Dune HD Pro 4K (Ultra) Thread - Page 182 - AVS Forum | Home Theater Discussions And Reviews
 1824Likes
post #5431 of 6471 Old 04-29-2019, 07:14 AM
polypenko's Avatar
I even get it at Ramdon, dune freezes up enterily.
Netflix app sometimes works, but eventough my Marantz sr7010 receiver indicates Dolby+, the
sound reproduced by the system is not actually 5.1 surround.
When I use the Netflix App on my LG Oled TV 4k, everything is a okay. (sound indicator Marantz shows Dolby Digital)
Marantz Sr7010 / Magnat Quantum Speakers / Tangent Rear Speakers / LG TV
polypenko is offline
post #5432 of 6471 Old 04-30-2019, 12:54 AM
Liked: 0
Since Firmware update 190412-0053 R13
the Dune freezes at starting sometimes
dagobert is offline
post #5433 of 6471 Old 04-30-2019, 05:47 AM
kadqs's Avatar
Quoted: 404 Post(s)
Liked: 329
Originally Posted by -Caesar- View Post
I finally (after a factory reset!) got Netflix running. But what a disappointment!!!!
When set to 2 channels, Netflix runs fine. When set to 5.1 it crashes ("Netflix has stopped").
WTF!!!
Do those Dune developers know what they are doing? Obviously not...
We are testing first beta firmware with Netflix 5.1 feature. The aim is to collect more cases to evaluate. For me 5.1 from Netflix works fine. No problems. Also at Dune Ultra 4K. But you shall check it at preinstalled version of the app, do not try Netflix app from Google Play etc. And if you have issues with starting the app after firmware upgrade, factory reset of the player is recomended.
After factory reset some Google/Android services are not enabled in the player. When you enter Google Play Store, Dune activates them but Some of them cause lot of backgroud activity inside the Android system. Thats why it is not enabled by default. Quality and perofmance of some applications can be affected by those background tasks.
So all your observations have value for Dune, help to improve and release fixes for next (official?) versions.
Please share your observations with Dune, send email to their support, describe your configuration, how you connect the player to your AV stuff etc.
So yes, Dune developers know what they are doing. They release new feature in beta firmware, to allow us to test it widely, and to gather feedback to improve product quality via next versions.
So also, if you have problems with some UHD BD menu support for some images - Dune will be thankfull for details.
-Caesar- likes this.
DuneHD Ultra4K, Pro4K, Neo4k, Duo4K, Solo4K, Base3D, TV-102w, QNAP/Synology, Fibaro, Sonos, iEast
kadqs is offline
post #5434 of 6471 Old 04-30-2019, 06:23 AM
Quoted: 87 Post(s)
Liked: 9
So all your observations have value for Dune, helps to improve and release fixes for next (official?) versions.
Thanks for the info.
I did a factory reset and installed the latest Netflix from the Google Play (as it was recommended by another forum member).
Next I will do a factory reset again and use the preinstalled Netflix and see if that fixes it.
Cheers
Caesar
-Caesar- is offline
post #5435 of 6471 Old 04-30-2019, 08:52 AM
polypenko's Avatar
Did a factory reset, but on my Done 4k the Netflix app still does not work.
When I start a Film it runs for approx 10 / 15 seconds than the app stops and you get the pop up screen
app stopped.
My Dune is connected to my Network via an utp cable.
post #5436 of 6471 Old 04-30-2019, 09:11 AM
kadqs's Avatar
Quoted: 404 Post(s)
Liked: 329
app stopped.
Dune is checking new version of Netflix app. It shall fix problems in some configuration. But it is still test version, a candidate to replace the one provided with firmware.
Please check it and confirm it you see any progress. You have to install it manually. Just download, place on USB memory, connect to Dune and execute it by pressing ENTER on the file.
http://files.dune-hd.com/tmp2/netfli...2019_04_30.apk
You can also contact Dune support via [email protected], describe them the case, they will instruct you what additional data do the need. Probably they will ask you to restart the player, start Netflix, "generate" the problem and create special Service File and send them to check. They will also ask you if it happens always, for each movie etc, so you can describe that in advance.
tbass2k, -Caesar- and dwys1960 like this.
kadqs is offline
post #5437 of 6471 Old 04-30-2019, 10:39 AM
polypenko's Avatar
Tks for the Software just installed it on the Dune.
First removed the old app. than did a new install restarted the Dune, normal 5.1 films work
however 4k Ultra content does not start. (eventhough I have a 4K subscription)
Will keep testing.
post #5438 of 6471 Old 04-30-2019, 04:48 PM
blenky's Avatar
Quoted: 1006 Post(s)
Liked: 931
Speaking for myself I wish that the Dune developers were concentrating on
- frame rate
- HDR metadata
- forced subs in MKV files
- audio sync options
- MaxCLL and MaxFALL (is this same as HDR metadata?)
