Dune HD Pro 4K (Ultra) Thread - Page 179 - AVS Forum | Home Theater Discussions And Reviews
 1833Likes
post #5341 of 6563 Old 04-20-2019, 09:33 AM
Tarpon65's Avatar
Quoted: 25 Post(s)
Originally Posted by jconjason View Post
You can always install it and see for yourself. If you aren't happy with an update you can roll back.
I installed it before I posted earlier, I just wasn't sure what this update added.
LG OLED65B6P TV, Anthem MRX520 Pre Pro, B&K AV5000 Amp, Panasonic BDK-55 Blu-ray, B&W 600 Series F/R/C/Rear Speakers, Dune 4K Pro and Amazon Fire Tv media players
Tarpon65 is offline
post #5342 of 6563 Old 04-20-2019, 09:38 AM
Quoted: 25 Post(s)
Liked: 2
Finally yeahhh!!!!!
Big day for all dune users
tukul28 is offline
post #5343 of 6563 Old 04-20-2019, 09:47 AM
McClane77's Avatar
Does it fix framerate issues?
McClane77 is offline
post #5344 of 6563 Old 04-20-2019, 09:51 AM
jconjason's Avatar
Quoted: 1401 Post(s)
Liked: 2329
Originally Posted by tbass2k View Post
Exactly, so far it's loaded every 4k image I've had quickly and flawlessly, of course imma test every title I have. Bravo Dune! Way not to listen to the haters and give up on your products and reputation.
Sent from my SM-N960U using Tapatalk
Same here. The handful I've tried loaded the menus perfectly. With anything I assume their will be some bugs but it's now implemented and they can continue to iron it out.
tbass2k likes this.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch 5.1.2
HSU VTF-3 MK5 HP
jconjason is offline
post #5345 of 6563 Old 04-20-2019, 09:57 AM
blenky's Avatar
Quoted: 1015 Post(s)
Liked: 936
Going to give this a whirl. Need to re connect my Dune as has been gathering dust the last few weeks.
As mentioned earlier there are other concerns other than UHD menu support. Does it fix the frame rate issue, add support for external srt when there are internal subs? Can you now adjust audio sync? Have they overhauled to not very good MyCollection?
I'm sure there other issues I have not mentioned.
Samsung UE55KS8000 | Pioneer SC-LX701 | Dune HD Pro 4K | Zidoo Z9S | Apple TV 4K | Nvidia Shield TV (2019) | Fire TV Stick 4K | Samsung UBD-K8500 UHD Player
blenky is online now
post #5346 of 6563 Old 04-20-2019, 10:09 AM
tbass2k's Avatar
Quoted: 342 Post(s)
Liked: 382
I've loaded about 12 titles so far, here's what I've noticed.
1. Subtitles on several UHD titles are enabled by default. Is there a setting in the Dune setup to disable this?
2. On the Captain America movies it loads fine but starts the movie at the menu/movie screen without giving you the option to go directly to the menu. If you press the pop up menu you can get there after the movie starts as normal.
Minor issues, but just some observations.
tbass2k is offline
post #5347 of 6563 Old 04-20-2019, 11:30 AM
tbass2k's Avatar
Quoted: 342 Post(s)
Liked: 382
Update:
So far only Bumblebee is not working properly. It loads the disc but when it gets to the main menu the disc options aren't there, it's just blank with the background of Bumblebee and the girl.
tbass2k is offline
post #5348 of 6563 Old 04-20-2019, 11:51 AM
Quoted: 35 Post(s)
Liked: 2
Bumble Bee gave me the same issue but on the regular Blu-ray, not UHD. It was like that before the new update too
rosche22 is offline
post #5349 of 6563 Old 04-20-2019, 12:45 PM
tbass2k's Avatar
Quoted: 342 Post(s)
Liked: 382
I was just about to type that I reinstalled the firmware and now the Bumblebee UHD menu is working. Interesting though about the regular bluray version, I haven't ripped it yet to test.....
Update- I stopped and restarted the Bumblebee UHD disc, back to no menu....must be an intermittent bug.
tbass2k is offline
post #5350 of 6563 Old 04-20-2019, 02:36 PM
markswift2003's Avatar
Quoted: 980 Post(s)
Liked: 687
Originally Posted by robena View Post
But something tells me all this is vastly off-topic and extremely controversial subject in this thread.
