Zappiti 4K HDR (Mini, One, Duo) Thread - Page 93 - AVS Forum | Home Theater Discussions And Reviews
 527Likes
post #2761 of 2819 Old 05-26-2019, 02:31 PM
sutton8's Avatar
Quoted: 341 Post(s)
Liked: 121
Originally Posted by Schafheide View Post
I also get the same message when I launch a BD (1080p). So how do we know what signal is being sent to our TV?
My player is connected to a Yamaha amp and I check the source input signal on that. Seems to be working as expected.
7.2 Yamaha RX-A3080, Monitor Audio (Apex & Silver), Seismic 110, XBOX, Vero 4K, Sony X700, LG OLED (E7V)
5.1 Denon X7200WA, Focal Dome, LG OLED (E6V)
In both Setups "Virgin Tivo V6, Zappiti 4K HDR, FireTV Stick 4K, Harmony Elite"
sutton8 is online now
post #2762 of 2819 Old 05-26-2019, 04:02 PM
Quoted: 69 Post(s)
Mine is connected direct to C7 Oled. Do you force the resolution to 3840 x 2160 or leave it on Auto?
Schafheide is offline
post #2763 of 2819 Old 05-26-2019, 07:02 PM
sutton8's Avatar
Quoted: 341 Post(s)
Liked: 121
Ive just left it on auto with all the options ticked. Seems to be working fine.
post #2764 of 2819 Old 05-27-2019, 01:31 AM
Quoted: 69 Post(s)
What message do you see when you launch a BD rip and what for a DVD rip?
post #2765 of 2819 Old 05-27-2019, 02:12 AM
sutton8's Avatar
Quoted: 341 Post(s)
Liked: 121
Bit strange
DVD - it asks me if I want to change the TV System for a better experience, and presumably that means let the Zap do the upscaling. You can choose cancel or confirm. Cancel leaves it as source direct and my receiver reports [email protected] etc...
Bluray - no option to change message and receiver reports [email protected]
UHD - no option to change message and receiver reports [email protected]
I'm on an LG 4K OLED like you. So source direct is working to expectation but I don't know why it gives you the option to change DVD?
marine92104 likes this.
post #2766 of 2819 Old 05-27-2019, 02:26 AM
sutton8's Avatar
Quoted: 341 Post(s)
Liked: 121
Just checked and in advanced options I have the "Auto 29/59" option checked which is why it must be giving giving the message for DVD.
My display is generally set to [email protected] HZ which is presumably why I am not getting the offer to upscale on Bluray.
post #2767 of 2819 Old 05-27-2019, 02:33 AM
Quoted: 69 Post(s)
For DVD I get the same message. My display is set (developer settings) 3840x2160 @ 23Hz (as they recommend). I am on firmware 3.10
Bottom line - is the PQ on Direct Output better?
post #2768 of 2819 Old 05-27-2019, 03:06 AM
sutton8's Avatar
Quoted: 341 Post(s)
Liked: 121
[/FONT]
I was getting wavy lines at the top of one DVD when the Zap did the upscaling. Using source direct it was fine and no lines. So I am leaving it on but differences are not massive otherwise.
post #2769 of 2819 Old 05-27-2019, 04:39 AM
Liked: 0
My view is that they have to do something with the sync of the subs . ..The Dune on that has better accuracy
Dimitris Asimakopoulos is offline
post #2770 of 2819 Old 05-27-2019, 04:42 AM
Liked: 0
Did you try the "direct output" function? - released since a few days and works fine with all my testfiles.
ThanOS2017 is offline
post #2771 of 2819 Old 05-27-2019, 06:50 AM
sutton8's Avatar
Quoted: 341 Post(s)
Liked: 121
That is what I’m saying. Source direct gets rid of the wavy lines on the dvd that are otherwise there if the zap does the scaling itself.
Macroblocker likes this.
post #2772 of 2819 Old 05-27-2019, 09:43 PM
Quoted: 69 Post(s)
Thank you Sutton8
I have applied your settings.
I agree that there is not much difference (if any).
But for the time being I will leave Direct Output on.
post #2773 of 2819 Old 05-27-2019, 11:01 PM
Quoted: 69 Post(s)
BTW
Given that UK is PAL (25Hz), why did you decide on 60Hz instead of 50Hz ?
post #2774 of 2819 Old 05-27-2019, 11:07 PM
sutton8's Avatar
Quoted: 341 Post(s)
Liked: 121
BTW
Most of the devices I use such as FireTV, Roku, Vero, Zap etc... seem to work best at 60Hz for their menus. On most I can now switch to match the original frame rate of material. Only really see the value of 50Hz in broadcast TV shows.
post #2775 of 2819 Old 05-28-2019, 12:46 AM
Quoted: 69 Post(s)
OK thank you - I mostly only use 25Hz HDTV broadcast. Cheers.
post #2776 of 2819 Old 05-28-2019, 01:22 AM
Quoted: 238 Post(s)
Liked: 102
Depending on the quality of video gear this makes a HUGE difference within your setup! This is one of the best updates so far.
