Zidoo X9S - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 72Likes
post #211 of 339 Old 03-07-2019, 07:13 AM
MagnumX's Avatar
Quoted: 1453 Post(s)
Liked: 928
Did you even look in settings before posting here?
giomania, xiaNaix and deano86 like this.
Click THEATER (Updated: Nov-12-2019) for pics: Epson 3100 3D Projector, DaLite 92" screen, 11.1.6 (Marantz SR7012 + Yamaha HTR-5960 + Onkyo ESPro) - Dialog Lift - PSB T45/B15/S50/X1T/CS500 Speakers & Def Tech PF-1500 15" sub; 2nd Room (Updated Apr-22-2019): 48" Plasma TV, Carver AL-III, Carver C-5 Pre-Amp, Technics SH-AC500D, Dual Carver TFM-35x Amps (Active Bi-Amp), Klipsch Surrounds ; Sources: PS4, LG UP875 UHD, Nvidia Shield (KODI), ATV4K, Zidoo X9S, LD, GameCube : Props (Updated 1-31-20)
MagnumX is offline
post #212 of 339 Old 03-07-2019, 07:15 AM
Franconian's Avatar
Quoted: 41 Post(s)
Liked: 31
Quick Settings > Playback > Default Language > Default Subtitle > Off
or
Start a movie, press Menu, then Advanced > Default subtitle lang > Off
LG OLED 65B8 | Denon AVR-X3500H | Zidoo X9S | Panasonic DP-UB824 | Nubert nuLine 84 / CS-44 / 24 / AW-600 | Xbox One X | PS4 | Synology DS216+II​
Franconian is offline
post #213 of 339 Old 03-07-2019, 03:49 PM
sharok's Avatar
Quoted: 423 Post(s)
Liked: 118
I didn't even know where to look.
sharok is online now
post #214 of 339 Old 03-07-2019, 03:51 PM
sharok's Avatar
Quoted: 423 Post(s)
Liked: 118
or
Thanks. I turned it off.
I was using the second option for every single movie.
post #215 of 339 Old 03-07-2019, 03:52 PM
MagnumX's Avatar
Liked: 928
Kind of hard to miss the settings on the main screen (upper right and lower icon). Then you just look for subtitles and turn them off.
MagnumX is offline
post #216 of 339 Old 03-08-2019, 09:35 AM
sharok's Avatar
Quoted: 423 Post(s)
Liked: 118
or
Hi Franconian,
Something odd happened after I turned off the subtitle.
Poster Wall was my default page. Every time I turned on Zidoo, the poster was used to appear as my default page.
Since I turned off the subtitle, the default page has changed to "Home".
Is there any way I can set the poster wall as my default page again?
Thank You
post #217 of 339 Old 03-08-2019, 10:07 AM
b curry's Avatar
Quoted: 1141 Post(s)
Liked: 737
Originally Posted by sharok View Post
Hi Franconian,
Thank You
Go to the APK tile and open it. Select the APK that you want, in your case HT2. Long press on OK. Click on Launch at Start. An Asterisk will appear on that tile as a launch APK.
b curry is offline
post #218 of 339 Old 03-08-2019, 03:24 PM
sharok's Avatar
Quoted: 423 Post(s)
Liked: 118
I did as you directed me.
The HT 2.0 had a star already next to it even before I performed the long OK click on it. I deselected and re-selected it again. But for some reason it still shows "Home" as the default page when it boots up.
That is odd.
post #219 of 339 Old 03-08-2019, 03:29 PM
b curry's Avatar
Liked: 737
That is odd.
Did you click on "Launch at Startup"?
b curry is offline
post #220 of 339 Old 03-08-2019, 03:32 PM
sharok's Avatar
Quoted: 423 Post(s)
Liked: 118
Yes I did.I think it gets a star next to it after I click on it.
post #221 of 339 Old 03-08-2019, 04:05 PM
b curry's Avatar
Liked: 737
Well, I don't know what to tell you. That's the sequence to do what you asked.
b curry is offline
post #222 of 339 Old 03-08-2019, 07:19 PM
sharok's Avatar
Quoted: 423 Post(s)
Liked: 118
This is minor, I can live with it.
