Dune HD Pro 4K (Ultra) Thread - Page 168 - AVS Forum | Home Theater Discussions And Reviews
 1668Likes
post #5011 of 5825 Old 03-15-2019, 01:27 PM
robena's Avatar
Quoted: 175 Post(s)
Liked: 75
Originally Posted by stefanop View Post
thank you very much, I've looked for it in the website and I haven0t found it.
P.S. with 12bit 4:2:2 output MHV UHD play fine. Problem is with 10 bits.
I use 10 bit 4.4.4 without problems, which prevents the TV to resync since it's its EDID native mode for UHD.
Maybe were you using 10 bit 4.2.2? Or 4.2.0? Or Auto?
Robert
robena is offline
post #5012 of 5825 Old 03-16-2019, 08:31 AM
Quoted: 114 Post(s)
Liked: 29
Yes I was using 10 bit 4:2:2. I'll give it a try in a minute...
stefanop is offline
post #5013 of 5825 Old 03-16-2019, 08:42 AM
Quoted: 114 Post(s)
Liked: 29
File is TheMeg4K
10 bit 4:4:4 = Radiance reports 23.999Hz (with other settings in 10bits, 4:2:0, 4:2:2, the value is the same)
12 bit 4:2:2 = Radiance reports 23.974Hz
stefanop is offline
post #5014 of 5825 Old 03-18-2019, 08:22 AM
kadqs's Avatar
Quoted: 403 Post(s)
Liked: 329
Originally Posted by jowicrt View Post
@kadqs any news on upcoming firmware? You are as quiet as Dune...
As you can see, dune releases now Alfa versions at http://dune-hd.com/dunecontrol/
Initially it was about remote controll and HTTP API. But till now they released there 3 updates, and included much more improvements, not only for API and the mobile app.
So even if you do not install, you can see the progress and what Dune is workin on. Release notes are available there.
I personally focused on testing mobile App, and I like it very much.
As I know, in the next release we can expect first version of BD4K Menu support. Desired and requested for a long time. Dune informed that they are closing final tests before public release. But it is not sure if they will release as alfa or beta or...
I also tested small patch for Netflix, that enables multichannel audio at Pro4k/Max4K and Ultra4K models. Worked well for me, so I home Dune will release it also quite soon.
I have no more news for now.
Thanks to the new API, we can expect new integration with smarthome systems soon. Maybe it is a value for some of you.
DuneHD Ultra4K, Pro4K, Neo4k, Duo4K, Solo4K, Base3D, TV-102w, QNAP/Synology, Fibaro, Sonos, iEast
kadqs is offline
post #5015 of 5825 Old 03-18-2019, 09:12 AM
robena's Avatar
Quoted: 175 Post(s)
Liked: 75
@kadqs does the Alpha firmware only implements the control functions, or does it correct some bugs (such as incorrect 23.976 output) or add missing features (such as subs sync)?
Robert
robena is offline
post #5016 of 5825 Old 03-18-2019, 10:46 AM
kadqs's Avatar
Quoted: 403 Post(s)
Liked: 329
Release notes are published with the alfa versions. Open the link and read. There are more fixes not related to API and the APP.
I do not know if Dune is working on 23.976 fix.
-Caesar- likes this.
kadqs is offline
post #5017 of 5825 Old 03-18-2019, 10:51 AM
jconjason's Avatar
Quoted: 1164 Post(s)
Liked: 1994
Thank you!
Samsung 65" KS8000
Denon AVR 6300H
Klipsch 5.1.2
HSU VTF-3 MK5 HP
jconjason is offline
post #5018 of 5825 Old 03-18-2019, 11:38 AM
robena's Avatar
Quoted: 175 Post(s)
Liked: 75
Oops, missed that, I did not scroll down enough and only saw the APK release notes. Thanks.
It doesn't seem that the crucial things that are missing compared to the Solo have been added, it's a real shame to see Dune wasting time on new features before fixing the most basic ones.
Robert
robena is offline
post #5019 of 5825 Old 03-18-2019, 12:03 PM
blenky's Avatar
Quoted: 924 Post(s)
Liked: 838
Thanks for the updates. I'm going to wait until the introduction of UHD menus!
Samsung UE55KS8000 | Pioneer SC-LX701 | Dune HD Pro 4K | Zidoo Z9S | Apple TV 4K | Samsung UBD-K8500 UHD Player
blenky is offline
post #5020 of 5825 Old 03-18-2019, 12:53 PM
markswift2003's Avatar
Quoted: 690 Post(s)
Liked: 453
....it's a real shame to see Dune wasting time on new features before fixing the most basic ones.
