Zappiti 4K HDR (Mini, One, Duo) Thread - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 532Likes
post #2791 of 2842 Old 06-01-2019, 12:41 PM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
Originally Posted by Eventidal View Post
I had to restart the Zappiti and then it worked perfectly.
I’ve got the Zappiti display setting to Auto
Direct output mode on all resolution on
Tried rebooting still showing up as 4k on my receiver and my sony
veger69 is offline
post #2792 of 2842 Old 06-01-2019, 12:48 PM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
I set the display settings to 1080p in the Zappiti and the receiver changed to 1080p and on the apps menu and the main menu it still showed 1080p but as soon as I selected the Zappiti Video it changed to 4k? And wouldn’t switch back until I re-selected 1080p in settings
I was able to force it to 1080p by changing the tab in the direct mode settings to force the UI into 1080p but it’s not outputting in direct mode because the DVD showed 1080p
veger69 is offline
post #2793 of 2842 Old 06-01-2019, 01:17 PM
Quoted: 69 Post(s)
Originally Posted by veger69 View Post
Ok I turned on direct output but even when play a 1080p Blu-ray rip or DVD rip it still shows 4k on my receiver and my Sony A9F. I’d rather use the Sony chip for upscale but can’t get my Zappiti to output native
Any help would be appreciated
Have you tried forcing resolution to 1080p (mine is 60Hz).
Schafheide is offline
post #2794 of 2842 Old 06-01-2019, 05:46 PM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
Yes I was able to force it but that’s not direct because the DVD was 1080p as well
veger69 is offline
post #2795 of 2842 Old 06-01-2019, 08:58 PM
Quoted: 69 Post(s)
Not sure - I get 576i when I launch a DVD (as expected).
post #2796 of 2842 Old 06-03-2019, 01:38 PM
Wryker's Avatar
Quoted: 189 Post(s)
Liked: 69
I turned on Auto Direct and lost my picture. Nothing - zip. Turning it off and on I got to the Menu and if I select Videos POOF - no picture. I have the Sony 4K PJ and a Denon AVR that supports full 4K so I ended up resetting my One back to factory settings and did NOT download this update and I'm back to having a picture.
Lesson learned for me- it works as-is so I'm not going to try that again.
"..where you will never find a more wretched hive of scum and villainy."
Wryker is online now
post #2797 of 2842 Old 06-03-2019, 03:05 PM
Quoted: 69 Post(s)
Do you get the same result when you connect direct to your TV?
post #2798 of 2842 Old 06-03-2019, 08:54 PM
Quoted: 69 Post(s)
Well, after several days evaluating, I am very happy with Direct Output PQ.
So I am sticking with it.
Can't put a number on it, as I am not set up for a-b comparison.
Perhaps we need someone like Sledge hamma to do an A-B?
Well, after living with it - I am converted!
Obviously, if you enable Direct Output, you will be at the mercy of your TV up-scaling.
In my case the TV up-scaling (LG C7 Oled) is much better than before Direct Output.
post #2799 of 2842 Old 06-04-2019, 11:31 AM
sutton8's Avatar
Quoted: 344 Post(s)
Liked: 124
Handshaking is certainly worse under direct. When I am on another device and then go back to the Zap I get a blank screening meaning I have to switch off and on again the TV or receiver to re-establish. That never used to happen but not a biggie.
7.2 Yamaha RX-A3080, Monitor Audio (Apex & Silver), Seismic 110, XBOX, Intel NUC6CAYH, Sony X700, Panasonic TX65GZ950B
5.1 Denon X7200WA, Focal Dome, LG OLED (E6V)
In both Setups "Virgin Tivo V6, Zappiti 4K HDR, FireTV Stick 4K, Harmony Elite"
sutton8 is offline
post #2800 of 2842 Old 06-04-2019, 11:35 AM
silver-eye's Avatar
Quoted: 177 Post(s)
Liked: 118
Can confirm the same.. Denon avr
silver-eye is online now
post #2801 of 2842 Old 06-04-2019, 02:25 PM
Quoted: 69 Post(s)
At present I am using Direct Output with forced 1080p 60Hz display setting. When I launch either a DVD or BD rip, I get a message asking if I want to use 2160 display setting. I chose to cancel this. My TV then reports that the signal from Zap is either 576i or 1080p - as expected. I asked Tech Support if I can get rid of this unnecessary message. They suggested that I force display setting to 2160 instead. I have not tried this yet. Has anyone else tried this?
post #2802 of 2842 Old 06-04-2019, 03:14 PM
Quoted: 31 Post(s)
Liked: 2
I have GUI in 4k and I don't get the question when I play 1080p, it just changes.
I have noticed some small stutter a couple of times that was not in the movie when I reversed back to check again. Too early to blame the direct mode but have not seen this for a while before I changed to direct so it is suspected. Keep an eye out for this.
Sent from my SM-G930F using Tapatalk
SALVETA is online now
post #2803 of 2842 Old 06-04-2019, 06:32 PM
kingwiggi's Avatar
Quoted: 550 Post(s)
Liked: 351
Looked through the last couple of pages and didn't see it listed. Big jump in price from the 4K HDR DUO.
