Official 2017 (new) Amazon HDR FireTV Thread - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 266Likes
post #511 of 547 Old 10-05-2018, 10:45 AM
Paul Arnette's Avatar
Quoted: 66 Post(s)
Originally Posted by aaronwt View Post
It can do everything and more than the Pendant could. It should be good for everyone.
Assuming the 25% less RAM causes no issues(1.5GB vs. 2GB), I expect the FireTV 4K stick to be a nice upgrade over my FireTv 4K Pendant.
A good point was made earlier about the pendant's Ethernet cable option. I may miss that.
Paul Arnette is offline
post #512 of 547 Old 10-05-2018, 10:55 AM
Keenan's Avatar
Quoted: 3777 Post(s)
Liked: 3465
You mean this post?
Originally Posted by rdgrimes View Post
I stopped using my 4K gen-3 pendant because the video processing is so bad with the newest software.
Hopefully this new stick will do better. It supports the Ethernet adapter, which is good.
Keenan is offline
post #513 of 547 Old 10-05-2018, 11:05 AM
UHD Addict
aaronwt's Avatar
Quoted: 8913 Post(s)
Liked: 5696
The FireTv 4K stick has the same Ethernet Adapter option that plugs into the USB port. The same adapter that is used with the pendant is used with the new FireTV 4K stick.
But anyone with a properly setup wifi network will see identical or better results over wifi than the wired connection. Assuming it works like the pendant.
https://www.amazon.com/Amazon-Ethern...hernet+Adapter
Compatible with current Fire TV Stick (2016 release), Amazon Fire TV (2017 release), Fire TV Stick 4K, and Fire TV Cube.
53TB unRAID2--49TB unRAID3--45TB unRAID1a
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #514 of 547 Old 10-06-2018, 10:42 AM
Cliff Olson's Avatar
Quoted: 57 Post(s)
Liked: 55
I decided to plug my Fire TV 4k into my Oppo UDP-205's HDMI in, instead of right into my Samsung KS8000. I figured I would try and "force" feed my old Krell HTS 7.1 a DD+ signal this way, as I use the analog outs of the Oppo. Sure enough, it works. What's even more surprising is the picture is better than plugging directly into the TV. Strange but I'll take it. Only issue is input lag at times. I have to switch the input of the Oppo and then change it back to HDMI In for a fix.
galonzo and mrtickleuk like this.
Cliff Olson is offline
post #515 of 547 Old 10-06-2018, 04:00 PM
bobbino421's Avatar
Quoted: 1129 Post(s)
Liked: 712
Anyone know if the new season of The Man in the High Castle has Dolby Atmos?
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
Samsung HW-K950 Dolby Atmos sound bar
bobbino421 is offline
post #516 of 547 Old 10-06-2018, 04:09 PM
UHD Addict
aaronwt's Avatar
Liked: 5696
When does the new season start?
Sent from my Nexus 7(16GB) using Tapatalk
aaronwt is offline
post #517 of 547 Old 10-06-2018, 04:23 PM
UHD Addict
aaronwt's Avatar
Liked: 5696
Woohoo!! I didn't realize a new season started this weekend.
I just checked from six UHD sources and none had Atmos audio from season 3.
I guess I'll ostly watch from my x800 then. With one episode each from my other devices. I was hoping it would have been in DV, then I would have watched from my ATV 4K or TCL TV.
Sent from my Tab S 10.5 using Tapatalk
aaronwt is offline
post #518 of 547 Old 10-06-2018, 05:16 PM
bobbino421's Avatar
Liked: 712
Yesterday
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
post #519 of 547 Old 10-06-2018, 05:21 PM
bobbino421's Avatar
Liked: 712
Ok thanks for checking. My fire tv pendant is acting up with with Dolby Atmos with Jack Ryan or it’s my sound bar? I get the atmos option on my menu but it won’t engage. Could be a connection? Or the stupid EZCOO splitter I bought from amazon? Either way I’ve tried connecting straight to soundbar and also to my oppo 203 input and nothing?
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
post #520 of 547 Old 10-17-2018, 10:42 AM
galonzo's Avatar
Quoted: 1290 Post(s)
Liked: 1588
Originally Posted by mrtickleuk View Post
Originally Posted by galonzo View Post
The Ultra does support all except DV (and possibly HLG; there are supposedly HLG clips on YT that I haven't been able to test). Same goes for the Premier Plus (I have a 2016), and I'm not sure which current models are the same (Stick Plus maybe?).
Here's a HLG YouTube test clip:
@kokishin , I was finally able to test this out, and no, my 2016 P+ does not support HLG
aaronwt and kokishin like this.
Main: UN78HU9000/SEK-3500 | X4200W (Klipsch/HSU 5.1.2) | UDP-203 (fw 65-0131) | TiVo Bolt | Roku P+
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | AppleTV4K | TiVo Mini
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - UHD Digital codes (and some HD codes)
galonzo is offline
post #521 of 547 Old 10-17-2018, 03:00 PM
kokishin's Avatar
Quoted: 1228 Post(s)
Liked: 1222
Thanks for the update.
