Zappiti 4K HDR (Mini, One, Duo) Thread - Page 92 - AVS Forum | Home Theater Discussions And Reviews
 531Likes
post #2731 of 2836 Old 05-22-2019, 07:38 AM
silver-eye's Avatar
Quoted: 177 Post(s)
Liked: 117
here it is..
sutton8 likes this.
silver-eye is online now
post #2732 of 2836 Old 05-22-2019, 12:08 PM
marine92104's Avatar
Quoted: 300 Post(s)
Liked: 143
Not sure I understand what “source direct” means.
If you turn it on then a standard Blu-ray will not be upscaled to 4k?
If the Zappiti has a good upscaler why wouldn’t you want that?
marine92104 is online now
post #2733 of 2836 Old 05-22-2019, 12:33 PM - Thread Starter
Sledgehamma's Avatar
Quoted: 651 Post(s)
Liked: 355
Yes, a BD will be outputted at its native resolution, i.e. 1920x1080.
The Zappiti doesn't have a good upscaler.
Macroblocker likes this.
Sledgehamma is online now
post #2734 of 2836 Old 05-22-2019, 02:13 PM
Macroblocker's Avatar
Quoted: 237 Post(s)
Liked: 99
looking forward to this!
Macroblocker is offline
post #2735 of 2836 Old 05-22-2019, 03:09 PM
chaka2's Avatar
Can you talk about why their scaler is not good. They have a whole page (https://zappiti.com/zappiti_player_4...agicpixel.html) bragging about their 4k upscaling and down conversion.
chaka2 is offline
post #2736 of 2836 Old 05-22-2019, 04:58 PM
Amidujusu89's Avatar
Quoted: 33 Post(s)
I just downloaded the update for the direct mode but it does not seem to be working. I have to used the 1080p resolution or else it upscales everything.
Sampinto
Amidujusu89 is offline
post #2737 of 2836 Old 05-22-2019, 05:23 PM
Quoted: 237 Post(s)
Liked: 99
yup same here, not working for me, after visiting the Zappiti facebook page i see an update to explorer and Zappiti video is required, update coming soon.
post #2738 of 2836 Old 05-22-2019, 08:11 PM
Quoted: 33 Post(s)
Ok, that seems fair... I will wait till then. I do have to say that Zappiti is figuring out most of the kinks in their players. Forced subs in iso and mkv is the one major item left.
Sampinto
post #2739 of 2836 Old 05-23-2019, 12:42 AM
Quoted: 237 Post(s)
Liked: 99
well i updated the explorer to Beta but i noticed ever since i downloaded the service the player will not pass HDR anymore under any circumstances! resolution switches but no HDR and no way i can seem to fix it.
post #2740 of 2836 Old 05-23-2019, 07:12 AM
Liked: 0
hi all, my 4k hdr se won't play any TV shows thrown at it for some reason. Latest one i tried was HBO's Chernobyl series, but after identification, it will say Can't play video and that's it. Forced to watch it via VLC app on zappiti. these are the specs of the video, thank you:
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1 h 3 min
Bit rate mode : Constant
Bit rate : 8 985 kb/s
Nominal bit rate : 10 000 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.181
Stream size : 3.99 GiB (93%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
ajish82 is offline
post #2741 of 2836 Old 05-23-2019, 08:55 AM - Thread Starter
Quoted: 651 Post(s)
Liked: 355
Sure. Just have a look at my review where I compared it to the PCH A-500. Since then they improved it to version 2.5 (from 2.0), but they are super secret about it. I couldn't get any information about the way they allegedly implemented MagicPixel.
For one, it can't the deactivated for some reason, which is utter nonsense. Some people prefer an unaltered picture.
Second, they do not have deep access to the decoder, which is needed for what they are claiming.
All MagicPixel really is, is contrast "enhancements". Everything else is the same as on any other Realtek based player as they do not have any different video decoding/processing. They are just good at marketing.
