Dune HD Pro 4K (Ultra) Thread - Page 193 - AVS Forum | Home Theater Discussions And Reviews
 1753Likes
post #5761 of 6136 Old 06-22-2019, 10:37 PM
alex5723's Avatar
Quoted: 91 Post(s)
Originally Posted by Tsunamijhoe View Post
Yes Alex.. I use that function for bonus material,as there is no other way to play it,and it works really well.. I just move all extra material to a folder called same as movie,and add a (Extra),then yadis finds it,makes a playlist,i add the extra matarial using the genre in yadis,and then when i play it on the dune,it will just play 1 file after the other. A bit of a circumvention as yadis doesnt support bonus features like Yamj did..
I think you might have to name the files with part 1,part 2 and so on or yadis might play them in wrong order
alex5723 is offline
post #5762 of 6136 Old 06-23-2019, 10:54 PM
Bartimaus's Avatar
Quoted: 33 Post(s)
Hi,
my [email protected] is controlled by https://pi-hole.net/
This works like a charm. Maybe you will give it a try. Very simple to install. Works smoothly in the Background.
LivingRoom: Dune HD Solo Lite,Yamaha RX-V773,SamsungUE65KS8090,
Basement/HomeCinema: JVC-X5000, 3m 21:9 Framescreen + 2,8m 16:9 Tensionscreen, Denon X1400,Dune HD 4kpro ,Kathrein-UFS910-BPanther-Neutrino, QNAP TS653A 4x8TB+2x3TB
Bartimaus is offline
post #5763 of 6136 Old 06-24-2019, 12:18 PM
Tsunamijhoe's Avatar
Quoted: 233 Post(s)
Liked: 65
Anyone noticed/experience random chapter/scene menu pop up during play on certain blurays?<br />
I have experienced on a couple of blurays the pop up menu will show by itself whenever a chapter is reached. If you rewind it wont repeat.<br />
It has happened on 3 different blurays of which i only remembered 1 title. Live free or die hard from the 2017 collectors box https://m.blu-ray.com/movies/Live-Free-or-Die-Hard-Blu-ray/202885/ the menu pop up 3 times during play.
Tsunamijhoe is offline
post #5764 of 6136 Old 06-24-2019, 01:25 PM
tbass2k's Avatar
Quoted: 319 Post(s)
Liked: 306
It has happened on 3 different blurays of which i only remembered 1 title. Live free or die hard from the 2017 collectors box https://m.blu-ray.com/movies/Live-Fr...lu-ray/202885/ the menu pop up 3 times during play.
Yes, I've seen it too.....my most irritating bug with the Pro 4k right now is sound while fast forwarding or rewinding, completely unacceptable.
Sent from my SM-N960U using Tapatalk
tbass2k is online now
post #5765 of 6136 Old 06-24-2019, 02:05 PM
Quoted: 233 Post(s)
Liked: 65
OK,glad i am not the only one..
I sent a mail to support so they can add it to the long list of fixes that needs to be done if they dont know about it already..
I find the bluray function besides a working menu and playback to be really lacking.. The forward/rewind doesnt really work,it skips more than a real rewind/forward and yes it does with sound pops,and there is no time search which would be a real help why it works on everything else except in full menu mode i dont know,and i would also like to see a frame by frame function where you press pause,and press pause again will go 1 frame forward or something like that.
I would also like the audio information to be shown when pressing info button,not only video information like it is now. Also the info button is really limited in bluray menu mode.
But i would settle for better controls like a proper time search and proper forward/rewind.
tbass2k likes this.
Marantz 7704, Emotiva XPA-5,Emotiva XPA-2,Densen B-340+,B&W 683,B&W HTM61,B&W DS3,2XSVS PB-2000,4XMonitor Audio BX1 (Atmos),Sony VPL-HW65ES,Stewart 123" CIMA Neve Motorized, Dune HD Pro 4K, Mede8er x600 3D,Panasonic BD60,PS4
post #5766 of 6136 Old 06-26-2019, 04:16 AM
jowicrt's Avatar
Quoted: 704 Post(s)
Liked: 208
Originally Posted by Bartimaus View Post
Hi,
I'm using pihole as well, runs as a docker on my UNRAID server... but how do you set up pihole to prevent an internal device like the dune, from sending stuff out and showing these ads?
