Dune HD Pro 4K (Ultra) Thread - Page 198 - AVS Forum | Home Theater Discussions And Reviews
 1831Likes
post #5911 of 6553 Old 08-22-2019, 06:16 AM
GPBURNS's Avatar
Quoted: 514 Post(s)
Liked: 1038
Originally Posted by Manni01 View Post
Thanks for the confirmation.
I know that nothing matches my HTPC, but I still want to leave it behind. I’m fed up with the OS/driver instability, even with my old drivers (398.11). The fact that nVidia stopped supporting 3D annoys me even further as it makes upgrading my GPU impossible.I just want a single source that works predictably with all my content. I’ve got that with the m**** but the native interface (or the Oppo app) is not usable as a front end. Mymovies makes it very nice on the iPad, but I have some instability with network commands and forces me to keep a server on to process the bridge commands.
So if the Dune ever fixes the incorrect refresh rate with BD Folders, it becomes a serious candidate, because it’s the only player that is natively supported by mymovies (and its ipad app). Unless I only use mymovies as a CM and use it with a Zapitti and the zapitti app, but as the zapitti has the same chipset, I’m not sure it doesn’t have the same issues as the Dune.
I always here great thing about the madvr tone mapping but connecting pc to HT is not going to happen for many reasons- currently quite happy with custom gamma curves on JVC N7 but was interested to see madvr or equivalent in action with dynamic TM-is it possible to rip a UHD an then run it thru Madvr and save it as and MKV with the tone mapping embedded to be used with streamer of choice?- That way I get the dynamic tone mapping and continue to use Dune which has been flawless for me- Thanks
15400 Watts of Atmos Seaton Power -Quad SubMersived - JVC N7
GPBURNS is online now
post #5912 of 6553 Old 08-22-2019, 06:34 AM
mrlittlejeans's Avatar
Quoted: 153 Post(s)
Liked: 250
Originally Posted by markswift2003 View Post
The Dune most certainly has well documented frame rate/colour decoding issues at 4K but not at 2K.
It sounds like you may have a setting or two off - these are my settings for 2K and these play out frame perfect:
Setup/Video
Maximum video mode: 1080p 23.976Hz *
Auto framerate: All (24/50/60Hz) **
Auto Resolution: Enabled **
HDMI 3D Support: No
Setup/Video/Addition settings
Maximum HDMI color depth: 12 bit
Preferred HDMI color depth: Maximum
SDR/HDR conversion: Auto
Chroma ... 4K50/60 8-bit: 4:2:0
Chroma ... 4K50/60 12-bit: 4:2:0
Chroma ... 4K24..30 12-bit: 4:2:2 ***
Chroma ... non-4K 12-bit: 4:2:2
Analog A/V output: enabled
* set this to 4K 2160p 23.976Hz if you also want to play 4K
** These settings are very important!
*** Be aware that although frame rate will be correct in this mode, colour
decoding occurs internally at 8-bit with no dithering, so chroma banding can be
present dependent on encoding.
(attached pdf for reference - updated: removed old data and spurious 3D stuff)
Thanks Mark. I think the only thing I had different was the maximum video mode which I had at 2160p 60hz. Will change that to 24p and see if it makes a difference.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #5913 of 6553 Old 08-22-2019, 08:15 AM
markswift2003's Avatar
Quoted: 979 Post(s)
Liked: 683
That actually shouldn't make a difference as long as Auto framerate is set correctly, but since most material is going to be 23.976fps, it's best to choose that anyway - reduces resyncs.
Note that there is a difference between 24Hz and 23.976Hz and 23.976Hz is the one you want...
Zidoo Z9S | Nvidia Shield Pro | HDFury Vertex² | 32TB mirrored storage
Denon AVC-X8500H | JVC DLA X7000 | Screen Research 9ft multi aspect ClearPix 2 ISF screen
3 x PMC IB2S fronts | 4 x PMC Wafer 2 rears | 4 x PMC Wafer 1 ceiling | 2 x M&K SS550 THX height | Rel Stentor III
A pair of slippers, a comfy sofa and a glass of 16 year old single malt
markswift2003 is offline
post #5914 of 6553 Old 08-22-2019, 09:05 AM
Quoted: 153 Post(s)
Liked: 250
10-4. I just didn't want to type out 23.976.
markswift2003 likes this.
post #5915 of 6553 Old 08-22-2019, 04:15 PM
007james's Avatar
Quoted: 53 Post(s)
Liked: 46
I think we are overdue for a firmware update, i'd like to see chapter skip fixed for dvd iso's
tbass2k, lithiumus and DaveH1 like this.