Same CPU as DUO, comes with new enhanced remote and a few other feature updates.
ZAPPITI PRO 4K HDR
http://www.zappiti.com/zappiti-pro-4k-hdr.html
A7mad78 likes this.
Trinnov Altitude 32, LCR JBL M2, JBL LSR 708i, 705i, Q-SYS Core 110f, Amps- QSC CXD4.2Q, 4.3Q, 4.5Q
Kaleidescape Strato, Zapitti 4K HDR Duo, Xbox One X, 8TB Tivo Roamio Pro,
JVC RS600 + ISCO IIIL, 158" 2.40:1 AT screen, Calman 5 Enthusiast, i1 Pro 2, i1 Display Pro, Spyder 5, 3D LUT Box
Oppo UDP-203, BDP-105, Onkyo DAC-1000s, Onkyo DP-X1 DAP, QNAP TVS-871
kingwiggi is online now
post #2804 of 2842 Old 06-04-2019, 08:18 PM
Amidujusu89's Avatar
Quoted: 33 Post(s)
ZAPPITI PRO 4K HDR
I updated the zappiti video and first, the direct mode wasn't working. And then it hits me, I have been pressing play before zappiti compiles the technical information of the file... So I waited for zappiti to compile the info before pressing play during first access and wahla, it works perferctly.
Sampinto
Amidujusu89 is offline
post #2805 of 2842 Old 06-04-2019, 08:44 PM
Quoted: 173 Post(s)
Liked: 66
Love to know from the people who used this system is it worth to replace my oppo203 to zappiti for use with 4k projector I love the concept that get all my collection in one place and how is the quality of pic compare to the oppo if one use them both
And last if I want to buy the NAS RIP it doesn’t come with hard drive or the hard drive include?
Thx
A7mad78 is online now
post #2806 of 2842 Old 06-04-2019, 09:42 PM
marine92104's Avatar
Quoted: 301 Post(s)
Liked: 143
Thx
I’ve got both & I find myself using the Oppo 203 more. The Oppo has Dolby Vision & is a sharper picture.
I love the Zappiti video wall though.
The Oppo will also let you force Dolby Vision & some movies that are in HDR look better using the Oppo forced Dolby Vision.
I thought about the Zappiti NAS but it does not come with hard drives. You have to buy them seperately.
I believe you could use the Zappiti NAS networked to the Oppo & the Zappiti.
It would help if Zappiti improved the Blu-ray menus. I’m still having trouble with some of the forced subtitles.
It also annoys me that .iso files start with the subtitles on when using using Menus. The navigation isn’t as smooth when using Menus.
The Oppo always selects the forced subtitles & no problem playing Menus.
I still use the Zappiti but not nearly as much as the Oppo 203.
johng likes this.
marine92104 is online now
post #2807 of 2842 Old 06-04-2019, 09:47 PM
Quoted: 173 Post(s)
Liked: 66
It also annoys me that .iso files start with the subtitles on when using using Menus. The navigation doesn’t work for me as well with menus also.
Thx for the info so I think I will keep up with oppo and delay the buy of zappiti especially still K-scape is my main source but I was looking for rip option to my collection
Thx a lot
post #2808 of 2842 Old 06-04-2019, 10:21 PM
Quoted: 301 Post(s)
Liked: 143
They have software to play 4K .iso files on Oppo 203. They have a sharper picture on Oppo & the Dolby vision makes some of the titles a lot better if you have an OLED.
Zappiti has the best movie wall software I’ve found but I use it for MKVs since the software is smoother with navigation.
I rip the MKVs with the lossless audio track & forced subtitles then I leave the subtitles turned on so it will catch them if it has forced subtitles. It has worked flawlessly for me that way.
post #2809 of 2842 Old 06-04-2019, 10:24 PM
Quoted: 173 Post(s)
Liked: 66
Yes other option I have to move the oppo to my sony A1 Oled and keep the zappiti for the theater since the projector doesn’t play DV just an HDR
post #2810 of 2842 Old 06-05-2019, 06:42 AM
johng's Avatar
Quoted: 232 Post(s)
Liked: 107
Thx a lot
I have both and would not give up my Oppo 203. At the same time, I love the Zappiti video poster wall. It is much better than the Zidoo Z9s or X9s. The Oppo has been pretty much bullet-proof, but the Zappiti can be finicky at times. IMHO, the Zappiti NAS is overpriced for what it is. I bought a Synology NAS and a couple of larger drives set up as a RAID for data redundancy and everything is working very well. I can also access the Synology NAS through the Oppo. So, why do I keep the Oppo? My wife puts it very well when something isn't working properly on the streaming devices: "Just put in a Disc".
Oh, and one other thing about the Zappiti: you can travel with it. When we go on vacation I load up a portable usb drive with a lot of "content" and take the Zappiti with us. Wherever we are, I can plug it into a TV and have access to all the content on the drive. Make sure to bring the remote control, though. The last time I checked the Zappiti "app" for a smart phone can't power up the Zappiti. It's something I should check with tech support to see if they have updated their App.
