NVIDIA Shield (Android TV set-top box) - Page 482 - AVS Forum | Home Theater Discussions And Reviews
 4720Likes
post #14431 of 14456 Old 06-27-2020, 05:11 AM
JGrana's Avatar
Quoted: 246 Post(s)
Liked: 151
Originally Posted by ncted View Post
I used the Button Mapper method described here:
https://techwiser.com/remap-netflix-...hield-tv-2019/
Speaking of remapping the Netflix button, does anyone know if Logitech has added support for the new Shield?
I have stopped watching/emailing Logitech - pretty much have given up...
JGrana is offline
post #14432 of 14456 Old 06-27-2020, 05:14 AM
Orange_GT3's Avatar
Quoted: 120 Post(s)
Liked: 44
You need a Harmony Hub to connect via Bluetooth and it works perfectly.
65Goat and beerhunt like this.
Orange_GT3 is offline
post #14433 of 14456 Old 06-27-2020, 05:51 AM
Quoted: 2304 Post(s)
Liked: 1588
Some of us are waiting for the AI, Frame rate, Netflix and other new commands available in the 2019 Shield but yes for the normal 2015/2017 and 2019 stuff it works great.
Mike
Sony XBR-65X930E | ATV4K-64GB & 2-32GB 5th Gens | Nvidia Shield TV Pro 2017 | Nvidia Shield TV Pro 2019 | Logitech Harmony Elite
m_snow is offline
post #14434 of 14456 Old 06-27-2020, 09:01 AM
whiteboy714's Avatar
Quoted: 1909 Post(s)
Liked: 826
I just use the menu button and it brings up those options in the quick strings.
TCL 65R625 -- Denon X3500h -- Klipsch RP600m -- RP450C -- Ascend HTM 200 SE -- Dual Klipsch RW-10
whiteboy714 is offline
post #14435 of 14456 Old 06-27-2020, 09:29 AM
Liked: 1588
Right, but if there was a Harmony command for it you could program any key on the remote to do each function. You wouldn't have to go to the customized settings and change it each time.
JGrana likes this.
Mike
m_snow is offline
post #14436 of 14456 Old 06-27-2020, 10:44 AM
Liked: 826
I'm with you, it being one extra push it hasn't bothered me much.
post #14437 of 14456 Old 06-27-2020, 11:02 AM
Liked: 1588
For me (assuming it’s set to AI or something already) it’s a long press on the back button to get to Settings then scroll down to Remotes & Accessories then scroll to Customize Menu button then select the desired function then back out. Quick settings just has AI and frame rate. So that’s a lot of clicking, scrolling and selecting. It would be much easier to have keys programmed for some or all of the 16 functions. In any case maybe someday...
JGrana and beerhunt like this.
Mike
m_snow is offline
post #14438 of 14456 Old 06-29-2020, 02:38 PM
Stephen1254's Avatar
Quoted: 178 Post(s)
Liked: 55
Does ISP Affect Available Resolution?
I noticed some time ago that the highest resolution available on my 2017 Shield was 720p. Some online research suggested it could be an HDMI cable issue, so I swapped several cables, then went to a wireless module for my projector. I then got 4K as an available resolution. I've looked at it every few days for the past few weeks and sometimes I get 4K, sometimes 1080p. Nothing has changed in the setup.
Is it possible that my ISP is the issue, that there is some bandwidth limitation or maybe too many people in the neighborhood using at the same time that periodically won't allow streaming in 4K?
Stephen1254 is offline
post #14439 of 14456 Old 06-29-2020, 02:46 PM
Liked: 1588
Have you tried a internet speedtest app on your Shield? What was the download speed? What are you using to stream with? If you have Netflix you can go to Settings/Get Help/Check your network and it will tell you your connection speed. I believe you need at least 25 Mbps to get 4K.