007james is offline
post #5916 of 6553 Old 08-22-2019, 05:25 PM
lithiumus's Avatar
Quoted: 86 Post(s)
Liked: 38
Definitely overdue... framerate fix would do it for me. Add FF and RR search fix and im happy
lithiumus is offline
post #5917 of 6553 Old 08-23-2019, 12:25 AM
Quoted: 979 Post(s)
Liked: 683
Yep, that's all I need too. Nothing else.
post #5918 of 6553 Old 08-24-2019, 08:53 AM
Derek Potrykus's Avatar
Liked: 2
Hello everyone,
I have been a Dune Duo user for many years and have just upgraded to the Dune Pro 4K a few months ago.
I absolutely love it but am having a headache of a time getting my Yadis working on it (I used Yadis on my Duo for many years and have a large custom library).
The specific problem I am having is Yadis on the Dune finding the file to play once I click it in the fanart page.
I can export Yadis data from my PC to the Dune. The artwork/interface is properly displayed on the Dune interface. But when I click to play it cannot find the file.
I know that the problem must lay with the folder settings in Yadis. My old Dune settings were set up like this and always worked:
\\DISKSTATION\Movies1
nfs://192.168.1.100:/volume1/Movies1
With the new Dune it will not work. I also tried replacing nfs with smb but no go. Now I know that the only way for the Dune Pro 4K to see my network movies is by adding network drives first in the Dune by bringing up the pop up menu and selecting add network folder. I have that done and can watch any movie on my network without issues. But what do I tell Yadis in the folder settings to have it locate the location.
Very frustrated but hoping you all can help.
Cheers.
Derek Potrykus is offline
post #5919 of 6553 Old 08-24-2019, 09:08 AM
Liked: 2
Old setting in Yadis:
post #5920 of 6553 Old 08-24-2019, 09:15 AM
Liked: 2
Current Dune interface.
In the photo from the new Dune, the name box from the edit network folder is whited out by the camera for some reason but it should say Movies1.
ID:	2606542   Click image for larger version
post #5921 of 6553 Old 08-24-2019, 11:01 AM
Quoted: 979 Post(s)
Liked: 683
Originally Posted by Derek Potrykus View Post
Hello everyone,
Cheers.
Try this:
Folder: \\DISKSTATION\Movies1
Dune Path: smb://192.168.1.100/Movies1
etc...
There's no real need to use nfs these days, and it's always a bit of a headache.
(I assume Movies1 2 & 3 are shares and not folders?)
post #5922 of 6553 Old 08-24-2019, 11:19 AM
Liked: 2
Movies1, Movies2, Movies3, Movies4 are folders. The shares are Volume1, Volume2, Volume3, Volume4. I think that is what your asking.
I included some screens from my Synology that may help you.
In regards to: Folder ( \\DISKSTATION\Movies1 - Dune Path: smb://192.168.1.100/Movies1 ), I have done this and many variations of it but the Dune Yadis interface will not open any file.
ID:	2606620   Click image for larger version
ID:	2606622   Click image for larger version
post #5923 of 6553 Old 08-24-2019, 11:52 AM
Quoted: 979 Post(s)
Liked: 683
Ok, so if Volume 1 - 4 are shares, try:
Folder: \\DISKSTATION\Volume 1\Movies1
Dune Path: smb://192.168.1.100/Volume 1/Movies1
Capitalisation and spaces are important...
post #5924 of 6553 Old 08-24-2019, 05:48 PM
Liked: 2
Thanks Mark.
I will try the settings and will post regardless of whether they work or not (I hate when people get good results then you never hear from them if it worked or not).
post #5925 of 6553 Old 08-25-2019, 02:26 AM
Quoted: 979 Post(s)
Liked: 683
Thanks Mark.
It's just a case of getting the path right - what you don't want to do is delete the existing ones and start again because that'll delete the library (I think!) but if the above doesn't work, another way is to go to setup/folders and <add> another location - then click the browse button and locate say Movies1 on the network and this will automatically populate the "Folder" and "Dune path" boxes with the correct smb path.
Don't save that, but just copy and paste those paths out to say a text document and then copy/paste those back into the original entry... Then adapt for Movies2 etc...
post #5926 of 6553 Old 08-27-2019, 09:16 AM
Liked: 2
So far no joy.