- improved MyCollection
and NOT what will always be an imperfect implementation of Netflix. I'm sure the majority of us on here bought the Dune HD Pro 4K with little or no interest in its implementation. There are much better ways of getting Netflix.
jowicrt, a5ian300zx and avsforum2 like this.
Samsung UE55KS8000 | Pioneer SC-LX701 | Dune HD Pro 4K | Zidoo Z9S | Apple TV 4K | Nvidia Shield TV (2019) | Fire TV Stick 4K | Samsung UBD-K8500 UHD Player
blenky is offline
post #5439 of 6471 Old 05-01-2019, 02:02 AM
jowicrt's Avatar
Quoted: 704 Post(s)
Liked: 209
Yep. Dune was always a bit behind in user interface and (useless) apps, but made up for it by being technically close to perfect. Image quality could have been better compared to hi-end players though.
a5ian300zx likes this.
Arcam AVR850 • Pioneer KURO KRP-600M • KEF Reference Model 4/2/200c •• Velodyne DD15 •• HDI Dune 4K Solo • Logitech Squeezebox Radio/Duet • Wyrewizard Dreamcaster & Spellbinder (by Nordost) • JVC D-ILA-X7500 • HDFury Vertex
jowicrt is offline
post #5440 of 6471 Old 05-01-2019, 02:39 AM
a5ian300zx's Avatar
Quoted: 642 Post(s)
Liked: 217
- frame rate
- HDR metadata
- forced subs
Totally agree once they fix those issue only then I will consider buying another dune and even will go for the higher end model.
Netflix etc is all secondary after the core issues are fixed.
Sent from my Samsung Note 9 using Tapatalk
TV: Sony 65" A1E OLED Surround: Sennheiser AMBEO + SVS SB12-NSD Stereo: Yamaha AS500 + Kef Q300 Processor: DVDO Iscan Mini + Darbee 5000S Players: Oppo 203 (Coris) / Nvidia Shield TV Pro 2019 / VU+ Ultimo 4K NAS: Qnap TVS-871 Pro i7 10GBE
a5ian300zx is offline
post #5441 of 6471 Old 05-01-2019, 07:49 AM
Quoted: 692 Post(s)
Liked: 167
Forced subs works for HD/UHD BDMV folders.
Whirlpool0548 is offline
post #5442 of 6471 Old 05-01-2019, 08:04 AM
a5ian300zx's Avatar
Quoted: 642 Post(s)
Liked: 217
That's one part only. They do not work with mkv files.
So that does not meet everyone's needs.
post #5443 of 6471 Old 05-01-2019, 11:24 AM
Quoted: 692 Post(s)
Liked: 167
Then, be specific forced subs is not working for mkv.
post #5444 of 6471 Old 05-01-2019, 11:45 AM
a5ian300zx's Avatar
Quoted: 642 Post(s)
Liked: 217
If you read the post you will notice I did not post it, I just agreed with the orignal poster as I know what he meant
post #5445 of 6471 Old 05-01-2019, 12:03 PM
blenky's Avatar
Liked: 931
That was me - original post corrected to reflect MKV.
blenky is offline
post #5446 of 6471 Old 05-01-2019, 12:20 PM
halfelite's Avatar
Quoted: 650 Post(s)
Liked: 332
Finally got around to testing the new menu support. Dune did an excellent job on the menu implementation of the movies I tried they all worked. For now this has postponed picking up the oppo for menu support.
halfelite is offline
post #5447 of 6471 Old 05-01-2019, 04:59 PM
007james's Avatar
Quoted: 53 Post(s)
Liked: 46
I have had that happened twice to me
007james is offline
post #5448 of 6471 Old 05-01-2019, 05:07 PM
007james's Avatar
Quoted: 53 Post(s)
Liked: 46
Originally Posted by mike_carton View Post
This’d be where you can pick a chapter to play through Dune UI? This is a confirmed missing feature?! Even old players usually have this. Sometimes an ISO might not have chapter information.
Seems to be a missing feature, I just want to "skip" to the next chapter and the same .iso's , the chapter skip works fine on the D1
007james is offline
post #5449 of 6471 Old 05-01-2019, 05:26 PM
007james's Avatar
Quoted: 53 Post(s)
Liked: 46
SACD.iso/DSD/DSF Files
Has anyone been able to play any of these type of files or iso? If so, do the files need to be local (USB) or can they be played from a NAS. Also, what app on the dune HD pro worked for you? Any help/suggestions would be greatly appreciated. Thanks
007james is offline
post #5450 of 6471 Old 05-02-2019, 01:29 AM
Quoted: 692 Post(s)
Liked: 167
Chapter skip from the remote works if the movie is launched from BDMV folders via the blu-Ray menu.
