to Epson LS10500 projector.
It doesn't matter what resolution I choose for the Shield TV, it always outputs 2016P (4K) resolution to the Epson. It does switch the framerate correctly, such as 60hz, 24hz or 30hz, but just not the resolution. I have forced the resolution 1080P, 720P and it still outputs 2016P to the Epson. This is so annoying as I want my projector to do the 4K upscale, not the Shield to do the upscale, so I want it to be at 1080P for Netflix, etc.
Does anyone has the same problem and know how to fix it?
btran33 is online now
post #13300 of 13557 Old 12-13-2019, 07:39 AM
groove93's Avatar
Liked: 696
I can't recall how the drive was formatted but I did "zip and move" the data to my NAS. I completely forgot that I moved that information. Thanks for jogging my memory. I'll see if I can migrate this information back when I get home.
m_snow likes this.
Sony XBR55X900E
XBox One X
groove93 is offline
post #13301 of 13557 Old 12-13-2019, 12:11 PM
vapore0n's Avatar
Quoted: 45 Post(s)
Liked: 26
Originally Posted by btran33 View Post
Hi:
Did you change the resolution on the shield to be [email protected] on the device settings? That should have forced it. Are you upscaling to 4K on the AVR and thinking it’s the Shield?
vapore0n is offline
post #13302 of 13557 Old 12-13-2019, 01:19 PM
btran33's Avatar
Quoted: 246 Post(s)
Liked: 55
Yes, I had changed the resolution on the shield to 1080P/60 1080p/24 720p/60 etc...All with the same result, the Shield is still output at 2016P (4K). It does change the frame rate correctly, according to the Epson info, but not the resolution.
No, I'm not upscaling to 4K on the Marantz preamp as HDMI is set to passthrough, there should not be any upscale from the Marantz; I'm very sure but will check again tonight.
post #13303 of 13557 Old 12-13-2019, 02:48 PM
JRock3x8's Avatar
Quoted: 1894 Post(s)
Liked: 633
Is anyone else having issues with Disney plus on shield?
Menu runs fine but no video. Force stop the app, restart the shield, wired or wireless, reinstall the app, sign out sign in, reboot router. None of that worked.
JRock3x8 is offline
post #13304 of 13557 Old 12-13-2019, 02:52 PM
Keenan's Avatar
Quoted: 4226 Post(s)
Liked: 3923
It's working fine here on my Shield Pro(2019).
Keenan is online now
post #13305 of 13557 Old 12-13-2019, 05:41 PM
biglen's Avatar
Quoted: 591 Post(s)
Liked: 109
Working fine on my 2017 Shield too.
Sent from my SM-N975U using Tapatalk
biglen is online now
post #13306 of 13557 Old 12-13-2019, 06:17 PM
JRock3x8's Avatar
Liked: 633
I spent three hours troubleshooting this today. What a nightmare.
JRock3x8 is offline
post #13307 of 13557 Old 12-14-2019, 03:28 PM
Quoted: 32 Post(s)
Liked: 6
Did you change the resolution on the shield to be [email protected] on the device settings? That should have forced it. Are you upscaling to 4K on the AVR and thinking it’️s the Shield?
I was having the same issue with my OPTOMA UHD51A. I fixed it by setting the KODI GUI to 1080p 60hz.
So my SHIELD settings are as recommended (2160p at 59.-), the KODI global setting is 1080p at 60hz, I've whitelisted all available resolutions and refresh rates and have enabled refresh rate change on start/ stop..
With these settings, I have the same behavior add before the latest update. The shield outputs each file in its native resolution and refresh rate and my projector scales accordingly.
crutzulee is offline
post #13308 of 13557 Old 12-14-2019, 04:55 PM
btran33's Avatar
Quoted: 246 Post(s)
Liked: 55
I wished I can do that as well! However, the Epson LS10500 can't process HDR in [email protected] as it only has 10G HDMI. So I have to set the shield at [email protected] to get HDR, then for some reasons, kodi won't change resolution just refresh. Something is broken with the Shield as I have a Odroid C2 with CoreElec and Kodi works fine with the Epson. However, the Odroid C2 can't process 4K HDR, so that why I'm stuck with the Shield. I might just get the Odroid N2, which can process 4K HDR and be done with the Shield.
post #13309 of 13557 Old 12-15-2019, 08:11 AM
Quoted: 32 Post(s)
Liked: 6
Try setting the resolution for KODI's GUI to 1080p and whitelist all the resolutions you want.
post #13310 of 13557 Old 12-15-2019, 08:21 AM
btran33's Avatar
Quoted: 246 Post(s)
Liked: 55
be there, done that! It doesn't matter what resolution you set within Kodi or with the Shield; Shield will always output 4K to the Epson. Don't know why! I'm done with the Shield, nice and fast little box, but too many problems with their firmware.
post #13311 of 13557 Old 12-15-2019, 10:55 AM
Quoted: 32 Post(s)
Liked: 6
I totally feel your frustration as I've been there myself so many times. Each time I rant about the limitations of the SHIELD, I'm brought back to earth when I search for alternatives.
