NVIDIA Shield (Android TV set-top box) - Page 450 - AVS Forum | Home Theater Discussions And Reviews
 4339Likes
post #13471 of 13555 Old 01-09-2020, 08:56 AM
groove93's Avatar
Quoted: 1206 Post(s)
Liked: 696
Originally Posted by aaronwt View Post
What lossless audio dropout? I have no hotfixes or Betas on my Shields. And watching content with lossless audio daily using Plex or Plex within Kodi. I have not experienced any audio dropouts from any of the content I've been watching. Even 192Khz, 24 bit, 5.1 Dolby True HD plays fine. Well plays fine from Plex in Kodi, but not from the native Plex app. But that is a native Plex app issue.
There was an update you had to sign up for in order to fix audio dropouts with lossless audio. I had this issue whether I played a video in Plex or Kodi. The worse experience for me was when viewing "The Godfather". Once the fix was applied, everything was back to normal.
ckronengold likes this.
Sony XBR55X900E
Marantz SR7010/Marantz MM7025
Oppo UDP-203 - Nvidia Shield
XBox One X
Klipsch RP-260f - RP-440C - RP140sa- RP-160m - RB10 - Sony SA-WM500
groove93 is offline
post #13472 of 13555 Old 01-09-2020, 09:20 AM
thrillcat's Avatar
Quoted: 622 Post(s)
Liked: 602
This one. It was specific to lossless audio over Ethernet.
https://forums.plex.tv/t/shield-expe...op-outs/441116
I love my iPhone, but it will never replace my turntable. I've never seen Titanic OR XXXXXXXXX. Alexa is a stripper name.
The Cinema 1858 Remodel Thread
thrillcat is offline
post #13473 of 13555 Old 01-09-2020, 09:57 AM
atc98092's Avatar
Quoted: 1529 Post(s)
Liked: 741
Can't say I've experienced that. I watched my UHD rip of Jurassic Park a couple of days ago and never heard any audio issues. This wasn't my AVR with Atmos, so just the "normal" lossless audio. Can't remember if it's TrueHD or Master Audio.
Dan
Samsung JU7100 and NU7100 4K TVs, Yamaha RX-V583, Nvidia Shield, a number of Roku players and TVs, Windows 10 media server with Serviio and Plex. Other players and TVs as well.
atc98092 is offline
post #13474 of 13555 Old 01-09-2020, 11:03 AM
whiteboy714's Avatar
Quoted: 1574 Post(s)
Liked: 683
Originally Posted by shoman94 View Post
With all this talk about frame-rate and dynamic range switching, it has me thinking about Android TV built into my TV. It does all that but Nvidia can't do it?
Are you sure that your tv is doing auto frame switching? Often its hard to tell with internal apps. Plus when it comes to dynamic range your tv only has to do it for your tv. Shield has to make it work with all. Not defending them but this doesn't really compare.
dwaleke likes this.
TCL 65R625 -- Denon X1400h -- Klipsch RP600m -- RP450C -- Micca M-6S 6.5 -- Dual Klipsch RW-10
whiteboy714 is offline
post #13475 of 13555 Old 01-09-2020, 11:22 AM
groove93's Avatar
Liked: 696
Definitely depends on the Dislay. My Sony runs Android TV, and if I play a movie on Netflix (for example) using the native app on the TV, the display will change to "Cinema Home". With that said, this indicates that the movie is viewed in 24p. By the same token, if I playback movies on the Shield using Plex or Kodi/MrMC, the display will also change to Cinema Home as a result of 24p content.
My Shield is from 2015 and my Sony display is from 2017. So hardware limitations and lack of implementation of certain features (plus older hardware) with the Core OS could definitely be the culprit.
shoman94 likes this.
Sony XBR55X900E
XBox One X
groove93 is offline
post #13476 of 13555 Old 01-09-2020, 02:02 PM
Quoted: 1678 Post(s)
Liked: 921
Interesting. My 2019 Sony LCD (X950G) does nothing different with frame rate (outside of playback differences).
It switches between SDR/HDR/DV picture modes but nothing different between frame rates.
I suspect all streaming content from Android TV is played back at 60fps and the TV processing is detecting 24p inside 60p as it has the ability to do so.
I still prefer sending the TV native frame rate from external sources as this detection is not perfect.
Current TVs: 77" LG C9, 65" LG B7A, 55" TCL R625, 65” GT50 Plasma
dwaleke is offline
post #13477 of 13555 Old 01-09-2020, 02:12 PM
UHD Addict
aaronwt's Avatar
Quoted: 9665 Post(s)
Liked: 6358
Ethernet is the only way I watch content on my Shield TVs. I guess I was lucky?
Of course bad luck caught up with me. Since I need to exchange my defective 2019 Shield TV Pro.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #13478 of 13555 Old 01-09-2020, 02:18 PM
groove93's Avatar
Liked: 696
The 950G is the replacement of the 900F, which was the replacement for the 900E. Check to see if your display changes Display Modes when streaming from Netflix or Amazon.
