Official ROKU 4K (HDR) Premiere +/Ultra Owners Thread - Page 402 - AVS Forum | Home Theater Discussions And Reviews
 10629Likes
post #12031 of 12902 Old 11-04-2019, 08:26 AM
BobDyl's Avatar
Quoted: 146 Post(s)
Liked: 134
This latest update has semi-bricked my 2016 Roku Ultra. It's only displaying at 1080p, auto resolution is not working, but even worse, it cannot find any sync at all about half the time, so just a black screen. Absolutely zero problems with 4K prior to this update.
5.2.4: JVC RS540 | Stewart Greyhawk 120” 2.35 | AudioControl AVR-9 | Oppo 203 | TV 4K | Xbox One X | Roku Ultra | Triad Rackamp 700 | Gold/6 LCR | Silver surrounds & heights | Bronze/6 subs
5.1: Sony 940E | AudioControl AVR-7 | TV 4K | Xbox One X | Roku Ultra | Tivo Roamio OTA | Triad Rackamp 300 | Bronze/4 LCRS | Bronze/4 sub
BobDyl is online now
post #12032 of 12902 Old 11-04-2019, 12:51 PM
naustin's Avatar
Quoted: 1886 Post(s)
Liked: 1218
Sorry about that. I would suggest unplugging the Ultra to get a clean restart, followed by turning Off Native Refresh Rate and setting Subsampling to 4:2:0. Also turn off any Screen Savers.
After all that unplug the Ultra and restart. Then check for any Updates again. A little drastic but with a semi-bricked Roku, probably your best option.
P.S. Native Frame rate is an overrated headache with many TVs. Good luck.
naustin is online now
post #12033 of 12902 Old 11-04-2019, 12:53 PM
BobDyl's Avatar
Quoted: 146 Post(s)
Liked: 134
I'm going to give all of this a try. Thanks for the note!
post #12034 of 12902 Old 11-04-2019, 03:19 PM
BobDyl's Avatar
Quoted: 146 Post(s)
Liked: 134
Thanks for this again. Made these changes and am now getting picture at least, but the Roku is forcing 1080P no matter what the display settings are, so I think I just need to wait until the requisite bug fix from Roku... BTW, agreed on your comment re. native frame rate. Nothing but a headache at this point...cheers.
sparky7, galonzo and naustin like this.
post #12035 of 12902 Old 11-04-2019, 06:06 PM
Liked: 1
Originally Posted by JoeKustra View Post
First add Amazon Prime if it's not a channel already. Select that channel and Search for the Movie "Fury" with Brad Pitt. You don't need to join or pay. You can watch trailers for free. My Audio is set to Auto, but I still have software 9.2.0.
On the Yamaha, Select OSD, Information and Audio while the trailer is playing. It should show the audio as DD+. Under that it should show 3/2/0.1 after Channel.
Almost all of my cable channels are DD 5.1 with exceptions of Comedy Central is DD 2.0 and CNN is DD EX. There are a few DD 2.0 scattered around also.
Fury was a great example it seems to be working. Thanks!
Rembrandt12 is offline
post #12036 of 12902 Old 11-04-2019, 06:08 PM
Liked: 1
Originally Posted by tngiloy View Post
Audio Mode: AUTO
HDMI: Dolby Digital Plus, DTS
Brilliant. Thank you sir for the direct answer.
post #12037 of 12902 Old 11-04-2019, 11:46 PM
See The Light's Avatar
Quoted: 85 Post(s)
Liked: 99
I checked my 4660 tonight, and she was giving me 4K HDR.
So she hasn't regressed back to Auto or 1080. I have a Micro SD card in the 4660. I have the latest update, 9.2.0.
My 4660 is plugged into an outlet that is unswitched.
aaronwt and galonzo like this.
Cable Channel Choice is the only choice I want to make !!
See The Light is offline
post #12038 of 12902 Old 11-05-2019, 06:00 AM
Quoted: 1118 Post(s)
Liked: 457
Thanks to you. While checking Fury I noticed it wasn't 24fps. I had to fix that. I choose Fury since it's recent, small name, and does a good job making the sub-woofer work. It does look & sound better on Blu-ray and DTS-MA.
JoeKustra is offline
post #12039 of 12902 Old 11-06-2019, 07:13 AM
Quoted: 120 Post(s)
At a loss as to why my Roku Ultra is only streaming 1080P when watching Netflix. I have the 4K supbscription, using input #3 .
