Official ROKU 4K (HDR) Premiere +/Ultra Owners Thread - Page 360 - AVS Forum | Home Theater Discussions And Reviews
 9692Likes
post #10771 of 11522 Old 11-18-2018, 05:31 PM
atc98092's Avatar
Quoted: 1304 Post(s)
Liked: 526
I won't continue beyond this, because while we are discussing on-topic it probably doesn't interest a lot of people. RMP is only the front end user interface. The Roku firmware is responsible for the actual playback, and controls what media is supported. Dale has confirmed this multiple times. It is not capable of transcoding, and has no such ability. All transcoding must be performed before the stream is sent to the player. I realize that Roku doesn't publicly acknowledge everything their players support, and it makes it very frustrating for us that offer to support.
I hope I'm not coming across as combative or angry, because I'm not. But Roku does frustrate me sometimes with their lack of clarity about what their players can and can't do.
Dan
Samsung JU7100 4K TV, Yamaha RX-V583, Nvidia Shield, a number of Roku players and TVs, Windows 10 media server with Serviio and Plex. Other players and TVs as well.
atc98092 is offline
post #10772 of 11522 Old 11-18-2018, 05:38 PM
rdgcss's Avatar
Quoted: 195 Post(s)
Liked: 82
I think everyone will agree that almost all software & hardware contain 1 or bugs. Being a software developer I read lots of documentation. I don’t think I have ever read any documentation longer than 1 page that did not contain an error.
rdgcss is offline
post #10773 of 11522 Old 11-19-2018, 06:11 AM
MacinMan's Avatar
Quoted: 1054 Post(s)
Liked: 266
@atc98092 I just checked my 2017 Ultra (4660RW) and for video says (H.264/262/265 HEVC)
That's under OS 9.0.0.
MacinMan is offline
post #10774 of 11522 Old 11-19-2018, 06:22 AM
atc98092's Avatar
Liked: 526
That indicates MPEG-2 support. So far people have confirmed it for the two versions of Ultra (4640 and 4660). Haven't heard if the Premiere+ or any of the other new 4K capable players show that. I'm not going to buy one just to check. But it would be interesting to find out if the new Stick+ supports it as well.
Dan
atc98092 is offline
post #10775 of 11522 Old 11-19-2018, 06:27 AM
MacinMan's Avatar
Liked: 266
I can confirm it for the Premiere+, just checked. Still have issues with files with a DTS track not wanting to play, but Dolby seems to work fine. I tried Robots which is H.264 and standard DTS 5.1 (no HD audio) in an MKV and it wouldn't play with RMP. Reports damaged. The file plays with other devices though. I should try Titan A.E., its Mpeg2, with DTS, the other is AVC.
MacinMan is offline
post #10776 of 11522 Old 11-19-2018, 06:33 AM
atc98092's Avatar
Liked: 526
I probably have some DVD rips with DTS audio, but not certain what titles. I'll had to do some digging and see if DTS passthrough is still working. I do know that for some time I've had issues with Blu Ray rips that used to allow the core audio from DTS Master Audio to passthrough are now causing issues. So I've had to adjust my Serviio profiles to transcode the audio into DD. It used to work fine, but some Roku firmware update in the past 6 months mucked it up. Yeah, what a surprise.
Dan
atc98092 is offline
post #10777 of 11522 Old 11-19-2018, 06:42 AM
MacinMan's Avatar
Liked: 266
Titan A.E. is a DVD rip for me, and DTS plays, but it has the same issue as Plex, it's very broken up and choppy. It seems to be based on the Hardware / Software being used. The Black streaming stick from 2016 still works with DTS, but newer units do not. They have the broken audio with DTS. However, Plex still has a work around that sometimes works, and that is to set the video to full quality, and select the standard DTS track instead of HD. However, RMP isn't as friendly, and depending on the file in Plex, can lead to extra buffering, so for Roku, I've found it better to just stick with stereo, or a form of Dolby for audio, and use DTS with my blu-ray players. You seem to be happy with your Shield might consider getting one, but at this point, I really don't need it since DLNA with the Sony players is reliable, and, at least for my 1080p Setup, I can use PCM 5.1 with the Apple TV. It would really only be a concern for the 4K setup, if I ever decided to locally stream 4k content, which, I currently don't.