On my display I have "24p (sync)" mode enable which switches the Display to Cinema Home for 24p content. For the Shield, Kodi/MrMC and Plex have the ability to change the refresh rate without any manual adjustments. All other apps such as Netflix and Amazon require some type of intervention, such as Manually Switching the refresh rate, or using the Refresh Rate App. My Oppo 203 changes Refresh Rate as well and my display performs the same switch to Cinema Home. Of course you can use the Netlix addon for Kodi, which will allow automatic adjustments through those apps.
For now I created a task with my Harmony Remote which changes the Display to Cinema Home for Apps such as Netflix and Amazon Prime on the Shield. I can't use the Refresh Rate app because I use the native Live Channels App on my Shield. The Refresh Rate app causes issues with the Guide Data and Channel bar, and I suspect this is due to going into the Developer Settings and making further adjustments in order for the Refresh Rate app to perform its tasks.
Sony XBR55X900E
XBox One X
groove93 is offline
post #13479 of 13555 Old 01-10-2020, 12:39 PM
K_Thompson's Avatar
Quoted: 186 Post(s)
Liked: 62
Anyone using the Sennheiser Ambeo soundbar with the Nvidia Shield TV? If so, are you happy with your experience or are you having issues as described in the Ambeo soundbar thread?
K_Thompson is offline
post #13480 of 13555 Old 01-10-2020, 06:22 PM
Frichard's Avatar
Quoted: 57 Post(s)
Liked: 25
Hi,
I just bought a Shield TV.
Quick question. When you guys bought yours. Was the battery already in the remote control?
Mine was already in and dead. Sounds like I got pass a refurbished model. . .
NAD T758 v3 - 2x AUDIOSOURCE Amp100vs
Golden ear Triton 7 - Golden ear supercenter xl
4x Micca M-8C
Paradigm PW-2200
Samsung PN64D550 - Epson 5040ub
Frichard is offline
post #13481 of 13555 Old 01-10-2020, 08:30 PM
Liked: 921
Originally Posted by Frichard View Post
Hi,
Battery was in mine and mine was brand new.
dwaleke is offline
post #13482 of 13555 Old 01-10-2020, 09:40 PM
Frichard's Avatar
Quoted: 57 Post(s)
Liked: 25
Hi,
Alright I guess it's strange but normal then. Thank you
4x Micca M-8C
Paradigm PW-2200
Frichard is offline
post #13483 of 13555 Old 01-11-2020, 02:33 AM
obwizards's Avatar
Quoted: 16 Post(s)
Yes, mine was already installed
galonzo likes this.
obwizards is online now
post #13484 of 13555 Old 01-11-2020, 06:17 AM
Liked: 1
Same here - just picked up a new Shield TV from my Amazon Locker and the batteries were already in the remote.
galonzo likes this.
Incarniac is offline
post #13485 of 13555 Old 01-11-2020, 06:31 AM
psuKinger's Avatar
Quoted: 1640 Post(s)
Liked: 722
Anybody on here tried to pair one of the new 2019 (triangle-shaped; dedicated Netflix button) remotes with a 2015 shield? And if so, did you have success?
I just tried, fwiw, and it didn't seem to want to pair...
Living Room: Sony x940E; Denon x4400h; Ascend Sierra RAAL Tower L/R's and 2EX center, Ascend HTM-200SE Rears, Rythmik F25 sub. NVidia Shield, ATV4k, OPPO UDP-203, CCA.
Basement: Samsung PN58B650 LN-T4065F (x2); Onkyo TX-NR809; Polk Monitor 70 Series II L/R's, SVS PB-1000 sub. NVidia Shield (x2), Windows Desktop, CCA.
psuKinger is offline
post #13486 of 13555 Old 01-11-2020, 08:23 AM
HD-Master's Avatar
Quoted: 585 Post(s)
Liked: 690
I have. Works fine.
aaronwt, galonzo and psuKinger like this.
LG OLED65C7P - Professionally Calibrated l Apple TV 4K l Microsoft Xbox One S l Sony STR-ZA1100ES l Polk Audio CS2 Series II Center Channel l Polk Audio Monitor 60 Series II Floorstanding L/R l Polk Audio Monitor 45B Rear Surround l Dual BIC V1220 Subwoofers
HD-Master is offline
post #13487 of 13555 Old 01-11-2020, 08:40 AM
psuKinger's Avatar
Liked: 722
Originally Posted by HD-Master View Post
I have. Works fine.
I cannot explain why. But the simple act of:
1. trying-and-failing
2. Turning it off and posting this
3. Reading your post and heading back up again
4. Turning it back on
..... Fixed it. When I went back up to try again, they were paired!
post #13488 of 13555 Old 01-13-2020, 09:20 AM
ckronengold's Avatar
Quoted: 319 Post(s)
Liked: 127
Unresponsive Remote
Over the past couple of weeks, I've found the remote to my Shield being unresponsive or dropping the connection.
Anyone else experiencing this? Its not a battery issue, and it seems to resolve itself after 30 seconds or a minute.
But its pretty annoying when you're trying to bounce between episodes or clips.
thrillcat likes this.
