Dune HD Pro 4K (Ultra) Thread - Page 208 - AVS Forum | Home Theater Discussions And Reviews
 1780Likes
post #6211 of 6233 Old 11-27-2019, 10:00 PM
Quoted: 385 Post(s)
Liked: 248
Well then this player is off the list. I'm honestly stunned that this player suffers from frame stutters. Even the Zidoo fixed that. And it was said a long time ago that the DVD player was only temporary until they provide their own custom player software. Shame that DVD support is non-functional. I had high hopes for finally buying a dune but this player was a disappointment at launch and even now sounds unusable for my usage.
jerimiah is offline
post #6212 of 6233 Old 11-28-2019, 07:18 AM
kokokka's Avatar
Quoted: 29 Post(s)
Liked: 6
Have you used it? Have you tried? You just talking into the air! DVD? I don't understand! I would die if I had to watch DVD quality in a 4K TV. Because it's disaster. The frame stutters in turn are almost invisible! I use my 4K Pro more than one year, and this is a very good player! They will improve everything later, i'm sure.
Whirlpool0548 and Pretorian like this.
kokokka is offline
post #6213 of 6233 Old 11-28-2019, 09:26 AM
Bartimaus's Avatar
Quoted: 34 Post(s)
Originally Posted by markswift2003 View Post
And with a little bit of code sculduggery using DnSpy you can modify the exe too
Any chance to get a download-Link please ?
rofr likes this.
LivingRoom: Dune HD Solo Lite,Yamaha RX-V773,SamsungUE65KS8090,
Basement/HomeCinema: JVC-X5000, 3m 21:9 Framescreen + 2,8m 16:9 Tensionscreen, Denon X1400,Dune HD 4kpro ,Kathrein-UFS910-BPanther-Neutrino, QNAP TS653A 4x8TB+2x3TB
Bartimaus is offline
post #6214 of 6233 Old 11-29-2019, 11:13 AM
Liked: 0
+1
rofr is offline
post #6215 of 6233 Old 11-29-2019, 01:37 PM
robena's Avatar
Quoted: 197 Post(s)
Liked: 88
Agreed on the stutter, it's invisible for me.
Whirlpool0548 likes this.
Robert
robena is offline
post #6216 of 6233 Old 11-29-2019, 10:45 PM
Liked: 1
I don't realize any stutter either.
I'm playing mostly "MKV" files, and they're running as smooth as on my older Dunes with Sigma Chips.
hellhero is offline
post #6217 of 6233 Old 11-30-2019, 04:34 AM
Tsunamijhoe's Avatar
Quoted: 240 Post(s)
Liked: 67
Could you eleborate how you did that? Or share the modified yadis?
Thank you
Marantz 7704, Emotiva XPA-5,Emotiva XPA-2,Densen B-340+,B&W 683,B&W HTM61,B&W DS3,2XSVS PB-2000,4XMonitor Audio BX1 (Atmos),Sony VPL-HW65ES,Stewart 123" CIMA Neve Motorized, Dune HD Pro 4K, Mede8er x600 3D,Panasonic BD60,PS4
Tsunamijhoe is offline
post #6218 of 6233 Old 11-30-2019, 04:52 AM
markswift2003's Avatar
Quoted: 825 Post(s)
Liked: 567
Thank you
Using DnSpy I decompiled the executable and then simply changed descriptors for codecs I will never use for ones that I wanted - can't specifically remember which ones I changed as it was a while ago, but as an example, "Vorbis" changed for "Atmos" etc...
Same with video and resolutions.
Then allocated modified graphics in the skin to apply to those codecs.
Since it still uses an old version of MediaInfo it doesn't automatically apply them but it's just nice to select the correct codec etc from drop down boxes.
For the HDR logo, I just used the certification box and that only requires changing the certification entry in the language file to read "HDR" and again allocating graphics - certification is something that never worked for me and I'm not bothered about.
Zidoo Z9S | Dune Pro 4K | HDFury Vertex² | 32TB mirrored storage
Denon AVC-X8500H | JVC DLA X7000 | Screen Research 9ft multi aspect ClearPix 2 ISF screen
3 x PMC IB2S fronts | 4 x PMC Wafer 2 rears | 4 x PMC Wafer 1 ceiling | 2 x M&K SS550 THX height | Rel Stentor III
A pair of slippers, a comfy sofa and a glass of 16 year old single malt
markswift2003 is offline
post #6219 of 6233 Old 11-30-2019, 05:04 AM
Quoted: 240 Post(s)
Liked: 67
Using DnSpy I decompiled the executable and then simply changed descriptors for codecs I will never use for ones that I wanted - can't specifically remember which ones I changed as it was a while ago, but as an example, "Ogg" changed for "Atmos" etc...
