Dune HD Pro 4K (Ultra) Thread - Page 163 - AVS Forum | Home Theater Discussions And Reviews
 1756Likes
post #4861 of 6150 Old 02-22-2019, 11:38 AM
jowicrt's Avatar
Quoted: 704 Post(s)
Liked: 208
I always wonder if that would make a difference... i can imagine a good power supply will have it's effects. It would be subtle i guess (if any)?
Arcam AVR850 • Pioneer KURO KRP-600M • KEF Reference Model 4/2/200c •• Velodyne DD15 •• HDI Dune 4K Solo • Logitech Squeezebox Radio/Duet • Wyrewizard Dreamcaster & Spellbinder (by Nordost) • JVC D-ILA-X7500 • HDFury Vertex
jowicrt is offline
post #4862 of 6150 Old 02-22-2019, 11:57 AM
a5ian300zx's Avatar
Quoted: 611 Post(s)
Liked: 197
To be honest, I do find a good power supply or cable (with good shielding) help reduce picture noise levels and improves the sound stage but that's another conversation.
I used the original cable that came with solo4k for about few days then changed to this purifier and I did notice a difference but has been some years now since using it.
Like I say to users it's best to try it in your setup and see how you find it and of you don't like it return it for a full refund.
I have got my linear psu for my oppo aka poop coming soon.
Sent from my Samsung Note 9 using Tapatalk
habianchi likes this.
TV: Sony 65" A1E OLED Surround: Yamaha RXA3070 + Orbs Audio Mod 4/2 7.1.2 + SVS SB12-NSD Stereo: Yamaha AS500 + Kef Q300 Processor: DVDO Iscan Mini + Darbee 5000S Players: Oppo UDP-203 / Dune Solo 4K / Apple TV 4K / VU+ Ultimo 4K NAS: Qnap TVS-871 Pro i7 10GBE
a5ian300zx is offline
post #4863 of 6150 Old 02-22-2019, 02:54 PM
Axel's Avatar
Quoted: 219 Post(s)
Liked: 63
What video settings? There's only contrast, brightness etc. nothing special.
You might turn on auto resolution so the Dune won't scale, but your display will.
I was referring to Video Mode setting, like Maximum Video Mode, Auto Framerate or Color Depth.
I tried Auto Resolution enable/disable, but it didn’t seem to make much difference.
Display is a 65” LG OLED C8.
____
Axel
Axel is offline
post #4864 of 6150 Old 02-22-2019, 03:01 PM
Axel's Avatar
Quoted: 219 Post(s)
Liked: 63
Originally Posted by a5ian300zx View Post
In my opinion the oppo 203 and apple tv 4k both performed better than the dune pro 4k but not the the solo 4k which is on par in my opinion.
Phone camera does not capture it properly but this was the dune pro 4k one.
The pic you took, is this from a static test image or motion?
Is this clip available for download somewhere?
The biggest difference I saw was how poorly the Dune handled motion, unlike the Oppo.
_____
Axel
Axel is offline
post #4865 of 6150 Old 02-22-2019, 03:39 PM
jconjason's Avatar
Quoted: 1280 Post(s)
Liked: 2122
____
Axel
Is there a reason you don't want your OLED doing the upscaling?
Samsung 65" KS8000
Denon AVR 6300H
Klipsch 5.1.2
HSU VTF-3 MK5 HP
jconjason is offline
post #4866 of 6150 Old 02-22-2019, 03:43 PM
Axel's Avatar
Quoted: 219 Post(s)
Liked: 63
Not at all. It’s just that it didn’t seem to make a difference in reducing the motion artifacts when playing off the dune.
_______
Axel
Axel is offline
post #4867 of 6150 Old 02-22-2019, 06:37 PM
Quoted: 34 Post(s)
Liked: 0
I took my Solo 4K out of retirement and going to use it for 1080p files and use Pro 4K for 2160p files.
Fast forward is so useless on Pro 4K because it crashes the unit so easily but works fine on Solo 4K. I wish Dune would fix fast forward on Pro 4K.
Hulkster84 is offline
post #4868 of 6150 Old 02-22-2019, 08:20 PM
vadergr's Avatar
Quoted: 138 Post(s)
Liked: 53
I prefer to use the arrow keys. Up= 1min FW, Right = 10sec FW etc.