Unfortunately, it is the best box out there for the money. All boxes have there limitations. Many of them have worse issues at a higher cost!
At any rate, the one you are reporting is not a limitation of the SHIELD. I and many others have their boxes set up with full resolution and refresh rate switching specifically in KODI as it is one of the only apps that takes advantage of the android API that allows for this.
As last resort, I might suggest removing your amp from the chain to ensure that it is truly passing through the SHIELD's output.
aaronwt, galonzo and 3DSammy like this.
post #13312 of 13557 Old 12-16-2019, 03:40 PM
xekester's Avatar
Quoted: 20 Post(s)
Kodi Resume Playback Issue
Unable to resume movie playback when using Kodi (18.5). Have to reboot shield to recover. Plex works fine to resume playback. Shield 2019 pro, Synology NAS movie storage. Any suggestions appreciated. Thanks.
xekester is offline
post #13313 of 13557 Old 12-17-2019, 02:22 PM
UHD Addict
aaronwt's Avatar
Quoted: 9667 Post(s)
Liked: 6360
I'll need to check mine. I know that playing the plex app inside Kodi remembers the location. But I dont play content directly through Kodi very often.
Sent from my Galaxy S10
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #13314 of 13557 Old 12-17-2019, 02:26 PM
xekester's Avatar
Quoted: 20 Post(s)
Thanks Aaron, appreciate it.
xekester is offline
post #13315 of 13557 Old 12-17-2019, 05:18 PM
taz291819's Avatar
Quoted: 368 Post(s)
Liked: 255
I have a Shield 2019 Pro, use a Synology NAS, and Kodi 18.5 allows for resume. I'm not sure why it's not working for you.
Vizio P65-C1 (2016)
Onkyo Tx-NR656
JBL Studio Series (Front, Center, Right), JBL 250W Sub, Kenwood Rears, Onkyo Atmos Upfiring
LG UP970 UHD Player
Nvidia Shield TV
taz291819 is online now
post #13316 of 13557 Old 12-17-2019, 06:15 PM
Gary Quiring's Avatar
Quoted: 83 Post(s)
Liked: 26
I picked up a nVidia Shield Pro today. I am using a LG 65C9 and Pioneer LX503 receiver. I installed Kodi on the Shield Pro. Watching a 4k movie I noticed a lot of banding in the blue skies. I still have my Windows PC running Kodi-DSPlayer with madVR connected to the same system and the same movie does not show any banding on the PC version.
Is there anything that can done to fix the banding?
LG 65C9 OLED, Pioneer VSX-LX503 receiver, Pronto TSU-9400 remote
Speakers: ProAc Super Towers - front, ProAc EBT's - rears, Mirage - Center, JBL S120PII subwoofer
HTPC: Shield Pro 2019, Kodi
Storage: Synology DS2415+, TheCUS N5550 running DSM 6.2 via Jun's loader
Gary Quiring is offline
post #13317 of 13557 Old 12-17-2019, 06:25 PM
UHD Addict
aaronwt's Avatar
Liked: 6360
I have not noticed any banding from mine. I am outputting the 422 colorspace at 36 bit for UHD/HDR content.
Are you outputting at 10bit with 420 or 12bit with 422?
Sent from my Nexus 7(16GB)
galonzo likes this.
aaronwt is offline
post #13318 of 13557 Old 12-17-2019, 06:37 PM
UHD Addict
aaronwt's Avatar
Liked: 6360
I just tried two UHD MKV titles and two UHD BD ISO titles from my unRAIDs.
Using the Kodi interface to play them back.
Both my 2017 Shield and 2019 Shield Pro remembered the locations when I came back to play all of them.
But I also did not have the SHields go into standby at any time. The Shields were on the entire time.
aaronwt is offline
post #13319 of 13557 Old 12-17-2019, 07:09 PM
xekester's Avatar
Quoted: 20 Post(s)
Thanks taz and Aaron. I'm considering starting over from scratch -drop my Library, re-install Kodi. Maybe trying a previous version of Kodi. I could drop Kodi altogether and use Plex, but I kinda' like Kodi interface a little more. But I thank you for your support.
xekester is offline
post #13320 of 13557 Old 12-17-2019, 08:23 PM
taz291819's Avatar
Quoted: 368 Post(s)
Liked: 255
It may just have something to do with the cache. I'd try simply doing a library cleaning first. It's in the options somewhere.
Vizio P65-C1 (2016)
Onkyo Tx-NR656
LG UP970 UHD Player
Nvidia Shield TV
nvidia shield remotes , onkyo ht s7800 , samsung ks8000