By the way, Just wanted to clarify the Premiere+ DOES support Mpeg2 in RMP.
MacinMan is offline
post #10778 of 11522 Old 11-19-2018, 07:02 AM
atc98092's Avatar
Liked: 526
The most significant benefit (for me) with the Shield is playing everything (including lossless audio) without transcoding, and the ability to select and display captions. Since Roku doesn't do either, that's a huge plus. My Sony BD player will stream TrueHD but not DTS/MA, and captions only work for DVD rips and BD rips into the M2TS container. If a BD rip is in an MKV container (which most of mine are) the Sony recognizes there are captions but will not display them. If I remux the file into the M2TS container, then they display. But it's not worth the effort to remux them all.
Dan
atc98092 is offline
post #10779 of 11522 Old 11-19-2018, 08:46 AM
naustin's Avatar
Quoted: 1638 Post(s)
Liked: 1018
My Roku Stick+ and 2016 Ultra both just updated from 9.0.0 4052 to 9.0.0 build 4072.
galonzo likes this.
naustin is offline
post #10780 of 11522 Old 11-19-2018, 08:55 AM
MacinMan's Avatar
Liked: 266
I was just going to post that, my 2017 Ultra is in the process of updating to the same build now. Still nothing offered for the Premiere+.
Out of my 3 Roku devices, only the 2017 Ultra is getting the updates currently, the Premiere+ in the bedroom, and Streaming stick on my test monitor are both 2016 models and haven't updated past builds of 8.1 yet.
MacinMan is offline
post #10781 of 11522 Old 11-19-2018, 11:11 AM
LG8600User's Avatar
Quoted: 18 Post(s)
Liked: 24
Manual updating to 9.0.0-4072 has been enabled for my SS (3800) and SS+ (3810)
As far as RMP MPEG2 support goes, both models indicate support (H262), but on 8.1.0, very few of any MPEG2 encoded files I threw at it in either MPG or MKV format played or played correctedly - many weren't even seen by RMP.
On 9.0.0-4072, the same results were seen, aside from a few of the videos that played incorrectly on 8.1.0, played correctly.
LG8600User is offline
post #10782 of 11522 Old 11-19-2018, 11:23 AM
atc98092's Avatar
Liked: 526
Do you have native framerate enabled? If so, I suggest turning it off and trying the MPEG-2 video again. It makes a difference with my Ultra. They play, but hard to watch because of stuttering.
Dan
atc98092 is offline
post #10783 of 11522 Old 11-19-2018, 11:30 AM
MacinMan's Avatar
Liked: 266
My streaming stick is model 3600, not sure off the top of my head the Premiere+ is.
MacinMan is offline
post #10784 of 11522 Old 11-19-2018, 11:47 AM
atc98092's Avatar
Liked: 526
Just pulled my 3600 out of my suitcase, and saw it was still on 8.1.0.4645, but a 9.0 version is now available. I haven't traveled since Sept, so it's been offline since then. With 8.1 H.262 support was not listed, as I remembered and expected. Updating to 9.0 didn't change that, again as I expected. My guess is H.262 support is only going to be available for the 5th generation and later, and maybe even only the 4K capable versions. It sure would be nice if Roku would acknowledge which players will support it.
Dan
atc98092 is offline
post #10785 of 11522 Old 11-19-2018, 11:51 AM
MacinMan's Avatar
Liked: 266
Mine has 8.1.0 build 4145, not OS 9 here as of now for that device or Premiere+. FYI, DTS still works correctly on the 3600, it's the Premiere+ and Ultra that have issues, plus all current models of other Roku players.
