Disney Launches Movies Anywhere Streaming Service - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 209Likes
post #451 of 772 Old 10-19-2017, 07:41 AM
Sam S's Avatar
Quoted: 320 Post(s)
Liked: 138
Originally Posted by timdafweak View Post
Really, I wanted to thank you for compiling that list. I found your post on SD, which prompted me to look here. I am about to test with a redemption code for District 9.
EDIT: just redeemed Elysium and District 9 on Sony's site. Waiting patiently for them to show up in iTunes. Hopefully they come over as 4K. It didn't happen with "The Nice Guys", which I made the mistake of redeeming on Movies Anywhere (before reading this thread). iTunes has the 4K version, but it came over to iTunes in HD.
Did you get that 3 BD set for Elysium/D9/Chappie?
Sam S is offline
post #452 of 772 Old 10-19-2017, 07:49 AM
cydeweyz's Avatar
Quoted: 435 Post(s)
Liked: 416
Originally Posted by Sam S View Post
Correct. But at least you're guaranteed those rights via Sony, any maybe down the road iTunes (and others?) can pull entitlements directly from Sony?
Don’t bank on Sony “down the road”. Of the 44 Sony titles I have on Vudu, 10 have UHD disks available, but only 1 is in UHD on Vudu.
cydeweyz is online now
post #453 of 772 Old 10-19-2017, 07:57 AM
Sam S's Avatar
Quoted: 320 Post(s)
Liked: 138
So is there really no way to redeem Sony UHD codes for 4K playback on AppleTV? What is the 1 UHD title on VUDU?
Actually District 9 is available in 4K, and it just showed up in my list. Elysium on the other hand, you're right isn't in 4K (yet).
Actually, I just realized that none of those titles are UHD via VUDU, so there is no chance they'll show up as 4K for Apple TV 4K. They might say 4K on the overview screen, but if you start playing them and use the 'swipe down on remote' method, you'll see they're only HD.
Sam S is offline
post #454 of 772 Old 10-19-2017, 08:04 AM
timdafweak's Avatar
Quoted: 31 Post(s)
Yeah this was for the Elysium/District 9 BD set.
Aw shucks. Just so many exceptions to the rule. :/ back to the drawing board.
timdafweak is offline
post #455 of 772 Old 10-19-2017, 08:17 AM
Sam S's Avatar
Quoted: 320 Post(s)
Liked: 138
Might want to bookmark my post, as even I have to remind myself what I confirmed works, and where.
Sam S is offline
post #456 of 772 Old 10-19-2017, 08:17 AM
wxchaser's Avatar
Quoted: 179 Post(s)
Liked: 197
Redeemed code for Apollo 13 through iTunes, should be getting UHD, HD & SD from Universal - only getting HD on ATV4K.
wxchaser is offline
post #457 of 772 Old 10-19-2017, 08:20 AM
JaremyP's Avatar
Quoted: 772 Post(s)
Liked: 432
Can you redeem Sony codes directly on MA now? WIll that give UHD rights in iTunes when it ports in?
Video: JVC NX7, Stewart Cima Neve 135"
Audio: Marantz AV7704, Emotiva XPA-11 Gen 3
Speakers: Focal Electra 1038 Be x 2, Electra CC 1008 Be, Aria 906 x 8, REL S5 SHO x 2
Sources: Apple TV 4k, Kaleidescape Strato, Oppo 203, Xbox One X, Nintendo Switch
Xbox Live: TrackZ
JaremyP is offline
post #458 of 772 Old 10-19-2017, 08:22 AM
Quoted: 34 Post(s)
There is no UHD/4K version of Apollo 13 available on any service right now.
Nordic4tKnight is offline
post #459 of 772 Old 10-19-2017, 08:24 AM
kbmb's Avatar
Quoted: 984 Post(s)
Liked: 777
FandangoNow has UHD for Apollo 13. Redeems on FandangoNow should give you UHD in UV locker.
kbmb is offline
post #460 of 772 Old 10-19-2017, 08:27 AM
wxchaser's Avatar
Quoted: 179 Post(s)
Liked: 197
The Universal site shows UHD, HD and SD versions for Apollo 13.