Video: Epson 6050 / Panny DP-UB420 / OPPO-103
Audio: Marantz 7010 / MartinLogan Motion 40 (LR), 50XT (center), M2 (surrounds)
Streaming: nVidia Shield / Roku Ultra / Chromecast Ultra
NAS: Synology 1515+ Server: Ubuntu 18.04, i7-8700 CPU
HTPC: Win10 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
post #13489 of 13555 Old 01-13-2020, 09:58 AM
Quoted: 21 Post(s)
Nvidia Shield C9
I have had the shield for the last two years. It was the perfect Kodi box for me and performed great. But the recent updates have gone horribly wrong with hotfixes and so on. My real issue was loosing HDMI signal every so often, and when pausing a movie for longer than 5 mins Kodi would stall, I've tried many different solutions including factory reset a few times.
Finally i gave up I have a ODROID N2-4GB CoreELEC on my way which is hopefully a lot more stable and I hear good things about it
Jimmy2Shoes is offline
post #13490 of 13555 Old 01-13-2020, 10:40 AM
Liked: 683
Sounds like you had a dud honestly. Not common issues that people have.
But if your just looking for Kodi the N2 is great.
post #13491 of 13555 Old 01-13-2020, 03:02 PM
Quoted: 21 Post(s)
Ya it seems that way. It works most of the time but can be unreliable which is frustrating, Kodi is all I want as I have the AppleTv for other services. I hear good things about the N2 so I'm excited to try it out. Good to hear others are not having this problem, but I'm 100 percent sure it was the software update that bricked the device.
post #13492 of 13555 Old 01-13-2020, 03:14 PM
Liked: 683
I picked up an N2 in the fall. It's been really solid, when the new Shield came out the N2 went to bedroom duty, so it doesn't get as much usage.
If you use it for music it doesn't have the limitations that the Shield (because of Android) has for Flac and PCM as far as bit perfect audio.
dwaleke and Jimmy2Shoes like this.
post #13493 of 13555 Old 01-13-2020, 03:24 PM
thrillcat's Avatar
Quoted: 622 Post(s)
Liked: 602
I’ve been having issues since I added a hot fix a few months back, stuff I didn’t have before. Laggy input. Will no longer stay paired with my Harmony Elite Hub. Freezes and locks up.
post #13494 of 13555 Old 01-13-2020, 05:14 PM
DaveFi's Avatar
Quoted: 886 Post(s)
Liked: 300
You don't even need the 4GB ODROID for CoreELEC, the 2GB version is more enough, which I have.
Yeah, the Shield just hasn't been stable for me for Kodi for a long time. Disappointing.
Jimmy2Shoes likes this.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #13495 of 13555 Old 01-13-2020, 07:44 PM
Quoted: 21 Post(s)
I wasn't sure which one to get, in hindsight 2gb sounds enough but anyway its on the way, I don't mind paying extra, stability is all i'm concerned about and I hear the picture processing is better and I'm a linux lover anyway. Android Tv has gone in the wrong direction IMO
I'll probably sell the shield cause I think its working fine, until you put kodi on it
post #13496 of 13555 Old 01-13-2020, 09:08 PM
taz291819's Avatar
Quoted: 367 Post(s)
Liked: 253
Strange, I've never had those issues with Kodi, whether on my 2015 or 2019 Shield.
Vizio P65-C1 (2016)
Onkyo Tx-NR656
JBL Studio Series (Front, Center, Right), JBL 250W Sub, Kenwood Rears, Onkyo Atmos Upfiring
LG UP970 UHD Player
Nvidia Shield TV
taz291819 is offline
post #13497 of 13555 Old 01-14-2020, 04:08 AM
rjruby's Avatar
Quoted: 44 Post(s)
Liked: 40
I've also noticed this on my two Shields. Batteries OK in both and line of site from one is 8 feet and on the other 12 feet. Not disconnecting for me but definitely unresponsive.
rjruby is offline
post #13498 of 13555 Old 01-14-2020, 07:55 AM
Quoted: 319 Post(s)
Liked: 127
Ok. Glad its not just me. Hopefully there will be an update/hotfix if there's enough people with the issue.
post #13499 of 13555 Old 01-14-2020, 06:02 PM
zrdb's Avatar
I can vouch that the N2 is fantastic, I've had mine for 2 months now and just sold my old Shield. BTW-get a 16 gig eMMc module with your N2, Coreelec loads faster than with a microsd card. I'm using a cheap 2.4 gig wifi remote controller with my 4 gig N2 and it works like a charm.
zrdb is offline
post #13500 of 13555 Old 01-15-2020, 06:01 AM
Quoted: 21 Post(s)
Thanks for the tip, I got the eMMc coming with it so nice to know I made the right decision. I plan on using ethernet, and a Bluetooth usb which I have to connect to my keyboard. I have the Harmony elite so will have to figure a way of setting that up but I'm sure there is good resource online to get me there so I'll cross that bridge when I get there. I think tomorrow hopefully.
Delighted your happy with the N2, gives me great confidence, I'm going to sell my shield too or give it to my brother in law, either way its gone
nvidia shield remotes , onkyo ht s7800 , samsung ks8000