As you suggested before, I locked the Zidoo on 1080p/24 (HDMI limited range). The box is 100% stable (no hiccups) for everything I use it for (BD, 3D, DVD). I pass the signal to my prosessor (pass through), then I use a processor called Darbee (you may have heard of it), then it goes to TV for up scaling. Both 3D and 2D look fantastic. I tried another box before (Popcorn A500) but it kept freezing. This box is what I was looking for as a replacement for my Oppo-103.
Thanks for your patience. Playback and picture quality are flawless.
post #223 of 339 Old 03-11-2019, 08:14 PM
deano86's Avatar
Quoted: 670 Post(s)
Liked: 342
This may be silly question, but how do I get the Zidoo to consecutively play my recently downloaded MKV and M2TS demo files? It plays one file in the folder, then stops and I have to select the next one under the Media Center app. Now, I found that ZDMC will play files consecutively .... but only if I switch to its internal Kodi based player instead of the rock solid Zidoo or external player. I find that the Kodi player to be glitchy and not very good. Any way to use the External player for playing individual files sequentially?
deano86 is offline
post #224 of 339 Old 03-17-2019, 11:25 AM
Ash Sharma's Avatar
Quoted: 1127 Post(s)
Liked: 807
I am looking for the same solution... I saw this post in the Zidoo forum to solve this problem - let us know if you fond a solution:
There is no Playlist Select in the Media Center.
You should select "Repeat All" in den Media Player Menu while Playback runs, then one Clip after the other will played well continously in a Folder. Except "MTS" Files....The Zidoo has a "Bug" with the Format, and aborts the "Next Play". I hope the "MTS" problem will be fixed as soon as possible.
Ash Sharma is offline
post #225 of 339 Old 03-17-2019, 12:33 PM
deano86's Avatar
Quoted: 670 Post(s)
Liked: 342
Well, in the meantime I have at least improved the performance of the ZDMC (Kodi) internal player by downloading the AresWizard program add-on. After making an adjustment to the Video cache settings, the player is at least tolerable for those demo files and obviously they do play consecutively for me. It just isn't the buttery smooth playback of the Zidoo player is all, but it is greatly improved after the change. I don't have an issue with it not playing M2TS files... as my demo files are indeed a mixture of MKV and M2TS..... I just have the menu setting set for consecutive file play ... not Repeat all.
deano86 is offline
post #226 of 339 Old 04-13-2019, 12:09 AM
sharok's Avatar
Quoted: 423 Post(s)
Liked: 118
My external USB hard drive to Zidoo X9S got corrupted and stopped working.
I'm going to best buy to get a new one and use my backup hard drive to copy all my movies and folders to the new hard drive.
The hard drive is exactly the same as the old one.
Do I need to clean all the movies in Zidoo and re-scan again or does Zidoo re-scans automatically without making duplicates?
I'm trying to avoid making duplicates of folders and movies.
Audio: 5.1 Martin Logan Summit X (Front), ML Stage (Center), ML Script i (Surround), Paradigm Seismic 110 (Subwoofer), Emotive XMC-1 (Processor), Anthem P5 (Amplifier)
Video: LG OLED65E6, Oppo-103, Zappiti (Media Player), Darbee (Video Processor)
post #227 of 339 Old 04-13-2019, 06:32 AM
b curry's Avatar
Liked: 737
It will re-scan automatically.
b curry is offline
post #228 of 339 Old 04-13-2019, 10:09 AM
sharok's Avatar
Quoted: 423 Post(s)
Liked: 118
post #229 of 339 Old 04-15-2019, 02:21 AM
Quoted: 87 Post(s)
Liked: 51
ZDMC crashes regullary in my setup. About 50% of the time when I start a movie ZDMC stops working. The movie keeps playing in the external player, but I get a message that ZDMC has stopped working. When the movie ends ZDMC start again from the beginning. Does anyone else have this problem?
My media is on an external server (SMB) and I also use an external Kodi database so all my Kodi devices have the same media library.