MacinMan is offline
post #10786 of 11522 Old 11-19-2018, 03:07 PM
Liked: 0
The Roku Media Player is the only one I know that will play H.262 without transcoding, and again that's apparently only on the Ultra. Plex and Chaneru will transcode, although I've never tried forcing Plex into Direct Play with H.262 content. It might work, maybe.
But again, check the Help panel in RMP, and the Supported Files panel lists the supported codecs. It should say H.262, since it's there for JoeKustra, and he has a 4660. On mine, the line says:
Video(H.264/262/265HVEC) - MKV, MOV, MP4.
As I mentioned, they've never listed the TS container, but it works as well.
I use the NextPVR plug-in for my Roku Ultra 4640 Plex client and am able to force Direct Play of MPEG2 TS container live OTA streams from the NextPVR app on my PC. I can confirm this is happening because the Plex transcoder isn't in use in the Windows Task Manager (plus the transcoder will push my underpowered CPU to 100% use).
However, I can't get NextPVR MPEG2 .ts recorded files to play in RMP (it indicates H.262 compatibility in help). I get the error message "The codec used to compress the video is not supported." These files will play forcing Direct Play in the Roku Plex client, but there are audio and video problems.
For some strange reason, the NextPVR live OTA streams play just fine on the Roku without any transcoding. But maybe that shouldn't be a surprise since the Roku TV's have to tackle these OTA streams.
azurenepsa is offline
post #10787 of 11522 Old 11-19-2018, 03:12 PM
dmarvin79's Avatar
Both my Streaming Stick +'s and Ultra updated to V9 today, and I now have Dolby Digital on all the live channels of DirecTV Now. Not sure if it's the firmware or the DirecTV Now app, but I'm glad to hear it.
Dennis
dmarvin79 is offline
post #10788 of 11522 Old 11-19-2018, 03:31 PM
UHD Addict
aaronwt's Avatar
Quoted: 8913 Post(s)
Liked: 5696
Originally Posted by rakstr View Post
Are you sure about the MPEG2? The reason I ask is that it's not listed on the specs and all the discussion on PLEX says it's not supported.
I have a PLEX server and it needs to transcode liveTV (MPEG2) to H.264 in order to play on the ROKU. It seems to be "common knowledge" that only the NVidea Shield and a couple native Android boxes support MPEG2.
I was hoping that would change with the patent expiration.
TIA.
Plex shows direct playback from my Broadcast MPEG2 recordings. It doesn't show that it's transcoding the video. This is on my 2016 Ultra and a Streaming Stick+.
53TB unRAID2--49TB unRAID3--45TB unRAID1a
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #10789 of 11522 Old 11-19-2018, 05:15 PM
rakstr's Avatar
Quoted: 382 Post(s)
Liked: 169
Can you give some screen scrapes from your setup? It's not that way on the 2017 Ultra, nor Stick, nor Stick+. See attached, all on 9.0, Theater is the Ultra.
Also, what does your server/tuner setup look like? I've got 2 Hauppauge quad cards in a 4th gen i7 setup. The Ultra is wired on switched Gb from the server and the sticks/stick+ are wireless AC.
ID:	2485092   Click image for larger version
ID:	2485094   Click image for larger version
ID:	2485096   Click image for larger version
rakstr is online now
post #10790 of 11522 Old 11-19-2018, 06:00 PM
UHD Addict
aaronwt's Avatar
Liked: 5696
Is it because I am not on 9.0 yet?
Sent from my Nexus 7(16GB) using Tapatalk
aaronwt is offline
post #10791 of 11522 Old 11-19-2018, 06:04 PM
rakstr's Avatar
Quoted: 382 Post(s)
Liked: 169
Not for me, same results before I upgraded. Can you share the screen scrapes and setup info????
post #10792 of 11522 Old 11-19-2018, 08:06 PM
Liked: 0
Actually, it looks like my NextPVR recorded MPEG2 .ts files do play fine forcing Direct Play in the Roku Plex client. For some reason, I was experiencing some audio/video problems when I previously played one of the files.