-TV is XBR65X750D
-iTunes library comes through in 4K
-Apple TV+ content is in 4K
- HDMI cable is an Audioquest 18GPS
What am I doing wrong?
Even the internal Netflix app can stream 4K
Projector: VPLHW40ES + DIY 125" Screen AVR: CX-A5100 + B&K REF 200.7
Speakers: DEFINITIVE TECHNOLOGY BP2000(FL/FR), CLR2000 (C), DEFINITIVE TECHNOLOGY BP10 (RL/RR),
MONITOR AUDIO CT265FX (Ceiling ATMOS/DTS), (4) MONITOR AUDIO CT265FX (Ceiling R/L REAR SURR)
Tweeter2002 is offline
post #12040 of 12902 Old 11-06-2019, 08:04 AM
atc98092's Avatar
Quoted: 1529 Post(s)
Liked: 741
There have been some reports of Ultra devices showing they are set on 4K/60, but in actuality are only outputing 1080. The workaround is to manually select 4K/60, instead of leaving the display setting on auto. However, the Ultra reverts to auto by itself (it appears to happen overnight) so it has to be set again. If it's only sending 1080 out, that could be your Netflix issue.
Tweeter2002 likes this.
Dan
Samsung JU7100 and NU7100 4K TVs, Yamaha RX-V583, Nvidia Shield, a number of Roku players and TVs, Windows 10 media server with Serviio and Plex. Other players and TVs as well.
atc98092 is online now
post #12041 of 12902 Old 11-06-2019, 09:20 AM
Quoted: 120 Post(s)
Originally Posted by atc98092 View Post
There have been some reports of Ultra devices showing they are set on 4K/60, but in actuality are only outputing 1080. The workaround is to manually select 4K/60, instead of leaving the display setting on auto. However, the Ultra reverts to auto by itself (at appears to happen overnight) so it has to be set again. If it's only sending 1080 out, that could be your Netflix issue.
I'll try a force and see what happens, thanks.
post #12042 of 12902 Old 11-06-2019, 11:48 AM
naustin's Avatar
Liked: 1218
-TV is XBR65X750D
You say AppleTV+ is 4K, is that on your Roku? Make sure you have the HDMI Port 3 on your Sony set to "Enhanced" if your set can accept HDR content. Also log on to Netflix via PC and check your video settings.
galonzo and Tweeter2002 like this.
post #12043 of 12902 Old 11-06-2019, 12:05 PM
JudgeSmails's Avatar
Quoted: 208 Post(s)
Liked: 240
Having horrible audio synch issues recently. Wasn't like this when I first used the Roku, so I am thinking it may be related to an update. Apps are inconsistent with Netflix seemingly fine, Hulu just a tad off and Amazon Prime unwatchable. I've had to change the delay on my receiver to improve but even then it is slightly off. Very disappointing.
Big Trouble in Little China - greatest film ever made
Gamertag: Team Banzai
JudgeSmails is offline
post #12044 of 12902 Old 11-06-2019, 01:49 PM
BobDyl's Avatar
Quoted: 146 Post(s)
Liked: 134
-TV is XBR65X750D
This is 100% a Roku issue, same thing is happening to me. The *only* difference between properly functioning Roku Ultra and broken Roku Ultra in my setup: the latest Roku firmware.
Rey L and Tweeter2002 like this.
post #12045 of 12902 Old 11-06-2019, 02:56 PM
Quoted: 120 Post(s)
Yeah, it streams 4K with out any problem.
***************UPDATE************
I just swapped out my Ultra for my Premiere+ from upstairs and now recieving 4K. The Dancing Birds looks fantastic. I'd have to say this is the first time seeing 4K in my home
Thanks to all that responded with advice.
naustin likes this.
post #12046 of 12902 Old 11-06-2019, 03:16 PM
naustin's Avatar
Liked: 1218
I'm glad you are getting 4K but are you getting HDR?
1. Make sure you have the HDMI Port 3 on your Sony set to "Enhanced".
2. Also log on to Netflix via PC and check your video settings are best quality.
post #12047 of 12902 Old 11-06-2019, 03:18 PM
LG8600User's Avatar
Quoted: 178 Post(s)
Liked: 208
FoxSports Updated Their Roku App to 3.21
FoxSports updated the Roku app to 3.21 - no word (changelog or otherwise) on whether this includes any HDR (HLG or HDR10) enabling functionality.
Other platforms (ATV4K/FireTV) may have been updated as well.
