Xiaomi Mi Box - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 45Likes
post #151 of 324 Old 12-28-2016, 06:51 AM
TampopoLoco's Avatar
Originally Posted by Brajesh View Post
If you have ESFileExplorer, uninstall it and that little icon should go away.
Originally Posted by Gabre View Post
He doesnt need to uninstall it, just uncheck one of the options in ES file explorer. Forgot how its called.
Anybody got Netflix to work,also, any way to get Amazon video to work?
Sent from my Pixel XL
If there's simply a box to uncheck, would rather that than having to uninstall ESFileExplorer. Need it to sideload apps.
TampopoLoco is offline
post #152 of 324 Old 12-28-2016, 07:07 AM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
How do you sideload apps? I mean i know how,just what sourcedo you ise to find andrpid tv apps,or it can be any for regularandroid?
I would like to install amazon video amd maybe a diferent netflix app, instead the one from playstore?
Gabre is offline
post #153 of 324 Old 01-11-2017, 03:40 PM
unmesh59's Avatar
Originally Posted by zibaji View Post
My prob with this is wifi only and while using built in VLC as DLNA it freeze momentarily to buffer why the hell no ethernet?
I've been fortunate in having no problems over WiFi with any of the apps including VLC, Kodi etc but then I have an AP near this unit. I also plugged in a ASIX based USB Ethernet Adapter I own (as have others in this thread) and it was recognized and set up instantly so that is a possibility to consider.
unmesh59 is offline
post #154 of 324 Old 01-11-2017, 03:47 PM
unmesh59's Avatar
Originally Posted by Xzyl View Post
Luckily its easy enough to add a USB Ethernet adapter like I did with my Nexus Player. XDA forum even had some members that found combination Ethernet adapter / USB hub that will also give you three extra USB ports.
I was unsuccessful in finding a reference to working Ethernet adapters / USB hub on xdaforums.com. Any chance you saved a link?
unmesh59 is offline
post #155 of 324 Old 01-11-2017, 07:28 PM
Liked: 0
Does anyone else have bad wifi signal with theirs, like low penetratration? I have my Nexus player beside my mibox didn't want to remove it yet Incase I don't like the mibox and found that I would get horrible buffering and low speed with the mi box meanwhile the Nexus player goes no issues.
The boxes are behind the TV in the fireplace nook.
white_noise is offline
post #156 of 324 Old 01-19-2017, 02:29 PM
Liked: 0
If you live in Europe, geekbuying just posted a $8 coupon for the Mi Box 4K: WBRTRQJZ. It's shipped from Spain.
zaylynn is offline
post #157 of 324 Old 01-20-2017, 06:37 PM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
Any news anywhere about when could we expect Nougat 7.0 update, with support for Amazon Prime Video and other goodies?
As the last update still hasnt solved non functional Netflix...
Gabre is offline
post #158 of 324 Old 01-23-2017, 06:15 AM
vadergr's Avatar
Quoted: 137 Post(s)
Liked: 51
Both Netflix and Amazon support 4K on Mi Box ?
Is HD Audio supported from KODI or any other video player ?
vadergr is offline
post #159 of 324 Old 01-23-2017, 07:01 AM
TornadoTJ's Avatar
Quoted: 1934 Post(s)
Liked: 625
Several other boxes, including NVidia Shield.
TornadoTJ is offline
post #160 of 324 Old 01-23-2017, 07:16 AM
vadergr's Avatar
Quoted: 137 Post(s)
Liked: 51
Forgive me , i was not clear maybe.
I was only refering to MI Box (other video players was actually meant as other video apps )
So does Mi Box support 4K on Netflix and Amazon TV?
Is HD Audio suported through KODI or other video playback apps ?
vadergr is offline
post #161 of 324 Old 01-23-2017, 09:30 AM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
I would be highly against buying this MiBox again. It is a unfinished product, with issues, and no updates that would fix them.
What a waste of 140CAD dollars what I paid for it.
Gabre is offline
post #162 of 324 Old 01-23-2017, 01:23 PM
gentlejax's Avatar
Quoted: 44 Post(s)
Liked: 24
Ive not had any issues with it but maybe I am not using it for what you are. I was watching Netflix last night. not an issue.
again...that means nothing to some if they are using it totally different and it doesnt work.
gentlejax is offline
post #163 of 324 Old 01-23-2017, 01:54 PM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
NETFLIX is not working on multiple mibox-es, internet is full of complaints, its a known issue and they even issued an update that didnt fix anything.
Gabre is offline
post #164 of 324 Old 01-23-2017, 05:13 PM
Apgood's Avatar
Quoted: 158 Post(s)
Liked: 78
The latest update to the mi box fixed my Netflix issues.
Apgood is offline
post #165 of 324 Old 01-23-2017, 05:24 PM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
Great for you. Its still peice of c$&p for what Im concerned.
Gabre is offline
post #166 of 324 Old 01-24-2017, 07:00 AM
vadergr's Avatar
Quoted: 137 Post(s)
Liked: 51
Actually it has exctly the same interface with the Nvidia Shield.
Remote functions the same way as well.
If it is working properly, it should be good.
vadergr is offline
post #167 of 324 Old 01-24-2017, 07:20 AM
gentlejax's Avatar
Quoted: 44 Post(s)
Liked: 24
when you say it wont work for many on Netflix is that @4K?