wxchaser is offline
post #461 of 772 Old 10-19-2017, 08:27 AM
Sam S's Avatar
Quoted: 320 Post(s)
Liked: 138
I don't recommend redeeming Sony codes via MA. My Underworld UHD code came in as SD
Sam S is offline
post #462 of 772 Old 10-19-2017, 08:28 AM
wxchaser's Avatar
Quoted: 179 Post(s)
Liked: 197
Thanks when I redeemed the code I had two options - Fandango or iTunes (chose iTunes).
wxchaser is offline
post #463 of 772 Old 10-19-2017, 08:30 AM
Quoted: 34 Post(s)
Yep, but it’s not UHD yet on any Movies Anywhere service (iTunes, vudu, etc.)
post #464 of 772 Old 10-19-2017, 08:30 AM
kbmb's Avatar
Quoted: 984 Post(s)
Liked: 777
What a pain this all is. FandangoNow has been adding quite a few UHD titles that Vudu doesn't have yet (guessing mainly because they don't do HDR10 yet). So far FN redeems will send UHD rights to UV locker (I redeemed Serenity 4K on FN this morning for UHD in UV locker (only HDX on Vudu).
kbmb is offline
post #465 of 772 Old 10-19-2017, 08:34 AM
kbmb's Avatar
Quoted: 984 Post(s)
Liked: 777
What does your iTunes purchase history show? I'm guessing only HD since iTunes doesn't have it in 4K.
Correct. But FN is the only way to get "something" to show UHD rights. Movies Anywhere itself really needed to be setup to accept all codes AND show the quality - so you could have a record of what you own.
kbmb is offline
post #466 of 772 Old 10-19-2017, 08:35 AM
kbmb's Avatar
Quoted: 984 Post(s)
Liked: 777
I just redeemed the code and it was accepted via Fandango Now (I hadn't joined till today). It will hopefully migrate.
Duh.....should have remember it's a dual redeem! Nice! Congrats!
kbmb is offline
post #467 of 772 Old 10-19-2017, 08:39 AM
Sam S's Avatar
Quoted: 320 Post(s)
Liked: 138
So FandangoNow might be a bust, too. Regardless if it transfers 4K rights to UV (which is the same behavior as redeeming via Sony 4K codes via SonyPicturesStore.com), the 4K entitlement won't show up for iTunes unless it makes it's way to VUDU in UHD.
Sam S is offline
post #468 of 772 Old 10-19-2017, 08:42 AM
kbmb's Avatar
Quoted: 984 Post(s)
Liked: 777
So Fandango now might be a bust, too. Regardless if it transfers 4K rights to UV, the 4K entitlement won't show up for iTunes unless it makes it's way to VUDU in UHD.
Correct, since MA only talks to Vudu. It's the same as redeeming on Sony if Vudu doesn't have the UHD yet. You are basically waiting for Vudu to get UHD in hopes that it transfers in the future based on the UV record.
In this case though, because he redeemed directly on iTunes as well, if iTunes adds the 4K, he'll be able to view it because it's not a "second session".
kbmb is offline
post #469 of 772 Old 10-19-2017, 08:46 AM
Sam S's Avatar
Quoted: 320 Post(s)
Liked: 138
Yup, which is why my plan is to redeem directly in iTunes everything I possibly can: Warner Bros, Fox, Universal.
Sam S is offline
post #470 of 772 Old 10-19-2017, 08:58 AM
JaremyP's Avatar
Quoted: 772 Post(s)
Liked: 432
On VUDU, if so that’s a known and acknowledged issue.
I want to know if a UHD code on MA comes into iTunes with UHD rights? Maybe I’ll buy one and try it myself.
Xbox Live: TrackZ
JaremyP is offline
post #471 of 772 Old 10-19-2017, 09:01 AM
wxchaser's Avatar
Quoted: 179 Post(s)
Liked: 197
It shows HD only. I contacted Apple via chat and got this response from them: "I spoke with a Senior Advisor about this and it looks like the HD 4K version is not in the iTunes Store which is why it didn’t download".
wxchaser is offline
post #472 of 772 Old 10-19-2017, 09:05 AM
kbmb's Avatar
Quoted: 984 Post(s)
Liked: 777
Correct that it's currently only HD. What I was saying before was that IF it goes 4K in iTunes, you'll get the free "upgrade" based on the code was redeemed directly on iTunes.
kbmb is offline
post #473 of 772 Old 10-19-2017, 09:08 AM
wxchaser's Avatar
Quoted: 179 Post(s)
Liked: 197
I hope so, it is one of my favorite all time movies. The launch scene where the astronaut says there is going to be a little jolt is classic (Helmets jerk down, then violently up). I own the original DVD but want the upgrade to higher definition.
wxchaser is offline
post #474 of 772 Old 10-19-2017, 09:12 AM
Sam S's Avatar
Quoted: 320 Post(s)
Liked: 138
If iTunes currently has them in 4K, I understand you can redeem via MA, and retain your 4K entitlement. It would be great if someone could check with 1984 Ghostbusters UHD, redeemed via MA. Because redeeming through Sony only gets it as far as VUDU, which has no 4K version, as such is just HD on iTunes.