G4n0nD0rf is offline
post #230 of 339 Old 04-15-2019, 06:57 AM
deano86's Avatar
Quoted: 670 Post(s)
Liked: 342
While I have not personally had this happen to me, it sure sounds like something got corrupt in your ZDMC application... Do you run a lot of addons in your ZDMC? ... maybe one of those is causing the problem... otherwise, I would either do a factory reset or just reload the ZDMC apk...
deano86 is offline
post #231 of 339 Old 04-15-2019, 11:31 AM
MagnumX's Avatar
Liked: 928
100% of mine crash from ZDMC if they're on the network (SMB). Zidoo simply doesn't like SMB3 (Mac). KODI (which uses SMB3) works just fine on the Zidoo, but doesn't get hardware support for 3D files nor perfect refresh rates with the Zidoo (at least the version I have on there). Local files (connected USB2 or USB3 hard drives) play back fine 95% of the time (I do get an occasional hiccup in the audio for unknown reasons once about every 3-4 movies or so for a split second). If Zidoo would just support SMB3, I think these issues would go away pronto. SMB1 is unsafe period. SMB2 is outdated. Even the NVIDIA Shield has gone to SMB3 for one direction already (next big update supposedly will finish it up) and they're massively behind the times.
MagnumX is offline
post #232 of 339 Old 04-15-2019, 04:51 PM
Liked: 0
Hi all I’m considering getting this to play TrueHD atmos contents, so wanna confirm it supports lossless atmos & dts-X. Also since there’s Z9s now, which of these two would be a better choice for lossless object based surround sound support? Thanks
Gundamexia is offline
post #233 of 339 Old 04-15-2019, 05:06 PM
MagnumX's Avatar
Liked: 928
Atmos and X and Auro-3D too (FWIW so long as it's inside a Master HD wrapper; unwrapped PCM audio will not play on my X9S at all) all play fine from my X9S.
MagnumX is offline
post #234 of 339 Old 04-27-2019, 09:04 PM
Liked: 0
Shld I get this x9s or the new Z9s? My main concern is video n audio (atmos or X) playback capability for mkv movie files. It will be paired with a Samsung n950 soundbar n LG C7 tv. Price difference is abt $100 so wondering is the Z9s worth spending the extra $100 or X9s is good enough. Appreciate any advice n insights. Thanks.
post #235 of 339 Old 04-28-2019, 04:36 AM
MagnumX's Avatar
Liked: 928
I think if you want to do 4K you should get the newer one. If 2K/3D is good enough, the X9S is fine.
MagnumX is offline
post #236 of 339 Old 04-28-2019, 10:03 AM
robnix's Avatar
Quoted: 1021 Post(s)
Liked: 766
Either one is fine for 4K. In terms of playback capability the 1295/1296 chipsets are identical.
Looky here!
robnix is offline
post #237 of 339 Old 04-28-2019, 10:34 AM
MagnumX's Avatar
Liked: 928
I could have sworn a review said 4K worked better. Maybe that was before a firmware update on the X9S? So what is better about the Z model, then?
MagnumX is offline
post #238 of 339 Old 04-28-2019, 12:52 PM
b curry's Avatar
Liked: 737
I asked myself the same question. Could not find an answer that was better than the extra money left in your pocket after buying the X9S. On paper, the only hardware difference is the I/O count and some memory access. The X9S has all the I/O's I need and I don't think anyone ever increases memory. The last firmware for the X9S seems to have produced a more stable box than the Z9S is at the moment.
I'm holding out until some one comes out with something better than the 1295/1296 SoC.
giomania likes this.
b curry is offline
post #239 of 339 Old 05-01-2019, 05:06 PM
sharok's Avatar
Quoted: 423 Post(s)
Liked: 118
Zidoo can differentiate between 2D movies and 3D movies when I append "3D" and the end of the movie name.
How do you do it for children movies?
I appended the word "Children" after the movie name, but Zidoo doesn't categorize it as children movie.
What should I do for HT2 to differentiate children movies from the rest?
post #240 of 339 Old 05-01-2019, 06:09 PM
MagnumX's Avatar
Liked: 928
When I originally put "3D" on the names of movies (previous firmware version), Zidoo got dozens wrong (the 3D part through it off completely and I had to hand fix them one by one). As of the last firmware update (which may have been several since it came out), they seemed to have fixed that.
MagnumX is offline