I'll probably/eventually get the new amazon 4K FTV Stick which is supposed to support HDR10, HLG, and DV as well as Atmos. However, if Roku has something equivalent or better, then it will get my serious consideration.
galonzo likes this.
Denon AVR-X6200W, Outlaw Audio 7125 Amp, Oppo UDP-203, Oppo BDP-103, Amazon Fire TV Stick, Tivo Roamio Pro, Pioneer Elite Andrew Jones Dolby Atmos Enabled EFS-73 Fronts/EBS-73 Surrounds, Chane A2.4 Center, SVS SB-2000 Sub, Panasonic Plasma TH-58PX600
avsforum Members Atmos & Auro Configuration Spreadsheet
I'm just a caveman. Your modern world frightens and confuses me. RIP Phil Hartman
kokishin is online now
post #522 of 547 Old 10-17-2018, 04:54 PM
dinjal546's Avatar
Netflix no ultra-HD option while using BT headphones and 3rd gen Fire TV 4K.
Need help to debug of issue with Netflix.
As soon as I connect BT headphones (MDRXB950BT/B) to Fire TV 4k, Netflix does not give me an option for Ultra-HD playback.
The moment I disconnect the BT headphones the ultra HD playback again appears.
I used hidden developer options and verified that the streams are indeed HD and ultra hd resolutions.
This is only happening on 3rd gen Fire TV 4K.
This does not happen on Fire TV 2nd generation box. The same BT headphones if connected does not remove the option of ultra hd for Netflix.
The Netflix versions are identical on both the boxes i.e 5.4.2
The 3rd Gen Fire TV 4K has the latest update of OS.
This definitely is an issue with 3rd Gen Fire TV 4K device.
I tired all options on audio settings on the 3rd Gen Fire TV 4K device and it has not changed the behavior of Netflix.
Talked to Amazon and they told me that this is third party app issue of Netflix and they cannot do anything.
Talked to Netflix and they tried to debug for atleat half hour and senior Engineer told me that on this chip Amlogic S905Z there are tunneling issues and the behavior cannot be fixed. They suggested that if I want to use BT headset and watch ultra hd netflix stream get a diff. box.
Any help is appreciated.
dinjal546 is offline
post #523 of 547 Old 10-17-2018, 05:15 PM
Keenan's Avatar
Liked: 3465
I hadn't used my FTV pendant for a while and decided to hook it back up today in anticipation of trying the new Stick due out at the end of the month. My question is about the match framerate function that was added to the FTV firmware just recently. The question is, does it actually work? I tried it on The Romanoffs and it looks as if it's skipping a frame every so often, in other words, it doesn't work. Playback utilizing 60 Hz playback works fine. This is with a Pendant and a Sony A9F connected through a Denon X4500.
Keenan is offline
post #524 of 547 Old 10-17-2018, 06:17 PM
UHD Addict
aaronwt's Avatar
Liked: 5696
The match framerate can work well, but in my experience it can depend on the setup. I was using a SOny UHD TV with an Onkyo receiver. With my FireTV 4K Pendant going through an HDMI switch as well as a ROku. I have several other UHD devices that work great with match framerate also going through HDMi switches. But my ROku Streaming Stick+ and the FireTV Pendant would have stability issues with match framerate on. Then I put a TCL 6 Series in the same location. And now the match Framerate switching has been solid with the FireTV Pendant and my Roku.
galonzo likes this.
aaronwt is offline
post #525 of 547 Old 10-17-2018, 10:41 PM
Keenan's Avatar
Liked: 3465
So, it sounds like it's hit or miss, I was hoping for better than that.
Keenan is offline
post #526 of 547 Old 10-17-2018, 11:04 PM
sutton8's Avatar
Quoted: 342 Post(s)
Liked: 123
For me the problem was with lip sync connected directly to a Denon X7200WA. So switched off and went back to 60Hz and couldn't tell much of a difference with motion, which was fine, though the lip sync error went.
7.2 Yamaha RX-A3080, Monitor Audio (Apex & Silver), Seismic 110, XBOX, Vero 4K, Sony X700, Panasonic TX65GZ950B
5.1 Denon X7200WA, Focal Dome, LG OLED (E6V)
In both Setups "Virgin Tivo V6, Zappiti 4K HDR, FireTV Stick 4K, Harmony Elite"
sutton8 is offline
post #527 of 547 Old 10-19-2018, 10:04 AM
mrtickleuk's Avatar
Quoted: 4369 Post(s)
Liked: 6623
Sounds like you already have the answer? It's a hardware limited of that chip. Not sure what else there is to add from what the Senior Engineer found.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #528 of 547 Old 10-19-2018, 12:34 PM
brotony's Avatar
Quoted: 408 Post(s)
Liked: 321
So the TV may also be equipped with Bluetooth output if you're talking about it rendering HDR (I only suggest that because your TV would be fairly new)? Can you connect your BT headset to TV instead?
I prefer the TV for mine because I can use all the inputs without having to reconnect sources when switching. Same for my optically connected wireless headphone set; base is connected to TV optical output.
The TV likely doesn't limit the input to SDR for Bluetooth audio but sure is a bummer the FTV3 can't handle both (UHD and Bluetooth) simultaneously.
