Official ROKU 4K (HDR) Premiere +/Ultra Owners Thread - Page 383 - AVS Forum | Home Theater Discussions And Reviews
 9767Likes
post #11461 of 11637 Old 05-13-2019, 02:34 PM
rakstr's Avatar
Quoted: 390 Post(s)
Liked: 175
I'm sorry I can't seem to follow what you're complaining about. Enjoy.
Originally Posted by Johnson-from-Arizona View Post
You imply wrongly of course that some how what we end users want has something to do with the way ROKU develops it's firwmare.
ROKU announced the release. The delay this time is long for even them.
Some part of that observation you think has something to do with what I want with my ROKU?
rakstr is offline
post #11462 of 11637 Old 05-13-2019, 05:33 PM
Quoted: 201 Post(s)
Liked: 99
"I'm sorry I can't seem to follow what you're complaining about."
You don't understand it but you feel free to express your criticism? I usually try to understand what I'm criticizing.
It was pretty easy to follow. ROKU announced a FW update. They usually take a certain amount of time. This time its even longer then the previous times. A much longer time in fact. ROKU continues to be their own worse enemy.
Johnson-from-Arizona is offline
post #11463 of 11637 Old 05-15-2019, 05:51 AM
artur9's Avatar
Quoted: 991 Post(s)
Liked: 377
Maybe Roku is finally learning caution ;-)
Anywho, I finally got a 4K TV. IIUC, there's no way to get the Roku Ultra to send native resolution to let the TV do the upscaling?
What settings should I use on the Ultra to yield the best 4k "experience"?
artur9 is offline
post #11464 of 11637 Old 05-15-2019, 06:03 AM
atc98092's Avatar
Quoted: 1329 Post(s)
Liked: 545
You are correct, there is no resolution switching ability in any Roku device. Whatever resolution you have the Roku set to is what it will output, regardless of original resolution. Depending on the material, it may be preferable to let the Roku upscale, or other times the TV can do a better job. All you can really do is test it each way and see if one way looks better than another. If the TV does a better job, that means changing the Roku resolution when watching 4K material vs. other content.
The Nvidia Shield will switch resolution on the fly, along with framerate, and it's the only reasonably priced player that does to my knowledge. Some of the inexpensive Android boxes might, but they are generally lacking support for other things.
Dan
Samsung JU7100 4K TV, Yamaha RX-V583, Nvidia Shield, a number of Roku players and TVs, Windows 10 media server with Serviio and Plex. Other players and TVs as well.
atc98092 is offline
post #11465 of 11637 Old 05-16-2019, 11:24 AM
Erod's Avatar
Quoted: 1222 Post(s)
Liked: 742
How much better, if any, is the picture from a Roku Ultra versus a PS4 Pro?
Video: JVC RS620/X9500 projector, Stewart ST130 screen, Panasonic ub820 UHD player
Audio: Anthem AVM60 preamp, Anthem MCA525 amp, B&K Reference 125.7 amp
Subs: dual SVS PC-12 cylinders
Speakers: Jamo 626k4 in-wall mains, Jamo 631k4 bi/dipole surrounds, DefTech DI6.5R heights
Erod is offline
post #11466 of 11637 Old 05-17-2019, 12:48 AM
LG8600User's Avatar
Liked: 24
SS+ (3810) Updated to 9.1.0 Build 4095-50
As stated my SS+ (3810) updated to 9.1.0 Build 4095-50 last night.
SS (3800) did not update nor was a manual update available.
There is a new Setting: Payment Method (shows current method and allows you to update it)
Reset the theme as per usual, and a "featured" theme (National Streaming Week) was also made available/enabled.
Seems more stable especially with Advanced Display Settings (Auto-adjust display refresh rate, HDR Subsampling) enabled/switched.
Did get the occasional HDCP error when switching refresh rates, but it recovered when playing other content then back to the original "problem" content.
Didn't specifically test any of the advertised 9.1 "features" (Voice, Guest, Search, Offers) as I don't use nor care about such "features".
galonzo and naustin like this.