Mike
m_snow is offline
post #14440 of 14456 Old 06-29-2020, 02:53 PM
Quoted: 178 Post(s)
Liked: 55
I just ran a test on my desktop and got 237Mbps. My Shield is hardwired. It certainly seems fast enough. I'm going into the menu of the Shield and looking at the display preferences, without accessing any particular app. I just can't figure out why sometimes 4K is available and sometimes only 1080p is available.
post #14441 of 14456 Old 06-29-2020, 02:56 PM
Liked: 826
Are you talking about through a streaming service like Netflix? Or the default resolution of the shield home screen?
post #14442 of 14456 Old 06-29-2020, 03:08 PM
Quoted: 178 Post(s)
Liked: 55
It would be the default resolution of the Shield home screen.
post #14443 of 14456 Old 06-29-2020, 03:11 PM
Liked: 826
Yeah I don't see how that could have anything to do with ISP bandwidth. Sounds like a strange issue, maybe something
with EDID that for some reason the Shield is thinking that is all your device is capable of.
post #14444 of 14456 Old 06-29-2020, 03:35 PM
Liked: 1588
Got it. If it were me I’d focus on the Shield display settings. I’d also highly recommend trying certified premium HDMI cables such as the ones in the link below. Many of us use these just to rule out cables as an issue.
https://www.monoprice.com/product?p_id=15427
mjwagner and ncted like this.
Mike
m_snow is offline
post #14445 of 14456 Old 06-29-2020, 03:46 PM
Orange_GT3's Avatar
Quoted: 120 Post(s)
Liked: 44
Is there a sticky somewhere with a good starting point for all the Shield settings?
post #14446 of 14456 Old 06-29-2020, 05:29 PM
mjwagner's Avatar
Quoted: 1253 Post(s)
Liked: 1190
Not sure it covers all the settings but this is a very good reference to read thru:
https://www.nvidia.com/en-us/geforce...erything-you-/
beerhunt and Orange_GT3 like this.
Mark
mjwagner is offline
post #14447 of 14456 Old 06-29-2020, 05:36 PM
Orange_GT3's Avatar
Quoted: 120 Post(s)
Liked: 44
Thank you. I'll have a read of that.
post #14448 of 14456 Old 06-29-2020, 05:38 PM
mjwagner's Avatar
Liked: 1190
I doubt it’s an ISP issue but anything is possible. I would focus on your HDMI cables. If you are using an AVR make sure the HDMI cable from your Shield to your AVR is a Certified Premium HDMI cable (I use Monoprice 6 ft ultra slim for all my interconnects). For trouble shooting I would go direct from your Shield to your projector. You won’t have sound but so what, you are just trying to locate what is causing your video issue. If your run to the projector is over 20 feet or so I would recommend a fiber optic HDMI cable. I have used RUIPRO and DTech with good results.
3DSammy likes this.
Mark
mjwagner is offline
post #14449 of 14456 Old 06-29-2020, 06:01 PM
Liked: 826
It should be as simple as setting the resolution to 2160 59hz. Seems like something is borked if that doesn't work for you. I agree
with the recommendation for monoprice certified HDMI cables, you can also get them at amazon for a few bucks.
post #14450 of 14456 Old 06-29-2020, 06:03 PM
Orange_GT3's Avatar
Quoted: 120 Post(s)
Liked: 44
Nothing is borked for me. I was just wondering what a good starting point would be for the settings. I really haven't changed anything since it came out of the box.
Maybe you meant to reply to someone else?
post #14451 of 14456 Old 06-29-2020, 06:04 PM
Liked: 826
Ah yes my bad thought you were the guy with resolution issues.
post #14452 of 14456 Old 07-09-2020, 05:33 PM
Redmist's Avatar
Quoted: 57 Post(s)
Liked: 31
Any word on the Dolby Vision red push issue? Without proper DV, the shield is a bit of a paper weight for me.
Redmist is offline
post #14453 of 14456 Old 07-09-2020, 06:05 PM
lax01's Avatar
Quoted: 775 Post(s)
Liked: 563
Did you mean to post in this thread? https://www.avsforum.com/forum/39-ne...emote-154.html
Don't think the original Shield can do Dolby Vision....per my understanding - you need the new new
Josh
lax01 is online now
post #14454 of 14456 Old 07-09-2020, 06:07 PM
Redmist's Avatar
Quoted: 57 Post(s)
Liked: 31
Yes, sorry, if a mod could move the post, that would be good.
Redmist is offline
post #14455 of 14456 Old 07-10-2020, 08:34 PM
plissken99's Avatar
Quoted: 300 Post(s)
Liked: 95
AI upscaling all of a sudden isn’t working. Says everything is unsupported content? Why the lie?
The more things change, the more they stay the same.
Snake Plissken
plissken99 is online now
post #14456 of 14456 Old 07-10-2020, 08:44 PM
HD-Master's Avatar
Quoted: 806 Post(s)
Liked: 916
Wrong thread. This is for the older model. Only the 2019 versions have AI Upscaling.
HD-Master is online now
nvidia shield remotes , onkyo ht s7800 , samsung ks8000