Arcam AVR850 • Pioneer KURO KRP-600M • KEF Reference Model 4/2/200c •• Velodyne DD15 •• HDI Dune 4K Solo • Logitech Squeezebox Radio/Duet • Wyrewizard Dreamcaster & Spellbinder (by Nordost) • JVC D-ILA-X7500 • HDFury Vertex
jowicrt is offline
post #5767 of 6136 Old 06-26-2019, 06:56 AM
markswift2003's Avatar
Quoted: 746 Post(s)
Liked: 507
I use it too, but the Dune seems to call by IP address (213.239.217.79) rather than relying on DNS so that would bypass the Pi-Hole.
I found the easiest way is to block the Dune outgoing traffic on your firewall, assuming you don't need it to access the internet.
Zidoo Z9S | Dune Pro 4K | HDFury Vertex | 32TB mirrored storage
Denon AVC-X8500H | JVC DLA X7000 | Screen Research 9ft multi aspect ClearPix 2 ISF screen
3 x PMC IB2S fronts | 4 x PMC Wafer 2 rears | 4 x PMC Wafer 1 ceiling | 2 x M&K SS550 THX height | Rel Stentor III
A pair of slippers, a comfy sofa and a glass of 16 year old single malt
markswift2003 is offline
post #5768 of 6136 Old 06-26-2019, 08:01 PM
lithiumus's Avatar
Quoted: 78 Post(s)
Liked: 35
Even if they enabled the built in player function where the up and down arrow keys would skip by the minute and left right by 10 seconds would be usable.
lithiumus is online now
post #5769 of 6136 Old 06-27-2019, 06:30 AM
vadergr's Avatar
Quoted: 138 Post(s)
Liked: 53
Agree with you.
Never used FF, RW on a Dune. Skipping with the arrow keys is way better(and faster).
vadergr is offline
post #5770 of 6136 Old 06-27-2019, 08:10 AM
lithiumus's Avatar
Quoted: 78 Post(s)
Liked: 35
Originally Posted by vadergr View Post
Agree with you.
Yeah the issue is that once you use the menu navigation to play the video, the arrow keys for skipping forward are disabled.
post #5771 of 6136 Old 06-27-2019, 04:48 PM
Quoted: 233 Post(s)
Liked: 65
Will Dune add time search using the arrow key in menu mode? Or is this just how it is? I cant recall if the search using arrow keys worked on my D1.
post #5772 of 6136 Old 06-27-2019, 06:22 PM
lithiumus's Avatar
Quoted: 78 Post(s)
Liked: 35
Arrow key time search works on the D1, 4k Solo and 4k Pro but only if you watch files or main movie mode. As soon as you watch via navigation / menu, arrow key time search is disabled. Im wishing they enabled it for navigation / menu mode...
post #5773 of 6136 Old 06-27-2019, 07:05 PM
Quoted: 233 Post(s)
Liked: 65
Yeah i know it doesnt work in menu mode,doesnt make sense though they would disable it on purpose in menu mode,must be a limitation in their player for full menu bluray.
post #5774 of 6136 Old 06-28-2019, 11:26 PM
Quoted: 147 Post(s)
Liked: 38
576i Playback
Hi all
Does anyone know how to enable 576i playback on the dune player
I got the latest beta firmware, set up all the match frame rate options but I get 576p from 576i files
In addition
1280x720 24fps files playback at 60fps not 24
4:3 files play back as squeezed video but in a 4:3 frame
If I set the dune to 576i max that gives 576i but hd outputs at 480
Is it not possible for the dune to just output the file as is? like the oppo 203 does on source direct
Thanks for any help
333444 is offline
post #5775 of 6136 Old 06-29-2019, 01:36 PM
Quoted: 123 Post(s)
Liked: 30
Originally Posted by 333444 View Post
Hi all
In addition
Thanks for any help
+1 Same Request, Same Hope
stefanop is offline
post #5776 of 6136 Old 06-29-2019, 01:44 PM
elove's Avatar
Quoted: 48 Post(s)
Hi
My dune is automatically playing the next video. Does anyone know how to disable auto play. I want it to stop and let me select which video I want to play. In settings, I checked the playback settings, but i didn't see where to disable auto play.
elove is offline
post #5777 of 6136 Old 06-30-2019, 12:23 AM
thxjay's Avatar
Quoted: 53 Post(s)
Liked: 38
Originally Posted by elove View Post
Hi
Can't remember exactly where it is (probably playback section) but there is an option for the enter button. You can choose to either play single file or create playlist.
thxjay is offline
post #5778 of 6136 Old 06-30-2019, 03:10 AM
Dannycj80's Avatar
Just ordered the Dune HD Pro 4K. I am wondering how it handles playback of 4K UHD HDR remuxs (uncompressed)? And also what is the max size of internal and external HDD the player reads?