But very refreshing for this thread - really enjoyed reading this....
robena likes this.
Zidoo Z9S | Nvidia Shield Pro | HDFury Vertex² | 32TB mirrored storage
Denon AVC-X8500H | JVC DLA X7000 | Screen Research 9ft multi aspect ClearPix 2 ISF screen
3 x PMC IB2S fronts | 4 x PMC Wafer 2 rears | 4 x PMC Wafer 1 ceiling | 2 x M&K SS550 THX height | Rel Stentor III
A pair of slippers, a comfy sofa and a glass of 16 year old single malt
markswift2003 is offline
post #5351 of 6563 Old 04-20-2019, 02:56 PM
halfelite's Avatar
Quoted: 654 Post(s)
Liked: 340
Either that or one...or two will whine that it took so long. I've noticed one....or two in this thread will never be happy with this product.
It took to long =P. For those that have flashed have you noticed any negative impact the firmware warns " There were big changes in the core parts of the firmware, so some
functions may be potentially broken in this version."
Nothing is standing out yet? Im busy all weekend so cant pull mine out to test yet but this might save me from buying the oppo unless I get the DV itch
halfelite is offline
post #5352 of 6563 Old 04-20-2019, 03:33 PM
blenky's Avatar
Liked: 936
Tested a few and so far very good. Implementation is better than the Zidoo - which matches with Dunes superior standard bluray menu support.
Only found one minor glitch so far. Deadpool 2 Super Duper Cut - on starting the intial logo appears in one quarter (top left) of screen. However after that its OK.
Whirlpool0548 likes this.
post #5353 of 6563 Old 04-20-2019, 03:59 PM
lithiumus's Avatar
Quoted: 86 Post(s)
Liked: 38
This is awesome! Will check the vertex and see if the framerate was corrected...
lithiumus is offline
post #5354 of 6563 Old 04-20-2019, 04:25 PM
robena's Avatar
Quoted: 236 Post(s)
Liked: 105
Nope, still 23.987.
So that, subs sync and maybe HDR meta data (I don't know how to check) are the last missing things to fix.
I must say though that I almost never notice a problem with the frame rate on my system.
Robert
robena is online now
post #5355 of 6563 Old 04-20-2019, 04:44 PM
007james's Avatar
Quoted: 53 Post(s)
Liked: 46
Well, I'm happy to see that Dune is continuing to work on firmware features/fixes, I hope that DVD chapter skip is in the making, overall, stability seems improved, thanks to Dune for their continuous efforts
007james is offline
post #5356 of 6563 Old 04-20-2019, 05:56 PM
robena's Avatar
Quoted: 236 Post(s)
Liked: 105
Well, unfortunately, dune_firmware_tv292a_190412_0053_r13 as the same problem as dune_firmware_tv292a_190330_0254_r13: it's unable to play single MKV files.
I just tried to watch an 40 minutes series properly remuxed with mkvtoolnix, and at minute 3, it jumped to minute 20. dune_firmware_tv292a_190330_0254_r13 had the same behavior, sometimes jumping, sometimes stopping to play.
The last usable firmware for MKV files is the alpha dune_firmware_tv292a_190330_0254_r13 one, the first to add default subs choice.
I reverted to it, and the same file played without a hitch.
Robert
post #5357 of 6563 Old 04-20-2019, 07:52 PM
mike_carton's Avatar
Liked: 42
Remaining:
- frame rate
- forced subs
- mkv file playing (with forced subs)
- subs sync
Anything else?
mike_carton is offline
post #5358 of 6563 Old 04-20-2019, 08:08 PM
jconjason's Avatar
Liked: 2329
I have no issue playing mkv files. Do you mean specifically with series? I only have movies in mkv, and they all play with no issue.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch 5.1.2
HSU VTF-3 MK5 HP
post #5359 of 6563 Old 04-20-2019, 08:27 PM
lithiumus's Avatar
Quoted: 86 Post(s)
Liked: 38
Nope, still 23.987.
I should be able to confirm Luminance Max / Min and MaxCLL and MaxFALL with the Vertex compared to the original source.