They just added some fancy names for up- and downscaling, which every player can do....
post #2742 of 2836 Old 05-23-2019, 09:32 AM
legionow112's Avatar
Quoted: 22 Post(s)
Liked: 7
Hi,
I'm thinking about buying Zappiti 4K HDR. How do you rate GUI speed, aesthetics, or is it refined software? Does Zappiti read audio and video codecs from .mkv and .m2ts files during the first scan of the library and presents them as stickers in the library (4K, HD, DTS Audio, HDR ....)? For comparison, in zidoo such information appears only after playing the file.
What are the main disadvantages of this device?
legionow112 is online now
post #2743 of 2836 Old 05-23-2019, 09:39 AM
Wryker's Avatar
Quoted: 189 Post(s)
Liked: 69
Originally Posted by legionow112 View Post
Hi,
I've had the Popcorn Hour A-110, A-400, and A-500 and I find this 4K HDR to be the 'best' media player yet. Much easier media scanning etc.
It puts the media information for the files including Blu-Ray, UHD, etc etc.
johng and legionow112 like this.
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
post #2744 of 2836 Old 05-23-2019, 10:22 AM
silver-eye's Avatar
Quoted: 177 Post(s)
Liked: 117
I also have a zidoo z9s, but the zappiti is my main player..
The only thing I would like them to add, is the change of contrast, brightness and hue, on-the-fly, like the zidoo..
apart from that, I prefer the Zappiti, has a way better "library" arrangement.
post #2745 of 2836 Old 05-23-2019, 11:06 AM
Quoted: 22 Post(s)
Liked: 7
I also have Z9S. I really do not like the user interface of this device, this HT 2 app is a joke, mistakes in translation, other minor bugs. I just do not like using z9s for this reason. I think zidoo doesn’t prioritize UX and GUI is too much clunky for my taste.
But putting aside GUI, are they (zappiti) on the same level of „technical support” as zidoo? I have read on zidoo forum that they claim to be „very close” with Realtek and that Realtek provides them latest firmware for SoC before others.
johng likes this.
post #2746 of 2836 Old 05-23-2019, 01:23 PM
sutton8's Avatar
Quoted: 342 Post(s)
Liked: 123
I believe Zidoo is the OEM that makes the Zappiti hardware. But yes their media centre and software in general sux. Zappiti used to have a poor rep for customer service but in the last few years are much improved. I’d now consider their customer service as excellent and mostly same day patient responses to queries. Firmware updates are slower than Zidoo on the whole though.
7.2 Yamaha RX-A3080, Monitor Audio (Apex & Silver), Seismic 110, XBOX, Vero 4K, Sony X700, Panasonic TX65GZ950B
5.1 Denon X7200WA, Focal Dome, LG OLED (E6V)
In both Setups "Virgin Tivo V6, Zappiti 4K HDR, FireTV Stick 4K, Harmony Elite"
sutton8 is online now
post #2747 of 2836 Old 05-23-2019, 03:49 PM
johng's Avatar
Quoted: 230 Post(s)
Liked: 105
Thanks for posting that. I updated Service and see the new options. It reset my Display preferences to 1080p. I manually changed it to 4K and it seems to work properly, but I haven't tested a 4K/HDR title. I'll test further tonight. I'm still wondering about Sledgehammer's post that Zappiti does not have a good upscaler. What I'm seeing looks pretty good, so the new feature has me scratching my head.
Good Viewing,John G  JVC DLA-X790 Projector, Vutec 110" (16x9) Bright White Screen, Oppo UDP-203 region free MOD disc player, Zappiti Mini4K HDR, Synology DS418 NAS, Yamaha RX-A2070 AVR, Toshiba 1250 NTSC-PAL Region Free BR Player, 7 Paradigm Reference spkrs w Dual Subs,   & Yamaha 6600 External Amp
johng is offline
post #2748 of 2836 Old 05-23-2019, 07:12 PM
Murilo's Avatar
Quoted: 264 Post(s)
Liked: 60
Does anyone have this working through the zappiti video?
