Dune HD Duo 4K Media Player - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 33Likes
post #121 of 141 Old 11-19-2017, 12:33 PM
rnrgagne's Avatar
Quoted: 82 Post(s)
Liked: 69
Is there a solution where can re-name or re-point My Collection or would I have to repeat the entire process of indexing again?
Current Gear: Anthem AVM60, D-Sonic 3500/7, Oppo UDP-203, PS Audio Nuwave Phono Pre, Technics SL1210 w/ Denon DL103, Dune Duo 4K, Vizio 75" 4K, Paradigm Sig. S6 & C3 v.3's, Studio ADP's, Velodyne SPLR1200.
rnrgagne is offline
post #122 of 141 Old 11-19-2017, 01:46 PM
kadqs's Avatar
Quoted: 404 Post(s)
Liked: 329
At MyCollection side is it not possible. Only reindexing. But there is a chance, that lot of your individual matching will be kept.
You can always reindex current HDD again, not removing past references, to check/compare.
if you remember label of your HDD from the past, you can also try to restore it to check if MyCollection folder will match the drive.
DuneHD Ultra4K, Pro4K, Neo4k, Duo4K, Solo4K, Base3D, TV-102w, QNAP/Synology, Fibaro, Sonos, iEast
kadqs is offline
post #123 of 141 Old 11-19-2017, 03:12 PM
rnrgagne's Avatar
Quoted: 82 Post(s)
Liked: 69
Well, not 100% sure how I did it but I found a way to "Add folder to My Collection" and had to rename the folder from Concerts to "Concerts B" to be able to index it. The good news is that it duplicated everything from the original folder so I didn't have to replicate work.
rnrgagne is offline
post #124 of 141 Old 11-22-2017, 01:37 PM
rnrgagne's Avatar
Quoted: 82 Post(s)
Liked: 69
Another question if I may;
I was under the impression that this would work as a NAS and have dlna capabilities. I can see it from my PC no problem but neither my Oppo, nor Anthem (via PlayFi) can find it to access the music files? Is there a way I pull this off, the manual is useless in this regard..
rnrgagne is offline
post #125 of 141 Old 11-23-2017, 08:36 AM
kadqs's Avatar
Quoted: 404 Post(s)
Liked: 329
Dune has no UPnP/DLAN server option. It acts as UPnP client, and after installing UPnP extension it support also UPnP-DMR, to accept streaming from UPnP DMC devices (usually mobile devices with special software).
So no server option available, and it is not sure if Dune will release such extension.
kadqs is offline
post #126 of 141 Old 11-23-2017, 11:45 AM
rnrgagne's Avatar
Quoted: 82 Post(s)
Liked: 69
Well that's disappointing, and I'd say that the fact they advertise "NAS" functioning is very misleading then..
This is what it says on their site:
"Built-in NAS function: Access files on attached storage devices (HDD, USB drive, etc) from local network (via SMB, FTP, UPnP/DLNA)"
WTF???
rnrgagne is offline
post #127 of 141 Old 11-23-2017, 02:15 PM
kadqs's Avatar
Quoted: 404 Post(s)
Liked: 329
WTF???
This specification is not correct. I know that at some websites and descriptions it is updated. But it seems, that not everywhere. SMB and FTP is fine.
kadqs is offline
post #128 of 141 Old 11-24-2017, 04:00 AM
jju
Quoted: 29 Post(s)
It is possible to install Twonky Server(manually) or Plex(plugin) or minidlna(manually) of mediatomb(manually)
jju is offline
post #129 of 141 Old 11-24-2017, 04:40 AM
kadqs's Avatar
Quoted: 404 Post(s)
Liked: 329
You have to check community plugins and extensions.
http://forum.hdtv.ru/index.php?showforum=47
kadqs is offline
post #130 of 141 Old 11-24-2017, 04:44 AM
jju
Quoted: 29 Post(s)
I did not ask a question. I listed the UPnP / DLAN server options known to me, which can be installed on dune 4k
jju is offline
post #131 of 141 Old 11-26-2017, 01:01 PM
rnrgagne's Avatar
Quoted: 82 Post(s)
Liked: 69
Well, I'm at a loss, but it's a happy one...
As of this morning I discovered that my iPhone's Oppo app sees my Dune and is playing my music files from there. It's different than Play-Fi because it's not routing through my phone, it's pulling from the Dune & bitstreaming via HDMI to my Anthem. Bitstreaming direct from the Dune might be the best audio option, but with the Oppo app I don't need to turn on the TV to navigate and it sounds the same to me...
rnrgagne is offline
post #132 of 141 Old 11-26-2017, 01:04 PM
edved1's Avatar
Quoted: 139 Post(s)
Liked: 92
Won't be replacing my Nvidia Shield TV anytime soon.
edved1 is offline
post #133 of 141 Old 11-27-2017, 03:39 AM
jju
Quoted: 29 Post(s)
what is the application for oppo?
jju is offline
post #134 of 141 Old 11-27-2017, 09:17 AM
rnrgagne's Avatar
Quoted: 82 Post(s)
Liked: 69
It's an iPhone remote control app for my Oppo BDP-203 player, it allows me to navigate through the player's menu system without having to turn on the TV it even has album art...
jju likes this.
rnrgagne is offline
post #135 of 141 Old 11-28-2017, 10:06 AM
videobruce's Avatar
Quoted: 899 Post(s)
Liked: 349
I didn't see anything on where to get this in the US.
Then, how about service?
Unless neither of those are important.
Recording free OTA TV for 'time shifting' has been here since 1975. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #136 of 141 Old 11-28-2017, 11:52 AM
b curry's Avatar
Quoted: 1291 Post(s)
Liked: 833
www.duneplayer.com They are also the distributor for the US AFAIK. They had a Black Friday sale that you just missed.
Amazon has them as well.
videobruce likes this.
b curry is offline
post #137 of 141 Old 11-28-2017, 12:09 PM
videobruce's Avatar
Quoted: 899 Post(s)
Liked: 349
Their site is well hidden when searching using "Dune HD".
post #138 of 141 Old 11-28-2017, 12:23 PM
b curry's Avatar
Liked: 833
Yes, it is.
You have to go to the "Where to Buy" on Dune HD's site and then click US/Canada. That will get you to www.hdi-usa.com. After that you click the "Dealers" tab and then click "Online Resellers" and that will get you to www.duneplayer.com; hdi-usa and duneplayer are the same place. The owner's name is Mike. He's in Flemington, NJ.
b curry is offline
post #139 of 141 Old 11-28-2017, 12:32 PM
videobruce's Avatar
Quoted: 899 Post(s)
Liked: 349
Sheesh...........
post #140 of 141 Old 11-20-2019, 12:42 AM
Liked: 0
Hello everyone, sorry if I resume this discussion on the Dune HD duo 4k after a long time. I bought it just last Saturday. I had read in the specifications that he was able to read all the new generation hdd over 6Tb. I have a Western Digital Red Internal 6000 GB, SATA III, 6000 Mb / s, 5400 RPM, 64 MB, 3.50 Inch (WD60EFRX). Inside it is naturally full of films from my collection. It is NTFS formatted, but with GPT partition for large drives. Dune hd duo 4k gives me back that it's impossible to read it. Do you have any contrary evidence or suggestions? Firmware installed by the reader just connected to the network. Thank you all for any reply
antycapp is offline
post #141 of 141 Old 05-28-2020, 11:04 AM
videogamelover5122's Avatar
Quoted: 125 Post(s)
sorry to revive old thread but anyone in usa have one they want to sell?? if so pm me
videogamelover5122 is offline