I never checked before but Ill have a look and see...
post #5360 of 6563 Old 04-20-2019, 10:17 PM
Quoted: 25 Post(s)
Liked: 2
Update:
U wait till 8min then voila the menu will came out
tukul28 is offline
post #5361 of 6563 Old 04-20-2019, 11:26 PM
lithiumus's Avatar
Quoted: 86 Post(s)
Liked: 38
Ok. I dont know where the Dune was previously but I can confirm that the Dune is sending correct Luminance Min/Max values via the Vertex output signal data compared to the video file data using Mediainfo on several releases...
However, the MaxCLL and MaxFALL are not correct. Some titles show both as 0 and some have values like 36731 and 49152 when they should be 1000 and 607 respectively.
HDR data is still not accurate
I watched a title with forced subs and they are not working via the UHD menu playback.
Seamless branching using UHD menus seems to be working!
jowicrt likes this.
post #5362 of 6563 Old 04-20-2019, 11:30 PM
robena's Avatar
Quoted: 236 Post(s)
Liked: 105
This time it was an episode the Amazon version of The Closer (S07-E16), remuxed with 2 custom PGS subs. One white, for viewing with a Solo, and one grey for viewing with the Pro in SDR to HDR conversion mode, the white one being blinding.
The time before, I don't remember.
The file must have a small glitch, because the alpha firmware triggers the TV OSD at the place that makes the new firmware jump. The alpha one, and all the previous ones, did not mind the glitch while the last 2 firmwares skip or terminate.
I'm guess that if I recode, not remux, the file will play nicely. Still, these glitches are not rare, the firmware should handle them more graciously like before.
Robert
post #5363 of 6563 Old 04-21-2019, 12:42 AM
Liked: 0
I have problem with my dune hd pro 4k (292b). When I turn off device by remote control, usb 3.0 port is still active (usb 2.0 port is inactive). Is it hardware problem or firmware? Thank you
Tomas Hirner is offline
post #5364 of 6563 Old 04-21-2019, 01:40 AM
polypenko's Avatar
Just tested the Netflix app. 5.1 audio works now , however I'm not able to start any UDH 4k content.
I'm located in the Netherlands.
Marantz Sr7010 / Magnat Quantum Speakers / Tangent Rear Speakers / LG TV
polypenko is offline
post #5365 of 6563 Old 04-21-2019, 02:11 AM
jowicrt's Avatar
Quoted: 705 Post(s)
Liked: 209
Originally Posted by mike_carton View Post
Remaining:
- frame rate
- forced subs
- subs sync
Anything else?
- audio sync
- HDR metadata
Arcam AVR850 • Pioneer KURO KRP-600M • KEF Reference Model 4/2/200c •• Velodyne DD15 •• HDI Dune 4K Solo • Logitech Squeezebox Radio/Duet • Wyrewizard Dreamcaster & Spellbinder (by Nordost) • JVC D-ILA-X7500 • HDFury Vertex
jowicrt is offline
post #5366 of 6563 Old 04-21-2019, 06:21 AM
tbass2k's Avatar
Quoted: 342 Post(s)
Liked: 382
You are joking, right?
tbass2k is offline
post #5367 of 6563 Old 04-21-2019, 07:47 AM
helcio.carvalho's Avatar
Quoted: 18 Post(s)
Remaining:
- frame rate
- forced subs
- subs sync
Anything else?
Audio sync, Dolby Atmos, settings for brightness, contrast, etc.
helcio.carvalho is offline
post #5368 of 6563 Old 04-21-2019, 08:02 AM
tbass2k's Avatar
Quoted: 342 Post(s)
Liked: 382
Dolby Atmos? Works fine for me. Did you mean Dolby Vision?
tbass2k is offline
post #5369 of 6563 Old 04-21-2019, 08:36 AM
blenky's Avatar
Liked: 936
Remaining:
- frame rate
- forced subs
- subs sync
Anything else?
Taken from other posts
- audio sync
- HDR metadata
- settings for brightness, contrast
And for me personally I would really like to see some (major) update to MyCollection. Of course they need to get the basics right first!
post #5370 of 6563 Old 04-21-2019, 08:50 AM
robena's Avatar
Quoted: 236 Post(s)
Liked: 105
I tried to reproduce the problem, to send a sample to Dune support. I couldn't, it seems random.
Robert