LG8600User is offline
post #11467 of 11637 Old 05-17-2019, 03:22 PM
JackB's Avatar
Quoted: 1353 Post(s)
Liked: 330
So I set my Ultra for Auto Detect. It correctly set the resolution to 1080P for my HD projector. It also detected 4K HDR at 60Hz for my second projector. When I went to Advanced Display Settings under System the Ultra offered two parameters; Auto-adjust display refresh rate and HDR subsampling. The first had Enabled or Disabled. Which should I choose?
Secondly, HDR subsampling offers 4.2.0 or 4.2.2. Does it make a difference what I choose?
I wouldn't ask these questions as trying them would probably work but the matrix of combinations gets pretty complex and I have assumed that experience on this thread as already determined the best combination. I would appreciate your experienced recommendation.
Jack
JackB is offline
post #11468 of 11637 Old 05-17-2019, 04:48 PM
atc98092's Avatar
Liked: 545
For the Auto-Refresh rate, it really depends on your display. Earlier firmware versions didn't play nice on my 4K Samsung. I think that was resolved, but I've moved my Ultra to a 1080 plasma so can't compare. In general I've left the refresh rate off because it impacted MPEG-2 playback in a detrimental way. For the sub-sampling, what I found was again it is display dependent. With my Samsung, 4:2:2 caused color banding, while 4:2:0 was much smoother. Other users report different results, so just try both and see how it looks. For me, it was most noticeable with sky shots.
Dan
atc98092 is offline
post #11469 of 11637 Old 05-18-2019, 07:54 PM
Edmund's Avatar
Quoted: 74 Post(s)
Liked: 38
If you need some extra wifi roku remotes that can control the volume of tv:
https://www.ebay.com/itm/Lot-of-10-R...53.m1438.l2649
Edmund is offline
post #11470 of 11637 Old 06-01-2019, 10:24 AM
Quoted: 201 Post(s)
Liked: 99
I guess I just dreamed ROKU said we'd have a firmware update. ROKU's version of Inception......
post #11471 of 11637 Old 06-02-2019, 12:14 AM
naustin's Avatar
Quoted: 1665 Post(s)
Liked: 1038
So much for the April 9 Blog post https://blog.roku.com/os-9-1
naustin is online now
post #11472 of 11637 Old 06-02-2019, 09:36 AM
Quoted: 201 Post(s)
Liked: 99
I honestly don't really care anymore. ROKU lost me some time ago. I'd be really annoyed had I bought a TV with ROKU integrated. Moving soon and leaving both ROKU's behind. They both have the optical out too like somehow that makes them "better".
Maybe the ROKU engineers all went to Boeing for the initial 737 Max anti stall software development so ROKU is stalled?
I know, I know. Disgusting.
post #11473 of 11637 Old 06-02-2019, 09:46 AM
JackB's Avatar
Liked: 330
What's the problem? My Roku Ultra works great and I use it daily.
rakstr, BJHebert and kbmb like this.
Jack
JackB is offline
post #11474 of 11637 Old 06-02-2019, 11:22 AM
UHD Addict
aaronwt's Avatar
Quoted: 8970 Post(s)
Liked: 5751
WHy is that? It's still Spring. Summer doesn''t start until June 21st.
william06 likes this.
49TB unRAID1a--53TB unRAID2--73TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #11475 of 11637 Old 06-02-2019, 12:09 PM
naustin's Avatar
Liked: 1038
Early summer is the later date for the Roku TVs.
Personally I don't care until there is a Dolby Vision version of the Roku streamers. 9.0 is adequate for my non DV needs. For DV I use my more modern & more expensive AppleTV 4Ks.
post #11476 of 11637 Old 06-02-2019, 01:50 PM
LG8600User's Avatar
Liked: 24
2 of 3 devices have 9.1-4111
2 of my 3 Roku devices (3810 and 2710) have each received 2 (two) different builds of 9.1: 4095 and 4111
My third device (3800) has yet to receive 9.1
Clearly a very staggered rollout, and some significant issues must have been found in 4095 resulting in the newer 4111 build (to test for correction) for initial 9.1 devices before releasing any build at all for non-upgraded devices.