Sam S is offline
post #475 of 772 Old 10-19-2017, 09:24 AM
Sam S's Avatar
Quoted: 320 Post(s)
Liked: 138
Can you explain how dual redeem works, and which platforms/studios it applies to?
Sam S is offline
post #476 of 772 Old 10-19-2017, 09:27 AM
cydeweyz's Avatar
Quoted: 435 Post(s)
Liked: 416
Correction- Spiderman Homecoming is the only UHD labeled and owned title I have in my Vudu Library when I sort by studio and choose Sony Pictures. When you look at the details for Spiderman, it shows the studio as Marvel, so I'm not sure if that's a Vudu error. When I go to my library on Sony Pictures Store and myuv.com, the only Sony movies I have that show Ultraviolet UHD rights are: Angry Birds, The Shallows, Life, Ghostbusters (2016) and The Magnificent Seven. Spiderman I redeemed via Google Play Store (MA), so it only shows as HD in the Sony Pictures Store. The Magnificent Seven is also labeled UHD and owned in my Vudu library, but the details page shows that studio as MGM (which means it's not MA and not in my iTunes Library). So zero Sony Pictures Store UHD movies in Vudu have UHD labels or rights when sorted by Sony Pictures studio. Confused yet?
Now to bring that back around to MA, here are the labels I see in iTunes today for the movies I have UHD rights for in the Sony Pictures Store-
Angry Birds (4K Dolbyvision)
The Shallows (HD)
Life (HD)
Ghostbusters 2016-Extended Edition (HD)
Geez, this is a mess. And you wonder why none of this is working the way we expect across all of these services.
In Conclusion- Spiderman: Homecoming (4K Dolbyvision) in iTunes, UHD in Vudu, HD in the Sony Pictures Store library.
post #477 of 772 Old 10-19-2017, 09:32 AM
kbmb's Avatar
Quoted: 984 Post(s)
Liked: 777
This was/is how it works when you don't factor in Movies Anywhere. I'm still not 100% sure how MA changes this, although I have heard that MA will burn the UV side.
Warner and Sony are UV only
Fox is UV -or- iTunes
Universal is UV -and- iTunes
Paramount is UV -and- iTunes
Lionsgate is sometimes UV -and- iTunes and other times not.
Usually you want to redeem the UV side first and then iTunes just to be safe. This is why on the groups/boards you will see people sell split codes.
When talking about the redeems above, it's generally where you redeem directly on Vudu and iTunes, not using something like MYUV or studio sites.
This can all change at anytime now that we have MA - but so far current codes still act this way.
Sam S, CarpeNoctem and wxchaser like this.
kbmb is offline
post #478 of 772 Old 10-19-2017, 09:32 AM
wxchaser's Avatar
Quoted: 179 Post(s)
Liked: 197
The Shallows (HD)
Life (HD)
I could not agree more with you about Geez, this is a mess! How much more confusing can they make it at this point? I'm linking the Federal Reserve to all my streaming accounts, lol
wxchaser is offline
post #479 of 772 Old 10-19-2017, 09:35 AM
kbmb's Avatar
Quoted: 984 Post(s)
Liked: 777
The Shallows (HD)
Life (HD)
Other than Spiderman Homecoming, and Magnificent Seven (which is technically MGM but kinda Sony), the only other UHD title Vudu has is Baby Driver.
And yes....it's an awful mess that MA should have solved by being the GO-TO place to redeem and manage movies. Instead it continues to be a glorified connection between retailers.
kbmb is offline
post #480 of 772 Old 10-19-2017, 09:44 AM
Sam S's Avatar
Quoted: 320 Post(s)
Liked: 138
The Shallows (HD)
Life (HD)
How did you redeem Spiderman: HC?
Does Angry Birds actually playback in 4K, even though it is labeled as such?
Sam S is offline
Disney , movies now
