Blu-ray ripper subtitle handling and backup discussion thread for the Dunes - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 62Likes
post #61 of 520 Old 02-20-2017, 08:57 AM
jasonkennethrose's Avatar
Quoted: 218 Post(s)
Liked: 94
Originally Posted by pepar View Post
... Scan ...
I think the button should be distinguished in some way ... larger, a different shape, a different color ... something to draw attention. It took me a while to determine how to proceed on my first usage.
I know the tutorial is somewhat behind for new features but it can easily be followed to get you through a disc. Or maybe the big ovals surrounding the correct buttons was to distracting. The messages in the status bar are pretty clear also.
jasonkennethrose is offline
post #62 of 520 Old 02-20-2017, 09:02 AM
Wireless member
pepar's Avatar
Quoted: 1565 Post(s)
Liked: 980
Tutorial?
He is missing the OK button. With the left/right scroll bar inside the program, Windoze display properties is a good guess. Text size?
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #63 of 520 Old 02-20-2017, 09:25 AM
Wireless member
pepar's Avatar
Liked: 980
Just in the process of upgrading to .096. What is "HartTest Blu-Ray Ripper 0.096?"
pepar is offline
post #64 of 520 Old 02-20-2017, 10:22 AM
Quoted: 218 Post(s)
Liked: 94
hart2hart was having an issue we were trying to resolve and it was a special version just for him.
post #65 of 520 Old 02-20-2017, 10:24 AM
Wireless member
pepar's Avatar
Liked: 980
Gotcha. Will ignore.
pepar is offline
post #66 of 520 Old 02-20-2017, 11:48 AM
termite's Avatar
Quoted: 223 Post(s)
Liked: 63
Originally Posted by jasonkennethrose View Post
Have you managed to make it through any discs yet? Were you doing anything during the loading of the tracks? Did you try closing the whole program and starting over? The window looks like it has an unusually large border but its been a long time since I was on Windows 7. The Load and OK button are in the exact same spot so if the Load appears the OK should also. I can load up a Windows 7 VM and test it if you can't get it to work at all. Are you using the default Windows display properties?
Not doing anything special here. Tried starting over few times but the issue of missing OK button remains.
Load button shows up when I have to select the playlist. But after loading the playlist, GUI refresh brings me to the above screen which has no OK button. I haven't played with any of the window display properties so I doubt that's an issue ..I suspect others on Windows should experience this as well??
Yamaha AVENTAGE RX-A3060, Altantic Tech System 350 THX
HSU VTF-3 MK5 HP Sub, Klipsch RP-140SA Atmos Height (x4)
Epson 5050UB, 120" 16:9 screen, Panasonic TC-P60ST50 Plasma
Dune HD Solo 4K, Popcorn Hour C-200, unRAID Server Pro OS 6
Oppo BDP-83, OPPO BDP-203, Fire TV Stick 4K, Sony BDP-BX520, Panasonic DMP‑BDT220
termite is offline
post #67 of 520 Old 02-20-2017, 11:53 AM
Wireless member
pepar's Avatar
Liked: 980
Just curious ... try loading a BD that doesn't have track listings beyond the width of the app's window. The one in your screenshot ... the English AC3 track's "dialnorm" text exceeds the window width. Just guessing though.
termite likes this.
pepar is offline
post #68 of 520 Old 02-20-2017, 12:14 PM
termite's Avatar
Quoted: 223 Post(s)
Liked: 63
That's a great guess! Just tried on another BD where the track listing fits within the app window and the OK button appeared!!
So you're right... that long track listing seems like the issue. You solved the case of the missing OK button
But we still need a solution for the problem. Hope Jason can help..
termite is offline
post #69 of 520 Old 02-20-2017, 12:27 PM
Wireless member
pepar's Avatar
Liked: 980
I am sure he is now pointed in the right direction!
pepar is offline
post #70 of 520 Old 02-20-2017, 02:12 PM
Quoted: 218 Post(s)
Liked: 94
I uploaded new versions 96a-d. If you could check each one, I would appreciate it. If none work I will load up Windows 7 so I can see if I can replicate the problem in house.
post #71 of 520 Old 02-20-2017, 02:44 PM
Wireless member
pepar's Avatar
Liked: 980
FWIW, I use Win 7 x64 and have never experienced this. But then I never loaded a title that caused a left/right scroll bar to appear.