Good Viewing,John G  JVC DLA-X790 Projector, Vutec 110" (16x9) Bright White Screen, Oppo UDP-203 region free MOD disc player, Zappiti Mini4K HDR, Synology DS418 NAS, Yamaha RX-A2070 AVR, Toshiba 1250 NTSC-PAL Region Free BR Player, 7 Paradigm Reference spkrs w Dual Subs,   & Yamaha 6600 External Amp
johng is offline
post #2811 of 2842 Old 06-05-2019, 07:57 AM
Quoted: 173 Post(s)
Liked: 66
I don’t know about that u can add outside disk rip I will look to this
Thx
post #2812 of 2842 Old 06-05-2019, 08:37 AM
Nick V's Avatar
Quoted: 310 Post(s)
Liked: 302
I have the NAS rip and I love the simplicity of just putting a disc in and it rips automatically.
I have a large collection of Blu-Ray and 4K Blu-Ray discs, and it's great to be able to rip them so simply in the NAS rip drive.
A7mad78 likes this.
Main System: Vizio P70 4K TV. Selah Vigore Speakers. KEF Q100 Rear L/R, Mirage BPS 400 LFE Sub. (2x)Rythmik FM8 Subs. Denon AVR-X4500H Receiver. Lyngdorf TDAI-3400 Integrated (2 channel). Oppo BDP-103. Zappiti Mini 4K HDR. GIK 242 Panels, Tri Traps, Monster Bass Trap. Various Vicoustic Desktop: Dynaudio BM6A mkII. Paradigm SUB10 w/ PBK. Cambridge DACMagic+ DAC. GIK 242 Panels, Monster Bass Trap Master Bedroom: Vizio M55 4K HDR. BG Radia In-Wall/Ceiling Speakers (5.2.2). NAD T758v3 Receiver
Nick V is offline
post #2813 of 2842 Old 06-05-2019, 10:12 PM
sutton8's Avatar
Quoted: 344 Post(s)
Liked: 124
In fairness I have a $400 low powered Celeron PC with 3 optical drives and I can rip UHD or whatever disc using MakeMKV with the click of a couple of buttons. It also acts as a server. So your version of “simplicity” comes at a premium of $2,000+.
ChldsPlay likes this.
sutton8 is offline
post #2814 of 2842 Old 06-05-2019, 10:18 PM
Quoted: 69 Post(s)
Re Direct Output
I have 2 One SE players. One has f/w 3.10 the other has f/w 3.13
When I play a 1080p file on the 3.10 - the TV says that the player is sending 1080p.
Play the same file on the 3.13 - the TV reports 1080i. Amazing?
post #2815 of 2842 Old 06-06-2019, 10:11 AM
Nick V's Avatar
Quoted: 310 Post(s)
Liked: 302
In fairness, I didn't pay that and my NAS rip is rack mounted in a centralized Middle Atlantic rack with structured wiring and I wouldn't consider ghetto'ing my system up for your version of frugality.
A7mad78 likes this.
Nick V is offline
post #2816 of 2842 Old 06-06-2019, 10:49 AM
sutton8's Avatar
Quoted: 344 Post(s)
Liked: 124
Haha good answer. I'm just saying that what Zappiti offers on their rip product can easily be achieved at a fraction of the cost. But each to their own.
johng likes this.
sutton8 is offline
post #2817 of 2842 Old 06-06-2019, 11:08 AM - Thread Starter
Sledgehamma's Avatar
Quoted: 653 Post(s)
Liked: 356
Well, that's pretty much true for every product. Also, MakeMKV is not as easy as the NAS RIP. You have to check manually for forced subtitles as not every BD has them marked as such. And don't get me started on TV series....I use MakeMKV exclusively but its far from a one click solution.
Its obviously meant for people who don't want to bother with this, but just put in the disc and be done with it. If you compare it to Kaleidescape its a pretty decent price point.
Sledgehamma is offline
post #2818 of 2842 Old 06-06-2019, 11:14 AM
sutton8's Avatar
Quoted: 344 Post(s)
Liked: 124
That does not make it any less valid as a point.
If you choose full disc backup on MakeMKV for BD and UHD then it is essentially a one click solution. As to selection of TV episodes then the rip product can't be any more smart than other solutions.
sutton8 is offline
post #2819 of 2842 Old 06-06-2019, 11:20 AM - Thread Starter
Quoted: 653 Post(s)
Liked: 356
True, I forgot about it as I only remux straight to mkv with that program.
post #2820 of 2842 Old 06-18-2019, 01:36 PM
legionow112's Avatar
Quoted: 22 Post(s)
Liked: 7
Ok, in anticipation of my new zappiti player I have installed Zappiti Server on my Synology NAS and Zappiti Video on my Mac to do a little bit of tinkering with this Movie DB. I have registered a free account, I have logged in to the zappiti NAS server, collection was created but ... I unable to add movie folders from my NAS. I have no idea what I doing wrong ...
Just an empty folder which in fact is filled with movies. It even didn't ask for my SMB username and password.
Name:	Zrzut ekranu 2019-06-18 o 22.29.13.png
legionow112 is online now