Give it a try.
a5ian300zx, blenky and Hulkster84 like this.
vadergr is offline
post #4869 of 6150 Old 02-22-2019, 08:32 PM
Quoted: 34 Post(s)
Liked: 0
Give it a try.
Yes i have been using that Right button a lot to forward a bit but still crashes the unit really really easily. And its not like im spamming the right button either.
Crashes the unit on both 2160p and 1080p files.
post #4870 of 6150 Old 02-22-2019, 10:46 PM
jconjason's Avatar
Liked: 2122
I have no issue fast forwarding.
Hulkster84 likes this.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch 5.1.2
HSU VTF-3 MK5 HP
post #4871 of 6150 Old 02-23-2019, 12:32 AM
djnice77's Avatar
Quoted: 72 Post(s)
_____
Axel
This test video can be downloaded from this link: https://forums.geforce.com/default/t...ce-evaluation/
This video used for 1080p->1080p chroma upscaling, banding and clipping evaulation only.
RTD1295's SD upscaling quality is superior, same as Lanczos3 and significally better than Amlogic and Rockchip.
djnice77 is offline
post #4872 of 6150 Old 02-23-2019, 01:09 AM
Quoted: 658 Post(s)
Liked: 160
+1
Whirlpool0548 is offline
post #4873 of 6150 Old 02-23-2019, 01:36 AM
vadergr's Avatar
Quoted: 138 Post(s)
Liked: 53
Weird.
As you see this is not something normal and not experience by other owners.
You can try resseting your device.
This is the case for playback via network and USB?
vadergr is offline
post #4874 of 6150 Old 02-23-2019, 01:54 AM
Quoted: 34 Post(s)
Liked: 0
Weird.
Oh i see.
Via USB 3.0 with really a fast usb 3.0 stick.
Damnit.
post #4875 of 6150 Old 02-23-2019, 01:56 AM
vadergr's Avatar
Quoted: 138 Post(s)
Liked: 53
Oh i see.
Damnit.
Try another port or with a different drive.
vadergr is offline
post #4876 of 6150 Old 02-23-2019, 01:57 AM
Quoted: 34 Post(s)
Liked: 0
Oh okay.
post #4877 of 6150 Old 02-23-2019, 02:29 AM
jowicrt's Avatar
Quoted: 704 Post(s)
Liked: 208
Why not use the Solo for 2160p as well? As long as it is not HDR, you won't need the Pro 4K.
And how do you switch between the 2? Do you cover the IR with your hand to turn the other one off?
There is no way to let the IR remote distinguish between the Solo and the Pro...
jowicrt is offline
post #4878 of 6150 Old 02-23-2019, 02:43 AM
Quoted: 34 Post(s)
Liked: 0
Well yea but 95% of 2160p movies are with HDR.
I use the same backlight remote for both. No need to cover IR, just turn off Solo or Pro from the switch at the back.
Damn it would have been awesome if Solo 4K had HDR.
post #4879 of 6150 Old 02-23-2019, 03:34 AM
jowicrt's Avatar
Quoted: 704 Post(s)
Liked: 208
If you 'find' tv episodes these days, some of them are 4K (x.265/h.265) as well, and not HDR. But yeah, UHD's are usually HDR.
jowicrt is offline
post #4880 of 6150 Old 02-23-2019, 03:36 AM
a5ian300zx's Avatar
Quoted: 611 Post(s)
Liked: 197
You can use this for 4k hdr test patterns.
https://www.diversifiedvideosolution...uhdhdr-10.html
djnice77 likes this.
post #4881 of 6150 Old 02-23-2019, 12:14 PM
Axel's Avatar
Quoted: 219 Post(s)
Liked: 63
Thank you! I'll check it out.
_____
Axel
Axel is offline
post #4882 of 6150 Old 02-25-2019, 11:49 PM
a5ian300zx's Avatar
Quoted: 611 Post(s)
Liked: 197
I asked dune if they will have any sort of parental lock for the player and just recieved the below reply.
"Hello!
Next firmware will include a possibility to protect any folder via a pin-code."
My reply was when can we expect it?