Eventidal is offline
post #2777 of 2819 Old 05-28-2019, 09:41 AM
marine92104's Avatar
Quoted: 294 Post(s)
Liked: 143
Forced subtitle support would have been better. Not sure why they don’t consider this important.
Impossible to watch a full back up of titles that use them like “Overlord” 4K, “Black Hawk Down”, etc.
marine92104 is offline
post #2778 of 2819 Old 05-28-2019, 10:02 AM
Quoted: 238 Post(s)
Liked: 102
If you make an ISO of Overlord and start the title via the disc menu it should be no problem to watch the forced subs!
post #2779 of 2819 Old 05-28-2019, 10:39 AM
ChldsPlay's Avatar
Quoted: 1102 Post(s)
Liked: 620
I'm not sure it's an option unless realtek does something.
I saw that Zidoo added it, but the chipset is not identical.
The Hodor Theater - Now with Atmos
Projector - JVC D-ILA NX7/Panasonic PT-AE8000U; Receiver - Yamaha Adventage A3050
LCR speakers - JTR Noesis 228 HT (3); Surr./Back - Klipsch Pro Cinema KPT-8000M (4)
Atmos In-ceiling - Niles DS8HD (4); Subs - Passive JTR Captivator Pro (2)
ChldsPlay is offline
post #2780 of 2819 Old 05-28-2019, 10:47 AM
Quoted: 294 Post(s)
Liked: 143
The Zappiti doesn’t have forced subtitle support. I just tried “Overlord” .iso with the menus again and it does not.
post #2781 of 2819 Old 05-28-2019, 10:48 AM
Quoted: 294 Post(s)
Liked: 143
So the Zappiti chipset doesn’t support forced subtitles?
post #2782 of 2819 Old 05-28-2019, 10:53 AM
ChldsPlay's Avatar
Liked: 620
According to them it does not currently. At least for files like mkv. I'm not sure it it doesn't work at all with any menu/isos, or if it's sporadic there.
post #2783 of 2819 Old 05-28-2019, 01:38 PM
Quoted: 238 Post(s)
Liked: 102
Sure it does (not Java!) :
http://zappiti.com/zappiti-firmware-beta.html
Changes since the version 3.11:
Added support for Blu-ray menus.
Added support for 4K UHD Blu-ray menus.
The info bar currently playing video now disappears after 4 sec (20 sec previously). when using the LEFT / RIGHT (+/- 1 min) and P + / P- (+/- 10 sec) direct access keys.
The info bar currently playing video now disappears instantly when playback resumes after a pause, no waiting time or fade-out for more comfortable use.
Forced subtitles support (only using BD menus)
post #2784 of 2819 Old 05-28-2019, 10:05 PM
Quoted: 294 Post(s)
Liked: 143
Maybe we should start keeping a list of .iso titles that do not work with forced subtitles when using the menus.
I can tell you that “Overlord” 4k does not work with forced subtitles. Unless you know German you better do a MKV rip with only the forced subtitles checked & leave the subtitles on.
post #2785 of 2819 Old 05-29-2019, 01:00 AM
Quoted: 69 Post(s)
Thank you Sutton8
Well, after several days evaluating, I am very happy with Direct Output PQ.
So I am sticking with it.
Can't put a number on it, as I am not set up for a-b comparison.
Perhaps we need someone like Sledgehamma to do an A-B?
post #2786 of 2819 Old 06-01-2019, 01:35 AM
pasadena's Avatar
Originally Posted by SALVETA View Post
I tried the new direct feature and I got 1080p instead of 4k as expected but the sound sync was off so I turned it off again and watched my movie upscaled by Z with sound synched.
So before I try to correct sync time via AVR etc it would be nice to know if more people got the same problem?
Sent from my SM-G930F using Tapatalk
I had the same problem a movie using the direct feature for the first time last night and the sound was not synced. Also, don't know if it's me or not but playing an animated movie seemed like it was toooo CGI'sh or too overly sharp or something and I think it over processed an older style movie where it saturated the colors too much.
Maybe the direct function needs getting used to or my eyes need to be checked
I have a One SE and LG 4K UHD non-HDR TV.
pasadena is offline
post #2787 of 2819 Old 06-01-2019, 01:56 AM
Quoted: 31 Post(s)
Liked: 2
Did you reboot the box after changing to direct mode? I don't think I did that the first time when I got the sync problem. But now when I tried again with a reboot the audio was fine, so I hope the audio will be synched from now on.
SALVETA is offline
post #2788 of 2819 Old 06-01-2019, 08:54 AM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
Ok I turned on direct output but even when play a 1080p Blu-ray rip or DVD rip it still shows 4k on my receiver and my Sony A9F. I’d rather use the Sony chip for upscale but can’t get my Zappiti to output native
Any help would be appreciated
veger69 is online now
post #2789 of 2819 Old 06-01-2019, 10:45 AM
Quoted: 238 Post(s)
Liked: 102
I had to restart the Zappiti and then it worked perfectly.
post #2790 of 2819 Old 06-01-2019, 10:59 AM
sutton8's Avatar
Quoted: 341 Post(s)
Liked: 121
Working for me too. Could be your display settings.