I tried your first answer and then tried just clicking the folder icon and navigating to each movie folder. Yadis will scrape the movies, I can export the results to the export folder, and the dune can read the Yadis folder and show all backdrops for each film. But when I click 'enter' on the backdrop screen to play the movie it will tell me it cannot locate the file. But I can play any movie from the Dune if I navigate to Sources/Movies1...etc.
I am now wondering if Yadis needs the path not to the shares on the NAS but to the path Dune uses to access my shares.
Any thoughts? I included screens of how I navigate to my shares on Dune.
ID:	2607770   Click image for larger version
ID:	2607772   Click image for larger version
ID:	2607774   Click image for larger version
ID:	2607776   Click image for larger version
post #5927 of 6553 Old 08-27-2019, 09:54 AM
Liked: 2
Try this:
etc...
It worked!!!
So I went back and began variations of paths (process of elimination) and you were correct except instead of using the ip address of the NAS I used its name. It worked immediately.
I want to thank you for your help. The high-end media players are a pain in the ass when it comes to setup but when you have them set...well worth the money and time....sometimes.
Cheers
post #5928 of 6553 Old 08-28-2019, 01:27 AM
Quoted: 979 Post(s)
Liked: 683
It worked!!!
Cheers
Fantastic! Glad you got it sorted.
post #5929 of 6553 Old 08-30-2019, 08:41 AM
bfrqrv's Avatar
Liked: 0
Hi, I have experience with many mediaplayers for decades and I am adicted to the disc feeling. That is a big problem with UHD BD-J because not many players support those. I am now trying the Dune HD PRO 4k and the UHD files do not open with the original BD-J menu, but they do play. Bluray is opening with the choise for lite and original, that's fine.
I thought I rad somewhere that this player was supporting UHD menu, but did I interperet that wrong?
bfrqrv is offline
post #5930 of 6553 Old 08-30-2019, 04:02 PM
Quoted: 712 Post(s)
Liked: 171
Dune Pro 4K opens 4K movies with the UHD menu for all the 4k movies I’ve tried using BDMV folders or ISO.
What do you get when you use the UHD menu ?
Whirlpool0548 is offline
post #5931 of 6553 Old 08-30-2019, 07:41 PM
tbass2k's Avatar
Quoted: 342 Post(s)
Liked: 382
You probably don't have beta firmware notifications enabled in the settings. Enable this and then make sure you update to the latest beta.
Sent from my SM-N975U using Tapatalk
tbass2k is online now
post #5932 of 6553 Old 08-31-2019, 06:54 AM
bfrqrv's Avatar
Liked: 0
Correct! How in earth could I not activate the beta's. Thanks!
bfrqrv is offline
post #5933 of 6553 Old 09-03-2019, 02:36 PM
Liked: 0
Hello all, I recently bought the Dune HD PRO 4k... watching Netflix and streaming movies from my computer. The past 1 week everything was working fine, till today when the Netflix was unable to load movies. At first when loading a movie, it only have sounds but no pictures. then after restart, the movie couldn't load at all after reaching 20% in Netflix. Ive tried uninstall, reboot and reinstalling Netflix but now when I open the Netflix app, the thing just wouldn't respond. Lastly I go to the android settings and reset everything back to the beginning where we need to setup the hardware. Problem is still exist now even I have done all those above and it seems non of the android software are working at all.
I have upgraded the firmware to the beta 190601_0246_12 but still unable to load. There is no issue with my Netflix or my internet as my PC are able to login those n watch 4k without any issues. My internet speed is 500mb dl / 100mb ul . Hope any masters here can guide me what should I do next?
jackmin76 is offline
post #5934 of 6553 Old 09-05-2019, 04:06 AM
blenky's Avatar
Quoted: 1015 Post(s)
Liked: 936
To watch streaming apps such as Netflix and Amazon prime you need to look elsewhere as the Dune is hopeless for this. Its primary use is a media playback device for local media. I have this and a Zidoo and both are rubbish for Netflix. I use an ATV for streaming apps.
sprins and Seryl like this.