Did you simply widen the app window?
pepar is offline
post #72 of 520 Old 02-20-2017, 03:01 PM
Quoted: 218 Post(s)
Liked: 94
I moved the order that the OK gets loaded in a and c. I moved the order that the OK gets loaded and forced a window redraw in b and d. I have never had to force a window redraw before. There was changes in the Treeview in version .080 because of other graphical issues but it was due to the up/down buttons. Its easy for me to fix things when I can replicate them here. Most issues that arise I cannot replicate or I would have seen them.
Only took me 20 minutes to load Windows 7 and find a disc that had wide enough tracks to test. Lets see how it goes.
Unfortunately I am not experiencing the disappearing OK button on Windows 7 with wide track listings.
post #73 of 520 Old 02-20-2017, 03:13 PM
termite's Avatar
Quoted: 223 Post(s)
Liked: 63
What's the difference between these 4 versions (a-d)? I tried each one and they all look the same with regards to the missing OK button. When the track listing exceeds the window width, the horizontal scroll bar at the bottom can be used to view it (this was true before also), but the OK button is not visible.
I'm running Win7 Ultimate X64.
termite is offline
post #74 of 520 Old 02-20-2017, 04:07 PM
Quoted: 218 Post(s)
Liked: 94
The differences are listed in the post above yours.
I have Windows 7 Ultimate x64 loaded and see no issues with the OK button and a track that requires scrolling. I am still looking at the boarder in your picture you posted. The Windows 7 Basic profile doesn't have boarders that wide.
Can you try 2 things. First select Batch Mode. This will cause the Use Subtitle Editor and Fix Cinemascope Subtitles options to not appear. Second if that doesn't change anything try changing your theme to Windows Classic (Old XP looking)
post #75 of 520 Old 02-20-2017, 04:23 PM
termite's Avatar
Quoted: 223 Post(s)
Liked: 63
Thanks! Just tried both and still has the same issue. Batch mode doesn't seem to help. Also tried Windows Classic & Windows Basic themes.
termite is offline
post #76 of 520 Old 02-20-2017, 05:33 PM
Wireless member
pepar's Avatar
Liked: 980
Win 7 Pro x64. Nice wide borders here. Am running a theme with Stardock ...
If you link me to the offending BD file I will test it.
pepar is offline
post #77 of 520 Old 02-20-2017, 05:43 PM
Quoted: 218 Post(s)
Liked: 94
Here's my Windows 7 Basic with long track information. I think its from The Edge of Seventeen.
Windows 7 with OK button
Works as expected.
Jungle Book without OK button
Jungle Book doesn't even show the OK button with no scroll bar needed. I can fix it now that I can see it broken.
Try the version "e". I don't like the buttons showing so early but its a quick work around for you.
Disregard the "e" version. Here's the deal. If your source path has a uppercase OK in the name the OK button will not show. You were backing up THE_JUNGLE_BOOK_3D. If you change the BOOK to BOok it works fine. I will include a complete fix in .097. For now just watch your source names.
termite likes this.
post #78 of 520 Old 02-20-2017, 07:05 PM
termite's Avatar
Quoted: 223 Post(s)
Liked: 63
Works as expected.
Glad you found the cause!! I was scratching my head and playing with my windows settings ..
I'd have never guessed that one ..
You suggestion to change the name works!!
termite is offline
post #79 of 520 Old 02-20-2017, 11:48 PM
termite's Avatar
Quoted: 223 Post(s)
Liked: 63
By the way I changed the BD folder name and went through the blu-ray ISO creation without errors but when trying to play using Dune Solo it quits with a message "no playlist". This is the first time I'm using the ripper so maybe I overlooked something?
termite is offline
post #80 of 520 Old 02-21-2017, 06:44 AM
Quoted: 218 Post(s)
Liked: 94
Have you tried just running through with an actual disc? If you mount the finished ISO in Windows is there a folder BDMV\PLAYLIST with a 00000.mpls in it? There really isn't anything to miss. All required actions will prompt you if you missed them. Everything else is optional depending on your needs.
post #81 of 520 Old 02-21-2017, 09:58 AM
termite's Avatar
Quoted: 223 Post(s)
Liked: 63
Thanks I'll try again on this.