FF/REW isn’t working smoothly. Also causes periodic freezes after use.
post #5451 of 6471 Old 05-02-2019, 02:22 AM
AYanguas's Avatar
Quoted: 74 Post(s)
Liked: 36
+1
It happened to me sometimes always with HDMI trough Dune ==> Denon 8500 ==> PJ Optoma UHZ65. The Dune PRO displays Load... and freeze there.
When powering down the receiver Denon, although HDMI is going through the Optoma directly, the Dune then starts properly always.
I wonder if it is some kind of HDMI handshake problem at the final stages of the startup.
AVR: Denon AVC X8500H (Atmos 7.1.6, DTS:X, Auro-3D 13.1)
DPY: Optoma UHZ65 / Lumene Majestic Premium 270C / TV LG C9
Ply:: Dune HD Solo 4K / Dune HD PRO 4K / Oppo 203 / Fire Stick 4K
SPs: Pulsar Audio Ambiente 7 /Ambiente Center /Master M5 /Access AC / B&W CCM 683
Oth: HDFury Vertex2
AYanguas is offline
post #5452 of 6471 Old 05-02-2019, 02:59 AM
blenky's Avatar
Liked: 931
I agree. Dunes bluray full menu support for standard and UHD is a fantastic job. Not found one movie that it can't handle. Just got hold of UHD version of Black Hawk Down. This has two versions of the movie seamlessly branched. The Dune handles it flawlessly.
a5ian300zx and Whirlpool0548 like this.
blenky is offline
post #5453 of 6471 Old 05-02-2019, 04:06 AM
alex5723's Avatar
Quoted: 98 Post(s)
Liked: 33
Netflix users : Bringing Studio Quality Sound to Netflix
Starting today, when you watch Netflix on your TV, it should sound even better.
..Today we’re excited to announce a new feature, high-quality audio, which takes our sound quality to another level. We gave it this straightforward name because it fits: high-quality audio delivers audio that sounds closer to what creators hear in the studio, so every little detail is captured for a richer, more intense experience. Additionally, if you have bandwidth or device limitations, we’ve made the feature adaptive so that we will deliver the best possible audio to match your capabilities. This is similar to what we already do for video...
https://media.netflix.com/en/company...und-to-netflix
alex5723 is offline
post #5454 of 6471 Old 05-02-2019, 01:16 PM
robnix's Avatar
Quoted: 1021 Post(s)
Liked: 766
Now that they have that sorted out, what I'd really like to see them do is stop development on My Collection, and just release a version of Kodi with their player as the default player. Someone smarter tell me how much work this really is.
Looky here!
robnix is offline
post #5455 of 6471 Old 05-02-2019, 01:51 PM
blenky's Avatar
Liked: 931
A great idea. Zidoo have done this and it works really well - however I prefer Zidoo's own movie wall!
blenky is offline
post #5456 of 6471 Old 05-02-2019, 01:57 PM
halfelite's Avatar
Quoted: 650 Post(s)
Liked: 332
The work is in the continued updates. You basically take the KODI code and fork it rip out the player in kodi and code around the Realtek player. Every time there is a major code update you almost have to start over. The answer to this is SoC makers stop using proprietary methods to communicate with the SoC. If they all used default android api method any player could work
robnix likes this.
post #5457 of 6471 Old 05-02-2019, 03:16 PM
Quoted: 692 Post(s)
Liked: 167
It’s a shame Zidoo didn’t also put in the effort to create solid playback of HD/UHD blu-Ray menu folders, sort out seamless branching and forced subs.
post #5458 of 6471 Old 05-02-2019, 06:16 PM
jconjason's Avatar
Quoted: 1377 Post(s)
Liked: 2299
Easy answer is to to use yaDIS. I did use Kodi on my Shield and while it is nice, it does take a while to customize it to your liking. For me, it's pretty easy to set up my yaDIS movie wall how I like it.
I do understand wanting something that's "built in" to the player.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch 5.1.2
HSU VTF-3 MK5 HP
jconjason is offline
post #5459 of 6471 Old 05-02-2019, 06:32 PM
robnix's Avatar
Liked: 766
Yadis is too static. I like the interactive features that you find in kodi skins and in My Collection like being able to browse directors and actors through the interface.
tbass2k and Nitemage like this.
Looky here!
robnix is offline
post #5460 of 6471 Old 05-03-2019, 06:52 AM
vadergr's Avatar
Quoted: 141 Post(s)
Liked: 55
Anyone checked with vertex or lumagen if 23.976 is correct in all cases (bd engine, mkv's, 4K) ?
Are the HDR metadata shown properly after the latest major fw?
vadergr is offline