My feelings exactly.
jowicrt and Hulkster84 like this.
Zidoo Z9S | Dune Pro 4K | HDFury Vertex | 32TB mirrored storage
Denon AVC-X8500H | JVC DLA X7000 | Screen Research 9ft multi aspect ClearPix 2 ISF screen
3 x PMC IB2S fronts | 4 x PMC Wafer 2 rears | 4 x PMC Wafer 1 ceiling | 2 x M&K SS550 THX height | Rel Stentor III
A pair of slippers, a comfy sofa and a glass of 16 year old single malt
markswift2003 is offline
post #5021 of 5825 Old 03-18-2019, 12:54 PM
Quoted: 53 Post(s)
Liked: 5
Blu-Ray .iso playback
Hi again,
I bought the Dune HD Pro 4K player which arrived today.
Connected the Dune to my Denon receiver which is connected to my NAS, Network file browser, found the NAS and connected everything fine through the network connections.
Now I went into the Dune's Source, found the 3D Metallica file but it shows as mpg file (not .iso). It doesn't play any .iso files.
Do I have to install another player to play the .iso files (and in 3D)?
I'm lost...
Thank you.
Cheers
Caesar
-Caesar- is online now
post #5022 of 5825 Old 03-18-2019, 02:10 PM
Quoted: 614 Post(s)
Liked: 156
Originally Posted by -Caesar- View Post
Hi again,
I'm lost...
Thank you.
Cheers
Caesar
Are the ISOs music files ?
New feature: When attempting to play SACD ISO (DSD ISO) audio files or
CUE audio playlist files, a recommendation to use HiByMusic application
is shown (with the option to directly launch the application) (after that
these files should be manually found and launched by the user inside
HiByMusic application; unfortunately, HiByMusic application does not
support direct launch-file action for these file types).
...........just a guess
Whirlpool0548 is offline
post #5023 of 5825 Old 03-18-2019, 02:31 PM
Quoted: 53 Post(s)
Liked: 5
Hi,
Thank you, no they are Blu-Ray .iso files (copied from my Blu-Rays with DVDFab and stored in .iso format on my NAS).
When I asked here in this forum people said yes, no problem. But did not mention how to play them back.
Cheers
Caesar
post #5024 of 5825 Old 03-18-2019, 02:39 PM
Quoted: 614 Post(s)
Liked: 156
Hi,
Cheers
Caesar
OK, will check if I have any ISOs to try, the fact that they don’t list as .iso is odd.
post #5025 of 5825 Old 03-18-2019, 03:15 PM
Quoted: 114 Post(s)
Liked: 29
Yes, it is.
ISO files do work on Dune Pro 4K, I've got tons of them in my NAS.
stefanop is offline
post #5026 of 5825 Old 03-18-2019, 03:22 PM
Quoted: 614 Post(s)
Liked: 156
Hi,
Cheers
Caesar
Can you verify the integrity of one of the DVDFab ISOs ?
E.g play it on a PC, or verify the structure using winrar or 7-zip ?
I have a copy of The Maze Runner 3D iso, Will verify it plays OK, although another user has confirmed many ISOs that play OK.
OK, tested The Maze Runner 3D iso - It lists as a .iso, plays correctly with blu-Ray menu.
There could be an issue with the ISOs, e.g not fully decrypted ?
post #5027 of 5825 Old 03-18-2019, 04:10 PM
robena's Avatar
Quoted: 175 Post(s)
Liked: 75
This alpha version FINALLY implements the possibility to have subs on by default, and to give priority to either internal or external. I was getting really tired to have to set on the subs manually at each start.
Sub sync stills does not work.
23.976 is still wrong, but (for me) almost unnoticeable, except very strangely for the "Arrow" TV series where I see dropped (or repeated, can't tell which) very often.
Robert
robena is offline
post #5028 of 5825 Old 03-18-2019, 05:12 PM
Quoted: 53 Post(s)
Liked: 5
Yes, it is.
In mvs decoded format?
What program do you use to create the Blu-Ray 3D .iso files?
What player on the Dune do you use to play those Blu-Ray .iso files?
Cheers
Caesar
post #5029 of 5825 Old 03-18-2019, 05:14 PM
Quoted: 53 Post(s)
Liked: 5
Thanks again mate.
They are playing fine on my PC (VLC-Player), though no 3D since that's not supported on my box.
What player do you use to play your Blu-Ray .iso files?
Should I update teh firmware?
Current version which is on that box is from 28/11/2018.
Cheers
Caesar
post #5030 of 5825 Old 03-18-2019, 05:29 PM
Quoted: 614 Post(s)
Liked: 156
Thanks again mate.