Today for some reason Ripper is failing to launch...
I get the following Errors message .. puzzling
termite is offline
post #82 of 520 Old 02-21-2017, 10:15 AM
Quoted: 218 Post(s)
Liked: 94
Can you show me whats in your settings.ini in your documents directory? After that you can delete the settings.ini and it will fix your issue. Or change the x and y positions in the setting.ini to 0.
post #83 of 520 Old 02-21-2017, 10:22 AM
Wireless member
pepar's Avatar
Liked: 980
I had this appear one time when I had switched desktop resolution and Ripper was closed at a location not available when I returned to normal rez. Deleting the ini fixed it.
pepar is offline
post #84 of 520 Old 02-21-2017, 10:23 AM
termite's Avatar
Quoted: 223 Post(s)
Liked: 63
What puzzles me is that I didn't do anything this morning... just started my PC and tried to launch the app..
Here's the Settings.ini
[Paths]
Eac3toPath=D:\Ripper\files
TsMuxeRPath=D:\Ripper\files
BDSup2SubPath=D:\Ripper\files
FfplayPath=D:\Ripper\files
WorkingPath=D:\Ripper\working
SourcePath=I:\THE_JUNGLE_BOok_3D
SavePath=L:
[Output]
OutputISO=1
OutputBR=0
OutputM2TS=0
[Options]
BatchMode=0
SkipRemux=0
DeleteWorking=1
EjectDisc=0
ExitProgram=1
CustomOutput=0
SameName=0
[Subtitles]
EditSubtitles=0
FixSubtitles=0
[Window]
X=
Y=
termite is offline
post #85 of 520 Old 02-21-2017, 11:39 AM
termite's Avatar
Quoted: 223 Post(s)
Liked: 63
Just wanted to post an update that I was finally able to generate a working ISO (on Dune) after first mounting the BD and using Ripper on it. Thanks again for all the help.
termite is offline
post #86 of 520 Old 02-21-2017, 12:23 PM
Quoted: 218 Post(s)
Liked: 94
If I could have seen the settings.ini prior to you deleting it I would have made a fix. But I think I can duplicate the issue based on the fact that it occured when changing resolutions. Im sure it was out of bounds of the current resolution and I can make a check that will correct the old bad location to a new good location.
I'm glad you managed to complete a good backup.
post #87 of 520 Old 02-28-2017, 10:19 AM
Wireless member
pepar's Avatar
Liked: 980
@jasonkennethrose , I am having a problem with 2012. Online information is that there are forced subs, and I do get a "fixed" sub track. But it is 46MB and contains every word spoken, regardless of the language, all in English. The fixed track and the BAK track are the same size. Any ideas?
pepar is offline
post #88 of 520 Old 02-28-2017, 11:21 AM
Quoted: 218 Post(s)
Liked: 94
The tracks that are marked "Fixed" mean you selected the Fix Cinemascope Subtitles option. The "BAK" files allow the subtitle editor to restore the original if needed. If a track contains subtitle events flagged as forced they will be named "Normal_Forced" or "Forced". If they might be forced events because of file size they will be named "Maybe". If you believe 2012 has forced events and they are not being detected as forced or maybe forced then you did not select a track that contained the correct data. Run through the disc again and select all available subtitle tracks of your desired language and select the option to use the subtitle editor.
I'm not at home at the moment but I can test 2012 later. I don't recall having any issues with it before.
post #89 of 520 Old 02-28-2017, 11:55 AM
halfelite's Avatar
Quoted: 654 Post(s)
Liked: 341
2012 if I remember right has 4 English tracks and track 1 contains both the forced and non forced lines so a type 1.
halfelite is offline
post #90 of 520 Old 02-28-2017, 03:15 PM
Quoted: 218 Post(s)
Liked: 94
My rip had only one Eng and one Chinese. I am going to re-rip it.
Mine has six subtitle tracks:
9: English - 1810 Normal 88 Forced
10: English - 2159 Closed Captioning
11: French - 1758 Normal 80 Forced
12: French - 79 Forced
13: English - 2483 Directors Comments
14: English - 914 Scene Descriptions