I'd speculate issues with the new functionality in 9.1 that I don't use (be nice if they focused more on corrective fixes for extant functionality first) are the source of the delay.
post #11477 of 11637 Old 06-02-2019, 03:53 PM
UHD Addict
aaronwt's Avatar
Liked: 5751
They installed 9.1 in my TCL Roku TV. But I that was because 9.0 had major issues in my setup. They rolled me back to 8.x for several weeks. And when they pushed 9.1 to the TV, everything was working correctly in my setup. Just like it did with 8.x
galonzo likes this.
aaronwt is offline
post #11478 of 11637 Old 06-02-2019, 04:05 PM
tngiloy's Avatar
Quoted: 472 Post(s)
Liked: 299
When they update a box do you get a message or notification that its been updated?
Or do you need to go into setup to check if its been updated?
"When all else fails, read the manual."
tngiloy is offline
post #11479 of 11637 Old 06-02-2019, 05:40 PM
mzs22's Avatar
Quoted: 226 Post(s)
Liked: 91
I started watching Russian Doll on netflix on my Roku ultra and had to turn the volume up to reference,when I watch netflix on my xbox one x I don't turn it up anywhere near that high to get good sound. Anyone have that same issue when using their roku ?
mzs22 is offline
post #11480 of 11637 Old 06-03-2019, 05:18 AM
Zoland2020's Avatar
Quoted: 147 Post(s)
Liked: 84
@mzs22 I have that issue too, expect that I'm on Denon and not Yamaha, but yeah I also had to turn the volume up to 60 to get good sound yet on other devices it's already loud enough to me at 45-50.
My current mancave room setup:
Vizio V436-G1 4K HDR TV | LG UBK90 4K Blu-ray player | Denon AVR-S740H AV Receiver (running 5.1.2 Dolby Atmos and DTS:X) | Xbox One X | Roku Ultra (2018 model)
Zoland2020 is offline
post #11481 of 11637 Old 06-03-2019, 06:13 AM
UHD Addict
aaronwt's Avatar
Liked: 5751
When I was updated to 9.1 I did not get a message. It had been updated for a day and a half or so when I looked and found out I was on 9.1.
But that also might have been because they had manually pushed the update to my set?
Sent from my Nexus 7(16GB)
galonzo likes this.
aaronwt is offline
post #11482 of 11637 Old 06-03-2019, 06:16 AM
atc98092's Avatar
Liked: 545
I've never seen an update notification on any Roku. If you don't notice any particular changes, you'll only know by checking the update menu to see the last date updated.
Dan
atc98092 is offline
post #11483 of 11637 Old 06-03-2019, 06:33 AM
Quoted: 201 Post(s)
Liked: 99
One of these days the update is supposed to change the way the ROKU looks. You'd know then I guess. Otherwise you notice when you check. Practically speaking Roku owns your device more or less. They do what they want as a result. Notify you the end user? Not a chance.
post #11484 of 11637 Old 06-03-2019, 12:42 PM
galonzo's Avatar
Quoted: 1308 Post(s)
Liked: 1656
It looks like mine was updated to 9.1.4111 three days ago; now Netfix doesn't respect frame matching (everything is being output at 60p) I'll try a reset...
Main: UN78HU9000/SEK-3500 | X4200W (Klipsch/HSU 5.1.2) | UDP-203 (fw 65-0131) | TiVo Bolt | Roku P+
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | AppleTV4K | TiVo Mini
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - UHD Digital codes (and some HD codes)
galonzo is offline
post #11485 of 11637 Old 06-03-2019, 01:08 PM
atc98092's Avatar
Liked: 545
I think I've seen a report of this on the Roku forum. It appears that it was a Netflix update, not the 9.1 update. Someone with 9.0 was still reporting the problem.
aaronwt and galonzo like this.
Dan
atc98092 is offline
post #11486 of 11637 Old 06-07-2019, 06:09 AM
Quoted: 201 Post(s)
Liked: 99
FW finally updated. Had to redo the display information as the new FW did not know it was a UHD HDCP 2.2 display again. Maybe they reworked that part of the code so it needed to learn again the display HDMI information? Who knows.
Once set last night did not lose the information playing with it. Will watch of course over time.
Captain Marvel off VUDU was fine, UHD, Atmos, etc. Played perfectly.
post #11487 of 11637 Old 06-08-2019, 04:08 PM
Quoted: 201 Post(s)
Liked: 99
Checking today. Seems to be holding HDCP 2.2.
naustin likes this.
post #11488 of 11637 Old 06-11-2019, 08:55 AM
artur9's Avatar
Quoted: 991 Post(s)
Liked: 377
Googled around and found no solution. Maybe one of you know what to do?