As before, we'll just have to wait and see with tomorrow night's game.
galonzo likes this.
LG8600User is offline
post #12048 of 12902 Old 11-06-2019, 04:06 PM
Quoted: 120 Post(s)
Netflix settings are set to best quality, I haven't looked into the "Enhanced" setting yet. Will do after dinner.
HDMI is set to enhanced
naustin likes this.
post #12049 of 12902 Old 11-06-2019, 05:54 PM
Quoted: 120 Post(s)
Does the firmware fix this issue?
post #12050 of 12902 Old 11-06-2019, 06:12 PM
BobDyl's Avatar
Quoted: 146 Post(s)
Liked: 134
Sorry -- I was not totally clear here. The latest firmware is what definitely broke 4K for me on the 2016 Roku Ultra.
post #12051 of 12902 Old 11-06-2019, 06:44 PM
kbmb's Avatar
Quoted: 1022 Post(s)
Liked: 863
For what it’s worth, my Ultra hasn’t switched back to auto since I forced it to 4K HDR. I don’t use a screensaver or go into sleep mode, so that might have something to do with it.
sparky7 and galonzo like this.
kbmb is offline
post #12052 of 12902 Old 11-06-2019, 08:19 PM
BobDyl's Avatar
Quoted: 146 Post(s)
Liked: 134
It’s worth checking if it’s actually outputting 4K. Mine says it’s doing 4K 60 but the tv is only receiving 1080p.
post #12053 of 12902 Old 11-06-2019, 10:06 PM
Overrid3's Avatar
Quoted: 194 Post(s)
Liked: 104
Hey all, not sure if this has been asked before, but I have a Roku Ultra (hooked up to my AVR via HDMI), and I noticed the sound is much louder than any of my other devices. I normally watch TV/movies at around -20 to -17 on the volume, but the Roku's output seems about 10 dB louder. I can just decrease the source input level to stay consistent with other devices, but I was wondering if anyone else noticed this?
Overrid3 is offline
post #12054 of 12902 Old 11-07-2019, 04:03 AM
kbmb's Avatar
Liked: 863
Yeah every time I turn the TV on, I hit the display button on my Harmony (Sony TV) to confirm the TV is showing 3840 x 2160. So far it has continued to stay on 4K. PITA to have to babysit it constantly.
I also confirm in the settings that it hasn’t moved back to the auto setting. So far it hasn’t.
BobDyl, sparky7 and galonzo like this.
kbmb is offline
post #12055 of 12902 Old 11-07-2019, 04:05 AM
kbmb's Avatar
Liked: 863
What are your other devices? The only thing I notice in my setup is that my ATV4K is generally lower than anything else. Roku and TiVo generally at the same levels.
BobDyl and galonzo like this.
kbmb is offline
post #12056 of 12902 Old 11-07-2019, 06:48 AM
Rey L's Avatar
Quoted: 37 Post(s)
Liked: 33
Is it stupid of me to look at the APPLE 4k TV device? This is the 2nd time I have issues with my ultra after a firmware update. First time it was almost 3 months till I had HDR functioning again. Now I am having the problems described above. I wonder if the apple device is better with firmware updates. I'm aware that there are a ton of TV and AVR combos out there but come on. My TV and AVR just turned a year old so it's not like I am trying to incorporate super outdated hardware.
Rey L is offline
post #12057 of 12902 Old 11-07-2019, 07:33 AM
BobDyl's Avatar
Quoted: 146 Post(s)
Liked: 134
Not stupid at all. Consider having both Roku and Apple TV connected to your TV. This is our setup. One of them will always work! Plus, with kids, failure is not an option. Parents know what I'm saying.
post #12058 of 12902 Old 11-07-2019, 07:41 AM
Quoted: 120 Post(s)
NBD, I appreciate your feedback. Roku needs to address this, I wonder how many people out there have these issues. I might do a factory reset and see what happens.
post #12059 of 12902 Old 11-07-2019, 07:45 AM
Quoted: 120 Post(s)
I like the Apple TV due to it's choices of movies and deals that are offered through iTunes. Plus the upgrade from HD to 4K is pretty remarkable.
post #12060 of 12902 Old 11-07-2019, 07:48 AM
kbmb's Avatar
Liked: 863
Note - now with the Apple TV app being available on Roku, you can get all those benefits without needing an actual Apple TV.
galonzo likes this.
kbmb is offline
hdr , roku ultra , settings , ultra hd