Dannycj80 is offline
post #5779 of 6136 Old 06-30-2019, 04:33 AM
blenky's Avatar
Quoted: 968 Post(s)
Liked: 877
Can answer first question - very well indeed!
Samsung UE55KS8000 | Pioneer SC-LX701 | Dune HD Pro 4K | Zidoo Z9S | Apple TV 4K | Samsung UBD-K8500 UHD Player
blenky is offline
post #5780 of 6136 Old 06-30-2019, 04:39 AM
Dannycj80's Avatar
Thanks Blinky.
post #5781 of 6136 Old 06-30-2019, 06:20 AM
GPBURNS's Avatar
Quoted: 428 Post(s)
Liked: 804
Don't believe limit on size - I have gone as high as 10TBs sata and usb 3 - have had no issues on hundreds of 4k HDR remixes/ISO's
Hulkster84 likes this.
15400 Watts of Atmos Seaton Power -Quad SubMersived - JVC N7
GPBURNS is offline
post #5782 of 6136 Old 06-30-2019, 09:49 AM
Quoted: 147 Post(s)
Liked: 38
I will second that, if only it could do 576i or 480i and the 4:3 aspect ratio worked as it should it would be quite a good player. I wish someone would tell me why all the media players are so full of upscaling. cant see the point my self
333444 is offline
post #5783 of 6136 Old 07-01-2019, 03:21 AM
alex5723's Avatar
Quoted: 91 Post(s)
I can't see the point of buying/using a 4K streamer for 480i/576i.
alex5723 is offline
post #5784 of 6136 Old 07-01-2019, 06:47 AM - Thread Starter
Sledgehamma's Avatar
Quoted: 658 Post(s)
Liked: 360
Because not everything is available in 720p or higher.
Sledgehamma is online now
post #5785 of 6136 Old 07-01-2019, 09:35 AM
Quoted: 147 Post(s)
Liked: 38
Well if someone has a collection of files in a range of formats from 480i up to 4k HDR they may want a simple no frills player box that can do what I would think to be a simple job
Pass whatever format the file is in to the Tv thus allowing the Tv to upscale not the box. In this day and age that seems simple enough but you try finding such a player for sale
Players have apps coming out of there ears can do almost anything even control room lighting but no frills playback no chance. Over on the Vero support forum they have even said picture quality for them is second place to how many apps they can get in the player. saying users want apps over best picture !!
333444 is offline
post #5786 of 6136 Old 07-01-2019, 10:54 AM
alex5723's Avatar
Quoted: 91 Post(s)
Quick Setting of Video Output Mode
The MODE button of the RC allows quick setting of video output mode without entering the setup menu. This type of video output configuration may be required in case after connecting your player to a TV/ monitor/projector you see no picture on the screen.
After pressing the MODE button you will enter the quick video setting mode. In this mode, pressing one of the digit buttons 1, 2, 3, 4, 5 switches to one of the following video output modes respectively:
Composite/Component, PAL
Composite/Component, NTSC
Digital A/V output, 480i, 60 Hz
Digital A/V output, 720p, 60 Hz
Digital A/V output, 1080i, 60 Hz
http://dune-hd.com/eng/support/onlin...l/system_setup
alex5723 is offline
post #5787 of 6136 Old 07-01-2019, 12:51 PM
Quoted: 147 Post(s)
Liked: 38
Thanks for that info, but what about 576i 50hz and why can the player not change the output to match the file without messing with buttons, oppo can manage it
333444 is offline
post #5788 of 6136 Old 07-02-2019, 08:48 AM
alex5723's Avatar
Quoted: 91 Post(s)
There maybe a passtrough option. I remember there was in my latest Dune HD Base 3D.
alex5723 is offline
post #5789 of 6136 Old 07-02-2019, 11:46 PM
Quoted: 147 Post(s)
Liked: 38
Hi Yes there is a passthorugh option for both frame rate and resolution - But i files are still output a p files if the options are enabled
333444 is offline
post #5790 of 6136 Old 07-03-2019, 09:01 AM
Liked: 0
Hi anyone have Netflix problems on the Dune HD pro 4k? For 3 days now Netflix always crashes and exits about 30 seconds after starting playing anything. Any ideas what can cause it? (other players on the same connection have no problems with Netflix) I am using the latest (beta) firmware, but it started happening with while the previous one was installed.(but before this it worked with that firmware for a month or two)
Bleddry is offline