I've attached images showing what I see in the Plex server status menu with Direct Play forced and what I see when I force transcoding. This video was recorded in NextPVR.
In the Roku Plex client, under Settings > Video, I have 'Direct Play' set to 'Forced'. I can also have it set to 'Auto' or 'Disable' and then force Direct Play per video by adjusting the settings on the video's menu page.
ID:	2485130   Click image for larger version
post #10793 of 11522 Old 11-19-2018, 09:14 PM
Christcorp's Avatar
Quoted: 442 Post(s)
Liked: 239
My roku ultra finally got the update to 9.0 today. It went straight to 4072. So far so good. Even my DirectvNow seems to be running a bit faster. Not as fast as my Apple tv 4K, but definitely faster. Loading time use to take 8-10 seconds and changing channels was 6-8 seconds. Now, loading the app takes about 4 seconds and changing channels averages 4-5 seconds. At least some improvement and a bit more bearable. Now, if my Roku premiere in the bedroom would update I'd be happy.
Michael
LG OLED65B7P, Yamaha 7810, 5.1.2 ATMOS
Philips 7302 BR/DV, ATV4K, Roku Ultra, Roku Premiere, Roku Stick+
Christcorp is offline
post #10794 of 11522 Old 11-19-2018, 10:22 PM
UHD Addict
aaronwt's Avatar
Liked: 5696
I got 9.0 tonight. I remember what I did. I had selected the direct play option so it would play more of my UHD rips. I just tried it and it is also direct playing mynmpeg2 broadcast recordings.
Sent from my Tab S 10.5 using Tapatalk
aaronwt is offline
post #10795 of 11522 Old 11-20-2018, 02:21 AM
lujan's Avatar
Quoted: 4280 Post(s)
Liked: 2414
I got 9.0 on the streaming stick + but not on the 2016 Ultra.
lujan
506 Ultra HD
721 HD
4 SD
lujan is online now
post #10796 of 11522 Old 11-20-2018, 04:45 AM
subacabra's Avatar
Quoted: 1562 Post(s)
Liked: 4592
Both my sticks and ultra got the new update last night.
Now getting dd on live channels with DtvNow.
Figures I just got the new fire stick 4k for that reason.
Although I must say the fire stick is way faster to load and change channels etc with DtvNow.
Edit:
Did some testing between Roku Ultra and Fire stick 4k and the Roku is almost as fast now to load/change channels on DtvNow.
subacabra is offline
post #10797 of 11522 Old 11-21-2018, 05:24 AM
MacinMan's Avatar
Liked: 266
Edit:
I think the most likely cause of Roku being slower then other devices on certain things is because it's not as well optimized. Roku seems to be like Microsoft when it comes to backward compatibility, and trying to keep as much legacy support as possible. While Amazon, Apple, Google, etc seem to only support a few models and try to keep optimized for the best experience with the latest software / content. I'm sure Roku tries to do the same, but they have more to support, plus when I did research, Roku is harder to write channels for then other platforms. That may have changed with newer developer tools, but also may explain why other platforms get a better app too.
MacinMan is offline
post #10798 of 11522 Old 11-21-2018, 07:41 AM
roland6465's Avatar
Quoted: 379 Post(s)
Liked: 373
I was able to manually update to 9.0 this morning on my Stick+. Hopefully it fixed my issue with display mode switching from what I set (4K/HDR/30) to Auto every couple of days.
galonzo likes this.
roland6465 is offline
post #10799 of 11522 Old 11-21-2018, 10:10 AM
Quoted: 194 Post(s)
Liked: 95
Remember with PLEX the PLEX server is doing the heavy lifting not the ROKU.
Johnson-from-Arizona is offline
post #10800 of 11522 Old 11-21-2018, 11:16 AM
UHD Addict
aaronwt's Avatar
Liked: 5696
Not when playing back directly with no transcoding.
aaronwt is offline
hdr , roku ultra , settings , ultra hd