Sent from my PH-1 using Tapatalk
brotony is offline
post #529 of 547 Old 10-19-2018, 04:43 PM
dinjal546's Avatar
unfortunately LG 49UB8500 does not have native audio BT. I plan to use BT transmitter connected to audio out from TV, to get over this issue.
post #530 of 547 Old 10-21-2018, 05:53 AM
anothermib's Avatar
Quoted: 169 Post(s)
Liked: 56
Hi, I have noticed that the Netflix app on my FTV 4k appears to send 2ch audio as 5.1DD+ (with only 2 channels active) rather than as actual 2ch stereo. Unfortunately that is preventing the upmixer on the AVR to work properly for that content.
The problem doesn’t seem to exist on other FTV apps (like youtube with firefox) or with the same Netflix content on other players (like Apple Tv).
Is that a known issue? Any fix or workaround?
anothermib is offline
post #531 of 547 Old 10-21-2018, 10:38 AM
kokishin's Avatar
Liked: 1222
Originally Posted by kokishin View Post
So far, not one cutout while listening to amazon music. HST, I'm kinda waiting for a deluge of amazon music cutouts (Murphy's Law).
@Lp85253
Well Murphy's Law finally hit. Started getting audio cutouts again. Had enough of this crap. I called amazon and told them I wanted to return my FTV pendant and get a credit even though it was out of the return period. The CSR got permission and I will return it this week. I went back to using my FTV Stick (gen 1) which sounds better and never cuts out. Perhaps someday I'll get the new FTV 4K Stick but I'll wait until it's well vetted by others. Or maybe a Roku.
aaronwt, galonzo, naustin and 1 others like this.
post #532 of 547 Old 10-21-2018, 10:46 AM
Quoted: 1907 Post(s)
Liked: 1620
@Lp85253
my roku+ stick is still playing flawless.. the only downside to the app is it lags some compared to the firestick when going through the different interfaces.. not bad , but it does lag in comparison.. if you have thousands of artists like i do it makes it a challenge...
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is online now
post #533 of 547 Old 01-04-2019, 08:10 AM
Liked: 0
I'm with you. Looking through notes on the newest Firestick 4k, I'm thinking it is the dongle/pendant. My soundbar, essentially the same as yours, works fine with ATMOS blu rays on my PS4. I've put in a ticket with Amazon support and am waiting for feedback. I heard 1 episode of Jack Ryan with ATMOS. The rest showed Atmos in the option but no blue light or LED indicator. Very aggravating since it was my sole reason for purchasing it as my fourth FireTV or Stick.
beppate is offline
post #534 of 547 Old 01-04-2019, 07:38 PM
WinMod21's Avatar
Quoted: 363 Post(s)
Liked: 127
3 questions please . . .
1) Is this the best thread for all things related to the Fire TV Cube?
2) Also, is there a thread somewhere for the Fired HD 10 ?
3) And is this: Official 2018 (new) FireTV Stick 4K--Dolby Vision, HDR10+, Dolby Atmos . . thread just 'Stick' related?
We purchased one a few weeks before Xmas; haven't un-boxed it yet, but hoping to tomorrow/Saturday. Thanks for any help & advice.
WinMod21 is offline
post #535 of 547 Old 01-04-2019, 07:48 PM
rdgrimes's Avatar
Quoted: 3752 Post(s)
Liked: 2956
Yes, this is the thread for the Cube. It uses the previous generation hardware, same as the 4K Pendant.
The 4K Stick is all new hardware, so right now that thread is Stick only.
brotony and WinMod21 like this.
rdgrimes is offline
post #536 of 547 Old 01-05-2019, 05:33 AM
WinMod21's Avatar
Quoted: 363 Post(s)
Liked: 127
Thanks very much, rdgrimes, really appreciate your reply. I guess the BestBuy sales gal left that part out. So the new Stick supports Dolby Vision, HDR10+, Dolby Atmos — whereas the Cube doesn't, huh?
WinMod21 is offline
post #537 of 547 Old 01-05-2019, 06:12 AM
rdgrimes's Avatar
Liked: 2956
Yes, plain HDR only on the cube.
WinMod21 likes this.
rdgrimes is offline
post #538 of 547 Old 01-05-2019, 12:52 PM
UHD Addict
aaronwt's Avatar
Liked: 5696
Yes. HDR10 from the Cube.
aaronwt is offline
post #539 of 547 Old 01-05-2019, 01:03 PM
WinMod21's Avatar
Quoted: 363 Post(s)
Liked: 127
Thanks aaronwt.
So except for no DV & HDR10+ & DA, does the FTV Cube do/support everything else that the FTV 4K Stick does, but with the addition of having voice & Alexa control?
WinMod21 is offline
post #540 of 547 Old 01-06-2019, 04:42 PM
WinMod21's Avatar
Quoted: 363 Post(s)
Liked: 127
. . .in fact, now we're trying to remember why we bought the FTV Cube, and besides Alexa & price [was $70], what the main differences are between the FTV Cube . . vs . . a Google Assistant [was $99.] w/ Chromecast Ultra 4K [was $60] ??
WinMod21 is offline