I am not sure what changing display preferences to 1080p and then manually change to 4k means?
I have it enabled, but zappiti simply wont switch through zappiti video anyway.
Murilo is offline
post #2749 of 2836 Old 05-23-2019, 08:05 PM
Liked: 0
How's everyone doing this morning/afternoon/evening/night? lol..
I just picked up a new One SE 4K, and was wondering if anyone else has had trouble accessing network shares over a windows network. The host PC is running windows 10. I looked on line, and tried about a dozen fixes and none worked. I have a local account set up on the host, and I can access all the shared drives with my old WD Live Hub and my Dune solo 4K. The only message I get is: Cannot Access Network Folders
This thing is driving me crazy. About to send it back...
pagan65 is offline
post #2750 of 2836 Old 05-23-2019, 09:05 PM
Quoted: 33 Post(s)
I also updated zappiti video and the direct resolution setting seems to work on some tv shows but not on others. For example, Fresh of the Boat is upscalled to 4k but Warrior plays correctly at 1080p. I wonder why? I want the tv to do 1080pm upscalling if needed; not the player... Just a minor glitch I guess...
Sampinto
post #2751 of 2836 Old 05-23-2019, 09:21 PM
Quoted: 237 Post(s)
Liked: 99
any problems with HDR?
post #2752 of 2836 Old 05-23-2019, 09:28 PM
Quoted: 33 Post(s)
No, I don't play any HDR content through the player; only my iso bluray rips... I hope someone on the forum coould chime in.
Sampinto
post #2753 of 2836 Old 05-23-2019, 09:45 PM
Murilo's Avatar
Quoted: 264 Post(s)
Liked: 60
HDR seems to be working fine for me and after my last post zappiti video updated and now its working fine.
Murilo is offline
post #2754 of 2836 Old 05-24-2019, 12:19 AM
Quoted: 237 Post(s)
Liked: 99
I managed to get HDR working again by doing a Factory reset, I'm going to assume this was an anomaly and try again.
post #2755 of 2836 Old 05-24-2019, 10:19 PM
Murilo's Avatar
Quoted: 264 Post(s)
Liked: 60
Does anyone have issues with source direct not launching some movies? The shape of water 4k for instance, it wont load the movie with source direct on, as soon as i turn it off, it works fine.
Very weird.
Murilo is offline
post #2756 of 2836 Old 05-24-2019, 11:57 PM
sutton8's Avatar
Quoted: 342 Post(s)
Liked: 123
Very weird.
Just tried that movie and it loaded. Just that it took about 25 seconds which is far longer than usual.
That aside i have source direct on and in Zappiti Video the message I get when I launch a UHD is “changing TV system to 2160p 23.967hz”. That is the message I’ve always had in the past and to me implies that the player is doing the scaling. Is there any way to check on the player itself that source direct is actually working, otherwise I’ll have to find the original remotes for TV and receiver.
post #2757 of 2836 Old 05-25-2019, 01:44 PM
Quoted: 237 Post(s)
Liked: 99
everything is now working for me fine for me now after updating Zappiti video
post #2758 of 2836 Old 05-26-2019, 04:06 AM
Quoted: 31 Post(s)
Liked: 2
I tried the new direct feature and I got 1080p instead of 4k as expected but the sound sync was off so I turned it off again and watched my movie upscaled by Z with sound synched.
So before I try to correct sync time via AVR etc it would be nice to know if more people got the same problem?
Sent from my SM-G930F using Tapatalk
SALVETA is offline
post #2759 of 2836 Old 05-26-2019, 01:24 PM
Quoted: 237 Post(s)
Liked: 99
will have to look closely at the sync when i test it out tonight
post #2760 of 2836 Old 05-26-2019, 01:48 PM
Quoted: 69 Post(s)
I also get the same message when I launch a BD (1080p). So how do we know what signal is being sent to our TV?
Schafheide is offline