I have no idea how to do that.. I tried opening the installed yadis.exe not the install program exe and tried searching for the descriptor,but found nothing like vorbis or divx or anything,also there is no decompile option only a debug as far as i can see.. I know how to modify the skins,but not the yadis exe.. I am also tired of having to remember which desciptor i assigned to atmos or dtsx and so on
post #6220 of 6233 Old 11-30-2019, 05:42 AM
Quoted: 825 Post(s)
Liked: 567
I'd love to share the modified exe, but it's not mine to share - yaDIS, although freeware, was never released open source so although I see no issue modifying for my own use, I can't release what does not belong to me.
post #6221 of 6233 Old 11-30-2019, 06:22 AM
Quoted: 240 Post(s)
Liked: 67
I see.. Any chance you could do a little tutorial then how to edit our own,if you have the time and inclination ofcourse? Do i open the install exe or the program exe in dnspy? Where are the descriptors located,and how do i modify and save the new wording? Is yadis c# or one of the other 2 languages it can edit?
Would one also be able to update the API for TMDB and TVDB if needed this way?
post #6222 of 6233 Old 11-30-2019, 06:25 AM
Quoted: 825 Post(s)
Liked: 567
As a pointer:
Install another instance of yaDIS to mess with (just in case).
Download and install dnSpy (https://github.com/0xd4d/dnSpy/releases)
Run it and open yadis.exe with it.
Goto "MainForm" in <yaDIS/yaDIS.exe/yaDIS>
Search for "Vorbis" in the code (ctrl F)
Right click in the code where you find "Vorbis" and chose "edit IL instructions"
Change "Vorbis" for "Atmos"
Hit "ok"
File "Save All" and confirm.
post #6223 of 6233 Old 11-30-2019, 06:26 AM
Quoted: 825 Post(s)
Liked: 567
Beat you to it
post #6224 of 6233 Old 11-30-2019, 07:06 AM
Quoted: 240 Post(s)
Liked: 67
As a pointer:
Hit "ok"
You sir are a prince among men :-).. Thank you.. Never too old to learn..
Do you know how to add an entry to the dropdown menus?
Now i can also add my bonus material in a proper fashion.. I have made a special case for bonus features,as well as a category so i can distinguish the bonus/extra material from the movie in the video wall.. Works very nice now.. I can chose Bonus features now in yadis/media/case.
markswift2003 likes this.
post #6225 of 6233 Old 11-30-2019, 08:06 AM
Quoted: 825 Post(s)
Liked: 567
You're very welcome, and yes indeed, most definitely never too old to learn.
I've not tried adding to the menus - I have re-ordered them, but adding would be more than a quick and dirty hack like this.
post #6226 of 6233 Old 11-30-2019, 05:32 PM
Quoted: 240 Post(s)
Liked: 67
Ah,ok. Well i just need one more case,i guess i can re-appropriate the "default" case,i aint adding too many HDTV these days anyways.. Now i just need a firmware fix for the stupid rewind/FF bug and a time search in full bd mode,and this player will be as perfect as it can get for my use. And after i got a blutooth remote for it that works i just love this player,so much so im thinking about buying a + just to have as backup as i doubt many more of these players will be made going forward.
post #6227 of 6233 Old 12-02-2019, 06:40 PM
blenky's Avatar
Quoted: 988 Post(s)
Liked: 903
It would be nice if you could adjust the audio sync as well!
tbass2k likes this.
Samsung UE55KS8000 | Pioneer SC-LX701 | Dune HD Pro 4K | Zidoo Z9S | Apple TV 4K | Nvidia Shield TV (2019) | Fire TV Stick 4K | Samsung UBD-K8500 UHD Player
blenky is offline
post #6228 of 6233 Old 12-05-2019, 02:06 PM
scoosdad's Avatar
HD Pro 4K audio sync adjustment
I have the Dune HD Pro 4K Plus and was disappointed to find that the audio sync adjustment wasn't there. Since the online manual said that it should have worked, I emailed Dune support and they replied as follows:
"The information stated on the website, in this case, refers to outdated models of the Sigma base. Current models, on the Android platform, do not support this feature. We apologize. We will correct the inaccuracy shortly."
scoosdad is offline
post #6229 of 6233 Old 12-05-2019, 02:48 PM
blenky's Avatar
Quoted: 988 Post(s)
Liked: 903
And how ****e is that! All the other Android players I've got have audio sync. Shame on Dune
blenky is offline
post #6230 of 6233 Old Yesterday, 09:23 AM
installer09's Avatar
Hi Guys , ive just bought a second HD pro for another tv . I only seem to be able to connect to one player at a time on my network , they both come up as operwrt . Any idea how to get round this ? Thanks
installer09 is offline
post #6231 of 6233 Old Yesterday, 11:40 AM
Quoted: 825 Post(s)
Liked: 567
Log into the Dune router interface at http://Dune_IP_Address:8080 and change the "Hostname" in <system\system>
Default username is "root" with no password.
post #6232 of 6233 Old Today, 12:42 AM
Thumbs up
[QUOTE=markswift2003;58927652]Log into the Dune router interface at http://Dune_IP_Address:8080 and change the "Hostname" in <system\system>
Default username is "root" with no password.[/QUOTE
Perfect thanks
post #6233 of 6233 Old Today, 11:29 AM
Quoted: 65 Post(s)
Liked: 8
Red face
Hi,
I just tried to buy one of them for a friend. They are sold out everywhere...
Is there an equal (or even better!) player which supports Bluray menus, plays DVDs and Blurays in .iso format and supports them in 3D?
Thank you kindly.
Cheers
Caesar
-Caesar- is online now