Watching Killing Eve via Roku Ultra Hulu Beta into HDMI port #3 . It was zoomed in so that only the top left quadrant was visible. It was a 4K image and nothing fixed it. Tried forcing the Roku to 4K HDR 60Hz, using Hulu non-beta, unplugged the A8F, the wide button on the remote said "Function not available."
It basically looked like the TV was in HD mode when it needed to switch to UltraHD.
How does one fix this? There doesn't seem to be a way to change the A8F's resolution.
P.S. To actually watch the show I used the built-in Hulu app but I don't know what resolution that was since the display button doesn't do anything in that mode.
artur9 is offline
post #11489 of 11637 Old 06-11-2019, 10:12 AM
brotony's Avatar
Quoted: 417 Post(s)
Liked: 340
My Roku Ultra with framerate auto switching on Hulu (my TV Samsung JS9500 native resolution 4K @60p , HDR capable) will do that zoom on resume, you describe. My only fix for Hulu on Roku is to disable the framerate auto switching feature in advanced video settings. For me, the framerate feature will also cause lip sync issues on resume. Starting over may correct the issue; resume from a previous incomplete view may be problematic.
Long time issue that appears to be Hulu app related on the Roku. Hulu support finally acknowledged it was an issue with their app on Roku but they've yet to fix it. Let them know and remind them it's ongoing without a fix yet. For this reason, I prefer to use the Apple TV 4K for Hulu on-demand because I like native framerate. Also, Roku framerate auto switching appears broken on Netflix since last app update; others are also reporting fixed refresh at 60 Hz in Netflix with their Roku.
I may even get HDCP errors with auto play enabled, watching clips on Hulu with the sorry framerate switching feature enabled. But Roku support feels this is an HDMI handshake error the Roku has with my TV. They've been unable to resolve this; replacing my Roku Ultra multiple times with similar repeatability on each replacement. However, it also appears to be induced by enabling auto framerate switching. I also find it odd that Hulu short clips will resume where previously watched, compounding issues with framerate auto switching enabled. They should start over at beginning by default, particularly with auto play, IMO. Very odd with all the issues the Hulu app errors randomly duplicating. Maybe Hulu should offer the restart from beginning option when resuming to eliminate the chances of duplicating these errors?
Sent from my PH-1 using Tapatalk
galonzo and artur9 like this.
brotony is online now
post #11490 of 11637 Old 06-14-2019, 07:58 AM
JGM
JGM's Avatar
Quoted: 152 Post(s)
Liked: 95
Initial experience with Sling on Roku -- not specifically too good
Took the plunge to fully cut the cord and bought a couple of Roku Premieres.
I had already researched live cable replacement options and settled on YouTube TV as the probable best option. But the Roku came with 30 days free Sling trial, so I figured I'd give that a try first (which is presumably exactly what Sling wants).
First problem came when I was anxious to finish the Roku setup and elected not to start the Sling trial during that process (assuming it would be available after setup). It turns out that the 30-day trial is ONLY available when you select it during the initial setup. It took a chat with a special rep at Sling (via a pointer given by the Roku rep) to get a code for a 30 day trial.
Sling install went fine. Everything worked out of the gate EXCEPT attempt to connect to live TV, which invariably spun for a few moments before failing with error message 8-270, telling me to try again in 24 hours. Nice first impression.
24 hours later I had a rather hilariously ineffective chat exchange with a nice Sling rep, involving multiple permutations of resets and reinstalls, and which basically concluded with them promising to "escalate" the issue to their technical team but that no problem ticket, return call, or other follow-up was possible.
48 hours after that the problem remained and I canceled. In the meantime YTTV, Netflix, Hulu and others work flawlessly.
A search here and on Reddit shows that this problem has existed in some form for several YEARS without anybody seeming to have a clue as to how to resolve.
Even had it worked, I suspect I still would have moved to YTTV due to the larger number of accounts/streams and the better DVR, as well as what I saw as a confusing channel lineup/display. This is a massive fail by Sling -- particularly given their huge current advertising push.
JoeKustra likes this.
JGM is offline
hdr , roku ultra , settings , ultra hd