I asked about the pro 4k and solo 4k.
xiaNaix likes this.
post #4883 of 6150 Old 02-26-2019, 12:29 AM
a5ian300zx's Avatar
Quoted: 611 Post(s)
Liked: 197
Reply to when we can expect it.
"Unfortunately, the dates are not yet clear"
post #4884 of 6150 Old 02-26-2019, 04:23 AM
Liked: 1
Originally Posted by kadqs View Post
I installed Amazon Prime Video from market. It has some content available without account.
But what is available for free depends on region.
I can watch trailers, some 1st episodes for Amazon TV series.
It plays for me, but SD, and not smooth. Navigation with Remote Controller is not complete, mouse has to be used, but also sometimes works strange. UI is optimized for touch controll, I guess.
Different Amazon Video app is available via AptoideTV market. As I see it is the app for Andoroid TV. It works more smooth, is optimized for Remote Controller, no audio breaks, and it adapts quality to connection bandwidth. As I see, trailers switch to HD after while of playback. But it is rather 720p.
At AptoideTV I see onemore app, Amazon Prime Video - this is same as in Google Play.
Question: Is Amazon Prime working now? Not sure about this, I installed two versions (Amazon Prime / Amazon video), started both apps and logged in. After that I can see (and navigate) throw the menus and even start trailers, but when I start a video screen keeps dark and after a while I get an error message to try it later...
Is there any possibility to watch Amazon Prime? Even 720p / stereo would be enough for me to start...
gogi74 is offline
post #4885 of 6150 Old 02-26-2019, 10:38 PM
jowicrt's Avatar
Quoted: 704 Post(s)
Liked: 208
@kadqs any news on upcoming firmware? You are as quiet as Dune...
jowicrt is offline
post #4886 of 6150 Old 02-27-2019, 09:50 AM
DiabloZoe's Avatar
Quoted: 25 Post(s)
I’ve kinda been monitoring this thread, haven’t used my 4K for quite a while. I work in NorCal and the player stays in Vegas. But it seems Dune has fallen? Is this the general consensus? My first player was an Himedia box. Got rid of that and have 4 dune players. Be cause they were well above the rest, used high end components and just worked. While I know no box is perfect. What happened to Dune? What is the general opinion? Are you guys getting rid of your Dune players?
DiabloZoe is offline
post #4887 of 6150 Old 02-27-2019, 11:03 AM
xiaNaix's Avatar
Quoted: 46 Post(s)
Liked: 38
I wouldn't say that. Dune and most of the others (Zidoo, etc.) are just having difficulty getting things working properly with the Android system. There isn't really a perfect box at this time.
Sony BDP-S6700 (Region Free) | Dune Solo 4K | Zidoo X9S
Epson Home Cinema 3100 | Silver Ticket STR-169110 110" Screen
Yamaha RX-A770 | Chane A2.4 L-C-R | Fluance XLBP Wide Dispersion Bipolar Rears | Hsu VTF-2 MK5 Sub
xiaNaix is offline
post #4888 of 6150 Old 02-27-2019, 12:43 PM
blenky's Avatar
Quoted: 968 Post(s)
Liked: 878
Not getting rid of mine yet. I also have a Z9S - which has its own issues. Just giving both time to see how they progress.
Samsung UE55KS8000 | Pioneer SC-LX701 | Dune HD Pro 4K | Zidoo Z9S | Apple TV 4K | Samsung UBD-K8500 UHD Player
blenky is offline
post #4889 of 6150 Old 02-27-2019, 04:13 PM
jconjason's Avatar
Liked: 2122
In a way, Dune has fallen. Leaving Sigma was a big blow to their product line. In my opinion they are still struggling to get these boxes working correctly with Realtek. It's been a step in the wrong direction.
With that said I have faith in Dune and believe they will eventually get things back on track. Some in this thread will lead you to believe Dune is "dead" and that these players are "garbage", but those same few people still own these "garbage" players. Some people like to bitch just to bitch.
xiaNaix likes this.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch 5.1.2
HSU VTF-3 MK5 HP
post #4890 of 6150 Old 02-27-2019, 05:52 PM
DiabloZoe's Avatar
Quoted: 25 Post(s)
I don't think Dune is dead, just not top of the food chain. Ive always thought Realtek to be junk...I was told that when I purchased my first media player. I see PCH is still using the sigma chip. Is this a outdated chip?