Samsung UE55KS8000 | Pioneer SC-LX701 | Dune HD Pro 4K | Zidoo Z9S | Apple TV 4K | Nvidia Shield TV (2019) | Fire TV Stick 4K | Samsung UBD-K8500 UHD Player
blenky is offline
post #5935 of 6553 Old 09-06-2019, 07:40 AM
kokokka's Avatar
Quoted: 34 Post(s)
Liked: 6
Unfortunately this is true. Netflix is stuttering, catastrophe. It is unfortunate that they cannot solve this simple problem! So i never use the Dune for the Netflix, rather i watch that on my QLED. The NF on the Samsung is great!
kokokka is offline
post #5936 of 6553 Old 09-07-2019, 07:58 AM
007james's Avatar
Quoted: 53 Post(s)
Liked: 46
Any Idea when the next firmware is due? Example: trying to play the dvd iso of Fleetwood Mac "Fleetwood Mac" and i could not select surround option at all at root menu or using at pop-up menu or the audio button, this player is a step down from the D1 which i may still switch back to
007james is offline
post #5937 of 6553 Old 09-07-2019, 10:52 AM
Quoted: 712 Post(s)
Liked: 171
For 4K UHD, too ?
post #5938 of 6553 Old 09-08-2019, 02:59 PM
007james's Avatar
Quoted: 53 Post(s)
Liked: 46
Originally Posted by Whirlpool0548 View Post
For 4K UHD, too ?
I have never used 4K UHD yet
007james is offline
post #5939 of 6553 Old 09-10-2019, 10:31 AM
GPBURNS's Avatar
Quoted: 514 Post(s)
Liked: 1038
Some great news for latest JVC projector owners - they are implementing firmware update for dynamic tone mapping -
and not dependent on (Max CLL/Max FALL) info -
" LONG BEACH, Calif, September 5, 2019 – Underscoring its commitment to offer the best possible home theater experience, JVC today announced a firmware update for its line of Native 4K D-ILA projectors that delivers a significant advancement in HDR performance. JVC will demonstrate this feature at the 2019 CEDIA Expo, September 12 - 14 in Denver at booth 2536.
This feature forward update adds JVC’s new Frame Adapt HDR function, which dynamically analyzes HDR10 picture level frame by frame and automatically adjusts the brightness & color to optimize HDR performance for each frame.
Because content brightness varies, a fixed setting cannot deliver optimum image quality. JVC’s new Frame Adapt HDR solves this by instantly analyzing the peak brightness of each frame or scene using a proprietary JVC algorithm, and adjusting dynamic range to provide the best possible HDR image. Frame Adapt HDR works with any HDR10 content, even content that does not contain brightness metadata (Max CLL/Max FALL).
MAIN FEATURES
1. Delivers images closer to reality
Dynamic range is adjusted in real time for optimal image projection. At the same time, saturation, hue, and brightness is analyzed and optimal corrections are made, which reduces color loss.
As a result, even within a single program, darker scenes have deeper blacks with enhanced color. Bright scenes have higher peak brightness without color loss while maintaining black level. All content is reproduced closer to what the human eye can see.
2. Compatible with all HDR10 content
Frame Adapt HDR adjustments are based on analysis of the input HDR10 signal. Therefore, it is effective on content with or without mastering information. As a result, all HDR10 content can be enjoyed with greater dynamic range and image quality than ever before.
3. Smooth gradation with 18-bit level gamma accuracy
The gamma processing accuracy, which in the past was based on 12-bit equivalent, has been improved to 18-bit and as a result gradation performance is dramatically improved. In any given scene, it reduces the banding effect in the bright portions and the crushing of dark portions. This provides accurate, smooth gradation along with higher average peak level brightness and increased color saturation, which has previously been a challenge with HDR content.
Other Improvements
* Support for 16x9 content when using a Panamorph Paladin DCR lens (adds Anamorphic D). It is now possible to leave a Paladin DCR lens in position and view both ultra-wide and 16x9 content correctly.
* Auto Calibration support for Spyder X sensor.
* Adds new presets to screen adjustment function.
The firmware will be available for download at no charge in October for the DLA-NX9, DLA-NX7 and DLA-NX5 as well as the DLA-RS3000, DLA-RS2000 and DLA-RS1000."
post #5940 of 6553 Old 09-10-2019, 11:00 AM
Quoted: 979 Post(s)
Liked: 683
MAIN FEATURES
Other Improvements
Awesome isn't it? Bet you can't wait to try it..
As I've said before I'm so close to pulling the trigger on an N7 but this now has me waiting to see how well DTM is implemented in comparison to MadVR Envy which should be unveiled this Thursday.. Exciting times!