Cheers
Caesar
The firmware version/date you quote is current, this is not a firmware issue.
I use the the default blu-Ray player.
But, you mentioned that when you see your movies listed, they are shown as mpg files.
My copy of the Maze Runner 3D ISO is listed as a .iso.
Select the file, press enter on the remote, playback starts, no need to select a player.
(To Play in 3D enable 3D in the Pro 4k video settings and on your display)
Are your ISOs fully decrypted, or, is VLC-player decrypting ?
The Pro 4K will not play unencrypted ISO files.
post #5031 of 5825 Old 03-18-2019, 06:28 PM
halfelite's Avatar
Quoted: 634 Post(s)
Liked: 330
Hi again,
I'm lost...
Thank you.
Cheers
Caesar
Sounds like you are not connected over samba or NFS. You are most likely seeing a upnp/dlna server running on your NAS which wont work with ISO files make sure you connect over samba or NFS
halfelite is offline
post #5032 of 5825 Old 03-18-2019, 06:34 PM
halfelite's Avatar
Quoted: 634 Post(s)
Liked: 330
Can you pick forced subtitles? Or is it strictly by language?
post #5033 of 5825 Old 03-18-2019, 06:59 PM
Quoted: 53 Post(s)
Liked: 5
Fully decrypted, but see below what the issue was...
post #5034 of 5825 Old 03-18-2019, 07:03 PM
Quoted: 53 Post(s)
Liked: 5
My friend, you are my hero today!
That was exactly the problem.
All works fine now and I don't have to send back this box.
Just one issue- the colours are not really the same as played back from my original Blu-rays over my Denon Blu-ray player. Is that the problem with the UHD not being functioning with this player?
Thank you kindly and enjoy the rest of the night (or where ever you are in the world).
Cheers
Caesar
post #5035 of 5825 Old 03-18-2019, 07:49 PM
jconjason's Avatar
Liked: 1994
Well, he did say the next firmware will have the first release for UHD menu support....
As I know, in the next release we can expect first version of BD4K Menu support. Desired and requested for a long time. Dune informed that they are closing final tests before public release. But it is not sure if they will release as alfa or beta or....
Samsung 65" KS8000
Denon AVR 6300H
Klipsch 5.1.2
HSU VTF-3 MK5 HP
post #5036 of 5825 Old 03-18-2019, 11:20 PM
robena's Avatar
Quoted: 175 Post(s)
Liked: 75
Neither.
You have the choice between an external srt file, or the first internal sub muxed in the MKV file.
I don't know if it works for full BDs, I only watch MKVs.
But if you want the forced subs, all you have to do (with MKVs) is either to put them into an srt file with the same name as the movie, or remux them into the movies first. The second solution allows to use any font that the tool that convert srt to sup (I user tsmuxer) supports, and to control the position. Me, I like my subs at the bottom of the visible video, so the height position varies whether the aspect ratio is 1.85, 2.0, 2.20 or 2.35.
Robert
robena is offline
post #5037 of 5825 Old 03-19-2019, 01:00 AM
Quoted: 614 Post(s)
Liked: 156
Cheers
Caesar
Good to hear you resolved the issue with correctly accessing files on your NAS. Didn’t suspect you were seeing them via DLNA.
HDR BT.2020 works fine on this player playback colour should be as for your Denon Blu-Ray player.
It’s just full UHD blu-Ray menus that are not yet working.
Using ‘play-lite’ you are able to play the main movie.
Check your video settings on the Pro 4K.
Is HDR enabled on the HDMI port of the display you are using for playback from the Pro 4K ?
How are the colours different, is the display ‘washed out’ ?
post #5038 of 5825 Old 03-19-2019, 01:16 AM
Quoted: 614 Post(s)
Liked: 156
Neither.
You don’t need to to anything to get forced subs from HD blu-Ray BDMV folder playback, the forced subs are automatically displayed.
(Also expect the same functionality for UHD blu-Ray BDMV folder playback + correct handling of seamless branching when Dune release UHD blu-Ray menus, hopefully very soon !).
post #5039 of 5825 Old 03-19-2019, 02:12 AM
blenky's Avatar
Quoted: 924 Post(s)
Liked: 838
I meant I would not bother with the current alpha releases but wait for the next beta that should have UHD menu support.
blenky is offline
post #5040 of 5825 Old 03-19-2019, 02:25 AM
Quoted: 114 Post(s)
Liked: 29
Cheers
Caesar
I use AnyDVD for 3D ISO and MakeMKV for the rest.
Internal Player, the default one you find when you first startup your Dune.
stefanop is offline
