Adding wifi in an outbuilding - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-28-2017, 01:01 PM - Thread Starter
fronzizzle's Avatar
Quoted: 13 Post(s)
Hello all,
I apologize if this isn't the right forum for this, I didn't see anyplace else it really fit.
I bought a 1.6 acre piece of property last fall, the house is middle/front and my outbuilding (a large pole barn) is near the back. I have Comcast cable for TV & internet, and an Asus router for my wifi.
There is a cable that goes from the house all the way out to the barn. It is approximately 140 ft. from where it connects in the house to the barn, then another 50 ft. inside the barn to the cable box I have. So, a long run.
I am able to watch all of my HD channels in the barn, so far without issue. I don't watch it a lot out there, but enough to be pretty confident that everything is okay.
However, the wifi signal out there is extremely weak/non-existent. My grand plan is to work on cars out there, meaning a laptop with internet access is extremely handy. Plus, I'm adding heat and would love to have a wifi-enabled thermostat so I can turn the heat on from in the house before I go out there.
What is the best way for me to get wifi out there?
fronzizzle is offline
post #2 of 10 Old 11-28-2017, 11:23 PM
Worf's Avatar
Quoted: 935 Post(s)
Liked: 668
Run an Ethernet cable out there and connect a wifi access point for that outbuilding directly.
Edit: another option is to use MoCA bridges to carry Ethernet over the cable line, so you don't have to run another cable to the building.
Worf is offline
post #3 of 10 Old 11-29-2017, 12:38 PM - Thread Starter
fronzizzle's Avatar
Quoted: 13 Post(s)
Thanks for the response. Running Ethernet out there isn't an option, the current conduit that goes underground is full and I don't really want to dig a 140' trench if I can help it.
I'm definitely going to look into the MoCA bridges, thanks for that tip.
post #4 of 10 Old 12-10-2017, 09:45 PM
malaugh's Avatar
Buy a power line extender, one device plugs into the AC next to your router, and the other end plugs into the AC in the shed
malaugh is offline
post #5 of 10 Old 12-13-2017, 09:06 AM
TornadoTJ's Avatar
Quoted: 1952 Post(s)
Liked: 626
MoCA beats powerline by a large margin, and if your breakers are not on the same leg in the panel, powerline won't work at all. If I were in your situation, I'd go MoCA, but I don't have ethernet out to my shop. I'm going to have to install some Ubiquiti Nanobeams for my setup.
If you scroll toward the end of this, Lon talks a little bit about MoCA, and I think there's a link to his MoCA review in the notes.
TornadoTJ is offline
post #6 of 10 Old 12-13-2017, 10:30 AM
solaris72's Avatar
Quoted: 40 Post(s)
Try mesh network, i think it will serve you better. netgear Orbi, google , linksys or eero to name a few.
Sony A1E - Since 11/30/2017
Apple TV 4k - Amazon Fire TV 4k - Chromcast Ultra - Nvidia Shield - Oppo 203 - Dune HD
Onkyo HT-S7800
solaris72 is offline
post #7 of 10 Old 12-13-2017, 10:39 AM
andygiddings's Avatar
Quoted: 118 Post(s)
Liked: 79
Not sure I've ever seen wifi (mesh or otherwise) work effectively over a 140ft distance without a wired backhaul?
Room 1 system: Paradigm Reference Active 7.2 system, Anthem AVM50, Oppo BDP-103. Pioneer Elite 610HD. Room 2: Samsung 65HU8550 with SEK3500, Paradigm Monitor 5.1 system, Denon AVR-X2400H, Oppo BDP-203, Nvidia Shield, Apple TV 4k
andygiddings is offline
post #8 of 10 Old 12-13-2017, 11:08 AM
TornadoTJ's Avatar
Liked: 626
Yeah, that's not going to work, or at best not very well.
post #9 of 10 Old 12-13-2017, 11:18 AM
provels's Avatar
Quoted: 35 Post(s)
Liked: 27
How about a kit like this?
https://www.newegg.com/Product/Produ...82E16833168114
__________________________________________
"How do I know what you hear?" - Firesign Theatre
provels is offline
post #10 of 10 Old 12-13-2017, 11:38 AM
TornadoTJ's Avatar
Liked: 626
Originally Posted by provels View Post
I don't know anything about that brand. I'm a huge Ubiquiti fan though. Follow my thread on their forum and you'll see their recommendation. It looks like about the same price point, too.
https://community.ubnt.com/t5/airMAX...2168639#M75055
You can get their stuff on Amazon.