Im not running it at 4K..but @ 1080p it looks great and works great.
I have had also 2 other different branded boxes that were just boxes with android loaded and some other apps. They crashed a lot and didnt play right ever. I sent them all back.
I have had no issues with this one since the start. I am using SPMC but I also use Kodi to test builds.
It may have been released with issues, just like they all seem to be, but it does have its postives and it was only $75 after tax.
You could have spent much more and had the same results.
was the SHIELD perfect from day one?
post #168 of 324 Old 01-24-2017, 08:23 AM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
Netflix wont play AT ALL
file sgart playing and after few seconds pops an Error: We have trouble playing this title right now, bla bla
Every single title. Spoke with netflix, spoke with xiaomi, nobody wont fix it.
And then I started searching online,and found hundreds of people with same Error
xiaomis forum is full of it.
Gabre is offline
post #169 of 324 Old 01-25-2017, 11:54 AM
gentlejax's Avatar
Quoted: 44 Post(s)
Liked: 24
Ive read some posts on it. read that some had issues that were fixed when updated. Mine has never had an issue. and it ran circles around the other 2 boxes I had.
I have another box coming and I am not sure its going to be better although hardware wise its 2x the box that the MiBox is.
but i have been happy with the performance so far with mine.
Do you have some kind of hard numbers on the amount of malfunctioning units ? I mean better than saying "all over the forum" I have been on the forum also
post #170 of 324 Old 01-25-2017, 12:00 PM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
Bud, it is a known issue. XIAOMI forum is full of it, reddit is full of it, its not an isolated case, members here were writing about if you go few pages back.
Xiaomi admited to me that they know about the issue. I literally called them.
Gabre is offline
post #171 of 324 Old 01-25-2017, 12:45 PM
psuKinger's Avatar
Quoted: 1503 Post(s)
Liked: 610
My experiences (generically), not specific tot he Mi box, have always been that streaming services like Netflix (perhaps the poster child) have unparalleled advanced server capabilities, and can do a great job in accomodating whatever WiFi connection somebody has and optimize the stream appropriately. They do this by owning some pretty advanced server hardware and using pretty modern file compression techniques...
Live TV, on the other hand, uses MPEG2, which is a pretty old (and inefficient) form of file compression. My primary interest in a Mi box, from the very beginning, was a hope that it would be a lower-cost (relative to a Shield) alternative to my Nexus Player for streaming Live TV + DVR to "less important TVs" in my home (I have 4 Shields on the 4 most critical sets). The lack of ethernet connection concerned me initially... and based on the feedback I see on here, I don't think it's going to serve my purposes any better than my Nexus Player already does (which is poor enough that I'd be willing to spend money on an upgrade, and the Mi box could have been that "upgrade", if it was...).
I wish they had opted for a hard-wired ethernet port option...
psuKinger is offline
post #172 of 324 Old 01-26-2017, 06:01 AM
Quoted: 17 Post(s)
Liked: 8
Pretty sure Amazon Prime is a SHIELD exclusive when it comes to AndroidTV.
npaladin2000 is offline
post #173 of 324 Old 01-26-2017, 07:00 AM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
Hopefully it will be possible to sideload it,
Here in Canada, when ai try to sodeload it, Prime launcher gives me options of 3 countries and I camt pick Canada, and if I pick US, wont work due to location
Gabre is offline
post #174 of 324 Old 01-26-2017, 07:05 AM
Quoted: 17 Post(s)
Liked: 8
I suppose that depends on how deeply embedded it is...and if there's any reliance on Tegra-specific functions. But it's not a seperate app.
post #175 of 324 Old 01-26-2017, 08:54 AM
gentlejax's Avatar
Quoted: 44 Post(s)
Liked: 24
I have a MiBox but since I bought a newer box on impulse I am going to run it and see if the hardware upgrades are worth it..
my question is since this MiBOX is a AndroidTV box and I had to get up in google when I got it will I need to do something to it before I give it to my brother?
I dont want him in my google or my emails.
I ask this because on the Amazon devices you must deregister it from under your name if you transfer ownership otherwise they have account access in your name.
what do I do about this google MiBox or is it tied to me like an amazon fire stick?
post #176 of 324 Old 01-26-2017, 08:02 PM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
just go into settings, and do a factory reset, that will delete all your information from the box, and bring it back to factory condition.
Gabre is offline
post #177 of 324 Old 01-28-2017, 10:12 AM
Quoted: 1933 Post(s)
Liked: 1648
hi .. does anybody know where i can order a replacement remote? mine got submerged in water and i lost the battery cover and lost some functionality..also , does anyone know of a good alternative remote? will the fire tv remote work .. if so does it pair the same as the original or as an extra device control in settings? thanks..
Lp85253 is online now
post #178 of 324 Old 02-01-2017, 08:28 PM
Liked: 1648
just an update for anyone interested. .. xiaomi is not selling replacement remotes yet... they suggested i find a compatible remote... i am currently using my tv remote thru cec& an air mouse remote ... the air mouse works well for most content ... the power button doesn't work though...
post #179 of 324 Old 02-04-2017, 03:09 PM
Liked: 1
Lack of Ethernet is a no no.
wurm02 is offline
post #180 of 324 Old 02-15-2017, 12:48 PM
Liked: 0
Is anybody here from Europe? How's it for $72 from Geekbuying?
anden09 is offline
